74VHCT595PW-Q100J
74VHCT595PW-Q100J
    NEXPERIA(安世)
    TSSOP16_5X4.4MM
    带输出锁存器的8位串行输入/串行输出或并行输出移位寄存器 TSSOP16_5X4.4MM 4.5~5.5V
74VHCT595PW-Q100J 数据手册
74VHC595-Q100; 74VHCT595-Q100 8-bit serial-in/serial-out or parallel-out shift register with output latches Rev. 1 — 15 November 2013 Product data sheet 1. General description The 74VHC595-Q100; 74VHCT595-Q100 are high-speed Si-gate CMOS devices and are pin compatible with Low-power Schottky TTL (LSTTL). It is specified in compliance with JEDEC standard No. 7A. The 74VHC595-Q100; 74VHCT595-Q100 are 8-stage serial shift registers with a storage register and 3-state outputs. The shift registers have separate clocks. Data is shifted on the positive-going transitions of the shift register clock input (SHCP). The data in each register is transferred to the storage register on a positive-going transition of the storage register clock input (STCP). If both clocks are connected together, the shift register is always one clock pulse ahead of the storage register. The shift register has a serial input (DS) and a serial standard output (Q7S) for cascading. It is also provided with asynchronous reset (active LOW) for all 8 shift register stages. The storage register has 8 parallel 3-state bus driver outputs. Data in the storage register appears at the output whenever the output enable input (OE) is LOW. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits  Automotive product qualification in accordance with AEC-Q100 (Grade 1)  Specified from 40 C to +85 C and from 40 C to +125 C  Balanced propagation delays  All inputs have Schmitt-trigger action  Inputs accept voltages higher than VCC  Input levels:  The 74VHC595-Q100 operates with CMOS input level  The 74VHCT595-Q100 operates with TTL input level  ESD protection:  MIL-STD-883, method 3015 exceeds 2000 V  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V (C = 200 pf, R = 0 )  Multiple package options 74VHC595-Q100; 74VHCT595-Q100 Nexperia 8-bit serial-in/serial-out or parallel-out shift register with output latches 3. Applications  Serial-to-parallel data conversion  Remote control holding register 4. Ordering information Table 1. Ordering information Type number 74VHC595D-Q100 Package Temperature range Name Description Version 40 C to +125 C SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 40 C to +125 C TSSOP16 plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 40 C to +125 C DHVQFN16 plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; 16 terminals; body 2.5  3.5  0.85 mm SOT763-1 74VHCT595D-Q100 74VHC595PW-Q100 74VHCT595PW-Q100 74VHC595BQ-Q100 74VHCT595BQ-Q100 5. Functional diagram 14 DS 11 SHCP 10 MR 8-STAGE SHIFT REGISTER Q7S 12 STCP 13 OE 9 8-BIT STORAGE REGISTER 3-STATE OUTPUTS Q0 Q1 Q2 Q3 Q4 Q5 Q6 Q7 15 1 Fig 1. 2 3 4 5 6 7 mna554 Functional diagram 74VHC_VHCT595_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 15 November 2013 © Nexperia B.V. 2017. All rights reserved 2 of 21 74VHC595-Q100; 74VHCT595-Q100 Nexperia 8-bit serial-in/serial-out or parallel-out shift register with output latches 13 EN3 12 11 10 SHCP STCP C1/ 1D 2D 3 2 3 4 4 5 Q5 5 6 Q6 6 7 Q7 7 OE 10 9 13 mna552 mna553 Logic symbol Fig 3. STAGE 0 D IEC logic symbol STAGES 1 TO 6 Q D STAGE 7 Q D Q7S Q FF7 FF0 CP 15 1 3 Q3 Q4 DS R 2 Q2 Fig 2. 14 1 Q1 MR SRG8 15 Q0 DS 11 9 Q7S 14 C2 12 CP R R SHCP MR D Q D Q LATCH LATCH CP CP STCP OE mna555 Q0 Fig 4. Q1 Q2 Q3 Q4 Q5 Q6 Q7 Logic diagram 74VHC_VHCT595_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 15 November 2013 © Nexperia B.V. 2017. All rights reserved 3 of 21 74VHC595-Q100; 74VHCT595-Q100 Nexperia 8-bit serial-in/serial-out or parallel-out shift register with output latches 6. Pinning information 6.1 Pinning 4 WHUPLQDO LQGH[DUHD  9+&4 9+&74  9&& 9+&4 9+&74 4   4   '6 4   9&& 4 4   4 4   2( 4   '6 4   67&3 4   2( 4  4   67&3 4  4   6+&3 4   05 *1'    46 46  6+&3  05 *1'  *1'  DDD 7UDQVSDUHQWWRSYLHZ DDD (1) This is not a supply pin. The substrate is attached to this pad using conductive die attach material. There is no electrical or mechanical requirement to solder this pad. However, if it is soldered, the solder land should remain floating or be connected to GND. Fig 5. Pin configuration SO16 and TSSOP16 Fig 6. Pin configuration DHVQFN16 6.2 Pin description Table 2. Pin description Symbol Pin Description Q1 1 parallel data output 1 Q2 2 parallel data output 2 Q3 3 parallel data output 3 Q4 4 parallel data output 4 Q5 5 parallel data output 5 Q6 6 parallel data output 6 Q7 7 parallel data output 7 GND 8 ground (0 V) Q7S 9 serial data output MR 10 master reset (active LOW) SHCP 11 shift register clock input STCP 12 storage register clock input OE 13 output enable input (active LOW) DS 14 serial data input Q0 15 parallel data output 0 VCC 16 supply voltage 74VHC_VHCT595_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 15 November 2013 © Nexperia B.V. 2017. All rights reserved 4 of 21 74VHC595-Q100; 74VHCT595-Q100 Nexperia 8-bit serial-in/serial-out or parallel-out shift register with output latches 7. Functional description Function table[1] Table 3. Control Input Output Function SHCP STCP OE MR DS Q7S Qn X X L NC X L L a LOW-level on MR only affects the shift registers X  L L X L L empty shift register loaded into storage register X X H L X L Z shift register clear; parallel outputs in high-impedance OFF-state  X L H H Q6S NC logic HIGH-level shifted into shift register stage 0. Contents of all shift register stages shifted through, e.g. previous state of stage 6 (internal Q6S) appears on the serial output (Q7S). X  L H X NC QnS contents of shift register stages (internal QnS) are transferred to the storage register and parallel output stages   L H X Q6S QnS contents of shift register shifted through; previous contents of the shift register is transferred to the storage register and the parallel output stages [1] H = HIGH voltage state; L = LOW voltage state;  = LOW-to-HIGH transition; X = don’t care; NC = no change; Z = high-impedance OFF-state. SHCP DS STCP MR OE Z-state Q0 Z-state Q1 Z-state Q6 Z-state Q7 Q7S mna556 Fig 7. Timing diagram 74VHC_VHCT595_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 15 November 2013 © Nexperia B.V. 2017. All rights reserved 5 of 21 74VHC595-Q100; 74VHCT595-Q100 Nexperia 8-bit serial-in/serial-out or parallel-out shift register with output latches 8. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage VI input voltage IIK input clamping current VI < 0.5 V [1] IOK output clamping current VO < 0.5 V or VO > VCC + 0.5 V [1] IO output current VO = 0.5 V to (VCC + 0.5 V) ICC IGND Tstg storage temperature Min Max Unit 0.5 +7.0 V 0.5 +7.0 V 20 - mA 20 +20 mA 25 +25 mA supply current - +75 mA ground current 75 - mA 65 +150 C - 500 mW total power dissipation Ptot Conditions Tamb = 40 C to +125 C [2] [1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. [2] For SO16 packages: above 70 C the value of Ptot derates linearly at 8 mW/K. For TSSOP16 packages: above 60 C the value of Ptot derates linearly at 5.5 mW/K. For DHVQFN16 packages: above 60 C the value of Ptot derates linearly at 4.5 mW/K. 9. Recommended operating conditions Table 5. Operating conditions Symbol Parameter Conditions Min Typ Max Unit 2.0 5.0 5.5 V 74VHC595-Q100 VCC supply voltage VI input voltage 0 - 5.5 V VO output voltage 0 - VCC V Tamb ambient temperature 40 +25 +125 C t/V input transition rise and fall rate VCC = 3.0 V to 3.6 V - - 100 ns/V VCC = 4.5 V to 5.5 V - - 20 ns/V 74VHCT595-Q100 VCC supply voltage 4.5 5.0 5.5 V VI input voltage 0 - 5.5 V VO output voltage 0 - VCC V Tamb ambient temperature 40 +25 +125 C t/V input transition rise and fall rate VCC = 4.5 V to 5.5 V - - 20 ns/V 74VHC_VHCT595_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 15 November 2013 © Nexperia B.V. 2017. All rights reserved 6 of 21 74VHC595-Q100; 74VHCT595-Q100 Nexperia 8-bit serial-in/serial-out or parallel-out shift register with output latches 10. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max VCC = 2.0 V 1.5 - - 1.5 - 1.5 - V VCC = 3.0 V 2.1 - - 2.1 - 2.1 - V VCC = 5.5 V 3.85 - - 3.85 - 3.85 - V VCC = 2.0 V - - 0.5 - 0.5 - 0.5 V VCC = 3.0 V - - 0.9 - 0.9 - 0.9 V VCC = 5.5 V - - 1.65 - 1.65 - 1.65 V HIGH-level VI = VIH or VIL output voltage IO = 50 A; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = 50 A; VCC = 3.0 V 2.9 3.0 - 2.9 - 2.9 - V IO = 50 A; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = 4.0 mA; VCC = 3.0 V 2.58 - - 2.48 - 2.40 - V IO = 8.0 mA; VCC = 4.5 V 74VHC595-Q100 VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage 3.94 - - 3.80 - 3.70 - V LOW-level VI = VIH or VIL output voltage IO = 50 A; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 50 A; VCC = 3.0 V - 0 0.1 - 0.1 - 0.1 V IO = 50 A; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 3.0 V - - 0.36 - 0.44 - 0.55 V IO = 8.0 mA; VCC = 4.5 V - - 0.36 - 0.44 - 0.55 V - - 0.1 - 1.0 - 2.0 A II input leakage current VI = 5.5 V or GND; VCC = 0 V to 5.5 V IOZ OFF-state VI = VIH or VIL; output current VO = VCC or GND; VCC = 5.5 V - - 0.25 - 2.5 - 10 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 4.0 - 40 - 80 A CI input capacitance - 3 10 - 10 - 10 pF 74VHCT595-Q100 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 - - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - - 0.8 - 0.8 - 0.8 V VOH HIGH-level VI = VIH or VIL; VCC = 4.5 V output voltage IO = 50 A 4.4 4.5 - 4.4 - 4.4 - V 3.94 - - 3.80 - 3.70 - V - 0 0.1 - 0.1 - 0.1 V - - 0.36 - 0.44 - 0.55 V IO = 8.0 mA VOL LOW-level VI = VIH or VIL; VCC = 4.5 V output voltage IO = 50 A IO = 8.0 mA 74VHC_VHCT595_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 15 November 2013 © Nexperia B.V. 2017. All rights reserved 7 of 21 74VHC595-Q100; 74VHCT595-Q100 Nexperia 8-bit serial-in/serial-out or parallel-out shift register with output latches Table 6. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 C Conditions VI = 5.5 V or GND; VCC = 0 V to 5.5 V 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max - - 0.1 - 1.0 - 2.0 A II input leakage current IOZ OFF-state VI = VIH or VIL; output current VO = VCC or GND per input pin; other inputs at VCC or GND; IO = 0 A; VCC = 5.5 V - - 0.25 - 2.5 - 10 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 4.0 - 40 - 80 A ICC additional per input pin; VI = VCC  2.1 V; supply current other inputs at VCC or GND; IO = 0 A; VCC = 4.5 V to 5.5 V - - 1.35 - 1.5 - 1.5 mA CI input capacitance - 3 10 - 10 - 10 pF 11. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); for test circuit, see Figure 13. Symbol Parameter 25 C Conditions Min 40 C to +85 C 40 C to +125 C Unit Typ[1] Max Min Max Min Max 74VHC595-Q100 tpd propagation SHCP to Q7S; see Figure 8 delay VCC = 3.0 V to 3.6 V [2] CL = 15 pF - 5.7 13.0 1.0 15.0 1.0 16.5 ns CL = 50 pF - 7.7 16.5 1.0 18.5 1.0 20.1 ns CL = 15 pF - 4.0 8.2 1.0 9.4 1.0 10.5 ns CL = 50 pF - 5.4 10.0 1.0 11.4 1.0 12.5 ns VCC = 4.5 V to 5.5 V STCP to Qn; see Figure 9 [2] VCC = 3.0 V to 3.6 V CL = 15 pF - 5.9 11.9 1.0 13.5 1.0 15.0 ns CL = 50 pF - 7.7 15.4 1.0 17.0 1.0 18.5 ns - 4.2 7.4 1.0 8.5 1.0 9.5 ns - 5.5 9.0 1.0 10.5 1.0 11.5 ns CL = 15 pF - 5.9 12.8 1.0 13.7 1.0 15.0 ns CL = 50 pF - 7.4 16.3 1.0 17.2 1.0 18.7 ns CL = 15 pF - 4.4 8.0 1.0 9.1 1.0 10.0 ns CL = 50 pF - 5.6 10.0 1.0 11.1 1.0 12.0 ns VCC = 4.5 V to 5.5 V CL = 15 pF CL = 50 pF MR to Q7S; see Figure 11 [3] VCC = 3.0 V to 3.6 V VCC = 4.5 V to 5.5 V 74VHC_VHCT595_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 15 November 2013 © Nexperia B.V. 2017. All rights reserved 8 of 21 74VHC595-Q100; 74VHCT595-Q100 Nexperia 8-bit serial-in/serial-out or parallel-out shift register with output latches Table 7. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); for test circuit, see Figure 13. Symbol Parameter ten 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ[1] Max Min Max Min Max CL = 15 pF - 5.6 11.5 1.0 13.5 1.0 15.0 ns CL = 50 pF - 7.4 15.0 1.0 17.0 1.0 18.5 ns [4] enable time OE to Qn; see Figure 12 VCC = 3.0 V to 3.6 V VCC = 4.5 V to 5.5 V tdis CL = 15 pF - 4.0 8.6 1.0 10.0 1.0 11.0 ns CL = 50 pF - 5.3 10.6 1.0 12.0 1.0 13.0 ns [5] disable time OE to Qn; see Figure 12 VCC = 3.0 V to 3.6 V CL = 15 pF - 5.4 11.0 1.0 13.0 1.0 14.5 ns CL = 50 pF - 8.7 15.7 1.0 16.2 1.0 17.5 ns CL = 15 pF - 3.8 8.0 1.0 9.5 1.0 10.5 ns CL = 50 pF - 5.8 10.3 1.0 11.0 1.0 12.0 ns VCC = 3.0 V to 3.6 V 80 125 - 60 - 40 - MHz VCC = 4.5 V to 5.5 V 130 170 - 110 - 90 - MHz VCC = 3.0 V to 3.6 V 5.0 - - 5.0 - 5.0 - ns VCC = 4.5 V to 5.5 V 5.0 - - 5.0 - 5.0 - ns VCC = 3.0 V to 3.6 V 5.0 - - 5.0 - 5.0 - ns VCC = 4.5 V to 5.5 V 5.0 - - 5.0 - 5.0 - ns VCC = 3.0 V to 3.6 V 5.0 - - 5.0 - 5.0 - ns VCC = 4.5 V to 5.5 V 5.0 - - 5.0 - 5.0 - ns VCC = 3.0 V to 3.6 V 3.5 - - 3.5 - 3.5 - ns VCC = 4.5 V to 5.5 V 3.0 - - 3.0 - 3.0 - ns VCC = 3.0 V to 3.6 V 8.5 - - 8.5 - 8.5 - ns VCC = 4.5 V to 5.5 V 5.0 - - 5.0 - 5.0 - ns VCC = 3.0 V to 3.6 V 1.5 - - 1.5 - 1.5 - ns VCC = 4.5 V to 5.5 V 2.0 - - 2.0 - 2.0 - ns VCC = 4.5 V to 5.5 V fmax tW maximum frequency pulse width SHCP or STCP; see Figure 8 and 9 SHCP HIGH or LOW; see Figure 8 STCP HIGH or LOW; see Figure 9 MR LOW; see Figure 11 tsu set-up time DS to SHCP; see Figure 9 SHCP to STCP; see Figure 10 th hold time 74VHC_VHCT595_Q100 Product data sheet DS to SHCP; see Figure 10 All information provided in this document is subject to legal disclaimers. Rev. 1 — 15 November 2013 © Nexperia B.V. 2017. All rights reserved 9 of 21 74VHC595-Q100; 74VHCT595-Q100 Nexperia 8-bit serial-in/serial-out or parallel-out shift register with output latches Table 7. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); for test circuit, see Figure 13. Symbol Parameter trec CPD recovery time 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ[1] Max Min Max Min Max VCC = 3.0 V to 3.6 V 3.0 - - 3.0 - 3.0 - ns VCC = 4.5 V to 5.5 V 2.5 - - 2.5 - 2.5 - ns - 180 - - - - - pF - 3.8 8.2 1.0 9.0 1.0 10.0 ns - 5.2 10.0 1.0 11.0 1.0 12.0 ns - 4.0 7.4 1.0 8.5 1.0 9.5 ns - 5.3 9.0 1.0 10.5 1.0 11.5 ns - 4.6 8.2 1.0 9.5 1.0 10.5 ns - 5.8 10.5 1.0 11.5 1.0 12.5 ns MR to SHCP; see Figure 11 power fi = 1 MHz; VI = GND to VCC dissipation capacitance [6] [7] 74VHCT595-Q100; VCC = 4.5 V to 5.5 V tpd propagation SHCP to Q7S; see Figure 8 delay CL = 15 pF [2] CL = 50 pF STCP to Qn; see Figure 9 [2] CL = 15 pF CL = 50 pF MR to Q7S; see Figure 11 [3] CL = 15 pF CL = 50 pF ten tdis [4] enable time OE to Qn; see Figure 12 CL = 15 pF - 4.8 9.0 1.0 11.0 1.0 12.0 ns CL = 50 pF - 6.2 11.6 1.0 13.0 1.0 14.5 ns - 3.6 6.9 1.0 8.0 1.0 9.0 ns [5] disable time OE to Qn; see Figure 12 CL = 15 pF - 5.8 10.3 1.0 11.0 1.0 12.0 fmax maximum frequency SHCP and STCP; see Figure 8 and 9 CL = 50 pF 130 170 - 110 - 90 - MHz tW pulse width SHCP HIGH or LOW; see Figure 8 5.0 - - 5.0 - 5.0 - ns STCP HIGH or LOW; see Figure 9 5.0 - - 5.0 - 5.0 - ns MR LOW; see Figure 11 5.0 - - 5.0 - 5.0 - ns tsu set-up time ns DS to SHCP; see Figure 9 3.0 - - 3.0 - 3.0 - ns SHCP to STCP; see Figure 10 5.0 - - 5.0 - 5.0 - ns th hold time DS to SHCP; see Figure 10 2.0 - - 2.0 - 2.0 - ns trec recovery time MR to SHCP; see Figure 11 3.0 - - 3.0 - 3.0 - ns 74VHC_VHCT595_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 15 November 2013 © Nexperia B.V. 2017. All rights reserved 10 of 21 74VHC595-Q100; 74VHCT595-Q100 Nexperia 8-bit serial-in/serial-out or parallel-out shift register with output latches Table 7. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); for test circuit, see Figure 13. Symbol Parameter CPD 25 C Conditions [6] power fi = 1 MHz; VI = GND to VCC dissipation capacitance Min Max Min Max Min Max - 190 - - - - - pF [7] [1] Typical values are measured at nominal supply voltage. [2] tpd is the same as tPHL and tPLH. [3] tpd is the same as tPHL only. [4] ten is the same as tPZL and tPZH. [5] tdis is the same as tPLZ and tPHZ. [6] 40 C to +85 C 40 C to +125 C Unit Typ[1] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; (CL  VCC2  fo) = sum of outputs; CL = output load capacitance in pF; VCC = supply voltage in V. [7] All 9 outputs switching. 12. Waveforms 1/fmax VI SHCP input VM GND tW t PHL t PLH VOH VM Q 7S output VOL mna557 Measurement points are given in Table 8. VOL and VOH are typical output voltage levels that occur with the output load. Fig 8. Shift clock pulse, maximum frequency and input to output propagation delays 74VHC_VHCT595_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 15 November 2013 © Nexperia B.V. 2017. All rights reserved 11 of 21 74VHC595-Q100; 74VHCT595-Q100 Nexperia 8-bit serial-in/serial-out or parallel-out shift register with output latches VI SHCP input VM GND 1/fmax t su VI STCP input VM GND tW t PHL t PLH VOH VM Q n output VOL mna558 Measurement points are given in Table 8. VOL and VOH are typical output voltage levels that occur with the output load. Fig 9. Storage clock to output propagation delays VI VM SHCP input GND t su t su th th VI VM DS input GND VOH VM Q 7S output VOL mna560 Measurement points are given in Table 8. The shaded areas indicate when the input is permitted to change for predictable output performance. VOL and VOH are typical output voltage levels that occur with the output load. Fig 10. Data set-up and hold times 74VHC_VHCT595_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 15 November 2013 © Nexperia B.V. 2017. All rights reserved 12 of 21 74VHC595-Q100; 74VHCT595-Q100 Nexperia 8-bit serial-in/serial-out or parallel-out shift register with output latches VI VM MR input GND tW t rec VI SHCP input VM GND t PHL VOH VM Q 7S output VOL mna561 Measurement points are given in Table 8. VOL and VOH are typical output voltage levels that occur with the output load. Fig 11. Master reset to output propagation delays VI VM OE input GND tPLZ tPZL VCC output LOW-to-OFF OFF-to-LOW VM VOL + 0.3 V VOL tPHZ VOH tPZH VOH − 0.3 V output HIGH-to-OFF OFF-to-HIGH VM GND outputs enabled outputs enabled outputs disabled mna450 Measurement points are given in Table 8. VOL and VOH are typical output voltage levels that occur with the output load. Fig 12. Enable and disable times Table 8. Measurement points Type Input Output VM VM 74VHC595-Q100 0.5VCC 0.5VCC 74VHCT595-Q100 1.5 V 0.5VCC 74VHC_VHCT595_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 15 November 2013 © Nexperia B.V. 2017. All rights reserved 13 of 21 74VHC595-Q100; 74VHCT595-Q100 Nexperia 8-bit serial-in/serial-out or parallel-out shift register with output latches VI tW 90 % negative pulse VM 0V tf tr tr tf VI 90 % positive pulse 0V VM 10 % VM VM 10 % tW VCC VCC G VI VO RL S1 open DUT CL RT 001aad983 Test data is given in Table 9. Definitions for test circuit: CL = load capacitance including jig and probe capacitance. RL = load resistance. RT = termination resistance should be equal to the output impedance Zo of the pulse generator. S1 = test selection switch. Fig 13. Load circuitry for switching times Table 9. Test data Type Input VI tr, tf CL RL tPHL, tPLH tPZH, tPHZ tPZL, tPLZ 74VHC595-Q100 VCC  3.0 ns 15 pF, 50 pF 1 k open GND VCC  3.0 ns 15 pF, 50 pF 1 k open GND VCC 74VHCT595-Q100 3.0 V 74VHC_VHCT595_Q100 Product data sheet Load S1 position All information provided in this document is subject to legal disclaimers. Rev. 1 — 15 November 2013 © Nexperia B.V. 2017. All rights reserved 14 of 21 74VHC595-Q100; 74VHCT595-Q100 Nexperia 8-bit serial-in/serial-out or parallel-out shift register with output latches 13. Package outline SO16: plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 D E A X c y HE v M A Z 16 9 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 8 e 0 detail X w M bp 2.5 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 10.0 9.8 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 0.01 0.019 0.0100 0.39 0.014 0.0075 0.38 0.039 0.016 0.028 0.020 inches 0.010 0.057 0.069 0.004 0.049 0.16 0.15 0.05 0.244 0.041 0.228 0.01 0.01 0.028 0.004 0.012 θ 8o o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT109-1 076E07 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Fig 14. Package outline SOT109-1 (SO16) 74VHC_VHCT595_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 15 November 2013 © Nexperia B.V. 2017. All rights reserved 15 of 21 74VHC595-Q100; 74VHCT595-Q100 Nexperia 8-bit serial-in/serial-out or parallel-out shift register with output latches TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 E D A X c y HE v M A Z 9 16 Q (A 3) A2 A A1 pin 1 index θ Lp L 1 8 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.40 0.06 8o o 0 Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT403-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Fig 15. Package outline SOT403-1 (TSSOP16) 74VHC_VHCT595_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 15 November 2013 © Nexperia B.V. 2017. All rights reserved 16 of 21 74VHC595-Q100; 74VHCT595-Q100 Nexperia 8-bit serial-in/serial-out or parallel-out shift register with output latches DHVQFN16: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; SOT763-1 16 terminals; body 2.5 x 3.5 x 0.85 mm A B D A A1 E c detail X terminal 1 index area terminal 1 index area C e1 e 2 7 y y1 C v M C A B w M C b L 1 8 Eh e 16 9 15 10 Dh X 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A(1) max. A1 b c D (1) Dh E (1) Eh e e1 L v w y y1 mm 1 0.05 0.00 0.30 0.18 0.2 3.6 3.4 2.15 1.85 2.6 2.4 1.15 0.85 0.5 2.5 0.5 0.3 0.1 0.05 0.05 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC JEITA SOT763-1 --- MO-241 --- EUROPEAN PROJECTION ISSUE DATE 02-10-17 03-01-27 Fig 16. Package outline SOT763-1 (DHVQFN16) 74VHC_VHCT595_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 15 November 2013 © Nexperia B.V. 2017. All rights reserved 17 of 21 74VHC595-Q100; 74VHCT595-Q100 Nexperia 8-bit serial-in/serial-out or parallel-out shift register with output latches 14. Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor ESD ElectroStatic Discharge HBM Human Body Model MIL Military MM Machine Model TTL Transistor-Transistor Logic 15. Revision history Table 11. Revision history Document ID Release date 74VHC_VHCT595_Q100 v.1 20131115 74VHC_VHCT595_Q100 Product data sheet Data sheet status Change notice Supersedes Product data sheet - - All information provided in this document is subject to legal disclaimers. Rev. 1 — 15 November 2013 © Nexperia B.V. 2017. All rights reserved 18 of 21 74VHC595-Q100; 74VHCT595-Q100 Nexperia 8-bit serial-in/serial-out or parallel-out shift register with output latches 16. Legal information 16.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 16.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 16.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74VHC_VHCT595_Q100 Product data sheet Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. All information provided in this document is subject to legal disclaimers. Rev. 1 — 15 November 2013 © Nexperia B.V. 2017. All rights reserved 19 of 21 Nexperia 74VHC595-Q100; 74VHCT595-Q100 8-bit serial-in/serial-out or parallel-out shift register with output latches No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. 16.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 17. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74VHC_VHCT595_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 15 November 2013 © Nexperia B.V. 2017. All rights reserved 20 of 21 Nexperia 74VHC595-Q100; 74VHCT595-Q100 8-bit serial-in/serial-out or parallel-out shift register with output latches 18. Contents 1 2 3 4 5 6 6.1 6.2 7 8 9 10 11 12 13 14 15 16 16.1 16.2 16.3 16.4 17 18 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . . 2 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 4 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 4 Functional description . . . . . . . . . . . . . . . . . . . 5 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 6 Recommended operating conditions. . . . . . . . 6 Static characteristics. . . . . . . . . . . . . . . . . . . . . 7 Dynamic characteristics . . . . . . . . . . . . . . . . . . 8 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 15 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 18 Legal information. . . . . . . . . . . . . . . . . . . . . . . 19 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 19 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 19 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 19 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 20 Contact information. . . . . . . . . . . . . . . . . . . . . 20 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 21 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 15 November 2013
74VHCT595PW-Q100J 价格&库存
很抱歉,暂时无法提供与“74VHCT595PW-Q100J”相匹配的价格&库存,您可以联系我们找货
