PTVS20VZ1USKYL
PTVS20VZ1USKYL
    NEXPERIA(安世)
    DSN1608
    ESD抑制器/TVS二极管 VRWM=20V VBR(Min)=22.2V VC=48.3V@ IPP=41A DSN1608-2
PTVS20VZ1USKYL 数据手册
PTVS20VZ1USK Transient voltage suppressor in DSN1608-2 for mobile applications 22 August 2016 Product data sheet 1. General description Unidirectional Transient Voltage Suppressor (TVS) in a very small leadless DSN1608-2 (SOD964) package. 2. Features and benefits • • • • • Rated peak pulse current: IPPM = 41 A (8/20 µs pulse) Rated peak pulse power: PPPM = 2000 W (8/20 µs pulse) Dynamic resistance Rdyn = 0.2 Ω Reverse current: IRM = 1 nA Very low package height: 0.29 mm 3. Applications • • • Power supply protection Industrial application Power management 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VRWM reverse standoff voltage Tamb = 25 °C - - 20 V IPPM peak pulse current tp = 8/20 µs [1][2] - - 41 A tp = 10/1000 μs [3][2] - - 6 A [1] [2] [3] In accordance with IEC 61000-4-5 (8/20 µs current waveform). Measured from pin 1 to pin 2. In accordance with IEC 61643-321 (10/1000 µs current waveform). PTVS20VZ1USK Nexperia Transient voltage suppressor in DSN1608-2 for mobile applications 5. Pinning information Table 2. Pinning information Pin Symbol Description 1 K 2 A Simplified outline Graphic symbol cathode 1 1 anode 2 2 sym035 Transparent top view DSN1608-2 (SOD964) 6. Ordering information Table 3. Ordering information Type number PTVS20VZ1USK Package Name Description Version DSN1608-2 leadless very small package; 2 terminals; body 1.6 x 0.8 x 0.29 mm SOD964 7. Marking Table 4. Marking codes Type number Marking code PTVS20VZ1USK Z9 PTVS20VZ1USK Product data sheet All information provided in this document is subject to legal disclaimers. 22 August 2016 © Nexperia B.V. 2017. All rights reserved 2 / 14 PTVS20VZ1USK Nexperia Transient voltage suppressor in DSN1608-2 for mobile applications 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions PPPM peak pulse power tp = 8/20 µs IPPM peak pulse current Min Max Unit [1][2] - 2000 W tp = 10/1000 μs [3][2] - 220 W tp = 8/20 µs [1][2] - 41 A tp = 10/1000 μs [3][2] - 6 A Tj junction temperature - 150 °C Tamb ambient temperature -40 125 °C Tstg storage temperature -65 150 °C ESD maximum ratings VESD [1] [2] [3] [4] electrostatic discharge voltage IEC 61000-4-2; contact discharge [4][2] - 30 kV IEC 61000-4-2; air discharge [4][2] - 30 kV In accordance with IEC 61000-4-5 (8/20 µs current waveform). Measured from pin 1 to pin 2. In accordance with IEC 61643-321 (10/1000 µs current waveform). Device stressed with ten non-repetitive ESD pulses. 001aaa631 001aaa630 120 IPP 100 % 100 % IPP; 8 µs IPP (%) 80 90 % e-t 50 % IPP; 20 µs 40 10 % 0 Fig. 1. 0 10 20 30 tp (µs) 8/20 µs pulse waveform according to IEC 61000-4-5 PTVS20VZ1USK Product data sheet t tr = 0.6 ns to 1 ns 40 30 ns 60 ns Fig. 2. ESD pulse waveform according to IEC 61000-4-2 All information provided in this document is subject to legal disclaimers. 22 August 2016 © Nexperia B.V. 2017. All rights reserved 3 / 14 PTVS20VZ1USK Nexperia Transient voltage suppressor in DSN1608-2 for mobile applications 006aab319 150 IPP (%) 100 % IPP; 10 µs 100 50 % IPP; 1000 µs 50 0 Fig. 3. 0 1.0 2.0 3.0 tp (ms) 4.0 10/1000 µs pulse waveform according to IEC 61643-321 9. Characteristics Table 6. Characteristics Symbol Parameter Conditions Min Typ Max Unit VRWM reverse standoff voltage Tamb = 25 °C - - 20 V VBR breakdown voltage IR = 10 mA; Tamb = 25 °C [1] 22.2 23.8 25.4 V IRM reverse leakage current VRWM = 20 V; Tamb = 25 °C [1] - 1 100 nA Cd diode capacitance f = 1 MHz; VR = 0 V; Tamb = 25 °C - 260 - pF VCL clamping voltage IPPM = 41 A; Tamb = 25 °C; tp = 8/20 µs [2][1] - 40.3 48.3 V IPPM = 6 A; Tamb = 25 °C; tp = 10/1000 μs [3][1] - 30.75 36.9 V IR = 10 A; Tamb = 25 °C [4][1] - 0.2 - Ω Rdyn [1] [2] [3] [4] dynamic resistance Measured from pin 1 to 2. In accordance with IEC 61000-4-5 (8/20 µs current waveform). In accordance with IEC 61643-321 (10/1000 µs current waveform). Non-repetitive current pulse, Transmission Line Pulse (TLP) tp = 100 ns; square pulse; ANSI / ESD STM5.5.1-2008. PTVS20VZ1USK Product data sheet All information provided in this document is subject to legal disclaimers. 22 August 2016 © Nexperia B.V. 2017. All rights reserved 4 / 14 PTVS20VZ1USK Nexperia Transient voltage suppressor in DSN1608-2 for mobile applications I aaa-024144 104 PPPM (W) 103 - VCL - VBR - VRWM V - IRM - IR - 102 + P-N 10 - IPP - IPPM Fig. 4. 006aab324 V-I characteristics for a unidirectional TVS protection diode 006aab321 1.2 Fig. 5. 10 102 103 tp (µs) Rated peak pulse power as a function of square pulse duration; typical values aaa-024145 102 IRM (nA) 10 PPPM PPPM(25°C) 104 1 0.8 10-1 10-2 0.4 10-3 0 Fig. 6. 0 50 100 150 Tj (°C) 10-4 -100 200 Relative variation of rated peak pulse power as a function of junction temperature; typical values PTVS20VZ1USK Product data sheet 0 100 Tamb (°C) 200 VRWM = 20 V Fig. 7. Relative variation of reverse leakage current as a function of ambient temperature; typical values All information provided in this document is subject to legal disclaimers. 22 August 2016 © Nexperia B.V. 2017. All rights reserved 5 / 14 PTVS20VZ1USK Nexperia Transient voltage suppressor in DSN1608-2 for mobile applications aaa-024146 30 IPP (A) 25 aaa-024147 70 IPP (A) 50 20 15 Rdyn = 0.07 Ω 30 10 5 10 0 Rdyn = 0.2 Ω -5 0 10 20 VCL (V) -10 30 tp = 100 ns; Transmission Line Pulse (TLP) Fig. 8. Fig. 9. 2 3 4 VCL (V) 5 Negative clamping voltage (TLP); typical values aaa-024148 VCL (V) 1 tp = 100 ns; Transmission Line Pulse (TLP) Positive clamping voltage (TLP); typical values 60 0 aaa-024149 0 VCL (V) 40 -5 20 -10 0 0 20 40 IPP (A) -15 -160 60 tp = 8/20 μs; according to IEC 61000-4-5 Fig. 10. Positive clamping voltage (8/20 µs pulse); typical values PTVS20VZ1USK Product data sheet -120 -80 -40 IPP (A) 0 tp = 8/20 μs; according to IEC 61000-4-5 Fig. 11. Negative clamping voltage (8/20 µs pulse); typical values All information provided in this document is subject to legal disclaimers. 22 August 2016 © Nexperia B.V. 2017. All rights reserved 6 / 14 PTVS20VZ1USK Nexperia Transient voltage suppressor in DSN1608-2 for mobile applications ESD TESTER 4 GHz DIGITAL OSCILLOSCOPE RG 223/U 50 Ω coax Rd 40 dB ATTENUATOR Cs 50 Ω DUT (DEVICE UNDER TEST) IEC 61000-4-2 ed.2 Cs = 150 pF; Rd = 330 Ω 10 2 V (kV) 8 V (kV) 0 6 -2 4 -4 2 -6 0 -8 -2 -10 0 10 20 30 40 50 t (ns) 60 70 -10 -10 unclamped +8 kV ESD pulse waveform (IEC 61000-4-2 network) 0 10 20 30 40 50 t (ns) 60 70 unclamped -8 kV ESD pulse waveform (IEC 61000-4-2 network) aaa-003952 Fig. 12. ESD clamping test setup and waveforms aaa-024150 60 VCL (V) 50 40 5 30 0 20 -5 VCL at 30 ns = 23 V 10 -10 0 -15 -10 -10 0 10 20 30 40 50 60 t (ns) Fig. 13. Clamped +8 kV pulse waveform (IEC 61000-4-2 network) PTVS20VZ1USK Product data sheet aaa-024151 15 VCL (V) 10 -20 -10 70 VCL at 30 ns = -1.6 V 0 10 20 30 40 50 60 t (ns) 70 Fig. 14. Clamped -8 kV pulse waveform (IEC 61000-4-2 network) All information provided in this document is subject to legal disclaimers. 22 August 2016 © Nexperia B.V. 2017. All rights reserved 7 / 14 PTVS20VZ1USK Nexperia Transient voltage suppressor in DSN1608-2 for mobile applications 10. Application information line to be protected (positive signal polarity) line to be protected (negative signal polarity) TVS diode TVS diode GND GND unidirectional protection of one line aaa-019403 Fig. 15. Application diagram PTVS20VZ1USK Product data sheet All information provided in this document is subject to legal disclaimers. 22 August 2016 © Nexperia B.V. 2017. All rights reserved 8 / 14 PTVS20VZ1USK Nexperia Transient voltage suppressor in DSN1608-2 for mobile applications 11. Package outline DSN1608-2, leadless very small package; 2 terminals; body 1.6 x 0.8 x 0.29 mm SOD964 L1 L2 L 1 2 b2 b (2x) b1 e1 e2 A A1 E D (1) Indication of Cathode 0 1 mm scale Dimensions (mm are the original dimensions) Unit A max 0.31 nom min 0.27 mm A1 0.03 b b1 b2 D E 0.71 0.645 0.46 0.85 1.65 0.69 0.625 0.44 0.75 1.55 e1 e2 0.6 0.285 L L1 L2 0.31 0.94 0.36 0.29 0.92 0.34 Note 1. The marking bar indicates the cathode. Outline version sod964_po References IEC JEDEC JEITA European projection Issue date 15-08-13 16-01-03 SOD964 Fig. 16. Package outline DSN1608-2 (SOD964) PTVS20VZ1USK Product data sheet All information provided in this document is subject to legal disclaimers. 22 August 2016 © Nexperia B.V. 2017. All rights reserved 9 / 14 PTVS20VZ1USK Nexperia Transient voltage suppressor in DSN1608-2 for mobile applications 12. Soldering SOD964 2 1.8 0.26 0.93 0.3 0.875 R = 0.075 mm 0.7 occupied area solder resist Cu trace solder paste Dimensions in mm 1.2 16-01-13 16-01-18 sod964_fr Fig. 17. Reflow soldering footprint for DSN1608-2 (SOD964) PTVS20VZ1USK Product data sheet All information provided in this document is subject to legal disclaimers. 22 August 2016 © Nexperia B.V. 2017. All rights reserved 10 / 14 PTVS20VZ1USK Nexperia Transient voltage suppressor in DSN1608-2 for mobile applications 13. Revision history Table 7. Revision history Data sheet ID Release date Data sheet status Change notice Supersedes PTVS20VZ1USK v.1 20160822 Product data sheet - - PTVS20VZ1USK Product data sheet All information provided in this document is subject to legal disclaimers. 22 August 2016 © Nexperia B.V. 2017. All rights reserved 11 / 14 PTVS20VZ1USK Nexperia Transient voltage suppressor in DSN1608-2 for mobile applications Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. 14. Legal information Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Data sheet status Document status [1][2] Product status [3] Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Definition Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. Definitions Preview — The document is a preview version only. The document is still subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. PTVS20VZ1USK Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of nonautomotive qualified products in automotive equipment or applications. All information provided in this document is subject to legal disclaimers. 22 August 2016 © Nexperia B.V. 2017. All rights reserved 12 / 14 PTVS20VZ1USK Nexperia Transient voltage suppressor in DSN1608-2 for mobile applications In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. PTVS20VZ1USK Product data sheet All information provided in this document is subject to legal disclaimers. 22 August 2016 © Nexperia B.V. 2017. All rights reserved 13 / 14 PTVS20VZ1USK Nexperia Transient voltage suppressor in DSN1608-2 for mobile applications 15. Contents 1. General description......................................................1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Quick reference data....................................................1 5. Pinning information......................................................2 6. Ordering information....................................................2 7. Marking.......................................................................... 2 8. Limiting values............................................................. 3 9. Characteristics..............................................................4 10. Application information............................................. 8 11. Package outline.......................................................... 9 12. Soldering................................................................... 10 13. Revision history........................................................11 14. Legal information..................................................... 12 © Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 22 August 2016 PTVS20VZ1USK Product data sheet All information provided in this document is subject to legal disclaimers. 22 August 2016 © Nexperia B.V. 2017. All rights reserved 14 / 14
PTVS20VZ1USKYL 价格&库存
很抱歉,暂时无法提供与“PTVS20VZ1USKYL”相匹配的价格&库存,您可以联系我们找货
PTVS20VZ1USKYL
  • 1+5.084431+0.63785
  • 10+3.1004410+0.38895
  • 100+1.94808100+0.24439
  • 500+1.44864500+0.18174
  • 1000+1.287031000+0.16146
  • 2000+1.150782000+0.14437
  • 5000+1.003095000+0.12584
库存:14727
