PESD5V0U1BLD,315
PESD5V0U1BLD,315
    NEXPERIA(安世)
    SOD-882D
    ESD VRWM=5 V VBR(Min)=5.5 V SOD882D
PESD5V0U1BLD,315 数据手册
PESD5V0U1BLD Ultra low capacitance bidirectional ESD protection diode Rev. 2 — 27 July 2011 Product data sheet 1. Product profile 1.1 General description Ultra low capacitance bidirectional ElectroStatic Discharge (ESD) protection diode designed to protect one signal line from the damage caused by ESD and other transients. The device is housed in a SOD882D leadless ultra small Surface-Mounted Device (SMD) plastic package with visible and solderable side pads. 1.2 Features and benefits      Bidirectional ESD protection of one line Ultra small SMD plastic package Solderable side pads Package height typ. 0.37 mm Ultra low diode capacitance Cd = 2.9 pF     AEC-Q101 qualified ESD protection up to 10 kV IEC 61000-4-2; level 4 (ESD) Ultra low leakage current: IRM = 5 nA 1.3 Applications  Computers and peripherals  Audio and video equipment  Cellular handsets and accessories  High-speed data lines  Communication systems  Portable electronics 1.4 Quick reference data Table 1. Quick reference data Symbol Parameter VRWM reverse standoff voltage Cd diode capacitance Conditions f = 1 MHz; VR = 0 V Min Typ Max Unit - - 5 V - 2.9 3.5 pF 2. Pinning information Table 2. Pinning Pin Description 1 cathode (diode 1) 2 cathode (diode 2) Simplified outline Graphic symbol [1] 1 2 1 2 sym045 Transparent top view [1] The marking bar indicates pin 1. PESD5V0U1BLD Nexperia Ultra low capacitance bidirectional ESD protection diode 3. Ordering information Table 3. Ordering information Type number Package PESD5V0U1BLD Name Description Version - leadless ultra small plastic package; 2 terminals; body 1  0.6  0.4 mm SOD882D 4. Marking Table 4. Marking codes Type number Marking code[1] PESD5V0U1BLD 0001 0000 [1] For SOD882D binary marking code description, see Figure 1. 4.1 Binary marking code description CATHODE BAR READING DIRECTION VENDOR CODE READING EXAMPLE: 0111 1011 MARKING CODE (EXAMPLE) READING DIRECTION 006aac477 Fig 1. SOD882D binary marking code description 5. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). PESD5V0U1BLD Product data sheet Symbol Parameter Tj Conditions Min Max Unit junction temperature - 150 C Tamb ambient temperature 55 +150 C Tstg storage temperature 65 +150 C All information provided in this document is subject to legal disclaimers. Rev. 2 — 27 July 2011 © Nexperia B.V. 2017. All rights reserved 2 of 11 PESD5V0U1BLD Nexperia Ultra low capacitance bidirectional ESD protection diode Table 6. ESD maximum ratings Tamb = 25 C unless otherwise specified. Symbol Parameter Conditions electrostatic discharge voltage VESD [1][2] IEC 61000-4-2 (contact discharge) machine model [2] MIL-STD-883 (human body model) [1] Device stressed with ten non-repetitive ESD pulses. [2] Measured from pin 1 to 2. Table 7. Min Max Unit - 10 kV - 400 V - 10 kV ESD standards compliance Standard Conditions IEC 61000-4-2; level 4 (ESD) > 15 kV (air); > 8 kV (contact) MIL-STD-883; class 3 (human body model) > 4 kV 001aaa631 IPP 001aaa630 120 100 % 90 % 100 % IPP; 8 μs IPP (%) 80 e−t 50 % IPP; 20 μs 40 10 % 0 10 20 30 30 ns 40 t (μs) Fig 2. t tr = 0.7 ns to 1 ns 0 8/20 s pulse waveform according to IEC 61000-4-5 PESD5V0U1BLD Product data sheet 60 ns Fig 3. ESD pulse waveform according to IEC 61000-4-2 All information provided in this document is subject to legal disclaimers. Rev. 2 — 27 July 2011 © Nexperia B.V. 2017. All rights reserved 3 of 11 PESD5V0U1BLD Nexperia Ultra low capacitance bidirectional ESD protection diode 6. Characteristics Table 8. Characteristics Tamb = 25 C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit VRWM reverse standoff voltage - - 5 V IRM reverse leakage current VRWM = 5 V - 5 100 nA VBR breakdown voltage IR = 5 mA 5.5 7 9.5 V Cd diode capacitance f = 1 MHz; VR = 0 V - 2.9 3.5 pF - 0.8 -  dynamic resistance rdyn [1] [1] IR = 10 A Non-repetitive current pulse, Transmission Line Pulse (TLP) tp = 100 ns; square pulse; ANS/IESD STM5-1-2008. 006aab036 3.0 IPP Cd (pF) 2.6 −VCL −VBR −VRWM IR IRM −IRM −IR VRWM VBR VCL 2.2 − 1.8 0 1 2 3 4 + −IPP 5 VR (V) 006aaa676 f = 1 MHz; Tamb = 25 C Fig 4. Diode capacitance as a function of reverse voltage; typical values PESD5V0U1BLD Product data sheet Fig 5. V-I characteristics for a bidirectional ESD protection diode All information provided in this document is subject to legal disclaimers. Rev. 2 — 27 July 2011 © Nexperia B.V. 2017. All rights reserved 4 of 11 PESD5V0U1BLD Nexperia Ultra low capacitance bidirectional ESD protection diode ESD TESTER RZ 450 Ω RG 223/U 50 Ω coax 4 GHz DIGITAL OSCILLOSCOPE 10× ATTENUATOR 50 Ω CZ DUT (DEVICE UNDER TEST) IEC 61000-4-2 network CZ = 150 pF; RZ = 330 Ω vertical scale = 10 A/div horizontal scale = 15 ns/div vertical scale = 10 V/div horizontal scale = 100 ns/div GND GND unclamped +8 kV ESD pulse waveform (IEC 61000-4-2 network) clamped +8 kV ESD pulse waveform (IEC 61000-4-2 network) pin 1 to 2 vertical scale = 10 A/div horizontal scale = 15 ns/div GND GND vertical scale = 10 V/div horizontal scale = 100 ns/div unclamped −8 kV ESD pulse waveform (IEC 61000-4-2 network) Fig 6. clamped −8 kV ESD pulse waveform (IEC 61000-4-2 network) pin 1 to 2 006aab037 ESD clamping test setup and waveforms PESD5V0U1BLD Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 27 July 2011 © Nexperia B.V. 2017. All rights reserved 5 of 11 PESD5V0U1BLD Nexperia Ultra low capacitance bidirectional ESD protection diode 7. Application information The PESD5V0U1BLD is designed for the protection of one bidirectional data or signal line from the damage caused by ESD and surge pulses. The device may be used on lines where the signal polarities are both, positive and negative with respect to ground. signal line PESD5V0U1BLD GND 006aac636 Fig 7. Application diagram Circuit board layout and protection device placement Circuit board layout is critical for the suppression of ESD, Electrical Fast Transient (EFT) and surge transients. The following guidelines are recommended: 1. Place the PESD5V0U1BLD as close to the input terminal or connector as possible. 2. The path length between the PESD5V0U1BLD and the protected line should be minimized. 3. Keep parallel signal paths to a minimum. 4. Avoid running protected conductors in parallel with unprotected conductors. 5. Minimize all Printed-Circuit Board (PCB) conductive loops including power and ground loops. 6. Minimize the length of the transient return path to ground. 7. Avoid using shared transient return paths to a common ground point. 8. Ground planes should be used whenever possible. For multilayer PCBs, use ground vias. 8. Test information 8.1 Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. PESD5V0U1BLD Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 27 July 2011 © Nexperia B.V. 2017. All rights reserved 6 of 11 PESD5V0U1BLD Nexperia Ultra low capacitance bidirectional ESD protection diode 9. Package outline 0.65 0.55 0.4 max 2 0.30 0.22 1.05 0.95 0.65 1 0.30 0.22 0.55 0.45 cathode marking on top side Dimensions in mm Fig 8. 10-08-06 Package outline SOD882D 10. Packing information Table 9. Packing methods The indicated -xxx are the last three digits of the 12NC ordering code.[1] Type number Package Description Packing quantity 10000 PESD5V0U1BLD [1] SOD882D 2 mm pitch, 8 mm tape and reel -315 For further information and the availability of packing methods, see Section 14. 11. Soldering 1.4 0.2 solder lands 0.8 (2×) 0.6 (2×) 0.7 (2×) solder resist solder paste Dimensions in mm 0.3 0.4 1 1.3 sod882d_fr Reflow soldering is the only recommended soldering method. Fig 9. PESD5V0U1BLD Product data sheet Reflow soldering footprint SOD882D All information provided in this document is subject to legal disclaimers. Rev. 2 — 27 July 2011 © Nexperia B.V. 2017. All rights reserved 7 of 11 PESD5V0U1BLD Nexperia Ultra low capacitance bidirectional ESD protection diode 12. Revision history Table 10. Revision history Document ID Release date Data sheet status Change notice Supersedes PESD5V0U1BLD v.2 20110727 Product data sheet - PESD5V0U1BLD v.1 Modifications: PESD5V0U1BLD v.1 PESD5V0U1BLD Product data sheet • Section 2 “Pinning information” is corrected. 20110504 Product data sheet - All information provided in this document is subject to legal disclaimers. Rev. 2 — 27 July 2011 - © Nexperia B.V. 2017. All rights reserved 8 of 11 PESD5V0U1BLD Nexperia Ultra low capacitance bidirectional ESD protection diode 13. Legal information 13.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 13.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 13.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia accepts no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from national authorities. PESD5V0U1BLD Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 27 July 2011 © Nexperia B.V. 2017. All rights reserved 9 of 11 PESD5V0U1BLD Nexperia Ultra low capacitance bidirectional ESD protection diode Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. 13.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 14. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com PESD5V0U1BLD Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 27 July 2011 © Nexperia B.V. 2017. All rights reserved 10 of 11 PESD5V0U1BLD Nexperia Ultra low capacitance bidirectional ESD protection diode 15. Contents 1 1.1 1.2 1.3 1.4 2 3 4 4.1 5 6 7 8 8.1 9 10 11 12 13 13.1 13.2 13.3 13.4 14 15 © Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . 1 General description . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . 1 Quick reference data . . . . . . . . . . . . . . . . . . . . 1 Pinning information . . . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Marking . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Binary marking code description. . . . . . . . . . . . 2 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2 Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Application information. . . . . . . . . . . . . . . . . . . 6 Test information . . . . . . . . . . . . . . . . . . . . . . . . . 6 Quality information . . . . . . . . . . . . . . . . . . . . . . 6 Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 7 Packing information . . . . . . . . . . . . . . . . . . . . . 7 Soldering . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 7 Revision history . . . . . . . . . . . . . . . . . . . . . . . . . 8 Legal information. . . . . . . . . . . . . . . . . . . . . . . . 9 Data sheet status . . . . . . . . . . . . . . . . . . . . . . . 9 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 10 Contact information. . . . . . . . . . . . . . . . . . . . . 10 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 27 July 2011
PESD5V0U1BLD,315 价格&库存
很抱歉,暂时无法提供与“PESD5V0U1BLD,315”相匹配的价格&库存,您可以联系我们找货
PESD5V0U1BLD,315
  • 5+5.99183
  • 10+3.51204
  • 100+2.34927
  • 500+1.81535
  • 1000+1.57805
  • 5000+1.24583
PESD5V0U1BLD,315
  • 5+5.99183
  • 10+3.51204
  • 100+2.34927
  • 500+1.81535
  • 1000+1.57805
  • 5000+1.24583
