PTVS5V0Z1USK
Transient voltage suppressor in DSN1608-2 for mobile
applications
22 August 2016
Product data sheet
1. General description
Unidirectional Transient Voltage Suppressor (TVS) in a very small leadless DSN1608-2 (SOD964)
package.
2. Features and benefits
Rated peak pulse current: IPPM = 80 A (8/20 µs pulse)
Rated peak pulse power: PPPM = 1200 W (8/20 µs pulse)
Dynamic resistance Rdyn = 0.06 Ω
Reverse current: IRM = 0.025 µA
Very low package height: 0.29 mm
3. Applications
Power supply protection
Industrial application
Power management
4. Quick reference data
Table 1. Quick reference data
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VRWM
reverse standoff
voltage
Tamb = 25 °C
5
V
IPPM
peak pulse current
tp = 8/20 µs
[1][2]
80
A
tp = 10/1000 μs
[3][2]
A
[1]
[2]
[3]
In accordance with IEC 61000-4-5 (8/20 µs current waveform).
Measured from pin 1 to pin 2.
In accordance with IEC 61643-321 (10/1000 µs current waveform).
PTVS5V0Z1USK
Nexperia
Transient voltage suppressor in DSN1608-2 for mobile applications
5. Pinning information
Table 2. Pinning information
Pin
Symbol Description
1
K
2
A
Simplified outline
Graphic symbol
cathode
1
1
anode
2
2
sym035
Transparent top view
DSN1608-2 (SOD964)
6. Ordering information
Table 3. Ordering information
Type number
PTVS5V0Z1USK
Package
Name
Description
Version
DSN1608-2
leadless very small package; 2 terminals; body 1.6 x 0.8 x 0.29
mm
SOD964
7. Marking
Table 4. Marking codes
Type number
Marking code
PTVS5V0Z1USK
Z2
PTVS5V0Z1USK
Product data sheet
All information provided in this document is subject to legal disclaimers.
22 August 2016
Nexperia B.V. 2017. All rights reserved
2 / 14
PTVS5V0Z1USK
Nexperia
8. Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
PPPM
peak pulse power
tp = 8/20 µs
IPPM
peak pulse current
Min
Max
Unit
[1][2]
1200
W
tp = 10/1000 μs
[3][2]
200
W
tp = 8/20 µs
[1][2]
80
A
tp = 10/1000 μs
[3][2]
A
Tj
junction temperature
150
°C
Tamb
ambient temperature
-40
125
°C
Tstg
storage temperature
-65
150
°C
ESD maximum ratings
VESD
[1]
[2]
[3]
[4]
electrostatic discharge
voltage
IEC 61000-4-2; contact discharge
[4][2]
30
kV
IEC 61000-4-2; air discharge
[4][2]
30
kV
Device stressed with ten non-repetitive ESD pulses.
001aaa631
001aaa630
120
IPP
100 %
100 % IPP; 8 µs
IPP
80
90 %
e-t
50 % IPP; 20 µs
40
10 %
Fig. 1.
tp (µs)
8/20 µs pulse waveform according to
IEC 61000-4-5
PTVS5V0Z1USK
Product data sheet
t
tr = 0.6 ns to 1 ns
40
30 ns
60 ns
Fig. 2.
ESD pulse waveform according to
IEC 61000-4-2
22 August 2016
3 / 14
PTVS5V0Z1USK
Nexperia
006aab319
150
IPP
100 % IPP; 10 µs
100
50 % IPP; 1000 µs
50
Fig. 3.
2.0
3.0
tp (ms)
4.0
10/1000 µs pulse waveform according to IEC 61643-321
9. Characteristics
Table 6. Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VRWM
reverse standoff
voltage
Tamb = 25 °C
5
V
VBR
breakdown voltage
IR = 10 mA; Tamb = 25 °C
[1]
6.4
7
7.8
V
IRM
reverse leakage
current
VR = 5 V; Tamb = 25 °C
[1]
0.025
1
µA
Cd
diode capacitance
f = 1 MHz; VR = 0 V; Tamb = 25 °C
1200
pF
VCL
clamping voltage
IPPM = 80 A; Tamb = 25 °C; tp = 8/20 µs
[2][1]
18
V
IPPM = 20 A; Tamb = 25 °C;
tp = 10/1000 μs
[3][1]
12
V
IR = 10 A; Tamb = 25 °C
[4][1]
0.06
Ω
Rdyn
[1]
[2]
[3]
[4]
dynamic resistance
Measured from pin 1 to 2.
Non-repetitive current pulse, Transmission Line Pulse (TLP) tp = 100 ns; square pulse; ANSI / ESD STM5.5.1-2008.
PTVS5V0Z1USK
Product data sheet
22 August 2016
4 / 14
PTVS5V0Z1USK
Nexperia
I
aaa-018460
104
PPPM
(W)
103
- VCL - VBR - VRWM
V
- IRM
- IR
102
P-N
10
- IPP
- IPPM
Fig. 4.
006aab324
V-I characteristics for a unidirectional TVS
protection diode
006aab321
1.2
Fig. 5.
PPPM
0.4
10
50
100
150
Product data sheet
104
aaa-018461
Tj (°C)
1
-100
200
Relative variation of rated peak pulse power
as a function of junction temperature; typical
values
PTVS5V0Z1USK
tp (µs)
IRM
(nA)
102
Fig. 6.
103
Rated peak pulse power as a funtion of square
pulse duration; typical values
0.8
103
PPPM(25°C)
Tamb (°C)
200
VRWM = 5 V
Fig. 7.
Relative variation of reverse leakage current
as a function of ambient temperature; typical
values
22 August 2016
5 / 14
PTVS5V0Z1USK
Nexperia
aaa-018462
30
IPP
(A)
25
aaa-018463
5
Rdyn = 0.06 Ω
Rdyn = 0.06 Ω
IPP
(A)
-5
-15
10
5
-25
4
6
8
VCL (V)
-35
10
tp = 100 ns; Transmission Line Pulse (TLP)
Fig. 8.
-3
-1
VCL (V)
Positive clamping voltage (TLP); typical values
Fig. 9.
Negative clamping voltage (TLP); typical values
aaa-018464
18
-2
aaa-018465
VCL
(V)
VCL
(V)
12
-4
6
-8
80
IPP (A)
-12
-140
120
PTVS5V0Z1USK
Product data sheet
-100
-80
-60
-40
-20
IPP (A)
tp = 8/20 μs; according to IEC 61000-4-5
Fig. 10. Positive clamping voltage (8/20 µs pulse);
typical values
-120
Fig. 11. Negative clamping voltage (8/20 µs pulse);
typical values
22 August 2016
6 / 14
PTVS5V0Z1USK
Nexperia
ESD TESTER
4 GHz DIGITAL
OSCILLOSCOPE
RG 223/U
50 Ω coax
Rd
40 dB
ATTENUATOR
Cs
50 Ω
DUT
(DEVICE
UNDER
TEST)
IEC 61000-4-2 ed.2
Cs = 150 pF; Rd = 330 Ω
10
2
V
(kV) 8
V
(kV) 0
6
-2
4
-4
2
-6
-2
-10
40
50
t (ns)
60
70
-10
-10
unclamped +8 kV ESD pulse waveform
(IEC 61000-4-2 network)
40
50
t (ns)
60
70
unclamped -8 kV ESD pulse waveform
aaa-003952
Fig. 12. ESD clamping test setup and waveforms
aaa-018466
25
VCL
(V)
5
10
-5
VCL at 30 ns = 7.9 V
-5
-15
-10
-10
40
50
60
t (ns)
Fig. 13. Clamped +8 kV pulse waveform
PTVS5V0Z1USK
Product data sheet
aaa-018467
15
VCL
(V)
10
-20
-10
70
VCL at 30 ns = -1.4 V
40
50
60
t (ns)
70
Fig. 14. Clamped -8 kV pulse waveform
22 August 2016
7 / 14
PTVS5V0Z1USK
Nexperia
10. Application information
line to be protected
(positive signal polarity)
(negative signal polarity)
TVS diode
TVS diode
GND
GND
unidirectional protection of one line
aaa-019403
Fig. 15. Application diagram
PTVS5V0Z1USK
Product data sheet
22 August 2016
8 / 14
PTVS5V0Z1USK
Nexperia
11. Package outline
DSN1608-2, leadless very small package; 2 terminals; body 1.6 x 0.8 x 0.29 mm
SOD964
L1
L2
L
1
2
b2 b (2x)
b1
e1
e2
A
A1
E
D
(1)
Indication
of Cathode
1 mm
scale
Dimensions (mm are the original dimensions)
Unit
A
max 0.31
nom
min 0.27
mm
A1
0.03
b
b1
b2
D
E
0.71 0.645 0.46
0.85
1.65
0.69 0.625 0.44
0.75
1.55
e1
e2
0.6
0.285
L
L1
L2
0.31
0.94
0.36
0.29
0.92
0.34
Note
1. The marking bar indicates the cathode.
Outline
version
sod964_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
15-08-13
16-01-03
SOD964
Fig. 16. Package outline DSN1608-2 (SOD964)
PTVS5V0Z1USK
Product data sheet
22 August 2016
9 / 14
PTVS5V0Z1USK
Nexperia
12. Soldering
SOD964
2
1.8
0.26
0.93
0.3
0.875
R = 0.075 mm
0.7
occupied area
solder resist
Cu trace
solder paste
Dimensions in mm
1.2
16-01-13
16-01-18
sod964_fr
Fig. 17. Reflow soldering footprint for DSN1608-2 (SOD964)
PTVS5V0Z1USK
Product data sheet
22 August 2016
10 / 14
PTVS5V0Z1USK
Nexperia
13. Revision history
Table 7. Revision history
Data sheet ID
Release date
Data sheet status
Change notice
Supersedes
PTVS5V0Z1USK v.2
20160822
Product data sheet
PTVS5V0Z1USK v.1
Modifications:
PTVS5V0Z1USK v.1
PTVS5V0Z1USK
Product data sheet
Changed product status
20160211
Preliminary data sheet
22 August 2016
11 / 14
PTVS5V0Z1USK
Nexperia
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
14. Legal information
Right to make changes — Nexperia reserves the right to
make changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Data sheet status
Document
status [1][2]
Product
status [3]
Objective
[short] data
sheet
Development This document contains data from
the objective specification for product
development.
Preliminary
[short] data
sheet
Qualification
This document contains data from the
preliminary specification.
Product
[short] data
sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Definition
Suitability for use — Nexperia products are not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer’s own
risk.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the Internet at URL http://www.nexperia.com.
Definitions
Preview — The document is a preview version only. The document is still
subject to formal approval, which may result in modifications or additions.
Nexperia does not give any representations or warranties as to
the accuracy or completeness of information included herein and shall have
no liability for the consequences of use of such information.
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local Nexperia
sales office. In case of any inconsistency or conflict with the
short data sheet, the full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product
is deemed to offer functions and qualities beyond those described in the
Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give
any representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
PTVS5V0Z1USK
Product data sheet
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes
no representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their
applications and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or
customer product design. It is customer’s sole responsibility to determine
whether the Nexperia product is suitable and fit for the
customer’s applications and products planned, as well as for the planned
application and use of customer’s third party customer(s). Customers should
provide appropriate design and operating safeguards to minimize the risks
associated with their applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default
in the customer’s applications or products, or the application or use by
customer’s third party customer(s). Customer is responsible for doing all
necessary testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications
and the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified,
the product is not suitable for automotive use. It is neither qualified nor
tested in accordance with automotive testing or application requirements.
Nexperia accepts no liability for inclusion and/or use of nonautomotive qualified products in automotive equipment or applications.
22 August 2016
12 / 14
PTVS5V0Z1USK
Nexperia
In the event that customer uses the product for design-in and use in
automotive applications to automotive specifications and standards,
customer (a) shall use the product without Nexperia’s warranty
of the product for such automotive applications, use and specifications, and
(b) whenever customer uses the product for automotive applications beyond
Nexperia’s specifications such use shall be solely at customer’s
own risk, and (c) customer fully indemnifies Nexperia for any
liability, damages or failed product claims resulting from customer design and
use of the product for automotive applications beyond Nexperia’s
standard warranty and Nexperia’s
product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
PTVS5V0Z1USK
Product data sheet
22 August 2016
13 / 14
PTVS5V0Z1USK
Nexperia
15. Contents
1. General description......................................................1
2. Features and benefits.................................................. 1
3. Applications.................................................................. 1
4. Quick reference data....................................................1
5. Pinning information......................................................2
6. Ordering information....................................................2
7. Marking.......................................................................... 2
8. Limiting values............................................................. 3
9. Characteristics..............................................................4
10. Application information............................................. 8
11. Package outline.......................................................... 9
12. Soldering................................................................... 10
13. Revision history........................................................11
14. Legal information..................................................... 12
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 22 August 2016
PTVS5V0Z1USK
Product data sheet
22 August 2016
14 / 14
