HEF4060B
14-stage ripple-carry binary counter/divider and oscillator
Rev. 9 — 8 July 2019
Product data sheet
1. General description
The HEF4060B is a 14-stage ripple-carry binary counter/divider and oscillator with three oscillator
terminals (RS, REXT and CEXT), ten buffered outputs (Q3 to Q9 and Q11 to Q13) and an
overriding asynchronous master reset input (MR).
The oscillator configuration allows design of either RC or crystal oscillator circuits. The oscillator
may be replaced by an external clock signal at input RS. The clock input' s Schmitt-trigger action
makes it highly tolerant to slower clock rise and fall times. The counter advances on the negativegoing transition of RS. A HIGH level on MR resets the counter (Q3 to Q9 and Q11 to Q13 = LOW),
independent of other input conditions.
It operates over a recommended VDD power supply range of 3 V to 15 V referenced to VSS (usually
ground). Unused inputs must be connected to VDD, VSS, or another input.
2. Features and benefits
Tolerant of slow clock rise and fall times
Fully static operation
5 V, 10 V, and 15 V parametric ratings
Standardized symmetrical output characteristics
Inputs and outputs are protected against electrostatic effects
Specified from -40 ° C to +85 ° C
Complies with JEDEC standard JESD 13-B
3. Ordering information
Table 1. Ordering information
All types operate from -40 ° C to +85 ° C.
Type number
Package
Name
Description
Version
HEF4060BT
SO16
plastic small outline package; 16 leads; body width 3.9 mm
SOT109-1
HEF4060BTT
TSSOP16
plastic thin shrink small outline package; 16 leads; body width 4.4 mm
SOT403-1
HEF4060B
Nexperia
4. Functional diagram
10
REXT
11
12
RS
9
CEXT
CP
CD
MR
Q3 Q4 Q5 Q6 Q7 Q8 Q9 Q11 Q12 Q13
7
Fig. 1.
14-STAGE BINARY COUNTER
5
4
6
14
13
15
1
2
3
001aae652
Functional diagram
CEXT
REXT
FF1
RS
CP
Q
CD
FF4
CP
Q
CD
MR
FF10
FF12
FF14
CP
CP
CP
Q
CD
Q3
Q
CD
Q9
Q
CD
Q11
Q13
001aae654
Fig. 2.
Logic diagram
5. Pinning information
5.1. Pinning
HEF4060B
Q11
1
16 VDD
Q12
2
15 Q9
Q13
3
14 Q7
Q5
4
13 Q8
Q4
5
12 MR
Q6
6
11 RS
Q3
7
VSS
8
HEF4060B
10 REXT
9
CEXT
Q11
1
16 VDD
Q12
2
15 Q9
Q13
3
14 Q7
Q5
4
13 Q8
Q4
5
12 MR
Q6
6
11 RS
Q3
7
10 REXT
VSS
8
001aae653
Fig. 3.
Pin configuration SOT109-1 (SO16)
HEF4060B
Product data sheet
9
CEXT
aaa-030139
Fig. 4.
Pin configuration SOT403-1 (TSSOP16)
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2019. All rights reserved
2 / 14
HEF4060B
Nexperia
5.2. Pin description
Table 2. Pin description
Symbol
Pin
Description
Q11 to Q13
1, 2, 3
counter output
Q3 to Q9
7, 5, 4, 6, 14, 13, 15
counter output
VSS
8
ground supply voltage
CEXT
9
external capacitor connection
REXT
10
oscillator pin
RS
11
clock input/oscillator pin
MR
12
master reset
VDD
16
supply voltage
6. Functional description
Table 3. Function table
H = HIGH voltage level; L = LOW voltage level; ↑ = LOW-to-HIGH clock transition; ↓ HIGH-to-LOW clock transition.
Output
Input
RS
MR
L
no change
L
count
X
H
L
7. Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
VDD
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
II/O
input/output current
IDD
supply current
Tstg
storage temperature
Tamb
ambient temperature
Ptot
total power dissipation
Tamb -40 °C to +85 °C
P
power dissipation
per output
[1]
Conditions
VI < -0.5 V or VI > VDD + 0.5 V
VO < -0.5 V or VO > VDD + 0.5 V
[1]
Min
Max
Unit
-0.5
+18
V
±10
mA
-0.5
VDD + 0.5
±10
mA
±10
mA
50
mA
-65
+150
°C
-40
+85
°C
500
mW
100
mW
V
For SOT109-1 (SO16) package: Ptot derates linearly with 12.4 mW/K above 110 °C.
For SOT403-1 (TSSOP16) package: Ptot derates linearly with 8.5 mW/K above 91 °C.
HEF4060B
Product data sheet
3 / 14
HEF4060B
Nexperia
8. Recommended operating conditions
Table 5. Recommended operating conditions
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VDD
supply voltage
3
15
V
VI
input voltage
VDD
V
Tamb
ambient temperature
in free air
-40
+85
°C
Δt/ΔV
input transition rise and fall
rate
input MR
VDD = 5 V
3.75
µs/V
VDD = 10 V
0.5
µs/V
VDD = 15 V
0.08
µs/V
9. Static characteristics
Table 6. Static characteristics
VSS = 0 V; VI = VSS or VDD unless otherwise specified.
Symbol Parameter
VIH
VIL
VOH
VOL
IOH
IOL
HIGH-level input
voltage
LOW-level input
voltage
HIGH-level output
voltage
|IO| < 1 μA
|IO| < 1 μA
|IO| < 1 μA
VDD
Tamb = -40 °C
Tamb = 25 °C
Tamb = 85 °C
Min
Max
Min
Max
Min
Max
3.5
3.5
3.5
V
10 V
7.0
7.0
7.0
V
15 V
11.0
11.0
11.0
V
5V
1.5
1.5
1.5
V
10 V
3.0
3.0
3.0
V
15 V
4.0
4.0
4.0
V
5V
4.95
4.95
4.95
V
10 V
9.95
9.95
9.95
V
15 V
14.95
14.95
14.95
V
5V
0.05
0.05
0.05
V
10 V
0.05
0.05
0.05
V
5V
Unit
LOW-level output
voltage
|IO| < 1 μA
15 V
0.05
0.05
0.05
V
HIGH-level output
current
VO = 2.5 V
5V
-1.7
-1.4
-1.1
mA
VO = 4.6 V
5V
-0.52
-0.44
-0.36
mA
VO = 9.5 V
10 V
-1.3
-1.1
-0.9
mA
VO = 13.5 V
15 V
-3.6
-3.0
-2.4
mA
VO = 0.4 V
5V
0.52
0.44
0.36
mA
VO = 0.5 V
10 V
1.3
1.1
0.9
mA
VO = 1.5 V
15 V
3.6
3.0
2.4
mA
15 V
±0.3
±0.3
±1.0
µA
5V
µA
10 V
40
40
300
µA
15 V
80
80
600
µA
7.5
pF
LOW-level output
current
II
input leakage current
IDD
supply current
CI
Conditions
input capacitance
HEF4060B
Product data sheet
IO = 0 A
4 / 14
HEF4060B
Nexperia
10. Dynamic characteristics
Table 7. Dynamic characteristics
Tamb = 25 °C; VSS = 0 V; CL = 50 pF; tr = tf ≤ 20 ns; unless otherwise specified.
Symbol
Parameter
Conditions
VDD
tpd
propagation delay
RS → Q3;
see Fig. 5
5V
transition time
tW
pulse width
trec
recovery time
fmax
[1]
[2]
[3]
[2] 183 ns + (0.55 ns/pF) CL
Min
Typ
Max
Unit
210
420
ns
10 V
69 ns + (0.23 ns/pF) CL
80
160
ns
15 V
42 ns + (0.16 ns/pF) CL
50
100
ns
5V
25
50
ns
10 V
10
ns
15 V
6
12
ns
MR → Qn;
HIGH to LOW
see Fig. 5
5V
73 ns + (0.55 ns/pF) CL
100
200
ns
10 V
29 ns + (0.23 ns/pF) CL
40
80
ns
15 V
22 ns + (0.16 ns/pF) CL
30
60
ns
see Fig. 5
5V
[3] 10 ns + (1.00 ns/pF) CL
60
120
ns
Qn → Qn + 1;
see Fig. 5
tt
Extrapolation formula[1]
10 V
9 ns + (0.42 ns/pF) CL
30
60
ns
15 V
6 ns + (0.28 ns/pF) CL
ns
minimum width; 5 V
RS HIGH;
10 V
see Fig. 5
15 V
120
60
ns
50
25
ns
30
15
ns
minimum width; 5 V
MR HIGH;
10 V
see Fig. 5
15 V
50
25
ns
30
15
ns
input MR;
see Fig. 5
maximum frequency input RS;
see Fig. 5
ns
5V
160
80
ns
10 V
80
40
ns
15 V
60
30
ns
5V
4
8
MHz
10 V
10
MHz
15 V
15
30
MHz
The typical values of the propagation delay and transition times are calculated from the extrapolation formulas shown (CL in pF).
tpd is the same as tPHL and tPLH.
tt is the same as tTHL and tTLH.
HEF4060B
Product data sheet
5 / 14
HEF4060B
Nexperia
Table 8. Power dissipation
Dynamic power dissipation PD and total power dissipation Ptot can be calculated from the formulas shown. Tamb = 25 °C.
Symbol Parameter
Conditions
VDD
Typical formula for PD and Ptot (μW)[1]
PD
per device
5V
PD = 700 x fi + ∑(fo x CL) x VDD
dynamic power
dissipation
2
2
10 V PD = 3300 x fi + ∑(fo x CL) x VDD
2
15 V PD = 8900 x fi + ∑(fo x CL) x VDD
Ptot
[1]
total power
dissipation
5V
when using
the on-chip
oscillator
2
2
Ptot = 700 x fosc + ∑(fo x CL) x VDD + 2 x Ct x VDD x fosc + 690 x VDD
2
2
2
2
10 V Ptot = 3300 x fosc + ∑(fo x CL) x VDD + 2 x Ct x VDD x fosc + 6900 x VDD
15 V Ptot = 8900 x fosc + ∑(fo x CL) x VDD + 2 x Ct x VDD x fosc + 22000 x VDD
Where:
fi = input frequency in MHz; fo = output frequency in MHz;
CL = output load capacitance in pF;
VDD = supply voltage in V;
∑(fo x CL) = sum of the outputs;
Ct = timing capacitance (pF);
fosc = oscillator frequency (MHz).
10.1. Waveforms and test circuit
tr
MR input
tf
10 %
90 %
VM
tW
1/fmax
trec
VM
RS input
tPHL
Qn output
tPLH
VM
tW
tPHL
90 %
10 %
tt
tt
001aaj472
Measurement points are given in Table 9.
Fig. 5.
Waveforms showing propagation delays for MR to Qn and CP to Q0, minimum MR, and CP pulse widths
Table 9. Measurement points
Supply voltage
Input
Output
VDD
VM
VM
5 V to 15 V
0.5VDD
0.5VDD
HEF4060B
Product data sheet
6 / 14
HEF4060B
Nexperia
VDD
VI
G
VO
DUT
CL
RT
001aag182
Test data is given in Table 10.
Definitions for test circuit:
DUT = Device Under Test;
CL = load capacitance including jig and probe capacitance;
RT = termination resistance should be equal to the output impedance Zo of the pulse generator.
Fig. 6.
Test circuit for measuring switching times
Table 10. Measurement point and test data
Supply voltage
Input
Load
VDD
VI
tr, tf
CL
5 V to 15 V
VSS or VDD
≤ 20 ns
50 pF
11. RC oscillator
HEF4060B
MR (from logic)
11 RS
C2
R2
REXT
CEXT
10
9
Rt
Ct
001aae655
Typical formula for oscillator frequency:
Fig. 7.
External component connection for RC oscillator
11.1. Timing component limitations
The oscillator frequency is mainly determined by Rt x Ct, provided Rt
很抱歉,暂时无法提供与“HEF4060BT,652”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+3.59640
- 10+2.84040
- 50+2.50560
- 100+2.10600
- 500+1.92240
- 1000+1.81440
