HEF4043BT,653
HEF4043BT,653
    NEXPERIA(安世)
    SOIC-16
    带3态输出的四路R/S锁存器
HEF4043BT,653 数据手册
HEF4043B Quad R/S latch with 3-state outputs Rev. 12 — 30 January 2020 Product 1. General description The HEF4043B is a quad R/S latch with 3-state outputs with a common output enable input (OE). Each latch has an active HIGH set input (1S to 4S), an active HIGH reset input (1R to 4R) and an active HIGH 3-state output (1Q to 4Q). When OE is HIGH, the latch output (nQ) is determined by the nR and nS inputs (see Table 3). When OE is LOW, the latch outputs are in the high impedance OFF-state. OE does not affect the state of the latch. The high impedance off-state feature allows common bussing of the outputs. It operates over a recommended VDD power supply range of 3 V to 15 V referenced to VSS (usually ground). Unused inputs must be connected to VDD, VSS, or another input. 2. Features and benefits • • • • • Fully static operation 5 V, 10 V, and 15 V parametric ratings Standardized symmetrical output characteristics Specified from -40 °C to +85 °C Complies with JEDEC standard JESD 13-B 3. Applications • Four-bit storage with output enable 4. Ordering information Table 1. Ordering information All types operate from -40 °C to +85 °C. Type number HEF4043BT Package Name Description Version SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 HEF4043B Nexperia Quad R/S latch with 3-state outputs 5. Functional diagram 4 1S 1Q 2 3 1R 6 2S 2Q 9 7 2R 3-STATE OUTPUTS 12 3S nS nQ 3Q 10 11 3R 14 4S nR 4Q 1 15 4R OE 5 OE to other latches 001aae616 Fig. 1. 001aae618 Functional diagram Fig. 2. Logic diagram for one latch 6. Pinning information 6.1. Pinning HEF4043B 4Q 1 16 VDD 1Q 2 15 4R 1R 3 14 4S 1S 4 13 n.c. OE 5 12 3S 2S 6 11 3R 2R 7 10 3Q VSS 8 9 2Q 001aae617 Fig. 3. HEF4043B Product Pin configuration SOT109-1 (SO16) All information provided in this document is subject to legal disclaimers. Rev. 12 — 30 January 2020 © Nexperia B.V. 2020. All rights reserved 2 / 11 HEF4043B Nexperia Quad R/S latch with 3-state outputs 6.2. Pin description Table 2. Pin description Symbol Pin Description 1Q to 4Q 2, 9, 10, 1 3-state buffered latch output 1R to 4R 3, 7, 11, 15 reset input (active HIGH) 1S to 4S 4, 6, 12, 14 set input (active HIGH) OE 5 common output enable input VSS 8 ground supply voltage n.c. 13 not connected VDD 16 supply voltage 7. Functional description Table 3. Function table H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high impedance state. Output Inputs OE nS nR nQ L X X Z H L H L H H X H H L L latched 8. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter VDD supply voltage IIK input clamping current VI input voltage IOK output clamping current II/O input/output current IDD supply current Tstg storage temperature Tamb ambient temperature Ptot total power dissipation Conditions VI < -0.5 V or VI > VDD + 0.5 V VO < -0.5 V or VO > VDD + 0.5 V HEF4043B Product power dissipation Max Unit -0.5 +18 V - ±10 mA -0.5 VDD + 0.5 - ±10 mA - ±10 mA - 50 mA -65 +150 °C -40 +85 °C - 500 mW - 100 mW V Tamb -40 °C to +85 °C • P Min SO16 package per output All information provided in this document is subject to legal disclaimers. Rev. 12 — 30 January 2020 © Nexperia B.V. 2020. All rights reserved 3 / 11 HEF4043B Nexperia Quad R/S latch with 3-state outputs 9. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter Conditions Min Typ Max Unit VDD supply voltage 3 - 15 V VI input voltage 0 - VDD V Tamb ambient temperature in free air -40 - +85 °C Δt/ΔV input transition rise and fall rate VDD = 5 V - - 3.75 μs/V VDD = 10 V - - 0.5 μs/V VDD = 15 V - - 0.08 μs/V 10. Static characteristics Table 6. Static characteristics VSS = 0 V; VI = VSS or VDD unless otherwise specified. Symbol Parameter VIH VIL VOH VOL IOH IOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage HIGH-level output current LOW-level output current II input leakage current IOZ OFF-state output current IDD CI HEF4043B Product supply current input capacitance Conditions VDD Tamb = -40 °C Tamb = 25 °C Tamb = 85 °C Unit Min Max Min Max Min Max 5V 3.5 - 3.5 - 3.5 - V 10 V 7.0 - 7.0 - 7.0 - V 15 V 11.0 - 11.0 - 11.0 - V 5V - 1.5 - 1.5 - 1.5 V 10 V - 3.0 - 3.0 - 3.0 V 15 V - 4.0 - 4.0 - 4.0 V 5V 4.95 - 4.95 - 4.95 - V 10 V 9.95 - 9.95 - 9.95 - V 15 V 14.95 - 14.95 - 14.95 - V 5V - 0.05 - 0.05 - 0.05 V 10 V - 0.05 - 0.05 - 0.05 V 15 V - 0.05 - 0.05 - 0.05 V VO = 2.5 V 5V - -1.7 - -1.4 - -1.1 mA VO = 4.6 V 5V - -0.52 - -0.44 - -0.36 mA VO = 9.5 V 10 V - -1.3 - -1.1 - -0.9 mA VO = 13.5 V 15 V - -3.6 - -3.0 - -2.4 mA VO = 0.4 V 5V 0.52 - 0.44 - 0.36 - mA VO = 0.5 V 10 V 1.3 - 1.1 - 0.9 - mA VO = 1.5 V 15 V 3.6 - 3.0 - 2.4 - mA 15 V - ±0.3 - ±0.3 - ±1.0 μA nQ output HIGH; returned to VDD 15 V - 1.6 - 1.6 - 12.0 μA nQ output LOW; returned to VSS 15 V - 1.6 - 1.6 - 12.0 μA IO = 0 A 5V - 20 - 20 - 150 μA 10 V - 40 - 40 - 300 μA 15 V - 80 - 80 - 600 μA - - - 7.5 - - pF |IO| < 1 μA |IO| < 1 μA |IO| < 1 μA |IO| < 1 μA All information provided in this document is subject to legal disclaimers. Rev. 12 — 30 January 2020 © Nexperia B.V. 2020. All rights reserved 4 / 11 HEF4043B Nexperia Quad R/S latch with 3-state outputs 11. Dynamic characteristics Table 7. Dynamic characteristics VSS = 0 V; Tamb = 25 °C; For waveforms and test circuit see Section 11.1; unless otherwise specified. Symbol Parameter Conditions VDD Extrapolation formula tPHL HIGH to LOW propagation delay nR → nQ; see Fig. 4 5V LOW to HIGH propagation delay nS → nQ; see Fig. 4 10 V 15 V tPLH tt transition time tPHZ tPLZ LOW to OFF-state propagation delay tPZH tPZL tW [1] [2] HIGH to OFF-state propagation delay nQ output; see Fig. 4 Typ Max Unit [1] 63 ns + (0.55 ns/pF)CL - 90 180 ns 24 ns + (0.23 ns/pF)CL - 35 70 ns 17 ns + (0.16 ns/pF)CL - 25 50 ns [1] 38 ns + (0.55 ns/pF)CL - 65 135 ns 10 V 14 ns + (0.23 ns/pF)CL - 25 50 ns 15 V 7 ns + (0.16 ns/pF)CL - 15 35 ns - 60 120 ns 5V 5V [1] [2] 10 ns + (1.00 ns/pF)CL 10 V 9 ns + (0.42 ns/pF)CL - 30 60 ns 15 V 6 ns + (0.28 ns/pF)CL - 20 40 ns 5V - 45 90 ns 10 V - 20 35 ns 15 V - 10 25 ns 5V - 50 100 ns 10 V - 20 40 ns 15 V - 10 25 ns 5V - 25 50 ns 10 V - 15 30 ns 15 V - 10 25 ns 5V - 40 80 ns 10 V - 20 45 ns 15 V - 15 35 ns nS input HIGH; 5 V minimum width; 10 V see Fig. 4 15 V 30 15 - ns 20 10 - ns 16 8 - ns nR input HIGH; 5 V minimum width; 10 V see Fig. 4 15 V 30 15 - ns 20 10 - ns 16 8 - ns OE → nQ; see Fig. 5 OE → nQ; see Fig. 5 OFF-state to HIGH propagation delay OE → nQ; see Fig. 5 OFF-state to LOW propagation delay OE → nQ; see Fig. 5 pulse width Min The typical values of the propagation delay and transition times are calculated from the extrapolation formulas shown (CL in pF). tt is the same as tTHL and tTLH. Table 8. Dynamic power dissipation PD PD can be calculated from the formulas shown. VSS = 0 V; tr = tf ≤ 20 ns; Tamb = 25 °C. Symbol PD HEF4043B Product Parameter dynamic power dissipation VDD Typical formula for PD (μW) where: 5V PD = 10 V PD = 15 V PD = 11400 x fi + Σ(fo x CL) x VDD fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VDD = supply voltage in V; Σ(fo x CL) = sum of the outputs. 2 1100 x fi + Σ(fo x CL) x VDD 2 4400 x fi + Σ(fo x CL) x VDD 2 All information provided in this document is subject to legal disclaimers. Rev. 12 — 30 January 2020 © Nexperia B.V. 2020. All rights reserved 5 / 11 HEF4043B Nexperia Quad R/S latch with 3-state outputs 11.1. Waveforms tr VI tf 90 % input nS VM 0V 10 % tW VI input nR VM 0V tW tPLH VOH tPHL 90 % output nQ VM 10 % VOL tTLH tTHL 001aai286 tr and tf are the input rise and fall times. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Transition times: transition time (tt) = HIGH LOW (tTHL) or LOW HIGH (tTLH) transition times. Measurement points are given in Table 9 and test data is given in Table 10. Fig. 4. Input minimum set (nS) and reset (nR) pulse widths, inputs nS or nR to latch output (nQ) propagation delay and nQ transition time VDD OE input VSS tPLZ output LOW-to-OFF OFF-to-LOW tPZL VDD VY VX VSS tPHZ output HIGH-to-OFF OFF-to-HIGH VDD tPZH VY VX VSS outputs on outputs off outputs on 001aag355 Measurement points are given in Table 9. Fig. 5. Output enable (OE) to latch output (nQ) enable time (tPZL and tPZH) and disable time (tPLZ and tPHZ) Table 9. Measurement points Supply voltage Input Output VDD VI VM VM VX VY 5 V to 15 V VDD or 0 V 0.5VDD 0.5VDD 0.1VDD 0.9VDD HEF4043B Product All information provided in this document is subject to legal disclaimers. Rev. 12 — 30 January 2020 © Nexperia B.V. 2020. All rights reserved 6 / 11 HEF4043B Nexperia Quad R/S latch with 3-state outputs VI negative pulse tW 90 % 90 % VM 10 % 0V VI positive pulse 0V VM 10 % tf tr tr tf 90 % 90 % VM VM 10 % 10 % tW 001aaj781 a. Input waveform VEXT VDD G VI RL VO DUT RT CL 001aaj915 b. Test circuit Test and measurement data is given in Table 10. Definitions test circuit: DUT = Device Under Test. RL = Load resistance; CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Fig. 6. Test circuit for measuring switching times Table 10. Test data Supply voltage Input VDD VI tr, tf CL RL tPLH, tPHL tPLZ, tPZL tPHZ, tPZH 5 V to 15 V VDD ≤ 20 ns 50 pF 1 kΩ open VDD GND HEF4043B Product Load VEXT All information provided in this document is subject to legal disclaimers. Rev. 12 — 30 January 2020 © Nexperia B.V. 2020. All rights reserved 7 / 11 HEF4043B Nexperia Quad R/S latch with 3-state outputs 12. Package outline SO16: plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 D E A X c y HE v M A Z 16 9 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 8 e w M bp 0 2.5 detail X 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 10.0 9.8 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 inches 0.069 0.010 0.057 0.004 0.049 0.01 0.019 0.0100 0.39 0.014 0.0075 0.38 0.16 0.15 0.05 0.039 0.016 0.028 0.020 0.01 0.01 0.004 0.028 0.012 0.244 0.041 0.228 θ o 8 o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. Fig. 7. HEF4043B Product REFERENCES OUTLINE VERSION IEC JEDEC SOT109-1 076E07 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Package outline SOT109-1 (SO16) All information provided in this document is subject to legal disclaimers. Rev. 12 — 30 January 2020 © Nexperia B.V. 2020. All rights reserved 8 / 11 HEF4043B Nexperia Quad R/S latch with 3-state outputs 13. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes HEF4043B v.12 20200130 Product data sheet - HEF4043B v.11 Modifications: • • • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Fig. 2: Typo corrected. HEF4043B v.11 20160324 Modifications: • HEF4043B v.10 20111118 Modifications: • HEF4043B v.9 20091216 Product data sheet - HEF4043B v.8 HEF4043B v.8 20091127 Product data sheet - HEF4043B v.7 HEF4043B v.7 20090710 Product data sheet - HEF4043B v.6 HEF4043B v.6 20081111 Product data sheet - HEF4043B v.5 HEF4043B v.5 20080729 Product data sheet - HEF4043B v.4 HEF4043B v.4 20080710 Product data sheet - HEF4043B_CNV v.3 HEF4043B_CNV v.3 19950101 Product specification - HEF4043B_CNV v.2 HEF4043B_CNV v.2 19950101 Product specification - - HEF4043B Product Product data sheet - HEF4043B v.10 Type number HEF4043BP (SOT38-4) removed. Product data sheet - HEF4043B v.9 Table 6: IOH minimum values changed to maximum All information provided in this document is subject to legal disclaimers. Rev. 12 — 30 January 2020 © Nexperia B.V. 2020. All rights reserved 9 / 11 HEF4043B Nexperia Quad R/S latch with 3-state outputs 14. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal HEF4043B Product Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 12 — 30 January 2020 © Nexperia B.V. 2020. All rights reserved 10 / 11 HEF4043B Nexperia Quad R/S latch with 3-state outputs Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Ordering information....................................................1 5. Functional diagram.......................................................2 6. Pinning information......................................................2 6.1. Pinning.........................................................................2 6.2. Pin description............................................................. 3 7. Functional description................................................. 3 8. Limiting values............................................................. 3 9. Recommended operating conditions..........................4 10. Static characteristics..................................................4 11. Dynamic characteristics.............................................5 11.1. Waveforms................................................................. 6 12. Package outline.......................................................... 8 13. Revision history..........................................................9 14. Legal information......................................................10 © Nexperia B.V. 2020. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 30 January 2020 HEF4043B Product All information provided in this document is subject to legal disclaimers. Rev. 12 — 30 January 2020 © Nexperia B.V. 2020. All rights reserved 11 / 11
HEF4043BT,653 价格&库存
很抱歉,暂时无法提供与“HEF4043BT,653”相匹配的价格&库存,您可以联系我们找货
HEF4043BT,653
    • 1+4.85100
    • 100+4.03700
    • 1250+3.66300
    • 2500+3.52000
    库存:4998
    HEF4043BT,653
    • 1+3.94909
    • 10+2.76437
    • 25+2.51230
    • 50+2.50389
    库存:902
    HEF4043BT,653
    • 1+4.376411+0.54881
    • 10+3.1016410+0.38895
    • 25+2.7759025+0.34811
    • 100+2.41243100+0.30253
    • 250+2.23873250+0.28074
    • 500+2.13427500+0.26765
    • 1000+2.066981000+0.25921
    库存:811
    HEF4043BT,653
    • 2500+1.289162500+0.16167
    • 5000+1.250405000+0.15681
    • 7500+1.230977500+0.15437
    • 12500+1.2094412500+0.15167
    • 17500+1.1968617500+0.15009
    • 25000+1.1847725000+0.14858
    • 62500+1.1587262500+0.14531
    库存:811
    HEF4043BT,653
