PESD5V0U4BF; PESD5V0U4BW
Ultra low capacitance bidirectional quadruple ESD
protection arrays
Rev. 01 — 15 August 2008
Product data sheet
1. Product profile
1.1 General description
Ultra low capacitance bidirectional quadruple ElectroStatic Discharge (ESD) protection
arrays in ultra small Surface-Mounted Device (SMD) plastic packages designed to protect
up to four signal lines from the damage caused by ESD and other transients.
Table 1.
Product overview
Type number
Package
Package configuration
Nexperia
JEDEC
PESD5V0U4BF
SOT886
MO-252
leadless ultra small
PESD5V0U4BW
SOT665
ultra small and flat lead
1.2 Features
n Bidirectional ESD protection of up to
n ESD protection up to 10 kV
four lines
n Ultra low diode capacitance: Cd = 2.9 pF n IEC 61000-4-2; level 4 (ESD)
n Ultra low leakage current: IRM = 5 nA
n AEC-Q101 qualified
1.3 Applications
n Computers and peripherals
n Audio and video equipment
n Cellular handsets and accessories
n 10/100/1000 Mbit/s Ethernet
n Communication systems
n Portable electronics
n Subscriber Identity Module (SIM) card
protection
n FireWire
n High-speed data lines
Nexperia
Ultra low capacitance bidirectional quadruple ESD protection arrays
1.4 Quick reference data
Table 2.
Tamb = 25 °C unless otherwise specified.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
5
V
f = 1 MHz; VR = 0 V
2.9
3.5
pF
Per diode
VRWM
reverse standoff voltage
Cd
diode capacitance
2. Pinning information
Table 3.
Pinning
Pin
Description
Simplified outline
Graphic symbol
PESD5V0U4BF
1
cathode (diode 1)
2
common cathode
3
cathode (diode 2)
4
cathode (diode 3)
5
common cathode
6
cathode (diode 4)
1
2
3
6
5
bottom view
1
6
2
5
3
4
4
006aab333
PESD5V0U4BW
1
cathode (diode 1)
2
common cathode
3
cathode (diode 2)
4
cathode (diode 3)
5
cathode (diode 4)
5
4
1
5
2
3
1
2
4
3
006aab334
3. Ordering information
Table 4.
Type number
Package
Name
Description
PESD5V0U4BF
XSON6
plastic extremely thin small outline package; no leads; SOT886
6 terminals; body 1 × 1.45 × 0.5 mm
PESD5V0U4BW
plastic surface-mounted package; 5 leads
SOT665
PESD5V0U4BF_PESD5V0U4BW_1
Product data sheet
Version
Nexperia B.V. 2017. All rights reserved
2 of 12
Nexperia
4. Marking
Table 5.
Marking codes
Type number
Marking code
PESD5V0U4BF
B1
PESD5V0U4BW
A6
5. Limiting values
Table 6.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
Per device
Tj
junction temperature
150
°C
Tamb
ambient temperature
−55
+150
°C
Tstg
storage temperature
−65
+150
°C
Table 7.
ESD maximum ratings
Symbol
Parameter
Conditions
Min
Max
Unit
Per diode
VESD
[1]
electrostatic discharge voltage
PESD5V0U4BF
IEC 61000-4-2
(contact discharge)
[2]
10
kV
PESD5V0U4BW
IEC 61000-4-2
(contact discharge)
[3]
10
kV
PESD5V0U4BF
MIL-STD-883 (human
body model)
[2]
8
kV
PESD5V0U4BW
MIL-STD-883 (human
body model)
[3]
8
kV
[1]
Device stressed with ten non-repetitive ESD pulses.
[2]
Measured from pin 1, 3, 4 or 6 to pin 2 or 5.
[3]
Measured from pin 1, 3, 4 or 5 to pin 2.
Product data sheet
3 of 12
Nexperia
Table 8.
ESD standards compliance
Standard
Conditions
Per diode
> 15 kV (air); > 8 kV (contact)
MIL-STD-883; class 3 (human body model)
> 4 kV
001aaa631
IPP
100 %
90 %
10 %
tr = 0.7 ns to 1 ns
t
30 ns
60 ns
Fig 1.
ESD pulse waveform according to IEC 61000-4-2
Product data sheet
4 of 12
Nexperia
6. Characteristics
Table 9.
Characteristics
Symbol Parameter
Conditions
Min
Typ
Max
Unit
Per diode
VRWM
reverse standoff
voltage
5
V
IRM
reverse leakage current VRWM = 5 V
5
100
nA
VBR
breakdown voltage
IR = 5 mA
5.5
6.5
9.5
V
Cd
diode capacitance
f = 1 MHz
VR = 0 V
2.9
3.5
pF
VR = 5 V
1.9
pF
100
Ω
differential resistance
rdif
IR = 1 mA
006aab036
3.0
IPP
Cd
(pF)
2.6
−VCL −VBR −VRWM
IR
IRM
−IRM
−IR
VRWM VBR VCL
2.2
1.8
2
3
4
−IPP
5
VR (V)
006aaa676
f = 1 MHz; Tamb = 25 °C
Fig 2.
Diode capacitance as a function of reverse
voltage; typical values
Fig 3.
V-I characteristics for a bidirectional
ESD protection diode
Product data sheet
5 of 12
Nexperia
ESD TESTER
450 Ω
RZ
RG 223/U
50 Ω coax
4 GHz DIGITAL
OSCILLOSCOPE
10×
ATTENUATOR
50 Ω
CZ
IEC 61000-4-2 network
CZ = 150 pF; RZ = 330 Ω
DUT
(DEVICE
UNDER
TEST)
vertical scale = 10 A/div
horizontal scale = 15 ns/div
vertical scale = 10 V/div
horizontal scale = 100 ns/div
GND
GND
unclamped +8 kV ESD pulse waveform
(IEC 61000-4-2 network)
(IEC 61000-4-2 network) pin 1 to 2
GND
GND
unclamped −8 kV ESD pulse waveform
Fig 4.
006aab037
ESD clamping test setup and waveforms
Product data sheet
6 of 12
Nexperia
7. Application information
The PESD5V0U4BF and the PESD5V0U4BW are designed for the protection of up to four
bidirectional data or signal lines from the damage caused by ESD and surge pulses. The
devices may be used on lines where the signal polarities are both, positive and negative
with respect to ground.
data- or transmission lines
DUT
1
6
2
5
3
4
006aab335
Fig 5.
Application diagram
Circuit board layout and protection device placement
Circuit board layout is critical for the suppression of ESD, Electrical Fast Transient (EFT)
and surge transients. The following guidelines are recommended:
1. Place the device as close to the input terminal or connector as possible.
2. The path length between the device and the protected line should be minimized.
3. Keep parallel signal paths to a minimum.
4. Avoid running protected conductors in parallel with unprotected conductors.
5. Minimize all Printed-Circuit Board (PCB) conductive loops including power and
ground loops.
6. Minimize the length of the transient return path to ground.
7. Avoid using shared transient return paths to a common ground point.
8. Ground planes should be used whenever possible. For multilayer PCBs, use ground
vias.
8. Test information
8.1 Quality information
This product has been qualified in accordance with the Automotive Electronics Council
(AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is
suitable for use in automotive applications.
Product data sheet
7 of 12
Nexperia
9. Package outline
0.50
max
1.05
0.95
1.7
1.5
0.04
max
0.6
3
4
2
5
1
6
0.40
0.32
0.35
0.27
0.6
0.5
5
4
0.25
0.17
0.3
0.1
0.5
1.5
1.4
1.7
1.5
1.3
1.1
0.5
1
3
0.18
0.08
0.27
0.17
0.5
1
Dimensions in mm
Fig 6.
2
04-07-22
Package outline PESD5V0U4BF (SOT886)
Dimensions in mm
Fig 7.
04-11-08
Package outline PESD5V0U4BW (SOT665)
10. Packing information
Table 10. Packing methods
The indicated -xxx are the last three digits of the 12NC ordering code.[1]
Type number
PESD5V0U4BF
Package Description
SOT886
PESD5V0U4BW SOT665
4000
5000
8000
4 mm pitch, 8 mm tape and reel; T1
[2]
-115
4 mm pitch, 8 mm tape and reel; T4
[3]
-132
2 mm pitch, 8 mm tape and reel
-315
-115
[1]
For further information and the availability of packing methods, see Section 14.
[2]
T1: normal taping
[3]
T4: 90° rotated reverse taping
Product data sheet
Packing quantity
8 of 12
Nexperia
11. Soldering
1.250
0.675
0.370
(6×)
0.500
1.700
solder lands
0.500
solder paste
0.270
(6×)
occupied area
Dimensions in mm
0.325
(6×)
0.425
(6×)
sot886_fr
Reflow soldering is the only recommended soldering method.
Fig 8.
Reflow soldering footprint PESD5V0U4BF (SOT886)
2.45
2.1
1.6
solder lands
0.4
(5×)
0.7
(2×)
placement area
2
1
0.25
0.3
0.55
solder paste
0.45 0.4
(2×) (2×)
0.538
occupied area
0.325 0.375
(2×) (2×)
Dimensions in mm
1.7
0.45
(4×)
0.6
0.5
(4×)
0.65
sot665_fr
Fig 9.
Reflow soldering footprint PESD5V0U4BW (SOT665)
Product data sheet
9 of 12
Nexperia
12. Revision history
Table 11.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
20080815
Product data sheet
Product data sheet
10 of 12
Nexperia
13. Legal information
13.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
13.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
13.3 Disclaimers
General — Information in this document is believed to be accurate and
reliable. However, Nexperia does not give any representations or
warranties, expressed or implied, as to the accuracy or completeness of such
information and shall have no liability for the consequences of use of such
information.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in medical, military, aircraft,
space or life support equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia accepts no liability for inclusion and/or use of
Nexperia products in such equipment or applications and
therefore such inclusion and/or use is at the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) may cause permanent
damage to the device. Limiting values are stress ratings only and operation of
the device at these or any other conditions above those given in the
Characteristics sections of this document is not implied. Exposure to limiting
values for extended periods may affect device reliability.
Terms and conditions of sale — Nexperia products are sold
subject to the general terms and conditions of commercial sale, as published
at http://www.nexperia.com/profile/terms, including those pertaining to warranty,
intellectual property rights infringement and limitation of liability, unless
explicitly otherwise agreed to in writing by Nexperia. In case of
any inconsistency or conflict between information in this document and such
terms and conditions, the latter will prevail.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
ESD protection devices — These products are only intended for protection
against ElectroStatic Discharge (ESD) pulses and are not intended for any other
usage including, without limitation, voltage regulation applications. Nexperia
accepts no liability for use in such applications and therefore
such use is at the customer’s own risk.
13.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
14. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Product data sheet
11 of 12
Nexperia
15. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
8.1
9
10
11
12
13
13.1
13.2
13.3
13.4
14
15
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1
General description. . . . . . . . . . . . . . . . . . . . . . 1
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Quick reference data. . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 2
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 5
Application information. . . . . . . . . . . . . . . . . . . 7
Test information . . . . . . . . . . . . . . . . . . . . . . . . . 7
Quality information . . . . . . . . . . . . . . . . . . . . . . 7
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 8
Packing information. . . . . . . . . . . . . . . . . . . . . . 8
Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 10
Legal information. . . . . . . . . . . . . . . . . . . . . . . 11
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 11
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Contact information. . . . . . . . . . . . . . . . . . . . . 11
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12
Date of release: 15 August 2008
很抱歉,暂时无法提供与“PESD5V0U4BW,115”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 4000+1.007494000+0.13041
- 8000+0.918208000+0.11885
- 12000+0.8727112000+0.11297
- 20000+0.8215720000+0.10635
- 28000+0.7912928000+0.10243
- 40000+0.7618540000+0.09862
