74HCT6323AD,112
74HCT6323AD,112
    NEXPERIA(安世)
    SOIC8_150MIL
    带振荡器的可编程纹波计数器;3-state
74HCT6323AD,112 数据手册
74HC6323A; 74HCT6323A Programmable ripple counter with oscillator; 3-state Rev. 4 — 9 July 2018 1 Product data sheet General description The 74HC6323A; 74HCT6323A is an oscillator designed for quartz crystal combined with a programmable 3-state counter, a 3-state output buffer and an overriding asynchronous master reset (MR). With the two select inputs S1 and S2 the counter can be switched in the divide-by-1, 2, 4 or 8 mode. If left floating the clock is divided by 8. The oscillator is designed to operate either in the fundamental or third overtone mode depending on the crystal and external components applied. On-chip capacitors minimize external component count for third overtone crystal applications. The oscillator may be replaced by an external clock signal at input X1. In this event the other oscillator pin (X2) must be floating. The counter advances on the negative-going transition of X1. A LOW level on MR resets the counter, stops the oscillator and sets the output buffer in the 3-state condition. MR can be left floating since an internal pull-up resistor will make the MR inactive. The X1 input has CMOS input switching levels and may be driven by a TTL output using a pull-up resistor connected to VCC. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. 2 Features and benefits • • • • • • • Programmable 3-stage ripple counter Suitable for over-tone crystal application up to 50 MHz (VCC = 5 V ± 10%) 3-state output buffer Two internal capacitors Recommended operating range for use with third overtone crystals 3 to 6 V Oscillator stop function (MR) Input levels: – For 74HC6323: CMOS level – For 74HCT6323: TTL level • ESD protection: – HBM JESD22-A114-A exceeds 2000 V – MM JESD22-A115-A exceeds 200 V • Specified from -40 °C to +85 °C and from -40 °C to +125 °C 74HC6323A; 74HCT6323A Nexperia Programmable ripple counter with oscillator; 3-state 3 Applications • • • • • • 4 Control counters Timers Frequency dividers Time-delay circuits CIO (Compact Integrated Oscillator) Third-overtone crystal operation Ordering information Table 1. Ordering information Type number 74HC6323AD Package Temperature range Name Description Version -40 °C to +125 °C SO8 plastic small outline package; 8 leads; body width 3.9 mm SOT96-1 74HCT6323AD 5 Functional diagram 6 7 5 X2 X1 CP MR CD 3 S1 2 S2 OUT 1 aaa-028595 Figure 1. IEC logic symbol 6 X2 7 X1 5 MR CP CD 3 - STAGE BINARY COUNTER AND DECODER S1 3 S2 2 OUT 1 aaa-028596 Figure 2. Functional diagram 74HC_HCT6323A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 9 July 2018 © Nexperia B.V. 2018. All rights reserved. 2 / 22 74HC6323A; 74HCT6323A Nexperia Programmable ripple counter with oscillator; 3-state X2 X1 7 pF (1) 7 pF CP Q CP Q CP Q FF FF FF R R R (1) VCC VCC DECODER VCC VCC VCC S1 MR OUT S2 aaa-028597 (1) Internal capacitors typical 7 pF each. Including stray capacitors on pin X1 and X2, total capacitance will be typical 12 pF per pin. Figure 3. Logic diagram 6 Pinning information 6.1 Pinning 74HC6323A 74HCT6323A OUT 1 8 VCC S2 2 7 X1 S1 3 6 X2 GND 4 5 MR aaa-028594 Figure 4. Pin configuration SOT96-1 (SO8) 6.2 Pin description Table 2. Pin description Symbol Pin Description OUT 1 counter output S1, S2 3, 2 mode select inputs for divide by 1, 2, 4 or 8 GND 4 ground (0 V) MR 5 master reset input (active LOW) X2 6 oscillator pin X1 7 clock input /oscillator pin VCC 8 supply voltage 74HC_HCT6323A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 9 July 2018 © Nexperia B.V. 2018. All rights reserved. 3 / 22 74HC6323A; 74HCT6323A Nexperia Programmable ripple counter with oscillator; 3-state 7 Functional description Table 3.  Inputs Outputs S1 S2 OUT 0 0 fi 0 1 fi/2 1 0 fi/4 1 1 fi/8 8 Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Max Unit -0.5 +7 V VCC supply voltage IIK input clamping current VI < -0.5 V or VI > VCC + 0.5 V - ±20 mA IOK output clamping current VO < -0.5 V or VO > VCC + 0.5 V - ±20 mA IO output current OUT output; -0.5 V < VO < VCC + 0.5 V - ±35 mA ICC supply current OUT output - 70 mA IGND ground current OUT output -70 - mA Tstg storage temperature -65 +150 °C - 500 mW Ptot total power dissipation [1] Tamb = -40 °C to +125 °C [1] Ptot derates linearly with 8 mW/K above 70 °C. 9 Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V) Symbol Parameter Conditions 74HC6323A 74HCT6323A Unit Min Typ Max Min Typ Max 2.0 5.0 6.0 4.5 5.0 5.5 V VCC supply voltage VI input voltage 0 - VCC 0 - VCC V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature -40 - +125 -40 - +125 °C Δt/ΔV input transition rise and fall rate VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V VCC = 6.0 V - - 83 - - - ns/V 74HC_HCT6323A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 9 July 2018 © Nexperia B.V. 2018. All rights reserved. 4 / 22 74HC6323A; 74HCT6323A Nexperia Programmable ripple counter with oscillator; 3-state 10 Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 1.5 1.2 - 1.5 - 1.5 - V VCC = 4.5 V 3.15 2.4 - 3.15 - 3.15 - V VCC = 6.0 V 4.2 3.2 - 4.2 - 4.2 - V VCC = 2.0 V - 0.8 0.5 - 0.5 - 0.5 V VCC = 4.5 V - 2.1 1.35 - 1.35 - 1.35 V VCC = 6.0 V - 2.8 1.8 - 1.8 - 1.8 V VCC = 4.5 V; X1 = GND; MR = VCC; IO = -2.6 mA 3.98 - - 3.84 - 3.7 - V VCC = 6.0 V; X1 = GND; MR = VCC; IO = -3.3 mA 5.48 - - 5.34 - 5.2 - V VCC = 4.5 V; X1 = VCC; MR = GND; IO = -2.6 mA 3.98 - - 3.84 - 3.7 - V VCC = 6.0 V; X1 = VCC; MR = GND; IO = -3.3 mA 5.48 - - 5.34 - 5.2 - V VCC = 2.0 V; X1 = GND; MR = VCC; IO = -20 µA 1.9 2.0 - 1.9 - 1.9 - V VCC = 4.5 V; X1 = GND; MR = VCC; IO = -20 µA 4.4 4.5 - 4.4 - 4.4 - V VCC = 6.0 V; X1 = GND; MR = VCC; IO = -20 µA 5.9 6.0 - 5.9 - 5.9 - V VCC = 2.0 V; X1 = VCC; MR = GND; IO = -20 µA 1.9 2.0 - 1.9 - 1.9 - V VCC = 4.5 V; X1 = VCC; MR = GND; IO = -20 µA 4.4 4.5 - 4.4 - 4.4 - V VCC = 6.0 V; X1 = VCC; MR = GND; IO = -20 µA 5.9 6.0 - 5.9 - 5.9 - V 74HC6323A VIH VIL VOH HIGH-level input voltage LOW-level input voltage HIGH-level output voltage 74HC_HCT6323A Product data sheet MR, X1, S1, S2 input MR, X1, S1, S2 input X2 output All information provided in this document is subject to legal disclaimers. Rev. 4 — 9 July 2018 © Nexperia B.V. 2018. All rights reserved. 5 / 22 74HC6323A; 74HCT6323A Nexperia Programmable ripple counter with oscillator; 3-state Symbol Parameter VOH VOL VOL HIGH-level output voltage LOW level output voltage LOW level output voltage Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max VCC = 2.0 V; IO = -20 µA 1.9 2.0 - 1.9 - 1.9 - V VCC = 4.5 V; IO = -20 µA 4.4 4.5 - 4.4 - 4.4 - V VCC = 6.0 V; IO = -20 µA 5.9 6.0 - 5.9 - 5.9 - V VCC = 4.5 V; IO = -6 mA 3.98 - - 3.84 - 3.7 - V VCC = 6.0 V; IO = -7.8 mA 5.48 - - 5.34 - 5.2 - V VCC = 4.5 V; X1 = VCC; MR = VCC; IO = 2.6 mA - - 0.26 - 0.33 - 0.4 V VCC = 6.0 V; X1 = VCC; MR = VCC; IO = 3.3 mA - - 0.26 - 0.33 - 0.4 V VCC = 2.0 V; X1 = VCC; MR = VCC; IO = 20 µA - 0.0 0.1 - 0.1 - 0.1 V VCC = 4.5 V; X1 = VCC; MR = VCC; IO = 20 µA - 0.0 0.1 - 0.1 - 0.1 V VCC = 6.0 V; X1 = VCC; MR = VCC; IO = 20 µA - 0.0 0.1 - 0.1 - 0.1 V VCC = 2.0 V; IO = 20 µA - 0.0 0.1 - 0.1 - 0.1 V VCC = 4.5 V; IO = 20 µA - 0.0 0.1 - 0.1 - 0.1 V VCC = 6.0 V; IO = 20 µA - 0.0 0.1 - 0.1 - 0.1 V VCC = 4.5 V; IO = 6 mA - - 0.26 - 0.33 - 0.4 V VCC = 6.0 V; IO = 7.8 mA - - 0.26 - 0.33 - 0.4 V OUT output; VI = VIH or VIL X2 output OUT output; VI = VIH or VIL II input leakage current X1 input; VCC = 6.0 V; MR = VCC; S1 = VCC; S2 = VCC - - ±0.1 - ±1.0 - ±1.0 µA Ipu pull-up current MR, S1 and S2 inputs; VCC = 6.0 V; VI = GND; see Figure 13 and Figure 14. -5 -30 -100 - - - - µA ICC supply current VCC = 6.0 V; VI = VCC or GND; IO = 0 A - - 8 - 80 - 160 µA CI input capacitance MR, S1 and S2 inputs - 3.5 - - - - - pF 74HC_HCT6323A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 9 July 2018 © Nexperia B.V. 2018. All rights reserved. 6 / 22 74HC6323A; 74HCT6323A Nexperia Programmable ripple counter with oscillator; 3-state Symbol Parameter Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max 2.0 - - 2.0 - 2.0 - V VCC = 4.5 V 3.15 - - 3.15 - 3.15 - V VCC = 5.5 V 3.85 - - 3.85 - 3.85 - V - - 0.8 - 0.8 - 0.8 V VCC = 4.5 V - - 1.35 - 1.35 - 1.35 V VCC = 5.5 V - - 1.65 - 1.65 - 1.65 V X1 = GND; MR = VCC; IO = -2.6 mA 3.98 - - 3.84 - 3.7 - V X1 = VCC; MR = GND; IO = -2.6 mA 3.98 - - 3.84 - 3.7 - V X1 = GND; MR = VCC; IO = -20 µA 4.4 4.5 - 4.4 - 4.4 - V X1 = VCC; MR = GND; IO = -20 µA 4.4 4.5 - 4.4 - 4.4 - V IO = -20 µA 4.4 4.5 - 4.4 - 4.4 - V IO = -6 mA 3.98 - - 3.84 - 3.7 - V IO = 2.6 mA - - 0.26 - 0.33 - 0.4 V IO = 20 µA - 0.0 0.1 - 0.1 - 0.1 V IO = 20 µA - 0.0 0.1 - 0.1 - 0.1 V IO = 6 mA - - 0.26 - 0.33 - 0.4 V 74HCT6323A VIH VIL VOH HIGH-level input voltage LOW-level input voltage HIGH-level output voltage MR, S1 and S2 inputs; VCC = 4.5 V to 5.5 V X1 input MR, S1 and S2 inputs; VCC = 4.5 V to 5.5 V X1 input X2 output; VCC = 4.5 V OUT output; VCC = 4.5 V; VI = VIH or VIL VOL LOW-level output voltage X2 output; VCC = 4.5 V; X1 = VCC; MR = VCC OUT output; VCC = 4.5 V; VI = VIH or VIL II input leakage current X1 input; VCC = 5.5 V; MR = VCC; S1 = VCC; S2 = VCC - - ±0.1 - ±1.0 - ±1.0 µA Ipu pull-up current MR, S1 and S2 inputs; VCC = 5.5 V; VI = GND; see Figure 13 and Figure 14. -5 -25 -100 - - - - µA 74HC_HCT6323A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 9 July 2018 © Nexperia B.V. 2018. All rights reserved. 7 / 22 74HC6323A; 74HCT6323A Nexperia Programmable ripple counter with oscillator; 3-state Symbol Parameter Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Min Typ Max Min Max Min Max Unit ICC supply current VCC = 5.5 V; VI = VCC or GND; IO = 0 A - - 8 - 80 - 160 µA ΔICC additional supply current MR, S1 and S2 inputs; VCC = 5.5 V; VI = VCC or GND; other inputs at VCC or GND; IO = 0 A - 40 144 - 180 - 196 µA CI input capacitance MR, S1 and S2 inputs - 3.5 - - - - - pF 74HC_HCT6323A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 9 July 2018 © Nexperia B.V. 2018. All rights reserved. 8 / 22 74HC6323A; 74HCT6323A Nexperia Programmable ripple counter with oscillator; 3-state 11 Dynamic characteristics Table 7. Dynamic characteristics GND = 0 V; CL = 50 pF unless otherwise specified; for test circuit see Figure 8. Symbol Parameter Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max VCC = 2.0 V - 61 185 - 230 - 275 ns VCC = 4.5 V - 22 37 - 46 - 55 ns VCC = 5.0 V; CL = 15 pF - 17 - - - - - ns VCC = 6.0 V - 19 31 - 39 - 47 ns VCC = 2.0 V - 74 235 - 290 - 350 ns VCC = 4.5 V - 27 47 - 58 - 70 ns VCC = 6.0 V - 23 40 - 49 - 60 ns VCC = 2.0 V - 91 285 - 355 - 425 ns VCC = 4.5 V - 33 57 - 71 - 85 ns VCC = 6.0 V - 28 48 - 60 - 72 ns VCC = 2.0 V - 105 335 - 415 - 500 ns VCC = 4.5 V - 38 67 - 83 - 100 ns VCC = 6.0 V - 32 57 - 71 - 85 ns - 36 150 - 185 - 225 ns - 13 30 - 37 - 45 ns - 11 26 - 31 - 38 ns - 61 200 - 250 - 300 ns - 22 40 - 50 - 60 ns - 19 34 - 43 - 51 ns VCC = 2.0 V - 75 150 - 185 - 225 ns VCC = 4.5 V - 15 30 - 37 - 45 ns VCC = 6.0 V - 13 26 - 31 - 38 ns 74HC6323A tpd propagation X1 to OUT divide by 1; S1 = GND; S2 = GND; see Figure 5 delay [1] X1 to OUT divide by 2; S1 = GND; S2 = VCC; see Figure 5 X1 to OUT divide by 4; S1 = VCC; S2 = GND; see Figure 5 X1 to OUT divide by 8; S1 = VCC; S2 = VCC; see Figure 5 tPZL OFF-state MR to OUT; see Figure 6 to LOW VCC = 2.0 V propagation delay VCC = 4.5 V VCC = 6.0 V tPZH OFF-state MR to OUT; see Figure 6 to HIGH VCC = 2.0 V propagation delay VCC = 4.5 V [2] VCC = 6.0 V tdis disable time MR to OUT; see Figure 6 74HC_HCT6323A Product data sheet [3] All information provided in this document is subject to legal disclaimers. Rev. 4 — 9 July 2018 © Nexperia B.V. 2018. All rights reserved. 9 / 22 74HC6323A; 74HCT6323A Nexperia Programmable ripple counter with oscillator; 3-state Symbol Parameter tt tW transition time pulse width Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max VCC = 2.0 V - 14 60 - 75 - 90 ns VCC = 4.5 V - 5 12 - 15 - 19 ns VCC = 6.0 V - 4 10 - 13 - 15 ns VCC = 2.0 V 50 17 - 60 - 75 - ns VCC = 4.5 V 10 6 - 12 - 15 - ns VCC = 6.0 V 9 5 - 10 - 13 - ns VCC = 2.0 V 80 22 - 100 - 120 - ns VCC = 4.5 V 16 8 - 20 - 24 - ns VCC = 6.0 V 14 7 - 17 - 20 - ns VCC = 2.0 V 100 19 - 125 - 150 - ns VCC = 4.5 V 20 7 - 25 - 30 - ns VCC = 6.0 V 17 6 - 21 - 26 - ns VCC = 2.0 V 10 17 - 8 - 6.6 - MHz VCC = 4.5 V 50 85 - 40 - 33 - MHz - 90 - - - - - MHz 59 100 - 47 - 39 - MHz divide by 1; S1 = GND; S2 = GND - 54 - - - - - pF divide by 2; S1 = GND; S2 = VCC - 42 - - - - - pF divide by 4; S1 = VCC; S2 = GND - 36 - - - - - pF divide by 8; S1 = VCC; S2 = VCC - 33 - - - - - pF [4] OUT; see Figure 5 X1 HIGH or LOW; see Figure 5 MR LOW; see Figure 7 trec fmax recovery time maximum frequency MR to X1; see Figure 7 X1; see Figure 5 VCC = 5.0 V; CL = 15 pF VCC = 6.0 V CPD power An external clock is applied to X1 dissipation with: tr = tf ≤ 6 ns, VI = GND to VCC, capacitance MR = HIGH 74HC_HCT6323A Product data sheet [5] All information provided in this document is subject to legal disclaimers. Rev. 4 — 9 July 2018 © Nexperia B.V. 2018. All rights reserved. 10 / 22 74HC6323A; 74HCT6323A Nexperia Programmable ripple counter with oscillator; 3-state Symbol Parameter Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max VCC = 4..5 V - 24 40 - 50 - 60 ns VCC = 5.0 V; CL = 15 pF - 17 - - - - - ns - 29 50 - 62 - 75 ns - 35 60 - 75 - 90 ns - 40 70 - 87 - 105 ns - 16 30 - 37 - 45 ns - 22 38 - 47 - 57 ns - 21 35 - 43 - 52 ns - 5 12 - 15 - 19 ns 10 6 - 12 - 15 - ns 16 8 - 20 - 24 - ns 24 12 - 30 - 36 - ns 50 85 - 40 - 33 - MHz - 90 - - - - - MHz 74HCT6323A tpd propagation X1 to OUT divide by 1; S1 = GND; S2 = GND; see Figure 5 delay [1] X1 to OUT divide by 2; S1 = GND; S2 = VCC; see Figure 5 VCC = 4.5 V X1 to OUT divide by 4; S1 = VCC; S2 = GND; see Figure 5 VCC = 4.5 V X1 to OUT divide by 8; S1 = VCC; S2 = VCC; see Figure 5 VCC = 4.5 V tPZL tPZH tdis OFF-state MR to OUT; see Figure 6 to LOW VCC = 4.5 V propagation delay OFF-state MR to OUT; see Figure 6 to HIGH VCC = 4.5 V propagation delay [2] disable time MR to OUT; see Figure 6 [3] VCC = 4.5 V tt tW [4] transition time OUT; see Figure 5 pulse width X1 HIGH or LOW; see Figure 5 VCC = 4.5 V VCC = 4.5 V MR LOW; see Figure 7 VCC = 4.5 V trec fmax recovery time MR to X1; see Figure 7 maximum frequency X1; see Figure 5 VCC = 4.5 V VCC = 4.5 V VCC = 5.0 V; CL = 15 pF 74HC_HCT6323A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 9 July 2018 © Nexperia B.V. 2018. All rights reserved. 11 / 22 74HC6323A; 74HCT6323A Nexperia Programmable ripple counter with oscillator; 3-state Symbol Parameter CPD [1] [2] [3] [4] [5] Conditions 25 °C -40 °C to +85 °C -40 °C to +125 °C Unit Min Typ Max Min Max Min Max divide by 1; S1 = GND; S2 = GND - 54 - - - - - pF divide by 2; S1 = GND; S2 = VCC - 42 - - - - - pF divide by 4; S1 = VCC; S2 = GND - 36 - - - - - pF divide by 8; S1 = VCC; S2 = VCC - 33 - - - - - pF [5] power An external clock is applied to X1 dissipation with: tr = tf ≤ 6 ns, Vi = GND to VCC, capacitance MR = HIGH tpd is the same as tPHL and tPLH. tPZH only applicable in the divide-by-1 mode and X1 must be HIGH. tdis is the same as tPLZ and tPHZ. tt is the same as tTHL and tTLH. CPD is used to determine the dynamic power dissipation (PD in μW): 2 2 PD = CPD × VCC × fi + (CL × VCC × fo) + (Ipull-up × VCC) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; Ipull-up = pull-up currents in µA. Ipull-up is the summation of -II (μA) of S1 and S2 inputs at the LOW state. 11.1 Waveforms and test circuit 1/f max VI VM X1 INPUT GND tW t PHL VOH OUT OUTPUT VOL t PLH 90 % VM 10 % t THL t TLH aaa-028600 Measurement points are given in Table 8 VOL and VOH are typical voltage output levels that occur with the output load. Figure 5. The clock (X1) to output (OUT) propagation delays, the clock pulse width, the output transition times and the maximum clock frequency. 74HC_HCT6323A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 9 July 2018 © Nexperia B.V. 2018. All rights reserved. 12 / 22 74HC6323A; 74HCT6323A Nexperia Programmable ripple counter with oscillator; 3-state VI MR INPUT VM GND t PLZ VCC OUTPUT LOW - to - OFF OFF - to - LOW VOL t PZL VM t PHZ VOH VX t PZH VY OUTPUT HIGH - to - OFF OFF - to - HIGH GND VM outputs enabled outputs disabled outputs enabled aaa-028601 Measurement points are given in Table 8 VOL and VOH are typical voltage output levels that occur with the output load. Figure 6. The input MR to output OUT, 3-state enable and disable times tW VI VM MR INPUT GND t rec VI VM X1 INPUT GND aaa-028602 Measurement points are given in Table 8 VOL and VOH are typical voltage output levels that occur with the output load. Figure 7. The MR minimum pulse width and MR to X1 recovery time. Table 8. Measurement points Type Input Output VI VM VM VX VY 74HC6323A GND to VCC 0.5 x VCC 0.5 x VCC 0.1 x VCC 0.9 x VCC 74HCT6323A GND to 3 V 1.3 V 1.3 V 0.1 x VCC 0.9 x VCC 74HC_HCT6323A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 9 July 2018 © Nexperia B.V. 2018. All rights reserved. 13 / 22 74HC6323A; 74HCT6323A Nexperia Programmable ripple counter with oscillator; 3-state VI negative pulse VM VI GND VM 10 % GND positive pulse tW 90 % tf tr tr tf 90 % VM VM 10 % tW VCC G VI DUT VO RT CL 001aah768 Test data is given in Table 9. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. Figure 8. Test circuit for measuring switching times Table 9. Test data Type Input Load VI tr, tf CL 74HC6323A GND to VCC 6 ns 15 pF, 50 pF 74HCT6323A GND to 3 V 6 ns 15 pF, 50 pF 12 Application information 12.1 Typical Crystal Oscillator In Figure 9, R2 is the power limiting resistor. For starting and maintaining oscillation a minimum transconductance is necessary, so R2 should not be too large. A practical value for R2 is 2.2 kΩ. The oscillator has been designed to operate over a wide frequency spectrum, for quartz crystals operating in the fundamental mode and in the overtone mode. The circuit is a Pierce type oscillator and requires a minimum of external components. There are two on-chip capacitors, X1 and X2, of approximately 7 pF. Together with the stray and input capacitance the value becomes 12 pF for 8-pin SO packages. These values are convenient and make it possible to run the oscillator in the third overtone without external capacitors applied. If a certain frequency is chosen, the IC parameters, as forward transconductance, and the crystal parameters such as the motional resistances R1 (fundamental), R3 (third overtone) and R5 (fifth overtone), are of paramount importance. Also the values of the external components as Rs (series resistance) and the crystal load capacitances play an important role. Especially in overtone mode oscillations, Rb (bias resistance) and the load capacitance values are very important. 74HC_HCT6323A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 9 July 2018 © Nexperia B.V. 2018. All rights reserved. 14 / 22 74HC6323A; 74HCT6323A Nexperia Programmable ripple counter with oscillator; 3-state 12.2 Considerations for Fundamental Oscillator: In the fundamental oscillator mode, the Rb has only the function of biasing the inverter stage, so that it operates as an amplifier with a phase shift of approximately 180°. The value must be high, i.e. 100 kΩ up to 10 MΩ. The load capacitors C1 and C2, must have a value that is suitable for the crystal being used. The crystal is designed for a certain frequency having a specific load capacitance. C1 can be used to trim the oscillation frequency. The series resistance reduces the total loop gain. One function of it is therefore to reduce the power dissipation in the crystal. Rs also suppresses overtone oscillations and introduces a phase shift over a broad frequency range. This is of less concern provided Rs is not too high a value. Note: A combination of a small load capacitor value and a small series resistance, may cause a third overtone oscillation. 12.3 Considerations for Third-overtone Oscillator: In the overtone configuration, series resistance is no longer applied. This is essential otherwise the gain for third overtone can be too small for oscillation. A simple solution to suppress the fundamental oscillation, is to spoil the crystal fundamental activity. By dramatically reducing the value of the bias resistor of the inverting stage, and applying small load capacitors, it is possible to have an insufficient phase in the total loop for fundamental oscillation. However the phase for third overtone is good. It can be explained by the Rb × Cl time constant. During oscillation the crystal with the load capacitors cause a phase shift of 180°. Because Rb is parallel with the crystal (no Rs), Rb spoils the phase for fundamental. Rb × Cl must be of a value, that it is not spoiling the phase for third overtone too much. Because third overtone is a 3 times higher frequency than the fundamental, the Rb × Cl cannot 'maintain' the higher third overtone frequency, which results in a less spoiled overtone phase. 74HC_HCT6323A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 9 July 2018 © Nexperia B.V. 2018. All rights reserved. 15 / 22 74HC6323A; 74HCT6323A Nexperia Programmable ripple counter with oscillator; 3-state MR (from logic) 7 MR (from logic) X1 X1 7 X2 Rbias 100 kΩ to 1 MΩ C1 22 pF to 37 pF X2 6 6 Rbias 3 kΩ R2 2.2 kΩ C1 1 pF to 10 pF (optional) C2 100 pF aaa-028607 aaa-028606 Applicable for third overtone crystals (lower damping resistance at the third harmonic frequency) at typical 50 MHz. For lower frequencies extra load capacitors must CL at which a crystal is specified (or adjusted) equals for this be supplied, or increase bias resistor. application C1 x C2/(C1 + C2) Figure 10. Typical set-up for a crystal oscillator Above 5 MHz replace R2 by a capacitor of half the value of C2. Figure 9. Typical setup for a crystal oscillator operating operating in the third overtone mode without the use of in the fundamental mode (1 MHz to 25 MHz) an inductor Table 10. Typical application values Fundamental mode Third overtone mode f (MHz) R2 (kΩ) 1 4.7 47 to 68 10 2.2 47 to 68 25 1 74HC_HCT6323A Product data sheet C1 (pF) 33 C2 (pF) f (MHz) Rbias (kΩ) C1 (pF) 50 3.0 4.7 33 All information provided in this document is subject to legal disclaimers. Rev. 4 — 9 July 2018 © Nexperia B.V. 2018. All rights reserved. 16 / 22 74HC6323A; 74HCT6323A Nexperia Programmable ripple counter with oscillator; 3-state aaa-028599 24 gfs (mA/V) 20 Rbias 16 560 kΩ VCC 12 0.47 µF VI (fi = 1 kHz) 100 µF input output 8 A IO 4 GND aaa-028598 0 gfs = ΔIO/ΔVI at vO is constant (see Figure 12) and MR = HIGH. 0 1 2 3 4 5 6 VCC (V) gfs as a function of the supply voltage VCC at Tamb = 25 °C. Figure 11. Test set-up for measuring forward transconductance Figure 12. Typical forward transconductance aaa-028604 40 -II (µA) aaa-028605 50 (3) -Il (µA) 30 40 20 (2) 30 10 20 (1) 0 0 (1) 10 1 2 3 4 5 VI (V) 6 0 (1) VCC = 2 V (2) VCC = 4.3 V (3) VCC = 6 V (1) VI = 0 V Figure 13. Typical input pull-up current as a function of the input voltage Figure 14. Typical input pull-up current as a function of the supply voltage (VCC) 1 2 3 4 5 VCC (V) 6 74HC6323A 74HCT6323A 5 MR aaa-028603 The input pull-up current is used to create a power-on delay time at MR. Figure 15. Power-on reset 74HC_HCT6323A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 9 July 2018 © Nexperia B.V. 2018. All rights reserved. 17 / 22 74HC6323A; 74HCT6323A Nexperia Programmable ripple counter with oscillator; 3-state 13 Package outline SO8: plastic small outline package; 8 leads; body width 3.9 mm SOT96-1 D E A X c y HE v M A Z 5 8 A2 Q A (A 3) A1 pin 1 index θ Lp 1 L 4 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 5.0 4.8 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 0.01 0.019 0.0100 0.20 0.014 0.0075 0.19 0.16 0.15 inches 0.010 0.057 0.069 0.004 0.049 0.05 0.244 0.039 0.028 0.041 0.228 0.016 0.024 0.01 0.01 0.028 0.004 0.012 θ o 8 o 0 Notes 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. 2. Plastic or metal protrusions of 0.25 mm (0.01 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT96-1 076E03 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 Figure 16. Package outline SOT96-1 (SO8) 74HC_HCT6323A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 9 July 2018 © Nexperia B.V. 2018. All rights reserved. 18 / 22 74HC6323A; 74HCT6323A Nexperia Programmable ripple counter with oscillator; 3-state 14 Abbreviations Table 11. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MM Machine Model TTL Transistor-Transistor Logic 15 Revision history Table 12. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT6323A v.4 20180709 Product data sheet - 74HC_HCT6323A v.3 Modifications: • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. • Legal texts have been adapted to the new company name where appropriate. 74HC_HCT6323A v.3 19930901 Product specification - 74HC_HCT6323A v.2 74HC_HCT6323A v.2 19901201 Product specification - 74HC_HCT6323A v.1 74HC_HCT6323A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 4 — 9 July 2018 © Nexperia B.V. 2018. All rights reserved. 19 / 22 74HC6323A; 74HCT6323A Nexperia Programmable ripple counter with oscillator; 3-state 16 Legal information 16.1 Data sheet status Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 16.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 16.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia's aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical 74HC_HCT6323A Product data sheet systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. All information provided in this document is subject to legal disclaimers. Rev. 4 — 9 July 2018 © Nexperia B.V. 2018. All rights reserved. 20 / 22 74HC6323A; 74HCT6323A Nexperia Programmable ripple counter with oscillator; 3-state Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia's warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia's specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer 74HC_HCT6323A Product data sheet design and use of the product for automotive applications beyond Nexperia's standard warranty and Nexperia's product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 16.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 4 — 9 July 2018 © Nexperia B.V. 2018. All rights reserved. 21 / 22 Nexperia 74HC6323A; 74HCT6323A Programmable ripple counter with oscillator; 3-state Contents 1 2 3 4 5 6 6.1 6.2 7 8 9 10 11 11.1 12 12.1 12.2 12.3 13 14 15 16 General description ............................................ 1 Features and benefits .........................................1 Applications .........................................................2 Ordering information .......................................... 2 Functional diagram ............................................. 2 Pinning information ............................................ 3 Pinning ............................................................... 3 Pin description ................................................... 3 Functional description ........................................4 Limiting values .................................................... 4 Recommended operating conditions ................ 4 Static characteristics .......................................... 5 Dynamic characteristics .....................................9 Waveforms and test circuit .............................. 12 Application information .................................... 14 Typical Crystal Oscillator ................................. 14 Considerations for Fundamental Oscillator: ..... 15 Considerations for Third-overtone Oscillator: ... 15 Package outline .................................................18 Abbreviations .................................................... 19 Revision history ................................................ 19 Legal information .............................................. 20 Please be aware that important notices concerning this document and the product(s) described herein, have been included in section 'Legal information'. © Nexperia B.V. 2018. All rights reserved. For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 9 July 2018 Document identifier: 74HC_HCT6323A
74HCT6323AD,112 价格&库存
很抱歉,暂时无法提供与“74HCT6323AD,112”相匹配的价格&库存,您可以联系我们找货
