PESD5V0X2UAMB
Ultra low capacitance unidirectional double ESD protection
diode
10 April 2014
Product data sheet
1. General description
Ultra low capacitance unidirectional double ElectroStatic Discharge (ESD) protection
diode in a DFN1006B-3 (SOT883B) leadless ultra small Surface-Mounted Device (SMD)
plastic package designed to protect up to two signal lines from the damage caused by
ESD and other transients.
2. Features and benefits
Ultra low diode capacitance: Cd = 0.8 pF
Ultra low package height of only 0.37 mm
ESD protection up to 15 kV; IEC61000-4-2
IPPM = 2.5 A; IEC 61643-321 (surge)
AEC-Q101 qualified
3. Applications
High-speed data lines
Portable electronics
Communication systems
Computers and peripherals
4. Quick reference data
Table 1.
Symbol
Parameter
Conditions
Cd
diode capacitance
f = 1 MHz; VR = 0 V
VRWM
reverse standoff
voltage
Min
Typ
Max
Unit
0.8
0.95
pF
5
V
Per diode
[1]
Measured from pin 1 or 2 to 3.
[1]
PESD5V0X2UAMB
Nexperia
Ultra low capacitance unidirectional double ESD protection diode
5. Pinning information
Table 2.
Pinning information
Pin
Symbol Description
1
K1
cathode (diode 1)
2
K2
cathode (diode 2)
3
A
common anode
Simplified outline
Graphic symbol
1
3
2
1
3
2
Transparent
top view
brb051
6. Ordering information
Table 3.
Type number
PESD5V0X2UAMB
Package
Name
Description
Version
DFN1006B-3
DFN1006B-3: leadless ultra small plastic package; 3 solder
lands; body 1.0 x 0.6 x 0.37 mm
SOT883B
7. Marking
Table 4.
Marking codes
Type number
Marking code
PESD5V0X2UAMB
0100 1111
PIN 1 INDICATION
READING DIRECTION
READING EXAMPLE:
0111
1011
MARKING CODE
(EXAMPLE)
READING DIRECTION
006aac673
Fig. 1.
DFN1006B-3 (SOT883B) binary marking code description
PESD5V0X2UAMB
Product data sheet
All information provided in this document is subject to legal disclaimers.
10 April 2014
Nexperia B.V. 2017. All rights reserved
2 / 13
PESD5V0X2UAMB
Nexperia
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
IPPM
rated peak pulse current
tp = 8/20 µs
2.5
A
Tj
junction temperature
150
°C
Tstg
storage temperature
-55
150
°C
Tamb
ambient temperature
-65
150
°C
Per diode
[1][2]
ESD maximum ratings
VESD
electrostatic discharge voltage
IEC 61000-4-2 (contact discharge)
[3][2]
15
kV
IEC 61000-4-2 (air discharge)
[3][2]
15
kV
machine model
[2]
400
V
10
kV
MIL-STD-883 (human body model)
[1]
[2]
[3]
According to IEC 61000-4-5 and IEC 61643-321.
Device stressed with ten non-repetitive ESD pulses.
001aaa631
001aaa630
120
IPP
100 %
100 % IPP; 8 µs
IPP
80
90 %
e- t
50 % IPP; 20 µs
40
10 %
Fig. 2.
t (µs)
8/20 µs pulse waveform according to
PESD5V0X2UAMB
Product data sheet
t
tr = 0.6 ns to 1 ns
40
30 ns
60 ns
Fig. 3.
ESD pulse waveform according to
IEC 61000-4-2
10 April 2014
3 / 13
PESD5V0X2UAMB
Nexperia
9. Characteristics
Table 6.
Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
5
V
Per diode
VRWM
reverse standoff
voltage
IRM
reverse leakage
current
VR = 5 V
[1]
1
10
nA
VCL
clamping voltage
IPP = 1 A; tp = 8/20 µs
[2][1]
13
V
IPP = 2.5 A; tp = 8/20 µs
[2][1]
14
V
VBR
breakdown voltage
IR = 10 mA
[1]
7.5
8.8
10
V
Cd
diode capacitance
f = 1 MHz; VR = 0 V
[1]
0.8
0.95
pF
Rdyn
dynamic resistance
IR = 10 A
[3][1]
0.65
Ω
[1]
[2]
[3]
Non-repetitive current pulse, Transmission Line Pulse (TLP); square pulse; ANSI / ESD STM5.5.1-2008.
I
aaa-011254
1.0
Cd
(pF)
0.8
0.6
- VCL - VBR - VRWM
V
- IRM
- IR
0.4
0.2
2
3
4
VR (V)
5
- IPP
- IPPM
f = 1 MHz; Tamb = 25 °C
Fig. 4.
P-N
Diode capacitance as a function of reverse
voltage; typical values
PESD5V0X2UAMB
Product data sheet
Fig. 5.
V-I characteristics for a unidirectional ESD
protection diode
10 April 2014
006aab324
4 / 13
PESD5V0X2UAMB
Nexperia
aaa-011255
30
I
(A)
VCL (V)
30
tp = 100 ns; Transmission Line Pulse (TLP)
Fig. 6.
Dynamic resistance
PESD5V0X2UAMB
Product data sheet
10 April 2014
5 / 13
PESD5V0X2UAMB
Nexperia
ESD TESTER
4 GHz DIGITAL
OSCILLOSCOPE
RG 223/U
50 Ω coax
Rd
40 dB
ATTENUATOR
Cs
50 Ω
DUT
(DEVICE
UNDER
TEST)
IEC 61000-4-2, ed.2
Cs = 150 pF; Rd = 330 Ω
10
2
V
(kV) 8
V
(kV) 0
6
-2
4
-4
2
-6
-2
-10
40
50
t (ns)
60
-10
-10
70
unclamped +8 kV ESD pulse waveform
(IEC 61000-4-2 network)
10
40
50
t (ns)
60
70
unclamped -8 kV ESD pulse waveform
VCL
(V)
VCL
(V)
60
-20
-20
-10
30
50
t (ns)
70
-100
-10
10
30
50
t (ns)
70
aaa-011256
Fig. 7.
ESD clamping test setup and waveforms
PESD5V0X2UAMB
Product data sheet
10 April 2014
6 / 13
PESD5V0X2UAMB
Nexperia
10. Test information
10.1 Quality information
This product has been qualified in accordance with the Automotive Electronics Council
(AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is
suitable for use in automotive applications.
11. Application information
The device is designed for the protection of up to two unidirectional data lines from surge
pulses and ESD damage.
line 1 to be protected
line 2 to be protected
DUT
DUT
GND
bidirectional protection
of one line
Fig. 8.
GND
unidirectional protection
of two lines
006aab252
Application diagram
Circuit board layout and protection device placement
Circuit board layout is critical for the suppression of ESD, Electrical Fast Transient (EFT)
and surge transients. The following guidelines are recommended:
1.
2.
3.
4.
5.
Place the device as close to the input terminal or connector as possible.
Minimize the path length between the device and the protected line.
Keep parallel signal paths to a minimum.
Avoid running protected conductors in parallel with unprotected conductors.
Minimize all Printed-Circuit Board (PCB) conductive loops including power and
ground loops.
6. Minimize the length of the transient return path to ground.
7. Avoid using shared transient return paths to a common ground point.
8. Use ground planes whenever possible. For multilayer PCBs, use ground vias.
PESD5V0X2UAMB
Product data sheet
10 April 2014
7 / 13
PESD5V0X2UAMB
Nexperia
12. Package outline
Leadless ultra small plastic package; 3 solder lands; body 1.0 x 0.6 x 0.37 mm
L (2x)
SOT883B
L1
2
b (2x)
3
e
b1
1
e1
A1
A
E
D
Dimensions
Unit
mm
1 mm
scale
A(1)
A1
b
b1
D
E
e
e1
L
L1
max 0.40 0.04 0.20 0.55 0.65 1.05
0.30 0.30
nom 0.37
0.15 0.50 0.60 1.00 0.35 0.65 0.25 0.25
min 0.34
0.12 0.47 0.55 0.95
0.22 0.22
Note
1. Including plating thickness
Outline
version
sot883b_po
References
IEC
JEDEC
JEITA
European
projection
Issue date
11-11-02
12-01-03
SOT883B
Fig. 9.
Package outline DFN1006B-3 (SOT883B)
PESD5V0X2UAMB
Product data sheet
10 April 2014
8 / 13
PESD5V0X2UAMB
Nexperia
13. Soldering
Footprint information for reflow soldering
SOT883B
1.3
0.7
R0.05 (8x)
0.9
0.6
0.7
0.25
(2x)
0.3
(2x)
0.3
0.4
(2x)
0.4
solder land
solder land plus solder paste
solder paste deposit
solder resist
occupied area
Dimensions in mm
sot883b_fr
Fig. 10. Reflow soldering footprint for DFN1006B-3 (SOT883B)
PESD5V0X2UAMB
Product data sheet
10 April 2014
9 / 13
PESD5V0X2UAMB
Nexperia
14. Revision history
Table 7.
Revision history
Data sheet ID
Release date
PESD5V0X2UAMB v.1 20140410
PESD5V0X2UAMB
Product data sheet
Data sheet status
Change notice
Supersedes
Product data sheet
10 April 2014
10 / 13
PESD5V0X2UAMB
Nexperia
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
15. Legal information
15.1 Data sheet status
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Document
status [1][2]
Product
status [3]
Objective
[short] data
sheet
Development This document contains data from
the objective specification for product
development.
Preliminary
[short] data
sheet
Qualification
This document contains data from the
preliminary specification.
Product
[short] data
sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Definition
Right to make changes — Nexperia reserves the right to
make changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the Internet at URL http://www.nexperia.com.
15.2 Definitions
Preview — The document is a preview version only. The document is still
subject to formal approval, which may result in modifications or additions.
Nexperia does not give any representations or warranties as to
the accuracy or completeness of information included herein and shall have
no liability for the consequences of use of such information.
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local Nexperia
sales office. In case of any inconsistency or conflict with the
short data sheet, the full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product
is deemed to offer functions and qualities beyond those described in the
Product data sheet.
15.3 Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give
any representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
PESD5V0X2UAMB
Product data sheet
Suitability for use in automotive applications — This Nexperia
product has been qualified for use in automotive
applications. Unless otherwise agreed in writing, the product is not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their
applications and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or
customer product design. It is customer’s sole responsibility to determine
whether the Nexperia product is suitable and fit for the
customer’s applications and products planned, as well as for the planned
application and use of customer’s third party customer(s). Customers should
provide appropriate design and operating safeguards to minimize the risks
associated with their applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default
in the customer’s applications or products, or the application or use by
customer’s third party customer(s). Customer is responsible for doing all
necessary testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications
and the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
10 April 2014
11 / 13
PESD5V0X2UAMB
Nexperia
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
15.4 Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
PESD5V0X2UAMB
Product data sheet
10 April 2014
12 / 13
PESD5V0X2UAMB
Nexperia
16. Contents
1
General description ............................................... 1
2
Features and benefits ............................................1
3
Applications ........................................................... 1
4
Quick reference data ............................................. 1
5
Pinning information ............................................... 2
6
Ordering information ............................................. 2
7
Marking ................................................................... 2
8
Limiting values .......................................................3
9
Characteristics ....................................................... 4
10
10.1
Test information ..................................................... 7
Quality information ............................................... 7
11
Application information .........................................7
12
Package outline ..................................................... 8
13
Soldering ................................................................ 9
14
Revision history ................................................... 10
15
15.1
15.2
15.3
15.4
Legal information .................................................11
Data sheet status ............................................... 11
Definitions ...........................................................11
Disclaimers .........................................................11
Trademarks ........................................................ 12
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 10 April 2014
PESD5V0X2UAMB
Product data sheet
10 April 2014
13 / 13
很抱歉,暂时无法提供与“PESD5V0X2UAMBYL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+4.243971+0.54903
- 10+2.5987710+0.33619
- 100+1.64521100+0.21284
