HEF4046BT,653
HEF4046BT,653
    NEXPERIA(安世)
    SOIC16_150MIL
    锁相环
HEF4046BT,653 数据手册
HEF4046B Phase-locked loop Rev. 6 — 24 March 2016 Product data sheet 1. General description The HEF4046B is a phase-locked loop circuit that consists of a linear Voltage Controlled Oscillator (VCO) and two different phase comparators with a common signal input amplifier and a common comparator input. A 7 V regulator (Zener) diode is provided for supply voltage regulation if necessary. For a functional description see Section 6. It operates over a recommended VDD power supply range of 3 V to 15 V referenced to VSS (usually ground). Unused inputs must be connected to VDD, VSS, or another input. 2. Features and benefits      Fully static operation 5 V, 10 V, and 15 V parametric ratings Standardized symmetrical output characteristics Specified from 40 C to +85 C Complies with JEDEC standard JESD 13-B 3. Ordering information Table 1. Ordering information All types operate from 40 C to +85 C. Type number HEF4046BT Package Name Description Version SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 HEF4046B Nexperia Phase-locked loop 4. Functional diagram 3+$6( &203$5$725 6,*B,1   3&B287  &203B,1   3&B287 3+$6( &203$5$725 ·1 5  3&3  9&2B,1 9&2B287  /2:3$66 ),/7(5 &$  & & 9&2 966 5 5  5 5   6)B287 6285&( )2//2:(5 &%  966 56) 966 ,1+  966 SLQ  =(1(5 DDH Fig 1. Functional diagram 5. Pinning information 5.1 Pinning +()% 3&3B287   9'' 3&B287   =(1(5 &203B,1   6,*B,1 9&2B287   3&B287 ,1+   5 &$   5 &%   6)B287 966   9&2B,1 DDH Fig 2. Pin configuration HEF4046B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 24 March 2016 © Nexperia B.V. 2017. All rights reserved 2 of 19 HEF4046B Nexperia Phase-locked loop 5.2 Pin description Table 2. Pin description Symbol Pin Description PCP_OUT 1 phase comparator pulse output PC1_OUT 2 phase comparator 1 output COMP_IN 3 comparator input VCO_OUT 4 VCO output INH 5 inhibit input C1A 6 capacitor C1 connection A C1B 7 capacitor C1 connection B VSS 8 ground supply voltage VCO_IN 9 VCO input SF_OUT 10 source-follower output R1 11 resistor R1 connection R2 12 resistor R2 connection PC2_OUT 13 phase comparator 2 output SIG_IN 14 signal input ZENER 15 Zener diode input for regulated supply VDD 16 supply voltage 6. Functional description 6.1 VCO control The VCO requires an external capacitor (C1) and resistor (R1) with an optional resistor (R2). Resistor R1 and capacitor C1 determine the frequency range of the VCO, while resistor R2 enables the VCO to have a frequency off-set if required. The high input impedance of the VCO simplifies the design of low-pass filters; it permits the designer a wide choice of resistor/capacitor ranges. In order not to load the low-pass filter, a source-follower output of the VCO input voltage is provided at SF_OUT (pin 10). If this is used, a load resistor (RL) should be connected from SF_OUT to VSS; if unused, SF_OUT should be left open. The VCO output (pin 4) can either be connected directly to the comparator input COMP_IN (pin 3) or via a frequency divider. A LOW-level at the inhibit input INH_IN (pin 5) enables the VCO and the source follower, while a HIGH-level turns both off to minimize standby power consumption. 6.2 Phase comparators The phase-comparator signal input SIG_IN (pin 14) can be direct-coupled, provided the signal swing is between the standard HE4000B family input logic levels. The signal must be capacitively coupled to the self-biasing amplifier at the signal input with smaller swings. Phase comparator 1 is an EXCLUSIVE-OR network. The signal and comparator input frequencies must have a 50 % duty factor to obtain the maximum lock range. The average output voltage of the phase comparator is equal to 0.5VDD when there is no signal or noise at the signal input. The average voltage to the VCO input VCO_IN is supplied by the low-pass filter connected to the output of phase comparator 1. This also causes the VCO to oscillate at the center frequency (f0). The frequency capture range (2fC) is defined as HEF4046B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 24 March 2016 © Nexperia B.V. 2017. All rights reserved 3 of 19 HEF4046B Nexperia Phase-locked loop the frequency range of input signals on which the PLL will lock if it was initially out of lock. The frequency lock range (2fL) is defined as the frequency range of input signals on which the loop will stay locked if it was initially in lock. The capture range is smaller or equal to the lock range. With phase comparator 1, the range of frequencies over which the PLL can acquire lock (capture range) depends on the low-pass filter characteristics and this range can be made as large as the lock range. Phase comparator 1 enables the PLL system to remain in lock in spite of high amounts of noise in the input signal. A typical behavior of this type of phase comparator is that it may lock onto input frequencies that are close to harmonics of the VCO center frequency. Another typical behavior is that the phase angle between the signal and comparator input varies between 0 and 180, and is 90 at the center frequency. Figure 3 shows the typical phase-to-output response characteristic. Figure 4 shows the typical waveforms for a PLL with a f0 locked phase comparator 1. 9''  9''  ƒ ƒ ƒ DDH (1) Average output voltage. Fig 3. Signal-to-comparator inputs phase difference for comparator 1 6,*B,1 &203B,1 9&2B287   3&B287 9'' 9&2B,1 966 DDH Fig 4. HEF4046B Product data sheet Typical waveforms for phase-locked loop with a f0 locked phase comparator 1 All information provided in this document is subject to legal disclaimers. Rev. 6 — 24 March 2016 © Nexperia B.V. 2017. All rights reserved 4 of 19 HEF4046B Nexperia Phase-locked loop Phase comparator 2 is an edge-controlled digital memory network. It consists of four flip-flops, control gating and a 3-state output circuit comprising p and n-type drivers with a common output node. When the p-type or n-type drivers are ON, they pull the output up to VDD or down to VSS respectively. This type of phase comparator only acts on the positive-going edges of the signals at SIG_IN and COMP_IN. Therefore, the duty factors of these signals are not of importance. If the signal input frequency is higher than the comparator input frequency, the p-type output driver is maintained ON most of the time, and both the n and p-type drivers are OFF (3-state) the remainder of the time. If the signal input frequency is lower than the comparator input frequency, the n-type output driver is maintained ON most of the time, and both the n and p-type drivers are OFF the remainder of the time. If the signal input and comparator input frequencies are equal, but the signal input lags the comparator input in phase, the n-type output driver is maintained ON for a time corresponding to the phase difference. If the comparator input lags the signal input in phase, the p-type output driver is maintained ON for a time corresponding to the phase difference. Subsequently, the voltage at the capacitor of the low-pass filter connected to this phase comparator is adjusted until the signal and comparator inputs are equal in both phase and frequency. At this stable point, both p and n-type drivers remain OFF and thus the phase comparator output becomes an open circuit and keeps the voltage at the capacitor of the low-pass filter constant. Moreover, the signal at the phase comparator pulse output (PCP_OUT) is a HIGH level, which can be used for indicating a locked condition. Thus, for phase comparator 2, no phase difference exists between the signal and comparator inputs over the full VCO frequency range. Moreover, the power dissipation due to the low-pass filter is reduced when this type of phase comparator is used, because both p and n-type output drivers are OFF for most of the signal input cycle. It should be noted that the PLL lock range for this type of phase comparator is equal to the capture range, independent of the low-pass filter. With no signal present at the signal input, the VCO is adjusted to its lowest frequency for phase comparator 2. Figure 5 shows typical waveforms for a PLL employing this type of locked phase comparator. 6,*B,1 &203B,1 9&2B287   9'' 3&B287 966 KLJKLPSHGDQFH2))VWDWH 9&2B,1 3&3B287 DDH Fig 5. HEF4046B Product data sheet Typical waveforms for phase-locked loop with a locked phase comparator 2 All information provided in this document is subject to legal disclaimers. Rev. 6 — 24 March 2016 © Nexperia B.V. 2017. All rights reserved 5 of 19 HEF4046B Nexperia Phase-locked loop Figure 6 shows the state diagram for phase comparator 2. Each circle represents a state of the comparator. The number at the top, inside each circle, represents the state of the comparator, while the logic state of the signal and comparator inputs are represented by a ‘0’ for a logic LOW or a ‘1’ for a logic HIGH, and they are shown in the left and right bottom of each circle. The transitions from one to another result from either a logic change at the signal input (S representing SIG_IN) or the comparator input (C representing COMP_IN). A positivegoing and a negative-going transition are shown by an arrow pointing up or down respectively. The state diagram assumes, that only one transition on either the signal input or comparator input occurs at any instant. • States 3, 5, 9 and 11 represent the output condition when the p-type driver is ON. • States 2, 4, 10 and 12 determine the condition when the n-type driver is ON. • States 1, 6, 7 and 8 represent the condition when the output is in its high-impedance OFF state; i.e. both p and n-type drivers are OFF, and the PCP_OUT output is HIGH. The condition at output PCP_OUT for all other states is LOW.    & 6 6 &           6 6      6 & &    &      6 SW\SHGULYHU21 QW\SHGULYHU21 QDQGSW\SH GULYHUVDUH2)) 6    & 6   & & &  &  6 6   & 6 & 6  VWDWHQXPEHURI WKHFRPSDUDWRU Q   ORJLFVWDWHRI FRPSDUDWRULQSXW SLQ DDH ORJLFVWDWHRI VLJQDOLQSXW SLQ S : 0 to 1 transition at the signal input SIG_IN. C : 1 to 0 transition at the comparator input COMP_IN. Fig 6. HEF4046B Product data sheet State diagram for comparator 2 All information provided in this document is subject to legal disclaimers. Rev. 6 — 24 March 2016 © Nexperia B.V. 2017. All rights reserved 6 of 19 HEF4046B Nexperia Phase-locked loop 7. Limiting values Table 3. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter VDD supply voltage IIK input clamping current VI input voltage IOK output clamping current II/O input/output current IDD supply current Tstg storage temperature Tamb ambient temperature Conditions Max Unit 0.5 +18 V VI < 0.5 V or VI > VDD + 0.5 V - 10 0.5 VDD + 0.5 - 10 mA - 10 mA VO < 0.5 V or VO > VDD + 0.5 V Ptot total power dissipation SO16 package P power dissipation per output [1] Min mA V - 50 mA 65 +150 C 40 +85 C - 500 mW - 100 mW [1] For SO16 package: Ptot derates linearly with 8 mW/K above 70 C. 8. Recommended operating conditions Table 4. Recommended operating conditions Symbol Parameter VDD supply voltage Conditions Min Typ Max 3 - 15 V as fixed oscillator only 3 - 15 V phase-locked loop operation 5 - 15 V VI input voltage Tamb ambient temperature in free air t/V input transition rise and fall rate for INH input VDD = 5 V HEF4046B Product data sheet Unit 0 - VDD V 40 - +85 C - - 3.75 s/V VDD = 10 V - - 0.5 s/V VDD = 15 V - - 0.08 s/V All information provided in this document is subject to legal disclaimers. Rev. 6 — 24 March 2016 © Nexperia B.V. 2017. All rights reserved 7 of 19 HEF4046B Nexperia Phase-locked loop 9. Static characteristics Table 5. Static characteristics VSS = 0 V; VI = VSS or VDD unless otherwise specified. Symbol Parameter Conditions Tamb = 40 C VDD Min HIGH-level input voltage VIH LOW-level input voltage VIL VOH VOL IOZ OFF-state output current supply current IDD input capacitance CI Min Max 3.5 - 3.5 - 3.5 - V - 7.0 - 7.0 - V 15 V 11.0 - 11.0 - 11.0 - V 5V - 1.5 - 1.5 - 1.5 V 10 V - 3.0 - 3.0 - 3.0 V 15 V - 4.0 - 4.0 - 4.0 V 5V 4.95 - 4.95 - 4.95 - V 10 V 9.95 - 9.95 - 9.95 - V 15 V 14.95 - 14.95 - 14.95 - V 5V - 0.05 - 0.05 - 0.05 V 10 V - 0.05 - 0.05 - 0.05 V 15 V - 0.05 - 0.05 - 0.05 V VO = 2.5 V 5V - 1.7 - 1.4 - 1.1 mA VO = 4.6 V 5V - 0.52 - 0.44 - 0.36 mA VO = 9.5 V 10 V - 1.3 - 1.1 - 0.9 mA VO = 13.5 V 15 V - 3.6 - 3.0 - 2.4 mA IO < 1 A IO < 1 A input leakage current Max 7.0 LOW-level output voltage II Min VO = 0.4 V 5V 0.52 - 0.44 - 0.36 - mA VO = 0.5 V 10 V 1.3 - 1.1 - 0.9 - mA VO = 1.5 V 15 V 3.6 - 3.0 - 2.4 - mA 15 V - 0.3 - 0.3 - 1.0 A output HIGH and returned to VDD 15 V - 1.6 - 1.6 - 12.0 A output LOW and returned to VSS 15 V - 1.6 - 1.6 - 12.0 A IO = 0 A 5V [1] - - 20 - - - A 10 V [1] - - 300 - - - A 15 V [1] - - 750 - - - A 5V [2] - 20 - 20 - 150 A 10 V [2] - 40 - 40 - 300 A 15 V [2] - 80 - 80 - 600 A - - - 7.5 - - pF for INH input [1] Pin 15 open; pin 5 at VDD; pins 3 and 9 at VSS; pin 14 open. [2] Pin 15 open; pin 5 at VDD; pins 3 and 9 at VSS; pin 14 at VDD;input current pin 14 not included. HEF4046B Product data sheet Unit 10 V IO < 1 A LOW-level output current IOL Tamb = 85 C 5V HIGH-level output voltage HIGH-level output current IOH IO < 1 A Max Tamb = 25 C All information provided in this document is subject to legal disclaimers. Rev. 6 — 24 March 2016 © Nexperia B.V. 2017. All rights reserved 8 of 19 HEF4046B Nexperia Phase-locked loop 10. Dynamic characteristics Table 6. Dynamic characteristics VSS = 0 V; Tamb = 25 C; CL = 50 pF; input transition times 20 ns. Symbol Parameter Conditions VDD Min Typ Max Unit SIG_IN input; at self-bias operating point 5V - 750 - k 10 V - 220 - k 15 V - 140 - k SIG_IN input A.C. coupled; peak-to-peak 5 V values; R1 = 10 k; R2 = ; C1 = 100 pF; 10 V independent of the lock range 15 V - 150 - mV - 150 - mV - 200 - mV 5V - - 1.5 V 10 V - - 3.0 V 15 V - - 4.0 V 5V 3.5 - - V 10 V 7.0 - - V 15 V 11.0 - - V Phase comparators RI Vi(sens) VIL VIH IIH IIL input resistance input voltage sensitivity LOW-level input voltage SIG_IN and COMP_IN inputs, DC coupled LOW; full temperature range HIGH-level input voltage SIG_IN and COMP_IN inputs, D.C. coupled HIGH; full temperature range HIGH-level input current LOW-level input current 5V - 7 - A 10 V - 30 - A 15 V - 70 - A 5V - 3 - A 10 V - 18 - A 15 V - 45 - A 5V - 150 - W 10 V - 2500 - W 15 V - 9000 - W VCO_IN at VDD; R1 = 10 k; R2 = ; C1 = 50 pF 5V 0.5 1.0 - MHz 10 V 1.0 2.0 - MHz 1.3 2.7 - MHz no frequency offset (fmin = 0 Hz) 5V [1] - 0.22 to 0.30 - % Hz/C 10 V [1] - 0.04 to 0.05 - % Hz/C 15 V [1] - 0.01 to 0.05 - % Hz/C 5V [1] - 0 to 0.22 - % Hz/C 10 V [1] - 0 to 0.04 - % Hz/C 15 V [1] - 0 to 0.01 - % Hz/C SIG_IN input; at VDD SIG_IN input; at VSS VCO P fmax power dissipation maximum frequency f0 = 10 kHz; R1 = 1 M; R2 = ; VCO_IN at 0.5 VDD; see Figure 10 to 12 15 V f/T frequency variation with temperature with frequency offset (fmin > 0 Hz) HEF4046B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 24 March 2016 © Nexperia B.V. 2017. All rights reserved 9 of 19 HEF4046B Nexperia Phase-locked loop Table 6. Dynamic characteristics …continued VSS = 0 V; Tamb = 25 C; CL = 50 pF; input transition times 20 ns. Symbol Parameter Conditions f/f relative frequency variation for VCO see Figure 13 and 14  duty factor input resistance Rin VDD Min Typ Max Unit R1 > 10 k 5V - 0.50 - % Hz R1 > 400 k 10 V - 0.25 - % Hz R1 = M 15 V - 0.25 - % Hz 5V - 50 - % 10 V - 50 - % 15 V - 50 - % VCO _OUT output for pin VCO_IN 10 M Source follower Voffset offset voltage RL = 10 k; VCO_IN at 0.5VDD RL = 50 k; VCO_IN at 0.5VDD f/f relative frequency variation VCO output; RL > 50 k; see Figure 13 5V [2] - 1.7 - V 10 V - 2.0 - V 15 V - 2.1 - V 5V - 1.5 - V 10 V - 1.7 - V 15 V - 1.8 - V 5V - 0.3 - % 10 V - 1.0 - % 15 V - 1.3 - % Zener diode VZ working voltage IZ = 50 A - - 7.3 - V Rdyn dynamic resistance For internal Zener diode; IZ = 1 mA - - 25 -  [1] Over the recommended component range. [2] The offset voltage is equal to the input voltage on pin VCO_IN minus the output voltage on pin SF_OUT. 11. Design information Table 7. Design information Test Using phase comparator 1 Using phase comparator 2 VCO adjusts with no signal on SIG_IN VCO in PLL system adjusts to center frequency (f0) VCO in PLL system adjusts to minimum frequency (fmin) Phase angle between SIG_IN and COMP_IN 90 at center frequency (f0), approaching 0 and 180 at the ends of the lock range (2fL) always 0 in lock (positive-going edges) Locks on harmonics of center frequency yes no Signal input noise rejection high low Lock frequency range (2fL) the frequency range of the input signal on which the loop will stay locked if it was initially in lock; 2fL = full VCO frequency range = fmax  fmin Capture frequency range (2fc) the frequency range of the input signal on which the loop will lock if it was initially out of lock depends on low-pass filter characteristics; 2fc < 2fL Center frequency (f0) HEF4046B Product data sheet 2fc = 2fL the frequency of the VCO when VCO_IN at 0.5VDD All information provided in this document is subject to legal disclaimers. Rev. 6 — 24 March 2016 © Nexperia B.V. 2017. All rights reserved 10 of 19 HEF4046B Nexperia Phase-locked loop 11.1 VCO component selection Recommended range for R1 and R2: 10 k to 1 M; for C1: 50 pF to any practical value. 1. VCO without frequency offset (R2 = ).  a. Given f0: use f0 with Figure 7 to determine R1 and C1. b. Given fmax: calculate f0 from f0 = 0.5fmax; use f0 with Figure 7 to determine R1 and C1. 2. VCO with frequency offset. a. Given f0 and 2fL : calculate fmin from the equation fmin = f0  2fL; use fmin with f max Figure 8 to determine R2 and C1; calculate ---------- from the equation f min f max f max f 0 + 2f L - ; use ---------- with Figure 9 to determine the ratio R2/R1 to obtain ---------- = ----------------f min f min f 0 – 2f L R1. f max b. Given fmin and fmax: use fmin with Figure 8 to determine R2 and C1; calculate ---------- ; f min f max use ---------- with Figure 9 to determine R2/R1 to obtain R1. f min IR  +] DDH  IPLQ +]                                  DDH                          & S)        & S) Tamb = 25 C; VCO_IN at 0.5VDD; INH_IN at VSS; R2 = . Lines (1), (4), and (7): VDD = 15 V; Tamb = 25 C; VCO_IN at VSS; INH_IN at VSS; R1 = . Lines (1), (4), and (7): VDD = 15 V; Lines (2), (5), and (8): VDD = 10 V; Lines (2), (5), and (8): VDD = 10 V; Lines (3), (6), and (9): VDD = 5 V; Lines (3), (6), and (9): VDD = 5 V; Lines (1), (2), and (3): R2 = 10 k; Lines (1), (2), and (3): R1 = 10 k; Lines (4), (5), and (6): R2 = 100 k; Lines (4), (5), and (6): R1 = 100 k; Lines (7), (8), and (9): R2 = 1 M. Lines (7), (8), and (9): R1 = 1 M. Fig 7. Typical center frequency as a function of capacitor C1 HEF4046B Product data sheet Fig 8. Typical frequency offset as a function of capacitor C1 All information provided in this document is subject to legal disclaimers. Rev. 6 — 24 March 2016 © Nexperia B.V. 2017. All rights reserved 11 of 19 HEF4046B Nexperia Phase-locked loop DDH  5 5 DDH  3 —:                     IPD[IPD[       5 Nȍ Line (1): VDD = 5 V; R2 = ; VCO_IN at 0.5VDD; CL = 50 pF. Line (2): VDD = 10 V, 15 V. Lines (1) and (2): VDD = 15 V; Lines (3) and (4): VDD = 10 V; Lines (5) and (6): VDD = 5 V; Lines (1), (3), and (5): C1 = 50 pF; Lines (2), (4), and (6): C1 = 1 F. Fig 9. Typical ratio of R2/R1 as a function of the ratio fmax/fmin DDH  3 —: Fig 10. Power dissipation as a function of R1 DDH  3 —:                          5 Nȍ 56) Nȍ R1 = ; VCO_IN at VSS (0 V); CL = 50 pF. VCO_IN at 0.5VDD; R1 = ; R2 = . Lines (1) and (2): VDD = 15 V; Line (1): VDD = 15 V; Lines (3) and (4): VDD = 10 V; Line (2): VDD = 10 V; Lines (5) and (6): VDD = 5 V; Line (3): VDD = 5 V. Lines (1), (3), and (5): C1 = 50 pF; Lines (2), (4), and (6): C1 = 1 F. Fig 11. Power dissipation as a function of R2 HEF4046B Product data sheet Fig 12. Power dissipation of source follower as a function of RL All information provided in this document is subject to legal disclaimers. Rev. 6 — 24 March 2016 © Nexperia B.V. 2017. All rights reserved 12 of 19 HEF4046B Nexperia Phase-locked loop I IPD[ I IR IR I ǻ9 ǻ9 9'' 9'' 99&2,1 DDH See Section 10. For VCO linearity: f1 + f2 f 0 = -------------2 f 0 – f 0 linearity = ----------------  100 % f 0 This figure and the above formula also apply to source follower linearity: substitute VO at SF_OUT for f. V = 0.3 V at VDD = 5 V; V = 2.5 V at VDD = 10 V; V = 5.0 V at VDD = 15 V. Fig 13. Definition of linearity HEF4046B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 24 March 2016 © Nexperia B.V. 2017. All rights reserved 13 of 19 HEF4046B Nexperia Phase-locked loop DDH   OLQ  DDH  OLQ                      5 Nȍ  5 Nȍ a. VDD = 5 V b. VDD = 10 V DDH  OLQ             5 Nȍ c. VDD = 15 V R2 = ; Line (1): C1 = 1 F; Line (2): C1 = 1 nF; Line (3): C1 = 100 pF; Line (4): C1 = 50 pF. Fig 14. VCO frequency linearity as a function of R1 HEF4046B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 24 March 2016 © Nexperia B.V. 2017. All rights reserved 14 of 19 HEF4046B Nexperia Phase-locked loop 12. Package outline 62SODVWLFVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP 627 ' ( $ ; F \ +( Y 0 $ =   4 $ $ $   $ SLQLQGH[ ș /S  /  H Z 0 ES   GHWDLO; PP VFDOH ',0(16,216 LQFKGLPHQVLRQVDUHGHULYHGIURPWKHRULJLQDOPPGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   PP                                                 LQFKHV         ș R R 1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPP LQFK PD[LPXPSHUVLGHDUHQRWLQFOXGHG 5()(5(1&(6 287/,1( 9(56,21 ,(& -('(& 627 ( 06 -(,7$ (8523($1 352-(&7,21 ,668('$7(   Fig 15. Package outline SOT109-1 (SO16) HEF4046B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 24 March 2016 © Nexperia B.V. 2017. All rights reserved 15 of 19 HEF4046B Nexperia Phase-locked loop 13. Revision history Table 8. Revision history Document ID Release date Data sheet status Change notice Supersedes HEF4046B v.6 20160324 Product data sheet - HEF4046B v.5 Modifications: HEF4046B v.5 Modifications: • Type number HEF4046BP (SOT38-4) removed. 20111118 • • • Product data sheet - HEF4046B v.4 Section Applications removed Table 5: IOH minimum values changed to maximum Table 6: Rin typical value changed from 106 M to 10 M HEF4046B v.4 20100105 Product data sheet - HEF4046B_CNV v.3 HEF4046B_CNV v.3 19950101 Product specification - HEF4046B_CNV v.2 HEF4046B_CNV v.2 19950101 Product specification - - HEF4046B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 24 March 2016 © Nexperia B.V. 2017. All rights reserved 16 of 19 HEF4046B Nexperia Phase-locked loop 14. Legal information 14.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 14.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 14.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. HEF4046B Product data sheet Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 6 — 24 March 2016 © Nexperia B.V. 2017. All rights reserved 17 of 19 HEF4046B Nexperia Phase-locked loop Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 14.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 15. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com HEF4046B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 24 March 2016 © Nexperia B.V. 2017. All rights reserved 18 of 19 Nexperia HEF4046B Phase-locked loop 16. Contents 1 2 3 4 5 5.1 5.2 6 6.1 6.2 7 8 9 10 11 11.1 12 13 14 14.1 14.2 14.3 14.4 15 16 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 1 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 2 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3 Functional description . . . . . . . . . . . . . . . . . . . 3 VCO control . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Phase comparators. . . . . . . . . . . . . . . . . . . . . . 3 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 7 Recommended operating conditions. . . . . . . . 7 Static characteristics. . . . . . . . . . . . . . . . . . . . . 8 Dynamic characteristics . . . . . . . . . . . . . . . . . . 9 Design information . . . . . . . . . . . . . . . . . . . . . 10 VCO component selection . . . . . . . . . . . . . . . 11 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 15 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 16 Legal information. . . . . . . . . . . . . . . . . . . . . . . 17 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 17 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Contact information. . . . . . . . . . . . . . . . . . . . . 18 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 24 March 2016 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: NXP: HEF4046BP,652 HEF4046BT,652 HEF4046BT,653
HEF4046BT,653 价格&库存
很抱歉,暂时无法提供与“HEF4046BT,653”相匹配的价格&库存,您可以联系我们找货
