74HC688PW,118
74HC688PW,118
    NEXPERIA(安世)
    TSSOP-20
    8位幅度比较器 TSSOP20_6.5X4.4MM 2~6V
74HC688PW,118 数据手册
74HC688 8-bit magnitude comparator Rev. 3 — 4 July 2018 1 Product data sheet General description The 74HC688 is an 8-bit magnitude comparator. It performs comparisons of two 8-bit binary or BCD words. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2 Features and benefits • • • • • Compare two 8-bit words Wide supply voltage range from 2.0 to 6.0 V CMOS input levels Complies with JEDEC standard: no. 7A ESD protection: – HBM JESD22-A114-F exceeds 2000 V – MM JESD22-A115-A exceeds 200 V • Multiple package options • Specified from -40 °C to +85 °C and from -40 °C to +125 °C 3 Ordering information Table 1. Ordering information Type number Package Temperature range Name Description Version 74HC688D −40 °C to +125 °C SO20 plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 74HC688DB −40 °C to +125 °C SSOP20 plastic shrink small outline package; 20 leads; body width 5.3 mm SOT339-1 74HC688PW −40 °C to +125 °C TSSOP20 plastic thin shrink small outline package; 20 leads; body width 4.4 mm SOT360-1 74HC688 Nexperia 8-bit magnitude comparator 4 Functional diagram 2 P0 4 P1 6 P2 8 P3 11 P4 13 P5 15 P6 17 P7 3 Q0 5 Q1 7 Q2 P=Q 9 Q3 12 Q4 14 Q5 16 Q6 18 Q7 19 P7 Q7 P6 Q6 P5 E 1 aaa-028700 Figure 1. Logic symbol Q5 P4 COMP 1 G1 2 0 Q4 4 P3 6 P=Q 8 Q3 P 11 13 P2 15 17 7 Q2 (P=Q) 1 3 19 P1 0 5 Q1 7 9 Q 12 P0 14 Q0 16 18 7 aaa-028701 Figure 3. IEC logic symbol 74HC688 Product data sheet E aaa-028702 Figure 2. Logic diagram All information provided in this document is subject to legal disclaimers. Rev. 3 — 4 July 2018 © Nexperia B.V. 2018. All rights reserved. 2 / 16 74HC688 Nexperia 8-bit magnitude comparator 5 Pinning information 5.1 Pinning 74HC688 74HC688 E 1 1 2 20 VCC 19 P=Q E P0 P0 2 20 VCC 19 P=Q Q0 3 18 Q7 Q0 3 18 Q7 P1 4 17 P7 P1 4 17 P7 Q1 5 16 Q6 Q1 5 16 Q6 P2 6 15 P6 P2 6 15 P6 Q2 7 14 Q5 Q2 7 14 Q5 P3 8 13 P5 P3 8 13 P5 Q3 9 12 Q4 Q3 9 12 Q4 GND 10 11 P4 GND 10 11 P4 aaa-028703 aaa-028704 Figure 4. Pin configuration SOT163-1 (SO20) Figure 5. Pin configuration SOT339-1 (SSOP20) and SOT360-1 (TSSOP20) 5.2 Pin description Table 2. Pin description Symbol Pin Description E 1 enable input (active LOW) P0, P1, P2, P3, P4, P5, P6, P7 2, 4, 6, 8, 11, 13, 15, 17 word P inputs Q0, Q1, Q2, Q3, Q4, Q5, Q6, Q7 3, 5, 7, 9, 12, 14, 16, 18 word Q inputs GND 10 ground (0 V) P=Q 19 equal to output VCC 20 supply voltage 6 Functional description Table 3. Function table H = HIGH voltage level; L = LOW voltage level; X = don’t care. inputs output data Pn, Qn E P=Q P=Q L L P>Q L H P VCC + 0.5 V [1] - ±20 mA [1] - ±20 mA - ±25 mA IOK output clamping current VO < -0.5 V or VO > VCC + 0.5 V IO output current -0.5 V < VO < VCC + 0.5 V ICC supply current - 50 mA IGND ground current -50 - mA Tstg storage temperature -65 +150 °C - 500 mW Ptot total power dissipation Tamb = -40 °C to +125 °C [2] [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] For SO20 Packages: Ptot derates linearly with 8 mW/K above 70 °C. For (T)SSOP20 Packages: Ptot derates linearly with 5.5 mW/K above 60 °C. 8 Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V) Symbol Parameter VCC supply voltage VI Min Typ Max Unit 2.0 5.0 6.0 V input voltage 0 - VCC V VO output voltage 0 - VCC V Tamb ambient temperature -40 - +125 °C Δt/ΔV input transition rise and fall rate VCC = 2.0 V - - 625 ns/V VCC = 4.5 V - 1.67 139 ns/V VCC = 6.0 V - - 83 ns/V 74HC688 Product data sheet Conditions All information provided in this document is subject to legal disclaimers. Rev. 3 — 4 July 2018 © Nexperia B.V. 2018. All rights reserved. 4 / 16 74HC688 Nexperia 8-bit magnitude comparator 9 Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol VIH VIL VOH VOL Parameter Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Min Typ Max Min Max Min Max Unit HIGH-level input VCC = 2.0 V voltage VCC = 4.5 V 1.5 1.2 - 1.5 - 1.5 - V 3.15 2.4 - 3.15 - 3.15 - V VCC = 6.0 V 4.2 3.2 - 4.2 - 4.2 - V LOW-level input VCC = 2.0 V voltage VCC = 4.5 V - 0.8 0.5 - 0.5 - 0.5 V - 2.1 1.35 - 1.35 - 1.35 V VCC = 6.0 V - 2.8 1.8 - 1.8 - 1.8 V IO = -20 μA; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = -20 μA; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = -20 μA; VCC = 6.0 V 5.9 6.0 - 5.9 - 5.9 - V IO = -4.0 mA; VCC = 4.5 V 3.98 4.32 - 3.84 - 3.7 - V IO = -5.2 mA; VCC = 6.0 V 5.48 5.81 - 5.34 - 5.2 - V IO = 20 μA; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 20 μA; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 20 μA; VCC = 6.0 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 4.5 V - 0.15 0.26 - 0.33 - 0.4 V IO = 5.2 mA; VCC = 6.0 V - 0.16 0.26 - 0.33 - 0.4 V HIGH-level output voltage LOW-level output voltage VI = VIH or VIL VI = VIH or VIL II input leakage current VI = VCC or GND; VCC = 6.0 V - - ±0.1 - ±1 - ±1 μA ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 8.0 - 80 - 160 μA CI input capacitance - 3.5 - - - - - pF 74HC688 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 4 July 2018 © Nexperia B.V. 2018. All rights reserved. 5 / 16 74HC688 Nexperia 8-bit magnitude comparator 10 Dynamic characteristics Table 7. Dynamic characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit, see Figure 8 Symbol tpd Parameter propagation delay Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max VCC = 2.0 V - 55 170 - 215 - 255 ns VCC = 4.5 V - 20 34 - 43 - 51 ns VCC = 5.0 V; CL = 15 pF - 17 - - - - - ns VCC = 6.0 V - 16 29 - 37 - 43 ns VCC = 2.0 V - 28 120 - 150 - 180 ns VCC = 4.5 V - 10 24 - 30 - 36 ns VCC = 5.0 V; CL = 15 pF - 8 - - - - - ns - 8 20 - 26 - 31 ns VCC = 2.0 V - 19 75 - 95 - 110 ns VCC = 4.5 V - 7 15 - 19 - 22 ns - 6 13 - 16 - 19 ns - 30 - - - - - pF Pn, Qn to P=Q; see Figure 6 [1] E to P=Q; see Figure 7 VCC = 6.0 V tt [2] transition time see Figure 7 VCC = 6.0 V CPD power dissipation capacitance per package; VI = GND to VCC [3] [1] tpd is the same as tPHL and tPLH. [2] tt is the same as tTHL and tTLH. [3] CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD × VCC × fi + Σ (CL × VCC × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; 2 Σ (CL × VCC × fo) = sum of outputs; CL = output load capacitance in pF; VCC = supply voltage in V. 74HC688 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 4 July 2018 © Nexperia B.V. 2018. All rights reserved. 6 / 16 74HC688 Nexperia 8-bit magnitude comparator 10.1 Waveforms and test circuit VI Pn, Qn input VM VM tPHL tPLH GND VOH VY VY VM P=Q output VM VX VOL VX tTHL tTLH aaa-028706 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Figure 6. Waveforms showing the word inputs (Pn, Qn) to the equal to output (P=Q) propagation delays and the output transition times. VI E input VM VM tPHL tPLH GND VOH VY VY VM P=Q output VM VX VOL VX tTHL tTLH aaa-028705 Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Figure 7. Waveforms showing the enable input (E) to the equal to output (P=Q) propagation delays and the output transition times. Table 8. Measurement points Input Output VI VM VM VX VY GND to VCC 0.5VCC 0.5VCC 0.1VCC 0.9VCC 74HC688 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 4 July 2018 © Nexperia B.V. 2018. All rights reserved. 7 / 16 74HC688 Nexperia 8-bit magnitude comparator VI negative pulse VM VI GND VM 10 % GND positive pulse tW 90 % tf tr tr tf 90 % VM VM 10 % tW VCC G VI DUT VO RT CL 001aah768 Test data is given in Table 9. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. Figure 8. Test circuit for measuring switching times Table 9. Test data Input Load VI tr, tf CL GND to VCC 6.0 ns 15 pF, 50 pF 74HC688 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 4 July 2018 Test tPLH, tPHL © Nexperia B.V. 2018. All rights reserved. 8 / 16 74HC688 Nexperia 8-bit magnitude comparator 11 Application information Two or more 74HC688 8-bit magnitude comparators may be cascaded to compare binary or BCD numbers of more than 8 bits. An example is shown in Figure 9. 74HC688 Pn 74HC688 Pn-1 P0 P=Q Qn 8 MSB 74HC688 P=Q Qn-1 E P=Q Q0 E output 8 LSB E aaa-028707 Figure 9. Binary or BCD comparator 74HC688 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 4 July 2018 © Nexperia B.V. 2018. All rights reserved. 9 / 16 74HC688 Nexperia 8-bit magnitude comparator 12 Package outline SO20: plastic small outline package; 20 leads; body width 7.5 mm SOT163-1 D E A X c y HE v M A Z 20 11 Q A2 A (A 3 ) A1 pin 1 index θ Lp L 1 10 e bp detail X w M 0 5 10 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y mm 2.65 0.3 0.1 2.45 2.25 0.25 0.49 0.36 0.32 0.23 13.0 12.6 7.6 7.4 1.27 10.65 10.00 1.4 1.1 0.4 1.1 1.0 0.25 0.25 0.1 0.9 0.4 inches 0.1 0.012 0.096 0.004 0.089 0.01 0.019 0.013 0.014 0.009 0.51 0.49 0.30 0.29 0.05 0.419 0.043 0.055 0.394 0.016 0.043 0.039 0.01 0.01 0.004 0.035 0.016 Z (1) θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT163-1 075E04 MS-013 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Figure 10. Package outline SOT163-1 (SO20) 74HC688 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 4 July 2018 © Nexperia B.V. 2018. All rights reserved. 10 / 16 74HC688 Nexperia 8-bit magnitude comparator SSOP20: plastic shrink small outline package; 20 leads; body width 5.3 mm D SOT339-1 E A X c HE y v M A Z 20 11 Q A2 pin 1 index A (A 3) A1 θ Lp L 1 10 bp e detail X w M 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) θ mm 2 0.21 0.05 1.80 1.65 0.25 0.38 0.25 0.20 0.09 7.4 7.0 5.4 5.2 0.65 7.9 7.6 1.25 1.03 0.63 0.9 0.7 0.2 0.13 0.1 0.9 0.5 8o 0o Note 1. Plastic or metal protrusions of 0.2 mm maximum per side are not included. OUTLINE VERSION SOT339-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-150 Figure 11. Package outline SOT339-1 (SSOP20) 74HC688 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 4 July 2018 © Nexperia B.V. 2018. All rights reserved. 11 / 16 74HC688 Nexperia 8-bit magnitude comparator TSSOP20: plastic thin shrink small outline package; 20 leads; body width 4.4 mm D SOT360-1 E A X c HE y v M A Z 11 20 Q A2 pin 1 index (A 3 ) A1 A θ Lp 1 L 10 detail X w M bp e 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 6.6 6.4 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.5 0.2 8o 0o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT360-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-153 Figure 12. Package outline SOT360-1 (TSSOP20) 74HC688 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 3 — 4 July 2018 © Nexperia B.V. 2018. All rights reserved. 12 / 16 74HC688 Nexperia 8-bit magnitude comparator 13 Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model 14 Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC688 v.3 20180704 Product data sheet - 74HC_HCT688 v.2 Modifications: • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. • Legal texts have been adapted to the new company name where appropriate. • Type numbers 74HC688N (SOT146-1), 74HCT688N (SOT146-1) and 74HCT688PW (SOT360-1) removed. 74HC_HCT688 v.2 19901201 74HC688 Product data sheet Product specification - All information provided in this document is subject to legal disclaimers. Rev. 3 — 4 July 2018 74HC_HCT688 v.1 © Nexperia B.V. 2018. All rights reserved. 13 / 16 74HC688 Nexperia 8-bit magnitude comparator 15 Legal information 15.1 Data sheet status Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia's aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical 74HC688 Product data sheet systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 3 — 4 July 2018 © Nexperia B.V. 2018. All rights reserved. 14 / 16 74HC688 Nexperia 8-bit magnitude comparator Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia's warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia's specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer 74HC688 Product data sheet design and use of the product for automotive applications beyond Nexperia's standard warranty and Nexperia's product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 3 — 4 July 2018 © Nexperia B.V. 2018. All rights reserved. 15 / 16 74HC688 Nexperia 8-bit magnitude comparator Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 10.1 11 12 13 14 15 General description ............................................ 1 Features and benefits .........................................1 Ordering information .......................................... 1 Functional diagram ............................................. 2 Pinning information ............................................ 3 Pinning ............................................................... 3 Pin description ................................................... 3 Functional description ........................................3 Limiting values .................................................... 4 Recommended operating conditions ................ 4 Static characteristics .......................................... 5 Dynamic characteristics .....................................6 Waveforms and test circuit ................................ 7 Application information ......................................9 Package outline .................................................10 Abbreviations .................................................... 13 Revision history ................................................ 13 Legal information .............................................. 14 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section 'Legal information'. © Nexperia B.V. 2018. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 4 July 2018 Document identifier: 74HC688
74HC688PW,118 价格&库存
很抱歉,暂时无法提供与“74HC688PW,118”相匹配的价格&库存,您可以联系我们找货
74HC688PW,118
  • 1+5.840721+0.73272
  • 10+4.1233010+0.51727
  • 50+3.4350650+0.43093
  • 100+3.22052100+0.40402
74HC688PW,118
  • 2500+2.627252500+0.32959
  • 5000+2.555785000+0.32063
74HC688PW,118
