74HC75D,653
74HC75D,653
    NEXPERIA(安世)
    SOIC-16
    四路双稳态透明锁存器
74HC75D,653 数据手册
INTEGRATED CIRCUITS DATA SHEET For a complete data sheet, please also download: • The IC06 74HC/HCT/HCU/HCMOS Logic Family Specifications • The IC06 74HC/HCT/HCU/HCMOS Logic Package Information • The IC06 74HC/HCT/HCU/HCMOS Logic Package Outlines 74HC/HCT75 Quad bistable transparent latch Product specification File under Integrated Circuits, IC06 December 1990 Philips Semiconductors Product specification Quad bistable transparent latch 74HC/HCT75 The 74HC/HCT75 have four bistable latches. The two latches are simultaneously controlled by one of two active HIGH enable inputs (LE1-2 and LE3-4). When LEn-n is HIGH, the data enters the latches and appears at the nQ outputs. The nQ outputs follow the data inputs (nD) as long as LEn-n is HIGH (transparent). The data on the nD inputs one set-up time prior to the HIGH-to-LOW transition of the LEn-n will be stored in the latches. The latched outputs remain stable as long as the LEn-n is LOW. FEATURES • Complementary Q and Q outputs • VCC and GND on the centre pins • Output capability: standard • ICC category: MSI GENERAL DESCRIPTION The 74HC/HCT75 are high-speed Si-gate CMOS devices and are pin compatible with low power Schottky TTL (LSTTL). They are specified in compliance with JEDEC standard no. 7A. QUICK REFERENCE DATA GND = 0 V; Tamb = 25 °C; tr = tf = 6 ns TYPICAL SYMBOL PARAMETER CONDITIONS UNIT HC tPHL/ tPLH propagation delay CL = 15 pF; VCC = 5 V nD to nQ, nQ 11 12 ns LEn-n to nQ, nQ 11 11 ns 3.5 3.5 pF 42 42 pF CI input capacitance CPD power dissipation capacitance per latch notes 1 and 2 Notes 1. CPD is used to determine the dynamic power dissipation (PD in µW): PD = CPD × VCC2 × fi + ∑ (CL × VCC2 × fo) where: fi = input frequency in MHz fo = output frequency in MHz ∑ (CL × VCC2 × fo) = sum of outputs CL = output load capacitance in pF VCC = supply voltage in V 2. For HC the condition is VI = GND to VCC For HCT the condition is VI = GND to VCC −1.5 V ORDERING INFORMATION See “74HC/HCT/HCU/HCMOS Logic Package Information”. December 1990 HCT 2 Philips Semiconductors Product specification Quad bistable transparent latch 74HC/HCT75 PIN DESCRIPTION PIN NO. SYMBOL NAME AND FUNCTION 1, 14, 11, 8 1Q to 4Q complementary latch outputs 2, 3, 6, 7 1D to 4D data inputs 4 LE3-4 latch enable input, latches 3 and 4 (active HIGH) 5 VCC positive supply voltage 12 GND ground (0 V) 13 LE1-2 latch enable input, latches 1 and 2 (active HIGH) 16, 15, 10, 9 1Q to 4Q latch outputs Fig.1 Pin configuration. December 1990 Fig.2 Logic symbol. 3 Fig.3 IEC logic symbol. Philips Semiconductors Product specification Quad bistable transparent latch 74HC/HCT75 FUNCTION TABLE INPUTS OPERATING MODES LEn-n OUTPUTS nD nQ nQ data enabled H H L H L H H L data latched L X q q Notes 1. H = HIGH voltage level L = LOW voltage level q = lower case letters indicate the state of the referenced output one set-up time prior to the HIGH-to-LOW LEn-n transition X = don’t care Fig.4 Functional diagram. Fig.5 Logic diagram. December 1990 4 Philips Semiconductors Product specification Quad bistable transparent latch 74HC/HCT75 DC CHARACTERISTICS FOR 74HC For the DC characteristics see “74HC/HCT/HCU/HCMOS Logic Family Specifications”. Output capability: standard ICC category: MSI AC CHARACTERISTICS FOR 74HC GND = 0 V; tr = tf = 6 ns; CL = 50 pF Tamb (°C) TEST CONDITIONS 74HC SYMBOL PARAMETER +25 −40 to+85 −40 to+125 min. typ. max. min. max. min. UNIT V CC (V) WAVEFORMS max. tPHL/ tPLH propagation delay nD to nQ 33 12 10 110 22 19 140 28 24 165 33 28 ns 2.0 4.5 6.0 Fig.6 tPHL/ tPLH propagation delay nD to nQ 39 14 11 120 24 20 150 30 26 180 36 31 ns 2.0 4.5 6.0 Fig.7 tPHL/ tPLH propagation delay LEn-n to nQ 33 12 10 120 24 20 150 30 26 180 36 31 ns 2.0 4.5 6.0 Fig.8 tPHL/ tPLH propagation delay LEn-n to nQ 39 14 11 125 25 21 155 31 26 190 38 32 ns 2.0 4.5 6.0 Fig.8 tTHL/ tTLH output transition time 19 7 6 75 15 13 95 19 16 110 22 19 ns 2.0 4.5 6.0 Figs 6 and 7 tW enable pulse width HIGH 80 16 14 17 6 5 100 20 17 120 24 20 ns 2.0 4.5 6.0 Fig.8 tsu set-up time nD to LEn-n 60 12 10 14 5 4 75 15 13 90 18 15 ns 2.0 4.5 6.0 Fig.9 th hold time nD to LEn-n 3 3 3 −8 −3 −2 3 3 3 3 3 3 ns 2.0 4.5 6.0 Fig.9 December 1990 5 Philips Semiconductors Product specification Quad bistable transparent latch 74HC/HCT75 DC CHARACTERISTICS FOR 74HCT For the DC characteristics see “74HC/HCT/HCU/HCMOS Logic Family Specifications”. Output capability: standard ICC category: MSI Note to HCT types The value of additional quiescent supply current (∆ICC) for a unit load of 1 is given in the family specifications. To determine ∆ICC per input, multiply this value by the unit load coefficient shown in the table below. INPUT UNIT LOAD COEFFICIENT nD LEn-n 0.75 1.00 AC CHARACTERISTICS FOR 74HCT GND = 0 V; tr = tf = 6 ns; CL = 50 pF Tamb (°C) TEST CONDITIONS 74HCT SYMBOL PARAMETER +25 −40 to +85 −40 to +125 min. typ. max. min. max. min. UNIT V CC (V) WAVEFORMS max. tPHL/ tPLH propagation delay nD to nQ 15 28 35 42 ns 4.5 Fig.6 tPHL/ tPLH propagation delay nD to nQ 15 28 35 42 ns 4.5 Fig.7 tPHL/ tPLH propagation delay LEn-n to nQ 13 28 35 42 ns 4.5 Fig.8 tPHL/ tPLH propagation delay LEn-n to nQ 15 30 38 45 ns 4.5 Fig.8 tTHL/ tTLH output transition time 7 15 19 22 ns 4.5 Figs 6 and 7 tW enable pulse width HIGH 16 4 20 24 ns 4.5 Fig.8 tsu set-up time nD to LEn-n 12 4 15 18 ns 4.5 Fig.9 th hold time nD to LEn-n 3 −2 3 3 ns 4.5 Fig.9 December 1990 6 Philips Semiconductors Product specification Quad bistable transparent latch 74HC/HCT75 AC WAVEFORMS (1) HC : VM = 50%; VI = GND to VCC. HCT: VM = 1.3 V; VI = GND to 3 V. (1) HC : VM = 50%; VI = GND to VCC. HCT: VM = 1.3 V; VI = GND to 3 V. Fig.6 Fig.7 Waveforms showing the data input (nD) to output (nQ) propagation delays and the output transition times. Waveforms showing the data input (nD) to output (nQ) propagation delays and the output transition times. The shaded areas indicate when the input is permitted to change for predictable output performance. (1) HC : VM = 50%; VI = GND to VCC. HCT: VM = 1.3 V; VI = GND to 3 V. Fig.9 (1) HC : VM = 50%; VI = GND to VCC. HCT: VM = 1.3 V; VI = GND to 3 V. Fig.8 Waveforms showing the latch enable input (LEn-n) pulse width, the latch enable input to outputs (nQ, nQ) propagation delays and the output transition times. December 1990 Waveforms showing the data set-up and hold times for nD input to LEn-n input. PACKAGE OUTLINES See “74HC/HCT/HCU/HCMOS Logic Package Outlines”. 7
74HC75D,653 价格&库存
很抱歉,暂时无法提供与“74HC75D,653”相匹配的价格&库存,您可以联系我们找货
74HC75D,653
74HC75D,653
