PESD5V0V1BLD
Very low capacitance bidirectional ESD protection diode
3 July 2018
Product data sheet
1. General description
Very low capacitance bidirectional ElectroStatic Discharge (ESD) protection diode designed to
protect one signal line from the damage caused by ESD and other transients. The device is housed
in a SOD882D leadless ultra small Surface-Mounted Device (SMD) plastic package with visible
and solderable side pads.
2. Features and benefits
Bidirectional ESD protection of one line
Ultra small SMD plastic package
Solderable side pads
Package height typ. 0.37 mm
Very low diode capacitance: Cd = 11 pF
Max. peak pulse power: PPPM = 45 W
Low clamping voltage: VCL = 12.5 V
Ultra low leakage current: IRM < 1 nA
ESD protection up to 30 kV
IEC 61000-4-2; level 4 (ESD)
IEC 61000-4-5 (surge); IPPM = 4.8 A
AEC-Q101 qualified
3. Applications
Computers and peripherals
Audio and video equipment
Cellular handsets and accessories
SIM card protection
Communication systems
Portable electronics
10/100 Mbit/s Ethernet
FireWire
4. Quick reference data
Table 1. Quick reference data
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Cd
diode capacitance
f = 1 MHz; VR = 0 V; Tamb = 25 °C
11
13
pF
VRWM
reverse standoff
voltage
Tamb = 25 °C
5
V
PESD5V0V1BLD
Nexperia
5. Pinning information
Table 2. Pinning information
Pin
Symbol Description
1
K1
cathode[1]
2
K2
cathode 2
Simplified outline
1
2
Graphic symbol
K1
K2
sym045
Transparent
top view
DFN1006D-2 (SOD882D)
[1]
The marking bar indicates pin 1.
6. Ordering information
Table 3. Ordering information
Type number
Package
PESD5V0V1BLD
Name
Description
Version
DFN1006D-2
leadless ultra small plastic package; 2 terminals; 0.65 mm pitch;
1 mm x 0.6 mm x 0.4 mm body
SOD882D
7. Marking
Table 4. Marking codes
Type number
Marking code
PESD5V0V1BLD
0111 0000
CATHODE BAR
READING DIRECTION
VENDOR CODE
READING EXAMPLE:
0111
1011
MARKING CODE
(EXAMPLE)
READING DIRECTION
006aac477
Fig. 1.
SOD882D binary marking code description
PESD5V0V1BLD
Product data sheet
All information provided in this document is subject to legal disclaimers.
3 July 2018
Nexperia B.V. 2018. All rights reserved
2 / 11
PESD5V0V1BLD
Nexperia
8. Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
PPPM
rated peak pulse power
tp = 8/20 µs
IPPM
rated peak pulse current
Min
Max
Unit
[1]
45
W
[1]
4.8
A
Per diode
Per device
Tj
junction temperature
150
°C
Tamb
ambient temperature
-55
150
°C
Tstg
storage temperature
-65
150
°C
30
kV
machine model
2
kV
MIL-STD-883 (human body model)
16
kV
ESD maximum ratings
VESD
[1]
[2]
electrostatic discharge
voltage
IEC 61000-4-2 (contact discharge)
[2]
Non-repetitive current pulse 8/20 µs exponential decay waveform according to IEC 61000-4-5.
Device stressed with ten non-repetitive ESD pulses.
001aaa630
120
IPP
100 %
100 % IPP; 8 µs
IPP
80
90 %
e-t
50 % IPP; 20 µs
40
10 %
Fig. 2.
t (µs)
8/20 µs pulse waveform according to
IEC 61000-4-5
PESD5V0V1BLD
Product data sheet
t
tr = 0.6 ns to 1 ns
40
30 ns
60 ns
Fig. 3.
ESD pulse waveform according to
IEC 61000-4-2
3 July 2018
001aaa631
3 / 11
PESD5V0V1BLD
Nexperia
9. Characteristics
Table 6. Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VRWM
reverse standoff
voltage
Tamb = 25 °C
5
V
VBR
breakdown voltage
IR = 5 mA; Tamb = 25 °C
5.8
6.8
7.8
V
IRM
reverse leakage
current
VRWM = 5 V; Tamb = 25 °C
1
10
nA
Cd
diode capacitance
11
13
pF
VCL
clamping voltage
IPP = 4.8 A; Tamb = 25 °C
[1]
12.5
V
Rdyn
dynamic resistance
IR = 10 A; Tamb = 25 °C
[2]
0.2
Ω
[1]
[2]
Non-repetitive current pulse, Transmission Line Pulse (TLP) tp = 100 ns; square pulse; ANSI/ESD STM5.5.1-20088.
006aab606
103
001aaa193
1.2
PPP
PPP
(W)
PPP(25°C)
102
0.8
10
0.4
1
1
10
102
tp (ms)
Tamb = 25 °C
Fig. 4.
Peak pulse power as a function of exponential
pulse duration; typical values
PESD5V0V1BLD
Product data sheet
Fig. 5.
150
Tj (°C)
200
Relative variation of peak pulse power as a
function of junction temperature; typical values
3 July 2018
50
4 / 11
PESD5V0V1BLD
Nexperia
006aab607
12
006aab608
103
IRM
IRM(25°C)
Cd
(pF)
102
10
10
1
8
10-1
6
2
3
4
VR (V)
10-2
-100
5
f = 1 MHz; Tamb = 25 °C
Fig. 6.
Fig. 7.
Diode capacitance as a function of reverse
voltage; typical values
-50
100
Tj (°C)
150
Relative variation of reverse leakage current
as a function of junction temperature; typical
values
IPP
-VCL -VBR -VRWM
IR
IRM
-IRM
-IR
VRWM VBR VCL
-IPP
006aaa676
Fig. 8.
V-I characteristics for a bidirectional ESD protection diode
PESD5V0V1BLD
Product data sheet
3 July 2018
5 / 11
PESD5V0V1BLD
Nexperia
ESD TESTER
4 GHz DIGITAL
OSCILLOSCOPE
RG 223/U
50 Ω coax
RZ
40 dB
ATTENUATOR
CZ
50 Ω
DUT
(DEVICE
UNDER
TEST)
IEC 61000-4-2 ed. 2
CZ = 150 pF; RZ = 330 Ω
vertical scale = 10 V/div
horizontal scale = 100 ns/div
vertical scale = 10 A/div
horizontal scale = 15 ns/div
GND
GND
clamped +8 kV ESD pulse waveform
(IEC 61000-4-2 network)
unclamped +8 kV ESD pulse waveform
GND
GND
clamped -8 kV ESD pulse waveform
unclamped -8 kV ESD pulse waveform
Fig. 9.
006aab609
ESD clamping test setup and waveforms
PESD5V0V1BLD
Product data sheet
3 July 2018
6 / 11
PESD5V0V1BLD
Nexperia
10. Application information
The PESD5V0V1BLD is designed for the protection of one bidirectional data of signal line form
the damage caused by ESD and surge pulses.The device may be used on lines where the signal
polarities are both, positive or negative with respect to ground. The PESD5V0V1BLD provides a
surge capability of 45 W per line for an 8/20 µs waveform.
line to be protected
PESD5V0V1Bx
GND
006aab610
Fig. 10. Application diagram
Circuit board layout and protection device placement
Circuit board layout is critical for the suppression of ESD, Electrical Fast Transient (EFT) and surge
transients. The following guidelines are recommended:
1.
2.
3.
4.
5.
6.
7.
8.
Place the device as close to the input terminal or connector as possible.
Minimize the path length between the device and the protected line.
Keep parallel signal paths to a minimum.
Avoid running protected conductors in parallel with unprotected conductors.
Minimize all Printed-Circuit Board (PCB) conductive loops including power and ground loops.
Minimize the length of the transient return path to ground.
Avoid using shared transient return paths to a common ground point.
Use ground planes whenever possible. For multilayer PCBs, use ground vias.
11. Test information
Quality information
This product has been qualified in accordance with the Automotive Electronics Council (AEC)
standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in
automotive applications.
PESD5V0V1BLD
Product data sheet
3 July 2018
7 / 11
PESD5V0V1BLD
Nexperia
12. Package outline
0.65
0.55
0.4
max
2
0.30
0.22
1.05
0.95
0.65
1
0.30
0.22
0.55
0.45
cathode marking on top side (if applicable)
Dimensions in mm
12-05-01
Fig. 11. Package outline DFN1006D-2 (SOD882D)
13. Soldering
1.4
0.2
solder lands
0.8
(2×)
0.6
(2×)
solder resist
0.7
(2×)
solder paste
Dimensions in mm
0.3
0.4
1
1.3
sod882d_fr
Fig. 12. Reflow soldering footprint for DFN1006D-2 (SOD882D)
PESD5V0V1BLD
Product data sheet
3 July 2018
8 / 11
PESD5V0V1BLD
Nexperia
14. Revision history
Table 7. Revision history
Data sheet ID
Release date
Data sheet status
Change notice
Supersedes
PESD5V0V1BLD_v.2
20180703
Product data sheet
PESD5V0V1BLD_v.1
Modifications
• The format of this data sheet has been redesigned to comply with the identity guidelines of
Nexperia.
• Legal texts have been adapted to the new company name where appropriate.
PESD5V0V1BLD_v.1
20101207
PESD5V0V1BLD
Product data sheet
Product data sheet
3 July 2018
9 / 11
PESD5V0V1BLD
Nexperia
Suitability for use in automotive applications — This Nexperia product
has been qualified for use in automotive applications. Unless otherwise
agreed in writing, the product is not designed, authorized or warranted to
be suitable for use in life support, life-critical or safety-critical systems or
equipment, nor in applications where failure or malfunction of an Nexperia
product can reasonably be expected to result in personal injury, death or
severe property or environmental damage. Nexperia and its suppliers accept
no liability for inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
15. Legal information
Data sheet status
Document status
[1][2]
Product
status [3]
Definition
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
PESD5V0V1BLD
Product data sheet
3 July 2018
10 / 11
PESD5V0V1BLD
Nexperia
Contents
1. General description......................................................1
2. Features and benefits.................................................. 1
3. Applications.................................................................. 1
4. Quick reference data....................................................1
5. Pinning information......................................................2
6. Ordering information....................................................2
7. Marking.......................................................................... 2
8. Limiting values............................................................. 3
9. Characteristics..............................................................4
10. Application information............................................. 7
11. Test information..........................................................7
12. Package outline.......................................................... 8
13. Soldering..................................................................... 8
14. Revision history..........................................................9
15. Legal information.......................................................10
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 3 July 2018
PESD5V0V1BLD
Product data sheet
3 July 2018
11 / 11
很抱歉,暂时无法提供与“PESD5V0V1BLD,315”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+4.94640
- 10+3.94200
- 30+3.44520
- 100+2.94840
- 500+2.64600
- 1000+2.49480
- 国内价格 香港价格
- 10000+0.4562610000+0.05906
- 20000+0.4155820000+0.05380
- 30000+0.3978830000+0.05151
