74HC85; 74HCT85
4-bit magnitude comparator
Rev. 3 — 20 April 2018
1
Product data sheet
General description
The 74HC85; 74HCT85 is a 4-bit magnitude comparator that can be expanded to almost
any length. They perform comparison of two 4-bit binary, BCD or other monotonic codes
and present the three possible magnitude results at the outputs (QA>B, QA=B and QAB, IA=B and IAB, QA=B and QAB
A2
B2
IAB
A1
B1
QAB
5
12 A1
QA>B
5
12 A1
QA=B
6
11 B1
QA=B
6
11 B1
10 A0
QAB output
QA=B
6
A=B output
QA B2
X
X
X
X
X
H
L
L
A3 = B3
A2 < B2
X
X
X
X
X
L
H
L
A3 = B3
A2 = B2
A1 > B1
X
X
X
X
H
L
L
A3 = B3
A2 = B2
A1 < B1
X
X
X
X
L
H
L
A3 = B3
A2 = B2
A1 = B1
A0 > B0
X
X
X
H
L
L
A3 = B3
A2 = B2
A1 = B1
A0 < B0
X
X
X
L
H
L
A3 = B3
A2 = B2
A1 = B1
A0 = B0
H
L
L
H
L
L
A3 = B3
A2 = B2
A1 = B1
A0 = B0
L
H
L
L
H
L
A3 = B3
A2 = B2
A1 = B1
A0 = B0
L
L
H
L
L
H
A3 = B3
A2 = B2
A1 = B1
A0 = B0
X
X
H
L
L
H
A3 = B3
A2 = B2
A1 = B1
A0 = B0
H
H
L
L
L
L
A3 = B3
A2 = B2
A1 = B1
A0 = B0
L
L
L
H
H
L
8
Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V)
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
Conditions
Min
Max
Unit
-0.5
+7
V
VI < -0.5 V or VI > VCC + 0.5 V
[1]
±20
mA
[1]
±20
mA
±25
mA
IOK
output clamping current
VO < -0.5 V or VO > VCC + 0.5 V
IO
output current
-0.5 V < VO < VCC + 0.5 V
ICC
supply current
50
mA
IGND
ground current
-50
mA
Tstg
storage temperature
-65
+150
°C
500
mW
Ptot
total power dissipation
Tamb = -40 °C to +125 °C
[2]
[1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2] For SO16 Packages: Ptot derates linearly with 8 mW/K above 70 °C.
For (T)SSOP16 Packages: Ptot derates linearly with 5.5 mW/K above 60 °C.
74HC_HCT85
Product data sheet
All information provided in this document is subject to legal disclaimers.
© Nexperia B.V. 2018. All rights reserved.
5 / 19
74HC85; 74HCT85
Nexperia
9
Recommended operating conditions
Table 5. Recommended operating conditions
Symbol
Parameter
Conditions
74HC85
74HCT85
Unit
Min
Typ
Max
Min
Typ
Max
2.0
5.0
6.0
4.5
5.0
5.5
V
VCC
supply voltage
VI
input voltage
VCC
VCC
V
VO
output voltage
VCC
VCC
V
Tamb
ambient temperature
-40
+125
-40
+125
°C
Δt/ΔV
input transition rise and fall rate
VCC = 2.0 V
625
ns/V
VCC = 4.5 V
1.67
139
1.67
139
ns/V
VCC = 6.0 V
83
ns/V
10 Static characteristics
Table 6. Static characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Conditions
25 °C
-40 °C to
+85 °C
-40 °C to
+125 °C
Min
Typ
Max
Min
Max
Min
Max
Unit
74HC85
VIH
VIL
VOH
VOL
HIGH-level input VCC = 2.0 V
voltage
VCC = 4.5 V
1.5
1.2
1.5
1.5
V
3.15
2.4
3.15
3.15
V
VCC = 6.0 V
4.2
3.2
4.2
4.2
V
LOW-level input VCC = 2.0 V
voltage
VCC = 4.5 V
0.8
0.5
0.5
0.5
V
2.1
1.35
1.35
1.35
V
VCC = 6.0 V
2.8
1.8
1.8
1.8
V
IO = -20 μA; VCC = 2.0 V
1.9
2.0
1.9
1.9
V
IO = -20 μA; VCC = 4.5 V
4.4
4.5
4.4
4.4
V
IO = -20 μA; VCC = 6.0 V
5.9
6.0
5.9
5.9
V
IO = -4.0 mA; VCC = 4.5 V
3.98
4.32
3.84
3.7
V
IO = -5.2 mA; VCC = 6.0 V
5.48
5.81
5.34
5.2
V
IO = 20 μA; VCC = 2.0 V
0.1
0.1
V
IO = 20 μA; VCC = 4.5 V
0.1
0.1
V
IO = 20 μA; VCC = 6.0 V
0.1
0.1
V
IO = 4.0 mA; VCC = 4.5 V
0.15
0.26
0.33
0.4
V
IO = 5.2 mA; VCC = 6.0 V
0.16
0.26
0.33
0.4
V
HIGH-level
output voltage
LOW-level
output voltage
74HC_HCT85
Product data sheet
VI = VIH or VIL
VI = VIH or VIL
6 / 19
74HC85; 74HCT85
Nexperia
Symbol
Parameter
Conditions
25 °C
-40 °C to
+85 °C
-40 °C to
+125 °C
Min
Typ
Max
Min
Max
Min
Max
Unit
II
input leakage
current
VI = VCC or GND; VCC = 6.0 V
±0.1
±1
±1
μA
ICC
supply current
VI = VCC or GND; IO = 0 A;
VCC = 6.0 V
8.0
80
160
μA
CI
input
capacitance
3.5
pF
74HCT85
VIH
HIGH-level input VCC = 4.5 V to 5.5 V
voltage
2.0
1.6
2.0
2.0
V
VIL
LOW-level input VCC = 4.5 V to 5.5 V
voltage
1.2
0.8
0.8
0.8
V
VOH
HIGH-level
output voltage
IO = -20 μA
4.4
4.5
4.4
4.4
V
IO = -4.0 mA
3.98
4.32
3.84
3.7
V
IO = 20 μA
0.1
0.1
V
IO = 4.0 mA
0.15
0.26
0.33
0.4
V
VOL
LOW-level
output voltage
VI = VIH or VIL; VCC = 4.5 V
II
input leakage
current
VI = VCC or GND; VCC = 5.5 V
±0.1
±1
±1
μA
ICC
supply current
VCC = 5.5 V
8.0
80
160
μA
ΔICC
additional supply per input pin; VI = VCC - 2.1 V;
other inputs at VCC or GND;
current
VCC = 4.5 V to 5.5 V; IO = 0 A
IAB inputs
100
360
450
490
μA
An, Bn and IA=B inputs
150
540
675
735
μA
3.5
pF
CI
input
capacitance
74HC_HCT85
Product data sheet
7 / 19
74HC85; 74HCT85
Nexperia
11 Dynamic characteristics
Table 7. Dynamic characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V);
CL = 50 pF unless otherwise specified; for test circuit, see Figure 8
Symbol
Parameter
Conditions
25 °C
-40 °C to
+85 °C
-40 °C to
+125 °C
Unit
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
63
195
245
295
ns
VCC = 4.5 V
23
39
49
59
ns
VCC = 6.0 V
18
33
42
50
ns
VCC = 5.0 V; CL = 15 pF
ns
VCC = 2.0 V
58
175
220
265
ns
VCC = 4.5 V
21
35
44
53
ns
VCC = 6.0 V
17
30
37
45
ns
18
ns
VCC = 2.0 V
50
140
175
210
ns
VCC = 4.5 V
18
28
35
42
ns
VCC = 6.0 V
14
24
30
36
ns
15
ns
VCC = 2.0 V
39
120
150
180
ns
VCC = 4.5 V
14
24
30
36
ns
VCC = 6.0 V
11
31
ns
11
ns
VCC = 2.0 V
19
75
95
110
ns
VCC = 4.5 V
7
15
19
22
ns
6
13
16
19
ns
18
pF
74HC85
tpd
propagation
delay
An, Bn to QA>B;
An, Bn to QAB to QAB;
An, Bn to QAB to QA
很抱歉,暂时无法提供与“74HCT85D,653”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+5.54581
- 10+3.97430
- 25+3.59340
- 100+3.10110
- 250+2.81363
- 国内价格 香港价格
- 2500+2.596182500+0.33710
- 5000+2.527015000+0.32812
- 7500+2.492367500+0.32362
- 12500+2.4539712500+0.31864
- 17500+2.4315317500+0.31573
- 25000+2.4099525000+0.31292
- 国内价格 香港价格
- 1+5.745531+0.74603
- 10+4.0443010+0.52514
- 25+3.6314325+0.47153
- 100+3.17051100+0.41168
- 250+2.95179250+0.38328
- 500+2.81969500+0.36613
- 1000+2.765901000+0.35914
- 国内价格 香港价格
- 1+5.404371+0.70173
- 10+3.8727010+0.50285
- 25+3.5071825+0.45539
- 100+3.02854100+0.39324
- 250+2.74135250+0.35595
