74HCT597D-Q100J
74HCT597D-Q100J
    NEXPERIA(安世)
    SOIC16_150MIL
    带输入触发器的8位移位寄存器 SOIC16_150MIL 4.5~5.5V
74HCT597D-Q100J 数据手册
74HC597-Q100; 74HCT597-Q100 8-bit shift register with input flip-flops Rev. 1 — 26 May 2014 Product data sheet 1. General description The 74HC597-Q100; 74HCT597-Q100 is an 8-bit shift register with input flip-flops. It consists of an 8-bit storage register feeding a parallel-in, serial-out 8-bit shift register. Both the storage register and the shift register have positive edge-triggered clocks. The shift register also has direct load (from storage) and clear inputs. Inputs include clamp diodes that enable the use of current limiting resistors to interface inputs to voltages in excess of VCC. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits  Automotive product qualification in accordance with AEC-Q100 (Grade 1)  Specified from 40 C to +85 C and from 40 C to +125 C  Complies with JEDEC standard JESD7A  Input levels:  For 74HC597-Q100: CMOS level  For 74HCT597-Q100: TTL level  8-bit parallel storage register inputs  Shift register has direct overriding load and clear  ESD protection:  MIL-STD-883, method 3015 exceeds 2000 V  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )  Multiple package options 3. Ordering information Table 1. Ordering information Type number 74HC597D-Q100 Package Temperature range Name Description 40 C to +125 C SO16 plastic small outline package; 16 leads; body width SOT109-1 3.9 mm TSSOP16 plastic thin shrink small outline package; 16 leads; SOT403-1 body width 4.4 mm 74HCT597D-Q100 74HC597PW-Q100 40 C to +125 C Version 74HC597-Q100; 74HCT597-Q100 Nexperia 8-bit shift register with input flip-flops 4. Functional diagram 67&3  ' ' ' ' ' ' ' ' 05  '6  67&3 05 '6      '   '  '  '   '   '  '  '    ,1387 )/,3)/236 %,7 6+,)7 5(*,67(5    3/ 4 ,1387 )/,3 )/236  6+&3 %,7 6+,)7 5(*,67(5  3/ 6+&3 DDD Fig 1. 4 DDD Functional diagram Fig 2. 5   Logic symbol 65* & &     &   '  ' '  ' '        DDD Fig 3. IEC Logic symbol 74HC_HCT597_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 26 May 2014 © Nexperia B.V. 2017. All rights reserved 2 of 20 74HC597-Q100; 74HCT597-Q100 Nexperia 8-bit shift register with input flip-flops 05 6+&3 3/ 67&3 '6 ' & 6 ' ' & ' 5 & 6 6 5 ' & ' 5 & 6 6 5 ' & ' 5 & 6 6 5 ' & ' 5 & 6 6 5 ' & ' 5 & 6 6 5 ' & ' 5 & 6 6 5 ' & ' 5 & 6 5 6 ' 4 & 5 DDD Fig 4. Logic diagram 74HC_HCT597_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 26 May 2014 © Nexperia B.V. 2017. All rights reserved 3 of 20 74HC597-Q100; 74HCT597-Q100 Nexperia 8-bit shift register with input flip-flops 5. Pinning information 5.1 Pinning +&4 +&74 '   9&& '   ' '   '6 +&4 '   9&& '   ' '   '6  67&3 '   3/  6+&3 '   67&3 '   6+&3 '   05 *1'   3/ '  '  '   05 '  *1'   4 DDD Fig 5.  4 DDD Pin configuration SO16 Fig 6. Pin configuration TSSOP16 5.2 Pin description Table 2. Pin description Symbol Pin Description GND 8 ground (0 V) Q 9 serial data output MR 10 asynchronous master reset input (active LOW) SHCP 11 shift register clock input (LOW-to-HIGH, edge-triggered) STCP 12 storage register clock input (LOW-to-HIGH, edge-triggered) PL 13 parallel load input (active LOW) DS 14 serial data input D0, D1, D2, D3, D4, D5, D6, D7 15, 1, 2, 3, 4, 5, 6, 7 parallel data inputs VCC 16 supply voltage 74HC_HCT597_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 26 May 2014 © Nexperia B.V. 2017. All rights reserved 4 of 20 74HC597-Q100; 74HCT597-Q100 Nexperia 8-bit shift register with input flip-flops 6. Functional description Table 3. Function table[1] Inputs Function STCP SHCP PL MR  X X X data loaded to input latches  X L H data loaded from inputs to shift register no clock edge X L H data transferred from input flip-flops to shift register X X L L invalid logic, state of shift register is indeterminate when signals removed X X H L shift register cleared X  H H shift register clocked Qn = Qn1, Q0 = DS [1] H = HIGH voltage level. L = LOW voltage level. X = don’t care.  = positive-going transition. 6+&3 '6 05 3/ 67&3 ' + / / ' / / / ' + / / ' / / / ' + / + ' + / + ' / / / ' + + / / 4 UHVHW VKLIW UHJLVWHU + / + + / + / + / + VHULDOVKLIW / / / / / VHULDOVKLIW + + VHULDOVKLIW VHULDOVKLIW ORDGLQSXW UHJLVWHU Fig 7. / SDUDOOHOORDG VKLIWUHJLVWHU ORDGLQSXW UHJLVWHU SDUDOOHOORDG VKLIWUHJLVWHU SDUDOOHOORDGERWK LQSXWDQGVKLIWUHJLVWHUV DDD Timing diagram 74HC_HCT597_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 26 May 2014 © Nexperia B.V. 2017. All rights reserved 5 of 20 74HC597-Q100; 74HCT597-Q100 Nexperia 8-bit shift register with input flip-flops 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter VCC supply voltage Conditions Min Max Unit 0.5 +7 V IIK input clamping current VI < 0.5 V or VI > VCC + 0.5 V - 20 mA IOK output clamping current VO < 0.5 V or VO > VCC + 0.5 V - 20 mA IO output current VO = 0.5 V to (VCC + 0.5 V) - 25 mA ICC supply current - +50 mA IGND ground current 50 - mA Tstg storage temperature 65 +150 C - 500 mW total power dissipation Ptot [1] [1] For SO16: Ptot derates linearly with 8 mW/K above 70 C. For TSSOP16 packages: Ptot derates linearly with 5.5 mW/K above 60 C. 8. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V) Symbol Parameter Conditions 74HC597-Q100 74HCT597-Q100 Unit Min Typ Max Min Typ Max VCC supply voltage 2.0 5.0 6.0 4.5 5.0 5.5 V VI input voltage 0 - VCC 0 - VCC V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature t/V input transition rise and fall rate 74HC_HCT597_Q100 Product data sheet 40 +25 +125 40 +25 +125 C VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V VCC = 6.0 V - - 83 - - - ns/V All information provided in this document is subject to legal disclaimers. Rev. 1 — 26 May 2014 © Nexperia B.V. 2017. All rights reserved 6 of 20 74HC597-Q100; 74HCT597-Q100 Nexperia 8-bit shift register with input flip-flops 9. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 C Conditions Min Typ VCC = 2.0 V 1.5 VCC = 4.5 V VCC = 6.0 V 40 C to +85 C 40 C to +125 C Unit Max Min Max Min Max 1.2 - 1.5 - 1.5 - V 3.15 2.4 - 3.15 - 3.15 - V 4.2 3.2 - 4.2 - 4.2 - V 74HC597-Q100 VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage VCC = 2.0 V - 0.8 0.5 - 0.5 - 0.5 V VCC = 4.5 V - 2.1 1.35 - 1.35 - 1.35 V VCC = 6.0 V - 2.8 1.8 - 1.8 - 1.8 V IO = 20 A; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = 20 A; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = 20 A; VCC = 6.0 V 5.9 6.0 - 5.9 - 5.9 - V IO = 4.0 mA; VCC = 4.5 V 3.98 4.32 - 3.84 - 3.7 - V IO = 5.2 mA; VCC = 6.0 V 5.48 5.81 - 5.34 - 5.2 - V IO = 20 A; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 20 A; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 20 A; VCC = 6.0 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 4.5 V - 0.15 0.26 - 0.33 - 0.4 V IO = 5.2 mA; VCC = 6.0 V - 0.16 0.26 - 0.33 - 0.4 V VI = VIH or VIL VI = VIH or VIL II input leakage current VI = VCC or GND; VCC = 6.0 V - - 0.1 - 1.0 - 1.0 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 8.0 - 80.0 - 160.0 A CI input capacitance - 3.5 - - - - - pF 74HCT597-Q100 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 - 0.8 - 0.8 V VOH HIGH-level output voltage VI = VIH or VIL; VCC = 4.5 V IO = 20 A 4.4 4.5 - 4.4 - 4.4 - V IO = 4.0 mA 3.98 4.32 - 3.84 - 3.7 - V LOW-level output voltage VI = VIH or VIL; VCC = 4.5 V IO = 20 A - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA - 0.15 0.26 - 0.33 - 0.4 V VI = VCC or GND; VCC = 5.5 V - - 0.1 - 1.0 - 1.0 A VOL II input leakage current 74HC_HCT597_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 26 May 2014 © Nexperia B.V. 2017. All rights reserved 7 of 20 74HC597-Q100; 74HCT597-Q100 Nexperia 8-bit shift register with input flip-flops Table 6. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 C Conditions Min Typ Max Min Max Min Max - 8.0 - 80.0 - 160.0 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V ICC additional supply current VI = VCC  2.1 V; other inputs at VCC or GND; VCC = 4.5 V to 5.5 V; IO = 0 A CI - 40 C to +85 C 40 C to +125 C Unit per input pin; DS input - 25 90 - 112.5 - 122.5 A per input pin; Dn inputs - 30 108 - 135 - 147 A per input pin; PL, MR inputs - 150 540 - 675 - 735 A per input pin; STCP, SHCP inputs - 150 540 - 675 - 735 A - 3.5 - - - - - pF input capacitance 10. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit, see Figure 14. Symbol Parameter 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max VCC = 2.0 V - 55 175 - 220 - 265 ns VCC = 4.5 V - 20 35 - 44 - 53 ns 74HC597-Q100 tpd propagation delay SHCP to Q; see Figure 8 [1] VCC = 5.0 V; CL = 15 pF - 17 - - - - - ns VCC = 6.0 V - 16 30 - 37 - 45 ns VCC = 2.0 V - 58 175 - 220 - 265 ns VCC = 4.5 V - 21 35 - 44 - 53 ns VCC = 6.0 V - 17 30 - 37 - 45 ns VCC = 2.0 V - 80 250 - 315 - 375 ns VCC = 4.5 V - 29 50 - 63 - 75 ns VCC = 5.0 V; CL = 15 pF - 25 - - - - - ns - 23 43 - 54 - 64 ns VCC = 2.0 V - 69 215 - 270 - 325 ns VCC = 4.5 V - 25 43 - 54 - 65 ns VCC = 5.0 V; CL = 15 pF - 21 - - - - - ns VCC = 6.0 V - 20 37 - 46 - 55 ns MR to Q; see Figure 9 STCP to Q; see Figure 8 [1] [1] VCC = 6.0 V PL to Q; see Figure 10 74HC_HCT597_Q100 Product data sheet [1] All information provided in this document is subject to legal disclaimers. Rev. 1 — 26 May 2014 © Nexperia B.V. 2017. All rights reserved 8 of 20 74HC597-Q100; 74HCT597-Q100 Nexperia 8-bit shift register with input flip-flops Table 7. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit, see Figure 14. Symbol Parameter tt tW transition time pulse width 25 C Conditions Min Typ 40 C to +85 C 40 C to +125 C Unit Max Min Max Min Max [2] see Figure 10 VCC = 2.0 V - 19 75 - 95 - 110 ns VCC = 4.5 V - 7 15 - 19 - 22 ns VCC = 6.0 V - 6 13 - 16 - 19 ns VCC = 2.0 V 80 11 - 100 - 120 - ns VCC = 4.5 V 16 4 - 20 - 24 - ns VCC = 6.0 V 14 3 - 17 - 20 - ns STCP HIGH or LOW; see Figure 8 SHCP HIGH or LOW; see Figure 8 VCC = 2.0 V 80 14 - 100 - 120 - ns VCC = 4.5 V 16 5 - 20 - 24 - ns VCC = 6.0 V 14 4 - 17 - 20 - ns VCC = 2.0 V 80 22 - 100 - 120 - ns VCC = 4.5 V 16 8 - 20 - 24 - ns VCC = 6.0 V 14 6 - 17 - 20 - ns VCC = 2.0 V 80 22 - 100 - 120 - ns VCC = 4.5 V 16 8 - 20 - 24 - ns VCC = 6.0 V 14 6 - 17 - 20 - ns MR LOW; see Figure 9 PL LOW; see Figure 10 trec tsu recovery time set-up time MR to SHCP; see Figure 11 VCC = 2.0 V 60 3 - 75 - 90 - ns VCC = 4.5 V 12 1 - 15 - 18 - ns VCC = 6.0 V 10 1 - 13 - 15 - ns Dn to STCP; see Figure 12 VCC = 2.0 V 60 8 - 75 - 90 - ns VCC = 4.5 V 12 3 - 15 - 18 - ns VCC = 6.0 V 10 2 - 13 - 15 - ns VCC = 2.0 V 60 11 - 75 - 90 - ns VCC = 4.5 V 12 4 - 15 - 18 - ns VCC = 6.0 V 10 3 - 13 - 15 - ns VCC = 2.0 V 60 11 - 75 - 90 - ns VCC = 4.5 V 12 4 - 15 - 18 - ns VCC = 6.0 V 10 3 - 13 - 15 - ns DS to SHCP; see Figure 12 PL to SHCP; see Figure 13 74HC_HCT597_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 26 May 2014 © Nexperia B.V. 2017. All rights reserved 9 of 20 74HC597-Q100; 74HCT597-Q100 Nexperia 8-bit shift register with input flip-flops Table 7. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit, see Figure 14. Symbol Parameter th hold time 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max Dn to STCP; see Figure 12 VCC = 2.0 V 5 3 - 5 - 5 - ns VCC = 4.5 V 5 1 - 5 - 5 - ns VCC = 6.0 V 5 1 - 5 - 5 - ns PL, DS to SHCP; see Figure 12 fmax maximum frequency VCC = 2.0 V 5 6 - 5 - 5 - ns VCC = 4.5 V 5 2 - 5 - 5 - ns VCC = 6.0 V 5 2 - 5 - 5 - ns VCC = 2.0 V 6.0 29 - 4.8 - 4.0 - MHz VCC = 4.5 V 30 87 - 24 - 20 - MHz - 96 - - - - - MHz 35 104 - 28 - 24 - MHz - 29 - - - - - pF - 23 40 - 50 - 60 ns - 20 - - - - - ns - 28 49 - 61 - 74 ns - 33 57 - 71 - 86 ns - 29 - - - - - ns - 30 52 - 65 - 78 ns - 26 - - - - - ns - 7 15 - 19 - 22 ns 16 6 - 20 - 24 - ns 16 7 - 20 - 24 - ns 25 14 - 31 - 38 - ns 20 10 - 25 - 30 - ns 12 2 - 15 - 18 - ns SHCP; see Figure 8 VCC = 5.0 V; CL = 15 pF VCC = 6.0 V CPD [3] power CL = 50 pF; f = 1 MHz; dissipation VI = GND to VCC capacitance 74HCT597-Q100 tpd propagation delay [1] SHCP to Q; see Figure 8 VCC = 4.5 V VCC = 5.0 V; CL = 15 pF [1] MR to Q; see Figure 9 VCC = 4.5 V [1] STCP to Q; see Figure 8 VCC = 4.5 V VCC = 5.0 V; CL = 15 pF [1] PL to Q; see Figure 10 VCC = 4.5 V VCC = 5.0 V; CL = 15 pF [2] tt transition time see Figure 8 tW pulse width STCP HIGH or LOW; see Figure 8 VCC = 4.5 V VCC = 4.5 V SHCP HIGH or LOW; see Figure 8 VCC = 4.5 V MR LOW; see Figure 9 VCC = 4.5 V PL LOW; see Figure 10 VCC = 4.5 V trec recovery time 74HC_HCT597_Q100 Product data sheet MR to SHCP; see Figure 11 VCC = 4.5 V All information provided in this document is subject to legal disclaimers. Rev. 1 — 26 May 2014 © Nexperia B.V. 2017. All rights reserved 10 of 20 74HC597-Q100; 74HCT597-Q100 Nexperia 8-bit shift register with input flip-flops Table 7. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit, see Figure 14. Symbol Parameter tsu set-up time 25 C Conditions 40 C to +85 C 40 C to +125 C Unit Min Typ Max Min Max Min Max 12 5 - 15 - 18 - ns 12 2 - 15 - 18 - ns 12 4 - 15 - 18 - ns 5 1 - 5 - 5 - ns 5 2 - 5 - 5 - ns 30 75 - 24 - 20 - MHz - 83 - - - - - MHz - 32 - - - - - pF Dn to STCP; see Figure 12 VCC = 4.5 V DS to SHCP; see Figure 12 VCC = 4.5 V PL to SHCP; see Figure 13 VCC = 4.5 V th hold time Dn to STCP; see Figure 12 VCC = 4.5 V PL, DS to SHCP; see Figure 12 VCC = 4.5 V fmax maximum frequency SHCP; see Figure 8 VCC = 4.5 V VCC = 5.0 V; CL = 15 pF CPD power CL = 50 pF; f = 1 MHz; dissipation VI = GND to VCC  1.5 V capacitance [3] [1] tpd is the same as tPLH and tPHL. [2] tt is the same as tTHL and tTLH. [3] CPD is used to determine the dynamic power dissipation (PD in W). PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of outputs. 74HC_HCT597_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 26 May 2014 © Nexperia B.V. 2017. All rights reserved 11 of 20 74HC597-Q100; 74HCT597-Q100 Nexperia 8-bit shift register with input flip-flops 11. Waveforms IPD[ 9, 67&36+&3 LQSXW 90 *1' W: W3+/ W3/+ 92+ 4RXWSXW 90 92/ DDD Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig 8. Shift clock and storage clock inputs to output, propagation delays, pulse widths and maximum clock frequency 9, 90 05LQSXW *1' W: W3+/ 92+ 4RXWSXW 90 92/ DDD Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig 9. input (MR) to (Q), output propagation delays and (MR) pulse width IPD[ 9, 90 3/LQSXW *1' W: W3/+ W3+/ 92+ 4RXWSXW 92/   90   W7+/ W7/+ DDD Measurement points are given in Table 8. VOL and VOH are typical voltage output levels that occur with the output load. Fig 10. Input (PL) to (Q), output propagation delays, PL pulse width and output transition times 74HC_HCT597_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 26 May 2014 © Nexperia B.V. 2017. All rights reserved 12 of 20 74HC597-Q100; 74HCT597-Q100 Nexperia 8-bit shift register with input flip-flops 9, 90 05LQSXW *1' WUHF 9, 6+&3LQSXW 90 *1' DDD Measurement points are given in Table 8. Fig 11. Input (MR) to shift clock (SHCP) and storage clock (STCP) recovery times 9, SRVLWLYH '6'QLQSXW 90 *1' 9, QHJDWLYH '6'QLQSXW 90 *1' WVX WK 9, 90 6+&3LQSXW *1' 9, 90 67&3LQSXW *1' WVX WK DDD Measurement points are given in Table 8. Fig 12. Hold and set-up times for (DS), (Dn) inputs to (SHCP), (STCP) inputs 9, 3/LQSXW 90 *1' 9, 90 6+&3LQSXW *1' WVX WK DDD Measurement points are given in Table 8. Fig 13. Set-up times for (PL) input to (SHCP) input 74HC_HCT597_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 26 May 2014 © Nexperia B.V. 2017. All rights reserved 13 of 20 74HC597-Q100; 74HCT597-Q100 Nexperia 8-bit shift register with input flip-flops Table 8. Measurement points Type Input Output VM VI VM 74HC597-Q100 0.5  VCC GND to VCC 0.5  VCC 74HCT597-Q100 1.3 V GND to 3 V 1.3 V VI tW 90 % negative pulse VM 0V tf tr tr tf VI 90 % positive pulse 0V VM 10 % VM VM 10 % tW VCC VCC G VI VO RL S1 open DUT CL RT 001aad983 Test data is given in Table 9. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. RL = Load resistance. S1 = Test selection switch. Fig 14. Test circuit for measuring switching times Table 9. Test data Type Input Load S1 position VI tr, tf CL RL tPHL, tPLH tPZH, tPHZ tPZL, tPLZ 74HC597-Q100 VCC 6 ns 15 pF, 50 pF 1 k open GND VCC 74HCT597-Q100 3V 6 ns 15 pF, 50 pF 1 k open GND VCC 74HC_HCT597_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 26 May 2014 © Nexperia B.V. 2017. All rights reserved 14 of 20 74HC597-Q100; 74HCT597-Q100 Nexperia 8-bit shift register with input flip-flops 12. Package outline SO16: plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 D E A X c y HE v M A Z 16 9 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 8 e 0 detail X w M bp 2.5 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 10.0 9.8 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 0.01 0.019 0.0100 0.39 0.014 0.0075 0.38 0.039 0.016 0.028 0.020 inches 0.010 0.057 0.069 0.004 0.049 0.16 0.15 0.05 0.244 0.041 0.228 0.01 0.01 0.028 0.004 0.012 θ 8o o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT109-1 076E07 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Fig 15. Package outline SOT109-1 (SO16) 74HC_HCT597_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 26 May 2014 © Nexperia B.V. 2017. All rights reserved 15 of 20 74HC597-Q100; 74HCT597-Q100 Nexperia 8-bit shift register with input flip-flops TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm SOT403-1 E D A X c y HE v M A Z 9 16 Q (A 3) A2 A A1 pin 1 index θ Lp L 1 8 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.40 0.06 8o o 0 Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT403-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Fig 16. Package outline SOT403-1 (TSSOP16) 74HC_HCT597_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 26 May 2014 © Nexperia B.V. 2017. All rights reserved 16 of 20 74HC597-Q100; 74HCT597-Q100 Nexperia 8-bit shift register with input flip-flops 13. Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MIL Military MM Machine Model TTL Transistor-Transistor Logic 14. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT597_Q100 v.1 20140526 Product data sheet - - 74HC_HCT597_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 26 May 2014 © Nexperia B.V. 2017. All rights reserved 17 of 20 74HC597-Q100; 74HCT597-Q100 Nexperia 8-bit shift register with input flip-flops 15. Legal information 15.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 15.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 15.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74HC_HCT597_Q100 Product data sheet Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. All information provided in this document is subject to legal disclaimers. Rev. 1 — 26 May 2014 © Nexperia B.V. 2017. All rights reserved 18 of 20 Nexperia 74HC597-Q100; 74HCT597-Q100 8-bit shift register with input flip-flops No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. 15.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 16. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74HC_HCT597_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 26 May 2014 © Nexperia B.V. 2017. All rights reserved 19 of 20 Nexperia 74HC597-Q100; 74HCT597-Q100 8-bit shift register with input flip-flops 17. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 11 12 13 14 15 15.1 15.2 15.3 15.4 16 17 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 1 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 4 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 4 Functional description . . . . . . . . . . . . . . . . . . . 5 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 6 Recommended operating conditions. . . . . . . . 6 Static characteristics. . . . . . . . . . . . . . . . . . . . . 7 Dynamic characteristics . . . . . . . . . . . . . . . . . . 8 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 15 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 17 Legal information. . . . . . . . . . . . . . . . . . . . . . . 18 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 18 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 19 Contact information. . . . . . . . . . . . . . . . . . . . . 19 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 26 May 2014
74HCT597D-Q100J 价格&库存
很抱歉,暂时无法提供与“74HCT597D-Q100J”相匹配的价格&库存,您可以联系我们找货
