74AVC1T1022DPJ
74AVC1T1022DPJ
    NEXPERIA(安世)
    TSSOP10_3X3MM
    1 至 4 扇出缓冲器 3.6Vcc
74AVC1T1022DPJ 数据手册
74AVC1T1022 1-to-4 fan-out buffer Rev. 2 — 16 March 2017 1 Product data sheet General description The 74AVC1T1022 is a translating 1-to-4 fan-out buffer suitable for use in clock distribution. It has dual supplies (VCC(A) and VCC(B)) for voltage translation. It also has a data input (A), four data outputs (1Yn and 2Yn) and an output enable input (OE). VCC(A) and VCC(B) can be independently supplied at any voltage between 0.8 V and 3.6 V. It makes the device suitable for low voltage translation between any of the following voltages: 0.8 V, 1.2 V, 1.5 V, 1.8 V, 2.5 V and 3.3 V. The levels of A, OE and 1Yn are referenced to VCC(A), outputs 2Yn are referenced to VCC(B). This supply configuration ensures that two of the fanned out signals can be used in level shifting. A HIGH on OE causes all outputs to be pulled LOW via pull-down resistors, a LOW on OE disconnects the pull-down resistors and enables all outputs. Schmitt trigger action at all inputs makes the circuit tolerant for slower input rise and fall time. The IOFF circuitry disables the output, preventing any damaging backflow current through the device when it is powered down. 2 Features and benefits • Wide supply voltage range: – VCC(A): 0.8 V to 3.6 V – VCC(B): 0.8 V to 3.6 V • Complies with JEDEC standards: – JESD8-12 (0.8 V to 1.3 V) – JESD8-11 (0.9 V to 1.65 V) – JESD8-7 (1.2 V to 1.95 V) – JESD8-5 (1.8 V to 2.7 V) – JESD8-B (2.7 V to 3.6 V) • ESD protection: – HBM ANSI/ESDA/JEDEC JS-001 Class 3B exceeds 8 kV – CDM JESD22-C101E exceeds 1000 V • Maximum data rates: – 380 Mbit/s (≥ 1.8 V to 3.3 V translation) – 200 Mbit/s (≥ 1.1 V to 3.3 V translation) – 200 Mbit/s (≥ 1.1 V to 2.5 V translation) – 200 Mbit/s (≥ 1.1 V to 1.8 V translation) – 150 Mbit/s (≥ 1.1 V to 1.5 V translation) – 100 Mbit/s (≥ 1.1 V to 1.2 V translation) • Latch-up performance exceeds 100 mA per JESD 78 Class II • Inputs accept voltages up to 3.6 V • Specified from -40 °C to +85 °C and -40 °C to +125 °C 74AVC1T1022 Nexperia 1-to-4 fan-out buffer 3 Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74AVC1T1022DP -40 °C to +125 °C TSSOP10 plastic thin shrink small outline package; 10 leads; body width 3 mm SOT552-1 74AVC1T1022GU -40 °C to +125 °C XQFN10 plastic, extremely thin quad flat package; no leads; 10 terminals; body 1.40 × 1.80 × 0.50 mm SOT1160-1 4 Marking Table 2. Marking codes Type number Marking code 74AVC1T1022DP B2 74AVC1T1022GU B2 74AVC1T1022 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 16 March 2017 © Nexperia B.V. 2017. All rights reserved. 2 / 25 74AVC1T1022 Nexperia 1-to-4 fan-out buffer 5 Functional diagram A 2 VCC(A) VCC(B) 9 2Y1 Rpd 8 2Y2 Rpd OE 4 7 1Y1 Rpd 6 1Y2 Rpd aaa-019804 Pin numbers are shown for TSSOP10 package only. Figure 1. Logic symbol 74AVC1T1022 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 16 March 2017 © Nexperia B.V. 2017. All rights reserved. 3 / 25 74AVC1T1022 Nexperia 1-to-4 fan-out buffer 6 Pinning information 6.1 Pinning 74AVC1T1022 10 VCC(B) 9 2Y1 GND 3 8 2Y2 OE 4 7 1Y1 GND 5 6 1Y2 GND 2 6 1Y1 1Y2 5 2 7 2Y2 GND 4 1 A A 1 OE 3 VCC(A) 8 2Y1 terminal 1 index area 9 VCC(B) 10 VCC(A) 74AVC1T1022 aaa-019806 Transparent top view aaa-019805 Figure 2. Pin configuration SOT552-1 (TSSOP10) Figure 3. Pin configuration SOT1160-1 (XQFN10) 6.2 Pin description Table 3. Pin description Symbol Pin Description SOT552-1 SOT1160-1 VCC(A) 1 10 supply voltage A A 2 1 data input (referenced to VCC(A)) 3, 5 2, 4 ground (0 V) OE 4 3 output enable input (active LOW) (referenced to VCC(A)) 1Y1, 1Y2 7, 6 6, 5 data outputs (referenced to VCC(A)) 2Y1, 2Y2 9, 8 8, 7 data outputs (referenced to VCC(B)) VCC(B) 10 9 supply voltage B GND [1] [1] All GND pins must be connected to ground (0 V). 74AVC1T1022 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 16 March 2017 © Nexperia B.V. 2017. All rights reserved. 4 / 25 74AVC1T1022 Nexperia 1-to-4 fan-out buffer 7 Functional description Table 4. Function table [1] Output Inputs OE A nYn L L L L H H H X L [1] H = HIGH voltage level; L = LOW voltage level; X = don’t care. 8 Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Max Unit VCC(A) supply voltage A -0.5 +4.6 V VCC(B) supply voltage B -0.5 +4.6 V VI input voltage [1] -0.5 +4.6 V OE = LOW [1] [2] [3] -0.5 OE = HIGH [1] -0.5 +4.6 VO output voltage VCCO + 0.5 V V IIK input clamping current VI < 0 V -50 - mA IOK output clamping current VO < 0 V -50 - mA IO output current VO = 0 V to VCCO - ±50 mA ICC supply current ICC(A) or ICC(B) - 100 mA IGND ground current -100 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 250 mW - 250 mW Tamb = -40 °C to +125 °C TSSOP10 package XQFN10 package [1] [2] [3] [4] [2] [4] The minimum input voltage ratings and output voltage ratings may be exceeded if the input and output current ratings are observed. VCCO is the supply voltage associated with the output port. VCCO + 0.5 V should not exceed 4.6 V. For TSSOP10 package: above 125°C, the value of Ptot derates linearly with 8.33 mW/K. 74AVC1T1022 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 16 March 2017 © Nexperia B.V. 2017. All rights reserved. 5 / 25 74AVC1T1022 Nexperia 1-to-4 fan-out buffer 9 Recommended operating conditions Table 6. Recommended operating conditions Symbol Parameter Conditions Min Max Unit VCC(A) supply voltage A 0.8 3.6 V VCC(B) supply voltage B 0.8 3.6 V VI input voltage 0 3.6 V 0 VCCO V 0 3.6 V -40 +125 °C 0 200 ns/V Tamb = 25 °C Unit VO OE = LOW output voltage [1] OE = HIGH Tamb ambient temperature Δt/ΔV input transition rise and fall rate [1] VCC(A) =0.8 V to 3.6 V VCCO is the supply voltage associated with the output port. 10 Static characteristics Table 7. Typical static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter VOH HIGH-level output voltage Conditions LOW-level output voltage Typ Max - 0.69 - V - 0.07 - V VI = VIH or VIL IO = -1.5 mA; VCC(A) = VCC(B) = 0.8 V VOL Min VI = VIH or VIL IO = 1.5 mA; VCC(A) = VCC(B) = 0.8 V II input leakage current A, OE input; VI = 0 V or 3.6 V; VCC(A) = VCC(B) = 0.8 V to 3.6 V - ±0.025 ±0.25 μA IOFF power-off leakage current VI or VO = 0 V to 3.6 V; VCC(B) = 0 V; VCC(A) = 0.8 V to 3.6 V - ±0.1 ±1 μA Rpd pull-down resistance - 50 - kΩ CI input capacitance A, OE input; VI = 0 V or 3.3 V; VCC(A) = VCC(B) = 3.3 V - 1.2 - pF CO output capacitance nYn; VO = 3.3 V or 0 V; VCC(A) = VCC(B) = 3.3 V - 4.7 - pF 74AVC1T1022 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 16 March 2017 © Nexperia B.V. 2017. All rights reserved. 6 / 25 74AVC1T1022 Nexperia 1-to-4 fan-out buffer Table 8. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter VIH VIL VOH VOL Conditions Tamb = -40 °C to +85 °C Tamb = -40 °C to +125 °C Min Max Min Max 0.70VCC(A) - 0.70VCC(A) - V VCC(A) = 1.1 V to 1.95 V 0.65VCC(A) - 0.65VCC(A) - V VCC(A) = 2.3 V to 2.7 V 1.6 - 1.6 - V VCC(A) = 3.0 V to 3.6 V 2 - 2 - V VCC(A) = 0.8 V - 0.30VCC(A) - 0.30VCC(A) V VCC(A) = 1.1 V to 1.95 V - 0.35VCC(A) - 0.35VCC(A) V VCC(A) = 2.3 V to 2.7 V - 0.7 - 0.7 V VCC(A) = 3.0 V to 3.6 V - 0.8 - 0.8 V VCCO - 0.1 - VCCO - 0.1 - V IO = -3 mA; VCC(A) = VCC(B) = 1.1 V 0.85 - 0.85 - V IO = -6 mA; VCC(A) = VCC(B) = 1.4 V 1.05 - 1.05 - V IO = -8 mA; VCC(A) = VCC(B) = 1.65 V 1.2 - 1.2 - V IO = -9 mA; VCC(A) = VCC(B) = 2.3 V 1.75 - 1.75 - V IO = -12 mA; VCC(A) = VCC(B) = 3.0 V 2.3 - 2.3 - V IO = 100 μA; VCC(A) = VCC(B) = 0.8 V to 3.6 V - 0.1 - 0.1 V IO =-3 mA; VCC(A) = VCC(B) = 1.1 V - 0.25 - 0.25 V IO = 6 mA; VCC(A) = VCC(B) = 1.4 V - 0.35 - 0.35 V IO = 8 mA; VCC(A) = VCC(B) = 1.65 V - 0.45 - 0.45 V IO = 9 mA; VCC(A) = VCC(B) = 2.3 V - 0.55 - 0.55 V HIGH-level input A, OE input voltage VCC(A) = 0.8 V LOW-level input voltage HIGH-level output voltage LOW-level output voltage 74AVC1T1022 Product data sheet Unit A, OE input VI = VIH or VIL IO = -100 μA; VCC(A) = VCC(B) = 0.8 V to 3.6 V [1] VI = VIH or VIL All information provided in this document is subject to legal disclaimers. Rev. 2 — 16 March 2017 © Nexperia B.V. 2017. All rights reserved. 7 / 25 74AVC1T1022 Nexperia 1-to-4 fan-out buffer Symbol Parameter II IOFF Conditions Tamb = -40 °C to +85 °C Tamb = -40 °C to +125 °C Unit Min Max Min Max IO = 12 mA; VCC(A) = VCC(B) = 3.0 V - 0.7 - 0.7 V input leakage current A, OE input; VI = 0 V or 3.6 V; - ±1 - ±5 μA power-off leakage current 1Yn; VI or VO = 0 V to 3.6 V; - ±5 - ±30 μA - ±5 - ±30 μA - 8 - 50 μA - 8 - 50 μA VCC(A) = VCC(B) = 0.8 V to 3.6 V VCC(A) = 0 V; VCC(B) = 0.8 V to 3.6 V 2Yn; VI or VO = 0 V to 3.6 V; VCC(B) = 0 V; VCC(A) = 0.8 V to 3.6 V ICC(A) supply current A VI = 0 V or VCC(A); IO = 0 A; VCC(A) = 0.8 V to 3.6 V; VCC(B) = 0.8 V to 3.6 V ICC(B) supply current B VI = 0 V or VCC(A); IO = 0 A; VCC(A) = 0.8 V to 3.6 V; VCC(B) = 0.8 V to 3.6 V [1] VCCO is the supply voltage associated with the output port. 11 Dynamic characteristics Table 9. Typical power dissipation capacitance at Tamb = 25 °C Symbol Parameter CPD [1] [2] power dissipation capacitance [1] [2] Conditions VCC(A) = VCC(B) Unit 0.8 V 1.2 V 1.5 V 1.8 V 2.5 V 3.3 V 1Yn; outputs enabled 17.6 18.4 18.5 18.8 20.6 23.5 pF 1Yn; outputs disabled 1.7 1.8 1.8 1.8 1.9 2.1 pF 2Yn; outputs enabled 17.2 17.9 18.0 18.3 19.9 22.8 pF 2Yn; outputs disabled 1.1 1.2 1.2 1.2 1.3 1.4 pF CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD × VCC × fi + Σ(CL × VCC × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = load capacitance in pF; VCC = supply voltage in V; 2 Σ(CL × VCC × fo) = sum of the outputs. fi = 10 MHz; VI = GND to VCC(A); tr = tf = 1 ns; CL = 0 pF; RL = ∞ Ω. 74AVC1T1022 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 16 March 2017 © Nexperia B.V. 2017. All rights reserved. 8 / 25 74AVC1T1022 Nexperia 1-to-4 fan-out buffer [1] Table 10. Typical dynamic characteristics at VCC(A) = 0.8 V and Tamb = 25 °C Voltages are referenced to GND (ground = 0 V); for test circuit, see Figure 6; for waveforms, see Figure 4 and Figure 5. Symbol Parameter tpd propagation delay tdis disable time ten [1] enable time Conditions VCC(B) Unit 0.8 V 1.2 V 1.5 V 1.8 V 2.5 V 3.3 V A to 1Yn 23 23 23 23 23 23 ns A to 2Yn 23 14 12 12 12 12 ns OE to 1Yn 20 20 20 20 20 20 ns OE to 2Yn 20 14 13 13 12 13 ns OE to 1Yn 25 25 25 25 25 25 ns OE to 2Yn 25 14 13 12 12 12 ns tpd is the same as tPLH and tPHL; tdis is the same as tPLZ and tPHZ; ten is the same as tPZL and tPZH. [1] Table 11. Typical dynamic characteristics at VCC(B) = 0.8 V and Tamb = 25 °C Voltages are referenced to GND (ground = 0 V); for test circuit, see Figure 6; for waveforms, see Figure 4 and Figure 5. Symbol Parameter tpd propagation delay tdis disable time ten [1] enable time Conditions VCC(A) Unit 0.8 V 1.2 V 1.5 V 1.8 V 2.5 V 3.3 V A to 1Yn 23 7.3 5.1 4.2 3.1 2.7 ns A to 2Yn 23 17 16 16 16 16 ns OE to 1Yn 20 7.0 5.1 4.8 3.7 3.5 ns OE to 2Yn 20 14 14 13 13 13 ns OE to 1Yn 25 7.9 5.5 4.4 3.3 2.8 ns OE to 2Yn 25 20 19 19 18 18 ns tpd is the same as tPLH and tPHL; tdis is the same as tPLZ and tPHZ; ten is the same as tPZL and tPZH. 74AVC1T1022 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 16 March 2017 © Nexperia B.V. 2017. All rights reserved. 9 / 25 74AVC1T1022 Nexperia 1-to-4 fan-out buffer Table 12. Dynamic characteristics for temperature range -40 °C to +85 °C and -40 °C to +125 °C Voltages are referenced to GND (ground = 0 V); for test circuit, see Figure 6. Symbol Parameter Conditions VCC(A) = VCC(B) Unit 1.2 V ± 0.1 V 1.5 V ± 0.1 V 1.8 V ± 0.15 V 2.5 V ± 0.2 V 3.3 V ± 0.3 V Max Max Max Max Max 0.5 0.3 0.2 0.2 0.1 ns 0.7 0.4 0.3 0.2 0.2 ns 0.9 0.5 0.4 0.3 0.2 ns Tamb = 25 °C tsk(o) output skew between any time output Tamb = -40 °C to +85 °C tsk(o) output skew between any time output Tamb = -40 °C to +125 °C tsk(o) output skew between any time output [1] Table 13. Dynamic characteristics for temperature range 25 °C Voltages are referenced to GND (ground = 0 V); for test circuit, see Figure 6; for waveforms, see Figure 4 and Figure 5. Symbol Parameter Conditions VCC(B) 1.2 V ± 0.1 V 1.5 V ± 0.1 V 1.8 V ± 0.15 V Unit 2.5 V ± 0.2 V 3.3 V ± 0.3 V Min Max Min Max Min Max Min Max Min Max VCC(A) = 1.1 V to 1.3 V tpd tdis ten propagation delay A to 1Yn 2.0 13.5 2.0 13.5 2.0 13.5 2.0 13.5 2.0 13.5 ns A to 2Yn 2.0 13.5 1.8 10.0 1.6 8.8 1.5 7.8 1.4 7.5 ns disable time OE to 1Yn 2.2 12.6 2.2 12.6 2.2 12.6 2.2 12.6 2.2 12.6 ns OE to 2Yn 2.2 12.6 1.9 10.3 2.0 10.2 1.8 9.2 2.1 10.0 ns OE to 1Yn 2.2 14.5 2.2 14.5 2.2 14.5 2.2 14.5 2.2 14.5 ns OE to 2Yn 2.2 14.5 1.9 10.5 1.7 9.2 1.5 8.0 1.5 7.6 ns propagation delay A to 1Yn 1.6 8.4 1.6 8.4 1.6 8.4 1.6 8.4 1.6 8.4 ns A to 2Yn 1.8 12.0 1.6 8.4 1.4 7.2 1.3 5.9 1.2 5.4 ns disable time OE to 1Yn 1.8 8.1 1.8 8.1 1.8 8.1 1.8 8.1 1.8 8.1 ns OE to 2Yn 2.1 10.6 1.8 8.1 1.9 8.0 1.6 6.9 1.9 7.7 ns OE to 1Yn 1.7 8.7 1.7 8.7 1.7 8.7 1.7 8.7 1.7 8.7 ns OE to 2Yn 2.0 12.7 1.7 8.7 1.5 7.5 1.4 6.0 1.3 5.5 ns A to 1Yn 1.3 6.6 1.3 6.6 1.3 6.6 1.3 6.6 1.3 6.6 ns A to 2Yn 1.8 11.4 1.5 7.8 1.3 6.6 1.1 5.2 1.1 4.7 ns enable time VCC(A) = 1.4 V to 1.6 V tpd tdis ten enable time VCC(A) = 1.65 V to 1.95 V tpd propagation delay 74AVC1T1022 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 16 March 2017 © Nexperia B.V. 2017. All rights reserved. 10 / 25 74AVC1T1022 Nexperia 1-to-4 fan-out buffer Symbol Parameter Conditions VCC(B) 1.2 V ± 0.1 V tdis 1.8 V ± 0.15 V 2.5 V ± 0.2 V 3.3 V ± 0.3 V Min Max Min Max Min Max Min Max Min Max OE to 1Yn 1.8 7.4 1.8 7.4 1.8 7.4 1.8 7.4 1.8 7.4 ns OE to 2Yn 2.0 10.1 1.7 7.6 1.8 7.4 1.5 6.2 1.8 7.0 ns OE to 1Yn 1.4 6.8 1.4 6.8 1.4 6.8 1.4 6.8 1.4 6.8 ns OE to 2Yn 1.9 12.2 1.6 8.2 1.4 6.8 1.2 5.4 1.1 4.8 ns propagation delay A to 1Yn 1.1 4.6 1.1 4.6 1.1 4.6 1.1 4.6 1.1 4.6 ns A to 2Yn 1.7 10.8 1.4 7.2 1.2 5.9 1.1 4.6 1.0 4.1 ns disable time OE to 1Yn 1.4 5.6 1.4 5.6 1.4 5.6 1.4 5.6 1.4 5.6 ns OE to 2Yn 1.9 9.6 1.6 6.9 1.7 6.8 1.4 5.6 1.7 6.3 ns OE to 1Yn 1.1 4.8 1.1 4.8 1.1 4.8 1.1 4.8 1.1 4.8 ns OE to 2Yn 1.8 11.6 1.5 7.7 1.3 6.3 1.1 4.8 1.0 4.2 ns propagation delay A to 1Yn 0.9 3.9 0.9 3.9 0.9 3.9 0.9 3.9 0.9 3.9 ns A to 2Yn 1.6 10.6 1.4 7.0 1.2 5.7 1.0 4.4 0.9 3.9 ns disable time OE to 1Yn 1.6 6.0 1.6 6.0 1.6 6.0 1.6 6.0 1.6 6.0 ns OE to 2Yn 1.9 9.3 1.5 6.8 1.6 6.6 1.3 5.3 1.6 6.0 ns OE to 1Yn 1.0 4.0 1.0 4.0 1.0 4.0 1.0 4.0 1.0 4.0 ns OE to 2Yn 1.8 11.3 1.4 7.4 1.3 6.0 1.1 4.6 1.0 4.0 ns disable time ten 1.5 V ± 0.1 V Unit enable time VCC(A) = 2.3 V to 2.7 V tpd tdis ten enable time VCC(A) = 3.0 V to 3.6 V tpd tdis ten [1] enable time tpd is the same as tPLH and tPHL; tdis is the same as tPLZ and tPHZ; ten is the same as tPZL and tPZH. [1] Table 14. Dynamic characteristics for temperature range -40 °C to +85 °C Voltages are referenced to GND (ground = 0 V); for test circuit, see Figure 6; for waveforms, see Figure 4 and Figure 5. Symbol Parameter Conditions VCC(B) 1.2 V ± 0.1 V 1.5 V ± 0.1 V 1.8 V ± 0.15 V Unit 2.5 V ± 0.2 V 3.3 V ± 0.3 V Min Max Min Max Min Max Min Max Min Max VCC(A) = 1.1 V to 1.3 V tpd tdis ten propagation delay A to 1Yn 0.9 14.7 0.9 14.7 0.9 14.7 0.9 14.7 0.9 14.7 ns A to 2Yn 0.9 14.7 0.8 11.2 0.7 9.9 0.6 8.8 0.6 8.5 ns disable time OE to 1Yn 1.0 14.7 1.0 14.7 1.0 14.7 1.0 14.7 1.0 14.7 ns OE to 2Yn 1.0 14.7 0.9 12.2 0.9 12.1 0.8 10.8 1.0 11.7 ns OE to 1Yn 1.0 15.8 1.0 15.8 1.0 15.8 1.0 15.8 1.0 15.8 ns enable time 74AVC1T1022 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 16 March 2017 © Nexperia B.V. 2017. All rights reserved. 11 / 25 74AVC1T1022 Nexperia 1-to-4 fan-out buffer Symbol Parameter Conditions VCC(B) 1.2 V ± 0.1 V 1.5 V ± 0.1 V 1.8 V ± 0.15 V Unit 2.5 V ± 0.2 V 3.3 V ± 0.3 V Min Max Min Max Min Max Min Max Min Max OE to 2Yn 1.0 15.8 0.8 11.8 0.8 10.3 0.7 8.9 0.7 8.5 ns propagation delay A to 1Yn 0.7 9.5 0.7 9.5 0.7 9.5 0.7 9.5 0.7 9.5 ns A to 2Yn 0.8 13.2 0.7 9.5 0.6 8.2 0.5 6.7 0.5 6.2 ns disable time OE to 1Yn 0.8 9.7 0.8 9.7 0.8 9.7 0.8 9.7 0.8 9.7 ns OE to 2Yn 0.9 12.4 0.8 9.7 0.8 9.7 0.7 8.3 0.9 9.0 ns OE to 1Yn 0.7 9.9 0.7 9.9 0.7 9.9 0.7 9.9 0.7 9.9 ns OE to 2Yn 0.9 14.0 0.7 9.9 0.7 8.5 0.6 6.9 0.6 6.2 ns propagation delay A to 1Yn 0.6 7.6 0.6 7.6 0.6 7.6 0.6 7.6 0.6 7.6 ns A to 2Yn 0.8 12.5 0.7 8.9 0.6 7.6 0.5 6.1 0.5 5.4 ns disable time OE to 1Yn 0.8 8.8 0.8 8.8 0.8 8.8 0.8 8.8 0.8 8.8 ns OE to 2Yn 0.9 11.7 0.8 9.0 0.8 8.8 0.7 7.4 0.8 8.2 ns OE to 1Yn 0.6 7.9 0.6 7.9 0.6 7.9 0.6 7.9 0.6 7.9 ns OE to 2Yn 0.8 13.5 0.7 9.3 0.6 7.9 0.6 6.3 0.5 5.6 ns propagation delay A to 1Yn 0.5 5.4 0.5 5.4 0.5 5.4 0.5 5.4 0.5 5.4 ns A to 2Yn 0.8 12.0 0.6 8.3 0.6 6.9 0.5 5.4 0.4 4.7 ns disable time OE to 1Yn 0.6 6.5 0.6 6.5 0.6 6.5 0.6 6.5 0.6 6.5 ns OE to 2Yn 0.9 11.0 0.7 8.3 0.8 8.0 0.6 6.5 0.8 7.2 ns OE to 1Yn 0.5 5.5 0.5 5.5 0.5 5.5 0.5 5.5 0.5 5.5 ns OE to 2Yn 0.8 12.8 0.7 8.7 0.6 7.3 0.5 5.5 0.5 4.8 ns propagation delay A to 1Yn 0.4 4.4 0.4 4.4 0.4 4.4 0.4 4.4 0.4 4.4 ns A to 2Yn 0.8 11.6 0.6 8.0 0.5 6.5 0.5 5.1 0.4 4.4 ns disable time OE to 1Yn 0.7 6.9 0.7 6.9 0.7 6.9 0.7 6.9 0.7 6.9 ns OE to 2Yn 0.9 10.8 0.7 8.0 0.7 7.7 0.6 6.2 0.7 6.9 ns OE to 1Yn 0.5 4.5 0.5 4.5 0.5 4.5 0.5 4.5 0.5 4.5 ns OE to 2Yn 0.8 12.5 0.6 8.4 0.6 6.9 0.5 5.2 0.5 4.5 ns VCC(A) = 1.4 V to 1.6 V tpd tdis ten enable time VCC(A) = 1.65 V to 1.95 V tpd tdis ten enable time VCC(A) = 2.3 V to 2.7 V tpd tdis ten enable time VCC(A) = 3.0 V to 3.6 V tpd tdis ten [1] enable time tpd is the same as tPLH and tPHL; tdis is the same as tPLZ and tPHZ; ten is the same as tPZL and tPZH. 74AVC1T1022 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 16 March 2017 © Nexperia B.V. 2017. All rights reserved. 12 / 25 74AVC1T1022 Nexperia 1-to-4 fan-out buffer [1] Table 15. Dynamic characteristics for temperature range -40 °C to +125 °C Voltages are referenced to GND (ground = 0 V); for test circuit, see Figure 6; for waveforms, see Figure 4 and Figure 5. Symbol Parameter Conditions VCC(B) 1.2 V ± 0.1 V 1.5 V ± 0.1 V 1.8 V ± 0.15 V Unit 2.5 V ± 0.2 V 3.3 V ± 0.3 V Min Max Min Max Min Max Min Max Min Max VCC(A) = 1.1 V to 1.3 V tpd tdis ten propagation delay A to 1Yn 0.9 15.7 0.9 15.7 0.9 15.7 0.9 15.7 0.9 15.7 ns A to 2Yn 0.9 15.7 0.8 12.1 0.7 10.8 0.6 9.7 0.6 9.3 ns disable time OE to 1Yn 1.0 16.5 1.0 16.5 1.0 16.5 1.0 16.5 1.0 16.5 ns OE to 2Yn 1.0 16.5 0.9 13.8 0.9 13.7 0.8 12.3 1.0 13.1 ns OE to 1Yn 1.0 16.9 1.0 16.9 1.0 16.9 1.0 16.9 1.0 16.9 ns OE to 2Yn 1.0 16.9 0.8 12.9 0.8 11.4 0.7 9.7 0.7 9.2 ns propagation delay A to 1Yn 0.7 10.4 0.7 10.4 0.7 10.4 0.7 10.4 0.7 10.4 ns A to 2Yn 0.8 14.1 0.7 10.4 0.6 9.0 0.5 7.3 0.5 6.8 ns disable time OE to 1Yn 0.8 11.0 0.8 11.0 0.8 11.0 0.8 11.0 0.8 11.0 ns OE to 2Yn 0.9 14.0 0.8 11.0 0.8 11.0 0.7 9.5 0.9 10.2 ns OE to 1Yn 0.7 10.9 0.7 10.9 0.7 10.9 0.7 10.9 0.7 10.9 ns OE to 2Yn 0.9 15.1 0.7 10.9 0.7 9.3 0.6 7.6 0.6 6.8 ns propagation delay A to 1Yn 0.6 8.3 0.6 8.3 0.6 8.3 0.6 8.3 0.6 8.3 ns A to 2Yn 0.8 13.6 0.7 9.7 0.6 8.3 0.5 6.7 0.5 6.0 ns disable time OE to 1Yn 0.8 10.0 0.8 10.0 0.8 10.0 0.8 10.0 0.8 10.0 ns OE to 2Yn 0.9 13.4 0.8 10.2 0.8 10.0 0.7 8.4 0.8 9.2 ns OE to 1Yn 0.6 8.7 0.6 8.7 0.6 8.7 0.6 8.7 0.6 8.7 ns OE to 2Yn 0.9 14.5 0.7 10.2 0.6 8.7 0.6 6.9 0.5 6.2 ns propagation delay A to 1Yn 0.5 5.9 0.5 5.9 0.5 5.9 0.5 5.9 0.5 5.9 ns A to 2Yn 0.8 12.9 0.6 9.1 0.6 7.6 0.5 5.9 0.4 5.2 ns disable time OE to 1Yn 0.6 7.5 0.6 7.5 0.6 7.5 0.6 7.5 0.6 7.5 ns OE to 2Yn 0.9 12.5 0.7 9.4 0.8 9.1 0.6 7.5 0.8 8.2 ns OE to 1Yn 0.5 6.1 0.5 6.1 0.6 6.1 0.6 6.1 0.6 6.1 ns OE to 2Yn 0.8 13.7 0.7 9.5 0.6 8.0 0.5 6.1 0.5 5.3 ns propagation delay A to 1Yn 0.4 4.9 0.4 4.9 0.4 4.9 0.4 4.9 0.4 4.9 ns A to 2Yn 0.8 12.5 0.6 8.7 0.5 7.2 0.5 5.6 0.4 4.9 ns disable time OE to 1Yn 0.7 7.7 0.7 7.7 0.7 7.7 0.7 7.7 0.7 7.7 ns enable time VCC(A) = 1.4 V to 1.6 V tpd tdis ten enable time VCC(A) = 1.65 V to 1.95 V tpd tdis ten enable time VCC(A) = 2.3 V to 2.7 V tpd tdis ten enable time VCC(A) = 3.0 V to 3.6 V tpd tdis 74AVC1T1022 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 16 March 2017 © Nexperia B.V. 2017. All rights reserved. 13 / 25 74AVC1T1022 Nexperia 1-to-4 fan-out buffer Symbol Parameter Conditions VCC(B) 1.2 V ± 0.1 V ten [1] enable time 1.5 V ± 0.1 V Unit 1.8 V ± 0.15 V 2.5 V ± 0.2 V 3.3 V ± 0.3 V Min Max Min Max Min Max Min Max Min Max OE to 2Yn 0.9 12.1 0.7 9.1 0.7 8.8 0.6 7.1 0.7 7.7 ns OE to 1Yn 0.5 4.9 0.5 4.9 0.5 4.9 0.5 4.9 0.5 4.9 ns OE to 2Yn 0.8 13.4 0.6 9.2 0.6 7.6 0.5 5.7 0.5 4.9 ns tpd is the same as tPLH and tPHL; tdis is the same as tPLZ and tPHZ; ten is the same as tPZL and tPZH. 11.1 Waveforms and test circuit VI A input VM GND tPHL tPLH VOH nYn output VM VOL aaa-019807 Measurement points are given in Table 16. VOL and VOH are typical output voltage levels that occur with the output load. Figure 4. The data input (A) to output (nYn) propagation delay times VI OE input VM GND tPLZ output LOW-to-OFF OFF-to-LOW tPZL VOH VM VX VOL tPHZ output HIGH-to-OFF OFF-to-HIGH VOH tPZH VY VM GND outputs enabled outputs disabled outputs enabled aaa-019808 Measurement points are given in Table 16. VOL and VOH are typical output voltage levels that occur with the output load. Figure 5. Enable and disable times 74AVC1T1022 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 16 March 2017 © Nexperia B.V. 2017. All rights reserved. 14 / 25 74AVC1T1022 Nexperia 1-to-4 fan-out buffer Table 16. Measurement points Supply voltage Input Output VCC(A), VCC(B) VM VM VX VY 0.8 V to 1.6 V 0.5VCC(A) 0.5VCCO VOL + 0.1 V VOH - 0.1 V 1.65 V to 2.7 V 0.5VCC(A) 0.5VCCO VOL + 0.15 V VOH - 0.15 V 3.0 V to 3.6 V 0.5VCC(A) 0.5VCCO VOL + 0.3 V VOH - 0.3 V [1] [1] VCCO is the supply voltage associated with the output port. tW VI 90 % negative pulse VM VM 10 % 0V VI tf tr tr tf 90 % positive pulse VM VM 10 % 0V tW VEXT VCC VI G RL VO DUT RT CL RL 001aae331 Test data is given in Table 17 RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance. VEXT = External voltage for measuring switching times. Figure 6. Test circuit for measuring switching times Table 17. Test data Supply voltage Input Load VCC(A), VCC(B) VI Δt/ΔV 0.8 V to 1.6 V VCC(A) 1.65 V to 2.7 V 3.0 V to 3.6 V [1] [2] [1] VEXT CL RL tPLH, tPHL tPZH, tPHZ tPZL, tPLZ ≤ 1.0 ns/V 15 pF 2 kΩ open GND 2VCCO VCC(A) ≤ 1.0 ns/V 15 pF 2 kΩ open GND 2VCCO VCC(A) ≤ 1.0 ns/V 15 pF 2 kΩ open GND 2VCCO [2] dV/dt ≥ 1.0 V/ns VCCO is the supply voltage associated with the output port. 74AVC1T1022 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 16 March 2017 © Nexperia B.V. 2017. All rights reserved. 15 / 25 74AVC1T1022 Nexperia 1-to-4 fan-out buffer 12 Typical propagation delay characteristics aaa-019810 30 (1) tpd (ns) tpd (ns) 24 27 18 24 12 21 (2) (3) (4) (5) (6) 6 0 0 12 24 a. Propagation delay (A to 1Yn) 36 48 CL (pF) aaa-020939 30 (1) (2) (3) (4) (5) (6) 18 60 15 0 12 24 36 48 CL (pF) 60 b. Propagation delay (A to 2Yn); VCC(B) = 0.8 V (1) VCC(A) = 0.8 V. (2) VCC(A) = 1.2 V. (3) VCC(A) = 1.5 V. (4) VCC(A) = 1.8 V. (5) VCC(A) = 2.5 V. (6) VCC(A) = 3.3 V. Figure 7. Typical propagation delay versus load capacitance; Tamb = 25 °C 74AVC1T1022 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 16 March 2017 © Nexperia B.V. 2017. All rights reserved. 16 / 25 74AVC1T1022 Nexperia 1-to-4 fan-out buffer aaa-019809 (1) 30 tpd (ns) 24 18 (2) 12 (3) (4) (5) (6) 6 0 0 10 20 30 40 50 CL (pF) 60 a. Propagation delay (A to 2Yn); VCC(A) = 0.8 V (1) VCC(B) = 0.8 V. (2) VCC(B) = 1.2 V. (3) VCC(B) = 1.5 V. (4) VCC(B) = 1.8 V. (5) VCC(B) = 2.5 V. (6) VCC(B) = 3.3 V. Figure 8. Typical propagation delay versus load capacitance; Tamb = 25 °C aaa-019811 10 tPLH (ns) tPHL (ns) (1) 8 aaa-019812 10 (1) 8 (2) (2) (3) (3) 6 6 (4) (5) 4 4 2 2 0 0 10 20 30 40 50 CL (pF) a. LOW to HIGH propagation delay (A to 2Yn); VCC(A) = 1.2 V 60 0 (4) (5) 0 10 20 30 40 50 CL (pF) 60 b. HIGH to LOW propagation delay (A to 2Yn); VCC(A) = 1.2 V (1) VCC(B) = 1.2 V. (2) VCC(B) = 1.5 V. (3) VCC(B) = 1.8 V. (4) VCC(B) = 2.5 V. (5) VCC(B) = 3.3 V. Figure 9. Typical propagation delay versus load capacitance; Tamb = 25 °C 74AVC1T1022 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 16 March 2017 © Nexperia B.V. 2017. All rights reserved. 17 / 25 74AVC1T1022 Nexperia 1-to-4 fan-out buffer aaa-019813 10 tPLH (ns) aaa-019814 10 tPHL (ns) 8 (1) 8 (1) (2) 6 6 (2) (3) (3) (4) 4 (4) (5) 4 (5) 2 0 2 0 10 20 30 40 50 CL (pF) a. LOW to HIGH propagation delay (A to 2Yn); VCC(A) = 1.5 V 0 10 20 30 40 50 CL (pF) 60 b. HIGH to LOW propagation delay (A to 2Yn); VCC(A) = 1.5 V aaa-019815 10 0 60 tPLH (ns) aaa-019816 10 tPHL (ns) 8 8 (1) 6 (2) (1) 6 (2) (3) (3) (4) (5) 4 2 0 (4) (5) 4 2 0 10 20 30 40 50 CL (pF) c. LOW to HIGH propagation delay (A to 2Yn); VCC(A) = 1.8 V 60 0 0 10 20 30 40 50 CL (pF) 60 d. HIGH to LOW propagation delay (A to 2Yn); VCC(A) = 1.8 V (1) VCC(B) = 1.2 V. (2) VCC(B) = 1.5 V. (3) VCC(B) = 1.8 V. (4) VCC(B) = 2.5 V. (5) VCC(B) = 3.3 V. Figure 10. Typical propagation delay versus load capacitance; Tamb = 25 °C 74AVC1T1022 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 16 March 2017 © Nexperia B.V. 2017. All rights reserved. 18 / 25 74AVC1T1022 Nexperia 1-to-4 fan-out buffer aaa-019817 10 tPLH (ns) aaa-019818 10 tPHL (ns) 8 8 (1) (1) 6 6 (2) (2) (3) (3) 4 2 0 (4) (5) 4 (4) (5) 2 0 10 20 30 40 50 CL (pF) a. LOW to HIGH propagation delay (A to 2Yn); VCC(A) = 2.5 V 0 10 20 30 40 50 CL (pF) 60 b. HIGH to LOW propagation delay (A to 2Yn); VCC(A) = 2.5 V aaa-019819 10 0 60 tPLH (pF) aaa-019820 10 tPHL (ns) 8 8 (1) (1) 6 6 (2) (2) (3) (3) 4 4 (4) (5) 2 0 (4) (5) 2 0 10 20 30 40 50 CL (pF) c. LOW to HIGH propagation delay (A to 2Yn); VCC(A) = 3.3 V 60 0 0 10 20 30 40 50 CL (pF) 60 d. HIGH to LOW propagation delay (A to 2Yn); VCC(A) = 3.3 V (1) VCC(B) = 1.2 V. (2) VCC(B) = 1.5 V. (3) VCC(B) = 1.8 V. (4) VCC(B) = 2.5 V. (5) VCC(B) = 3.3 V. Figure 11. Typical propagation delay versus load capacitance; Tamb = 25 °C 74AVC1T1022 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 16 March 2017 © Nexperia B.V. 2017. All rights reserved. 19 / 25 74AVC1T1022 Nexperia 1-to-4 fan-out buffer 13 Package outline TSSOP10: plastic thin shrink small outline package; 10 leads; body width 3 mm D E SOT552-1 A X c y HE v M A Z 6 10 A2 pin 1 index (A3) A1 A θ Lp L 1 5 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.15 0.23 0.15 3.1 2.9 3.1 2.9 0.5 5.0 4.8 0.95 0.7 0.4 0.1 0.1 0.1 0.67 0.34 6° 0° Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic or metal protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-07-29 03-02-18 SOT552-1 Figure 12. Package outline SOT552-1 (TSSOP10) 74AVC1T1022 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 16 March 2017 © Nexperia B.V. 2017. All rights reserved. 20 / 25 74AVC1T1022 Nexperia 1-to-4 fan-out buffer XQFN10: plastic, extremely thin quad flat package; no leads; 10 terminals; body 1.40 x 1.80 x 0.50 mm SOT1160-1 X D B A terminal 1 index area E A A1 A3 detail X e1 e v w b 3 5 C C A B C y1 C y L 2 6 1 7 e2 terminal 1 index area 10 L1 8 0 1 Dimensions Unit(1) max nom min mm 2 mm scale A A1 0.5 0.05 A3 b 0.25 0.127 0.20 0.00 0.15 D E e e1 e2 1.5 1.4 1.3 1.9 1.8 1.7 0.4 0.8 0.4 L L1 0.45 0.55 0.40 0.50 0.35 0.45 v 0.1 w y y1 0.05 0.05 0.05 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. References Outline version IEC JEDEC JEITA SOT1160-1 --- --- --- sot1160-1_po European projection Issue date 09-12-28 09-12-29 Figure 13. Package outline SOT1160-1 (XQFN10) 74AVC1T1022 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 2 — 16 March 2017 © Nexperia B.V. 2017. All rights reserved. 21 / 25 74AVC1T1022 Nexperia 1-to-4 fan-out buffer 14 Abbreviations Table 18. Abbreviations Acronym Description CDM Charged Device Model DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model 15 Revision history Table 19. Revision history Document ID Release date Data sheet status Change notice Supersedes 74AVC1T1022 v.2 20170316 Product data sheet - 74AVC1T1022 v.1 Modifications: • The format of this data sheet has been redesigned to comply with the new identity guidelines of Nexperia. • Legal texts have been adapted to the new company name where appropriate. 74AVC1T1022 v.1 20151207 74AVC1T1022 Product data sheet Product data sheet - All information provided in this document is subject to legal disclaimers. Rev. 2 — 16 March 2017 - © Nexperia B.V. 2017. All rights reserved. 22 / 25 74AVC1T1022 Nexperia 1-to-4 fan-out buffer 16 Legal information 16.1 Data sheet status Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 16.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 16.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia's aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical 74AVC1T1022 Product data sheet systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 2 — 16 March 2017 © Nexperia B.V. 2017. All rights reserved. 23 / 25 74AVC1T1022 Nexperia 1-to-4 fan-out buffer Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia's warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia's specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer 74AVC1T1022 Product data sheet design and use of the product for automotive applications beyond Nexperia's standard warranty and Nexperia's product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 16.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 2 — 16 March 2017 © Nexperia B.V. 2017. All rights reserved. 24 / 25 74AVC1T1022 Nexperia 1-to-4 fan-out buffer Contents 1 2 3 4 5 6 6.1 6.2 7 8 9 10 11 11.1 12 13 14 15 16 General description ............................................ 1 Features and benefits .........................................1 Ordering information .......................................... 2 Marking .................................................................2 Functional diagram ............................................. 3 Pinning information ............................................ 4 Pinning ............................................................... 4 Pin description ................................................... 4 Functional description ........................................5 Limiting values .................................................... 5 Recommended operating conditions ................ 6 Static characteristics .......................................... 6 Dynamic characteristics .....................................8 Waveforms and test circuit .............................. 14 Typical propagation delay characteristics ......16 Package outline .................................................20 Abbreviations .................................................... 22 Revision history ................................................ 22 Legal information .............................................. 23 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section 'Legal information'. © Nexperia B.V. 2017. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 16 March 2017 Document identifier: 74AVC1T1022
74AVC1T1022DPJ 价格&库存
很抱歉,暂时无法提供与“74AVC1T1022DPJ”相匹配的价格&库存,您可以联系我们找货
74AVC1T1022DPJ
  • 1+4.118811+0.51671
  • 10+2.8810510+0.36143
  • 25+2.5708225+0.32251
  • 100+2.23009100+0.27977
  • 250+2.06813250+0.25945
  • 500+1.97043500+0.24719
  • 1000+1.900991000+0.23848
74AVC1T1022DPJ
  • 2500+1.804932500+0.22643
  • 5000+1.753755000+0.22001
  • 7500+1.728097500+0.21679
  • 12500+1.6997012500+0.21323
  • 17500+1.6830817500+0.21115
  • 25000+1.6671225000+0.20914
