PESD5V0X1BCL,315
PESD5V0X1BCL,315
    NEXPERIA(安世)
    SOD-882
    ESD VRWM=5.5 V VBR(Min)=8.1 V VC=18 V IPP=1.7A SOD882
PESD5V0X1BCL,315 数据手册
PESD5V0X1BCL Extremely low capacitance bidirectional ESD protection diode Rev. 1 — 12 March 2012 Product data sheet 1. Product profile 1.1 General description Extremely low capacitance bidirectional ElectroStatic Discharge (ESD) protection diode in a leadless ultra small SOD882 (DFN1006-2) Surface-Mounted Device (SMD) plastic package designed to protect one signal line from the damage caused by ESD and other transients. The combination of extremely low capacitance, high ESD maximum rating and ultra small package makes the device ideal for high-speed data line protection. 1.2 Features and benefits  Bidirectional ESD protection of one line  ESD protection up to 8 kV  IEC 61000-4-2; level 4 (ESD)  Extremely low capacitance: Cd = 0.49 pF  AEC-Q101 qualified  Low clamping voltage: VCL = 18 V  Ultra low leakage current: IRM = 1 nA 1.3 Applications      Computers and peripherals Audio and video equipment Cellular handsets and accessories 10/100/1000 Mbit/s Ethernet USB, High-Definition Multimedia Interface (HDMI), FireWire     Portable electronics SIM card protection High-speed data lines Communication systems 1.4 Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit - - 5.5 V - 0.49 0.60 pF Per device VRWM reverse standoff voltage Cd diode capacitance f = 1 MHz; VR = 0 V PESD5V0X1BCL Nexperia Extremely low capacitance bidirectional ESD protection diode 2. Pinning information Table 2. Pinning Pin Description 1 cathode (diode 1) 2 cathode (diode 2) Simplified outline 1 Graphic symbol 1 2 2 sym045 Transparent top view 3. Ordering information Table 3. Ordering information Type number Package Name PESD5V0X1BCL Description Version DFN1006-2 leadless ultra small plastic package; 2 terminals; SOD882 body 1.0  0.6  0.5 mm 4. Marking Table 4. Marking codes Type number Marking code PESD5V0X1BCL 11 5. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit IPPM rated peak pulse current tp = 8/20 s - 1.7 A Tj junction temperature - 150 C Tamb ambient temperature 55 +150 C Tstg storage temperature 65 +150 C Per device [1] PESD5V0X1BCL Product data sheet [1] Device stressed with ten non-repetitive current pulses (8/20 s exponential decay waveform according to IEC 61000-4-5 and IEC 61643-321). All information provided in this document is subject to legal disclaimers. Rev. 1 — 12 March 2012 © Nexperia B.V. 2017. All rights reserved 2 of 12 PESD5V0X1BCL Nexperia Extremely low capacitance bidirectional ESD protection diode Table 6. ESD maximum ratings Tamb = 25 C unless otherwise specified. Symbol Parameter Conditions Min Max Unit electrostatic discharge voltage IEC 61000-4-2 (contact discharge) - 8 kV machine model - 400 V MIL-STD-883 (human body model) - 10 kV Per device VESD [1] [1] Device stressed with ten non-repetitive ESD pulses. Table 7. ESD standards compliance Standard Conditions Per device IEC 61000-4-2; level 4 (ESD) > 8 kV (contact) MIL-STD-883; class 3B (human body model) > 8 kV 001aaa631 IPP 001aaa630 120 100 % 90 % 100 % IPP; 8 μs IPP (%) 80 e−t 50 % IPP; 20 μs 40 10 % 0 10 20 30 30 ns 40 t (μs) Fig 1. t tr = 0.7 ns to 1 ns 0 8/20 s pulse waveform according to IEC 61000-4-5 PESD5V0X1BCL Product data sheet 60 ns Fig 2. ESD pulse waveform according to IEC 61000-4-2 All information provided in this document is subject to legal disclaimers. Rev. 1 — 12 March 2012 © Nexperia B.V. 2017. All rights reserved 3 of 12 PESD5V0X1BCL Nexperia Extremely low capacitance bidirectional ESD protection diode 6. Characteristics Table 8. Characteristics Tamb = 25 C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit Per device VRWM reverse standoff voltage - - 5.5 V IRM reverse leakage current VRWM = 5.5 V -
PESD5V0X1BCL,315
物料型号:PESD5V0X1BCL
器件简介:PESD5V0X1BCL是一款超低电容双向静电放电(ESD)保护二极管,采用无引脚超小型SOD882 (DFN1006-2)表面贴装设备(SMD)塑料封装。该器件设计用于保护一条数据线免受ESD和其他瞬态现象造成的损害。其超低电容、高ESD最大等级和超小封装的组合,使其非常适合高速数据线的保护。
引脚分配:文档中提供了引脚信息表,其中1号引脚和2号引脚均被标记为阴极(cathode)。
参数特性: - 反向工作电压(VRWM):5.5V - 二极管电容(Cd):0.49pF(典型值)至0.60pF(最大值) - 正向工作电压(VF):未明确列出,但可从应用图中推断 - 钳位电压(VCL):18V - 动态电阻(rdyn):0.9Ω(在1MHz频率和25°C环境温度下)
功能详解:PESD5V0X1BCL提供双向ESD保护,达到IEC 61000-4-2标准的8kV接触放电等级。其超低电容特性使其在高速数据线路上的应用中具有优势,同时具有低钳位电压和超低漏电流特性。
应用信息:适用于计算机及其外围设备、便携式电子设备、音视频设备、SIM卡保护、高速数据线、通信系统、手机及其配件、10/100/1000 Mbit/s以太网、USB、高清多媒体接口(HDMI)、火线等。
封装信息:PESD5V0X1BCL采用DFN1006-2封装,这是一种无引脚超小型塑料封装,具有2个端子,封装尺寸为1.0x0.6x0.5mm。
PESD5V0X1BCL,315 价格&库存
很抱歉,暂时无法提供与“PESD5V0X1BCL,315”相匹配的价格&库存,您可以联系我们找货
PESD5V0X1BCL,315
  • 1+4.583421+0.59410
  • 10+2.8204010+0.36558
  • 100+1.79031100+0.23206
  • 500+1.34124500+0.17385
  • 1000+1.196331000+0.15507
  • 2000+1.074212000+0.13924
  • 5000+0.941835000+0.12208
PESD5V0X1BCL,315
  • 10000+0.8599310000+0.11147
  • 20000+0.7910420000+0.10254
  • 30000+0.7559430000+0.09799
  • 50000+0.7165050000+0.09288
  • 70000+0.6931670000+0.08985
  • 100000+0.67046100000+0.08691
