PESD5V0U5BV,115
PESD5V0U5BV,115
    NEXPERIA(安世)
    SOT666
    ESD VRWM=5 V VBR(Min)=5.5V SOT666
PESD5V0U5BV,115 数据手册
PESD5V0U5BF; PESD5V0U5BV Ultra low capacitance bidirectional fivefold ESD protection arrays Rev. 01 — 15 August 2008 Product data sheet 1. Product profile 1.1 General description Ultra low capacitance bidirectional fivefold ElectroStatic Discharge (ESD) protection arrays in ultra small Surface-Mounted Device (SMD) plastic packages designed to protect up to five signal lines from the damage caused by ESD and other transients. Table 1. Product overview Type number Package Package configuration Nexperia JEDEC PESD5V0U5BF SOT886 MO-252 leadless ultra small PESD5V0U5BV SOT666 - ultra small and flat lead 1.2 Features n Bidirectional ESD protection of up to n ESD protection up to 10 kV five lines n Ultra low diode capacitance: Cd = 2.9 pF n IEC 61000-4-2; level 4 (ESD) n Ultra low leakage current: IRM = 5 nA n AEC-Q101 qualified 1.3 Applications n Computers and peripherals n Audio and video equipment n Cellular handsets and accessories n 10/100/1000 Mbit/s Ethernet n Communication systems n Portable electronics n Subscriber Identity Module (SIM) card protection n FireWire n High-speed data lines PESD5V0U5BF; PESD5V0U5BV Nexperia Ultra low capacitance bidirectional fivefold ESD protection arrays 1.4 Quick reference data Table 2. Quick reference data Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit - - 5 V f = 1 MHz; VR = 0 V - 2.9 3.5 pF Per diode VRWM reverse standoff voltage Cd diode capacitance 2. Pinning information Table 3. Pinning Pin Description Simplified outline Graphic symbol PESD5V0U5BF 1 cathode (diode 1) 2 common cathode 3 cathode (diode 2) 4 cathode (diode 3) 5 cathode (diode 4) 6 cathode (diode 5) 1 2 3 6 5 bottom view 1 6 2 5 3 4 4 006aab346 PESD5V0U5BV 1 cathode (diode 1) 2 common cathode 3 cathode (diode 2) 4 cathode (diode 3) 5 cathode (diode 4) 6 cathode (diode 5) 6 1 5 2 4 1 6 2 5 3 4 3 006aab346 3. Ordering information Table 4. Ordering information Type number Package Name Description PESD5V0U5BF XSON6 plastic extremely thin small outline package; no leads; SOT886 6 terminals; body 1 × 1.45 × 0.5 mm PESD5V0U5BV - plastic surface-mounted package; 6 leads SOT666 © PESD5V0U5BF_PESD5V0U5BV_1 Product data sheet Version Rev. 01 — 15 August 2008 Nexperia B.V. 2017. All rights reserved 2 of 12 PESD5V0U5BF; PESD5V0U5BV Nexperia Ultra low capacitance bidirectional fivefold ESD protection arrays 4. Marking Table 5. Marking codes Type number Marking code PESD5V0U5BF B2 PESD5V0U5BV G7 5. Limiting values Table 6. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit Per device Tj junction temperature - 150 °C Tamb ambient temperature −55 +150 °C Tstg storage temperature −65 +150 °C Table 7. ESD maximum ratings Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Max Unit IEC 61000-4-2 (contact discharge) - 10 kV MIL-STD-883 (human body model) - 8 kV Per diode VESD [1][2] electrostatic discharge voltage [1] Device stressed with ten non-repetitive ESD pulses. [2] Measured from pin 1, 3, 4, 5 or 6 to pin 2. © PESD5V0U5BF_PESD5V0U5BV_1 Product data sheet Rev. 01 — 15 August 2008 Nexperia B.V. 2017. All rights reserved 3 of 12 PESD5V0U5BF; PESD5V0U5BV Nexperia Ultra low capacitance bidirectional fivefold ESD protection arrays Table 8. ESD standards compliance Standard Conditions Per diode IEC 61000-4-2; level 4 (ESD) > 15 kV (air); > 8 kV (contact) MIL-STD-883; class 3 (human body model) > 4 kV 001aaa631 IPP 100 % 90 % 10 % tr = 0.7 ns to 1 ns t 30 ns 60 ns Fig 1. ESD pulse waveform according to IEC 61000-4-2 © PESD5V0U5BF_PESD5V0U5BV_1 Product data sheet Rev. 01 — 15 August 2008 Nexperia B.V. 2017. All rights reserved 4 of 12 PESD5V0U5BF; PESD5V0U5BV Nexperia Ultra low capacitance bidirectional fivefold ESD protection arrays 6. Characteristics Table 9. Characteristics Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit Per diode VRWM reverse standoff voltage - - 5 V IRM reverse leakage current VRWM = 5 V - 5 100 nA VBR breakdown voltage IR = 5 mA 5.5 6.5 9.5 V Cd diode capacitance f = 1 MHz VR = 0 V - 2.9 3.5 pF VR = 5 V - 1.9 - pF - - 100 Ω differential resistance rdif IR = 1 mA 006aab036 3.0 IPP Cd (pF) 2.6 −VCL −VBR −VRWM IR IRM −IRM −IR VRWM VBR VCL 2.2 − 1.8 0 1 2 3 4 + −IPP 5 VR (V) 006aaa676 f = 1 MHz; Tamb = 25 °C Fig 2. Diode capacitance as a function of reverse voltage; typical values Fig 3. V-I characteristics for a bidirectional ESD protection diode © PESD5V0U5BF_PESD5V0U5BV_1 Product data sheet Rev. 01 — 15 August 2008 Nexperia B.V. 2017. All rights reserved 5 of 12 PESD5V0U5BF; PESD5V0U5BV Nexperia Ultra low capacitance bidirectional fivefold ESD protection arrays ESD TESTER 450 Ω RZ RG 223/U 50 Ω coax 4 GHz DIGITAL OSCILLOSCOPE 10× ATTENUATOR 50 Ω CZ IEC 61000-4-2 network CZ = 150 pF; RZ = 330 Ω DUT (DEVICE UNDER TEST) vertical scale = 10 A/div horizontal scale = 15 ns/div vertical scale = 10 V/div horizontal scale = 100 ns/div GND GND unclamped +8 kV ESD pulse waveform (IEC 61000-4-2 network) clamped +8 kV ESD pulse waveform (IEC 61000-4-2 network) pin 1 to 2 vertical scale = 10 A/div horizontal scale = 15 ns/div GND GND vertical scale = 10 V/div horizontal scale = 100 ns/div unclamped −8 kV ESD pulse waveform (IEC 61000-4-2 network) Fig 4. clamped −8 kV ESD pulse waveform (IEC 61000-4-2 network) pin 1 to 2 006aab037 ESD clamping test setup and waveforms © PESD5V0U5BF_PESD5V0U5BV_1 Product data sheet Rev. 01 — 15 August 2008 Nexperia B.V. 2017. All rights reserved 6 of 12 PESD5V0U5BF; PESD5V0U5BV Nexperia Ultra low capacitance bidirectional fivefold ESD protection arrays 7. Application information The PESD5V0U5BF and the PESD5V0U5BV are designed for the protection of up to five bidirectional data or signal lines from the damage caused by ESD and surge pulses. The devices may be used on lines where the signal polarities are both, positive and negative with respect to ground. data- or transmission lines DUT 1 6 2 5 3 4 006aab347 Fig 5. Application diagram Circuit board layout and protection device placement Circuit board layout is critical for the suppression of ESD, Electrical Fast Transient (EFT) and surge transients. The following guidelines are recommended: 1. Place the device as close to the input terminal or connector as possible. 2. The path length between the device and the protected line should be minimized. 3. Keep parallel signal paths to a minimum. 4. Avoid running protected conductors in parallel with unprotected conductors. 5. Minimize all Printed-Circuit Board (PCB) conductive loops including power and ground loops. 6. Minimize the length of the transient return path to ground. 7. Avoid using shared transient return paths to a common ground point. 8. Ground planes should be used whenever possible. For multilayer PCBs, use ground vias. 8. Test information 8.1 Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. © PESD5V0U5BF_PESD5V0U5BV_1 Product data sheet Rev. 01 — 15 August 2008 Nexperia B.V. 2017. All rights reserved 7 of 12 PESD5V0U5BF; PESD5V0U5BV Nexperia Ultra low capacitance bidirectional fivefold ESD protection arrays 9. Package outline 0.50 max 1.05 0.95 1.7 1.5 0.04 max 0.6 3 4 2 5 1 6 0.40 0.32 0.35 0.27 6 0.6 0.5 5 4 0.25 0.17 0.3 0.1 0.5 1.5 1.4 1.7 1.5 1.3 1.1 pin 1 index 0.5 1 3 0.18 0.08 0.27 0.17 0.5 1 Dimensions in mm Fig 6. 2 04-07-22 Package outline PESD5V0U5BF (SOT886) Dimensions in mm Fig 7. 04-11-08 Package outline PESD5V0U5BV (SOT666) 10. Packing information Table 10. Packing methods The indicated -xxx are the last three digits of the 12NC ordering code.[1] Type number PESD5V0U5BF PESD5V0U5BV Package Description SOT886 SOT666 4000 5000 8000 4 mm pitch, 8 mm tape and reel; T1 [2] - -115 - 4 mm pitch, 8 mm tape and reel; T4 [3] - -132 - 2 mm pitch, 8 mm tape and reel - - -315 4 mm pitch, 8 mm tape and reel -115 - - [1] For further information and the availability of packing methods, see Section 14. [2] T1: normal taping [3] T4: 90° rotated reverse taping © PESD5V0U5BF_PESD5V0U5BV_1 Product data sheet Packing quantity Rev. 01 — 15 August 2008 Nexperia B.V. 2017. All rights reserved 8 of 12 PESD5V0U5BF; PESD5V0U5BV Nexperia Ultra low capacitance bidirectional fivefold ESD protection arrays 11. Soldering 1.250 0.675 0.370 (6×) 0.500 1.700 solder lands 0.500 solder paste 0.270 (6×) occupied area Dimensions in mm 0.325 (6×) 0.425 (6×) sot886_fr Reflow soldering is the only recommended soldering method. Fig 8. Reflow soldering footprint PESD5V0U5BF (SOT886) 2.75 2.45 2.1 1.6 solder lands 0.4 (6×) 0.25 (2×) 0.538 2 1.7 1.075 0.3 (2×) placement area 0.55 (2×) solder paste occupied area 0.325 0.375 (4×) (4×) Dimensions in mm 1.7 0.45 (4×) 0.6 (2×) 0.5 (4×) 0.65 (2×) sot666_fr Reflow soldering is the only recommended soldering method. Fig 9. Reflow soldering footprint PESD5V0U5BV (SOT666) © PESD5V0U5BF_PESD5V0U5BV_1 Product data sheet Rev. 01 — 15 August 2008 Nexperia B.V. 2017. All rights reserved 9 of 12 PESD5V0U5BF; PESD5V0U5BV Nexperia Ultra low capacitance bidirectional fivefold ESD protection arrays 12. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes PESD5V0U5BF_PESD5V0U5BV_1 20080815 Product data sheet - - © PESD5V0U5BF_PESD5V0U5BV_1 Product data sheet Rev. 01 — 15 August 2008 Nexperia B.V. 2017. All rights reserved 10 of 12 PESD5V0U5BF; PESD5V0U5BV Nexperia Ultra low capacitance bidirectional fivefold ESD protection arrays 13. Legal information 13.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 13.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. 13.3 Disclaimers General — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in medical, military, aircraft, space or life support equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) may cause permanent damage to the device. Limiting values are stress ratings only and operation of the device at these or any other conditions above those given in the Characteristics sections of this document is not implied. Exposure to limiting values for extended periods may affect device reliability. Terms and conditions of sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, including those pertaining to warranty, intellectual property rights infringement and limitation of liability, unless explicitly otherwise agreed to in writing by Nexperia. In case of any inconsistency or conflict between information in this document and such terms and conditions, the latter will prevail. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. ESD protection devices — These products are only intended for protection against ElectroStatic Discharge (ESD) pulses and are not intended for any other usage including, without limitation, voltage regulation applications. Nexperia accepts no liability for use in such applications and therefore such use is at the customer’s own risk. 13.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 14. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com © PESD5V0U5BF_PESD5V0U5BV_1 Product data sheet Rev. 01 — 15 August 2008 Nexperia B.V. 2017. All rights reserved 11 of 12 Nexperia PESD5V0U5BF; PESD5V0U5BV Ultra low capacitance bidirectional fivefold ESD protection arrays 15. Contents 1 1.1 1.2 1.3 1.4 2 3 4 5 6 7 8 8.1 9 10 11 12 13 13.1 13.2 13.3 13.4 14 15 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description. . . . . . . . . . . . . . . . . . . . . . 1 Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Quick reference data. . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 3 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 5 Application information. . . . . . . . . . . . . . . . . . . 7 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 7 Quality information . . . . . . . . . . . . . . . . . . . . . . 7 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 8 Packing information. . . . . . . . . . . . . . . . . . . . . . 8 Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 10 Legal information. . . . . . . . . . . . . . . . . . . . . . . 11 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 11 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Trademarks . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Contact information. . . . . . . . . . . . . . . . . . . . . 11 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 15 August 2008
PESD5V0U5BV,115 价格&库存
很抱歉,暂时无法提供与“PESD5V0U5BV,115”相匹配的价格&库存,您可以联系我们找货
