74AXP2T3407
Dual supply single buffer and single buffer with open-drain
Rev. 2 — 7 October 2016
Product data sheet
1. General description
The 74AXP2T3407 is a dual supply single buffer and a single buffer with open-drain
output. It features two input pins (nA), an output pin (1Y) and an open-drain output pin
(2Y) and dual supply pins (VCCI and VCCO). The inputs are referenced to VCCI and the
output is referenced to VCCO. All inputs can be connected directly to VCCI or GND. VCCI
can be supplied at any voltage between 0.7 V and 2.75 V and VCCO can be supplied at
any voltage between 1.2 V and 5.5 V. This feature allows voltage level translation.
Schmitt-trigger action at all inputs makes the circuit tolerant of slower input rise and fall
times.
This device ensures very low static and dynamic power consumption across the entire
supply range and is fully specified for partial power down applications using IOFF. The IOFF
circuitry disables the output, preventing the potentially damaging backflow current through
the device when it is powered down.
2. Features and benefits
Wide supply voltage range:
VCCI: 0.7 V to 2.75 V
VCCO: 1.2 V to 5.5 V
Low input capacitance; CI = 0.6 pF (typical)
Low output capacitance; CO = 1.8 pF (typical) for 1Y
Low output capacitance; CO = 1.3 pF (typical) for 2Y
Low dynamic power consumption; CPD = 0.4 pF at VCCI = 1.2 V (typical)
Low dynamic power consumption; CPD = 7.1 pF at VCCO = 3.3 V (typical)
Low static power consumption; ICCI = 0.5 A (85 C maximum)
Low static power consumption; ICCO = 1.8 A (85 C maximum)
High noise immunity
Complies with JEDEC standard:
JESD8-12A.01 (1.1 V to 1.3 V; nA inputs)
JESD8-11A.01 (1.4 V to 1.6 V)
JESD8-7A (1.65 V to 1.95 V)
JESD8-5A.01 (2.3 V to 2.7 V)
JESD8-C (2.7 V to 3.6 V; nY outputs)
JESD12-6 (4.5 V to 5.5 V; nY outputs)
ESD protection:
HBM ANSI/ESDA/JEDEC JS-001 Class 2 exceeds 2 kV
CDM JESD22-C101E exceeds 1000 V
74AXP2T3407
Nexperia
Latch-up performance exceeds 100 mA per JESD78D Class II
Inputs accept voltages up to 2.75 V
Low noise overshoot and undershoot < 10% of VCCO
IOFF circuitry provides partial power-down mode operation
Multiple package options
Specified from 40 C to +85 C
3. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74AXP2T3407DC
40 C to +85 C
VSSOP8 plastic very thin shrink small outline package; 8 leads;
body width 2.3 mm
74AXP2T3407GT
40 C to +85 C
XSON8
plastic extremely thin small outline package; no leads; SOT833-1
8 terminals; body 1 1.95 0.5 mm
74AXP2T3407GN
40 C to +85 C
XSON8
8 terminals; body 1.2 1.0 0.35 mm
SOT1116
74AXP2T3407GS
40 C to +85 C
XSON8
8 terminals; body 1.35 1.0 0.35 mm
SOT1203
SOT765-1
4. Marking
Table 2.
Marking
Type number
Marking code[1]
74AXP2T3407DC
r4
74AXP2T3407GT
r4
74AXP2T3407GN
r4
74AXP2T3407GS
r4
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
74AXP2T3407
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 22
74AXP2T3407
Nexperia
5. Functional diagram
9&&,
9&&2
DDD
Fig 1.
DDD
Logic symbol
Fig 2.
Logic diagram
6. Pinning information
6.1 Pinning
$;37
9&&,
9&&2
*1'
*1'
$;37
9&&,
9&&2
*1'
*1'
DDD
7UDQVSDUHQWWRSYLHZ
DDD
Fig 3.
Pin configuration SOT765-1
Fig 4.
Pin configuration SOT833-1, SOT1116 and
SOT1203
6.2 Pin description
Table 3.
Pin description
Symbol
Pin
Description
VCCI
1
input supply voltage
1A
2
data input
2A
3
data input
GND[1]
4, 5
ground (0 V)
2Y
6
data output (open-drain)
1Y
7
data output
VCCO
10
output supply voltage
[1]
All GND pins must be connected to ground (0 V).
74AXP2T3407
Product data sheet
3 of 22
74AXP2T3407
Nexperia
7. Functional description
Table 4.
Function table[1]
Supply voltage
Input
Output
VCCI
VCCO
1A
1Y
0.7 V to 2.75 V
1.2 V to 5.5 V
L
L
0.7 V to 2.75 V
1.2 V to 5.5 V
H
H
GND
1.2 V to 5.5 V
X
Z
0.7 V to 2.75 V
GND
X
Z
GND
GND
X
Z
Input
Output
[1]
H = HIGH voltage level; L = LOW voltage level.
Table 5.
Function table[1]
Supply voltage
VCCI
VCCO
2A
2Y
0.7 V to 2.75 V
1.2 V to 5.5 V
L
L
0.7 V to 2.75 V
1.2 V to 5.5 V
H
Z
GND
1.2 V to 5.5 V
X
Z
0.7 V to 2.75 V
GND
X
Z
GND
GND
X
Z
[1]
74AXP2T3407
Product data sheet
4 of 22
74AXP2T3407
Nexperia
8. Limiting values
Table 6.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Conditions
VCCI
VCCO
IIK
input clamping current
VI
input voltage
IOK
output clamping current
VI < 0 V
[1]
output voltage
VO
output current
ICCI
input supply current
ICCO
output supply current
IGND
ground current
Tstg
storage temperature
0.5
3.3
V
0.5
6.0
50
0.5
3.3
V
0.5
VCCO + 0.5
V
[1]
0.5
6.0
V
25
mA
50
mA
Tamb = 40 C to +85 C
[3]
mA
50
mA
50
mA
65
+150
C
250
mW
[1]
The minimum input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
VCCO + 0.5 V should not exceed 6.0 V.
[3]
V
mA
VO = 0 V to VCCO
total power dissipation
Ptot
Unit
50
Power-down or 3-state mode
IO
Max
[1][2]
VO < 0 V
Active mode
Min
For SOT833-1 package: above 70 C the value of Ptot derates linearly with 3.2 mW/K.
For SOT1203 package: above 80 C the value of Ptot derates linearly with 3.6 mW/K.
9. Recommended operating conditions
Table 7.
Symbol
Parameter
Min
Max
Unit
VCCI
0.7
2.75
V
VCCO
1.2
5.5
V
VI
input voltage
V
VO
output voltage
Active mode
VCCO
V
V
40
+85
C
ns/V
Tamb
ambient temperature
t/V
input transition rise
and fall rate
74AXP2T3407
Product data sheet
Conditions
VCCI = 0.7 V to 2.75 V
5 of 22
74AXP2T3407
Nexperia
10. Static characteristics
Table 8.
At recommended operating conditions, unless otherwise specified; voltages are referenced to GND (ground = 0 V).
Symbol Parameter
Conditions
Min
HIGH-level input
voltage
VIH
LOW-level input
voltage
VIL
VOH
HIGH-level output
voltage
LOW-level output
voltage
Typ 25 C Max 25 C Max 85 C
VCCI = 0.75 V to 0.85 V
0.75VCCI
V
VCCI = 1.1 V to 1.95 V
0.65VCCI
V
VCCI = 2.3 V to 2.7 V
1.6
V
0.25VCCI
0.25VCCI
V
0.35VCCI
0.35VCCI
V
0.7
0.7
V
1.05
V
1.05
V
IO = 2 mA; VCCO = 1.2 V
[1]
IO = 3 mA; VCCO = 1.4 V
IO = 4.5 mA; VCCO = 1.65 V
1.2
V
IO = 8 mA; VCCO = 2.3 V
1.7
V
IO = 10 mA; VCCO = 3.0 V
2.2
V
3.7
V
IO = 12 mA; VCCO = 4.5 V
VOL
Unit
[1]
0.18
V
0.35
0.35
V
0.45
0.45
V
0.7
0.7
V
0.8
0.8
V
0.8
0.8
V
0.001
0.1
0.5
A
0.001
0.1
0.5
A
[1]
II
input leakage
current
VI = 0 V to 2.75 V;
VCCI = 0 V to 2.75 V
IOZ
OFF-state output
current
VO = 0 V to 5.5 V;
VCCO = 1.2 V to 5.5 V
IOFF
power-off leakage
current
inputs; VI = 0 V to 2.75 V;
VCCI = 0 V; VCCO = 0 V to 5.5 V
[1]
0.01
0.1
0.5
A
output; VO = 0 V to 5.5 V;
VCCO = 0 V; VCCI = 0 V to 2.75 V;
VI = 0 V to 2.75 V
[1]
0.01
0.1
0.5
A
inputs; VI = 0 V or 2.75 V;
VCCI = 0 V to 0.1 V;
VCCO = 0 V to 5.5 V
[1]
0.02
0.1
0.5
A
output; VO = 0 V or 5.5 V;
VCCO = 0 V to 0.1 V;
VI = 0 V or 2.75 V
[1]
0.02
0.1
0.5
A
IOFF
[1]
additional
power-off leakage
current
Typical values are measured at VCCI = VCCO = 1.2 V unless otherwise specified.
74AXP2T3407
Product data sheet
6 of 22
74AXP2T3407
Nexperia
Table 9.
Static characteristics supply current
Symbol Parameter
input supply
current
ICCI
ICCO
ICCI
output supply
current
additional input
supply current
Conditions
Max 25 C
Typ 85 C
Max 85 C
VCCI = 0.7 V to 1.3 V
[1]
1
100
10
300
nA
VCCI = 1.3 V to 2.75 V
[2]
1
100
nA
VCCI = 2.75 V; VCCO = 0 V
1
100
nA
VCCI = 0 V; VCCO = 5.5 V
1
100
1
100
nA
VI = 0 V or VCCI; IO = 0 A;
see Table 10
VCCO = 1.2 V to 3.6 V
[1]
0.001
1.0
0.01
1.2
A
VCCO = 3.6 V to 5.5 V
[3]
0.8
1.5
1.0
1.8
A
0.001
0.1
0.003
0.2
A
VCCI = 0 V; VCCO = 3.6 V
0.2
0.6
0.3
0.8
A
0.4
0.8
0.5
1.0
A
VI = VCCI 0.5 V; VCCI = 2.5 V
2
100
14
150
A
Typical values are measured at VCCI = VCCO = 1.2 V.
[2]
Typical values are measured at VCCI = VCCO = 2.5 V.
[3]
Typical values are measured at VCCI = 1.2 V and VCCO = 5.0 V.
VCCI
Typ 25 C
VI = 0 V or VCCI;
[1]
Table 10.
Unit
Typical output supply current (ICCO )
VCCO
Unit
0V
1.2 V
0V
5
200
400
nA
0.8 V
1
10
150
200
300
500
800
nA
1.2 V
1
1
5
200
300
500
800
nA
1.5 V
1
1
5
100
300
500
800
nA
1.8 V
1
1
5
100
300
500
800
nA
2.5 V
1
1
5
100
100
500
800
nA
74AXP2T3407
Product data sheet
1.5 V
1.8 V
2.5 V
3.3 V
5.0 V
7 of 22
74AXP2T3407
Nexperia
11. Dynamic characteristics
Table 11. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V); for test circuit see Figure 12; for wave form see Figure 5.
Symbol Parameter
Conditions
VCCO
Unit
1.2 V
1.5 V 0.1 V
Typ[1]
Min
Typ[1]
1.8 V 0.15 V
Max
Min
Typ[1]
Max
22.1
3
17
76
3
15
72
VCCI = 1.1 V to 1.3 V
15.8
3.1
10.3
19.8
2.8
8.3
15.8
ns
VCCI = 1.4 V to 1.6 V
14.9
2.8
9.4
18.2
2.5
7.4
13.3
ns
VCCI = 1.65 V to 1.95 V
14.5
2.7
9.0
17.4
2.4
7.0
12.9
ns
14.1
2.5
8.6
16.9
2.2
6.6
12.2
ns
22.1
3
17
151
3
15
148
ns
15.8
3.1
10.3
19.8
2.8
8.3
15.8
ns
Tamb = 25 C
propagation nA to nY
delay
tpd
[2]
ns
delay
tpd
[2]
14.9
2.8
9.4
18.2
2.5
7.4
13.3
ns
14.5
2.7
9.0
17.4
2.4
7.0
12.9
ns
14.1
2.5
8.6
16.9
2.2
6.6
12.2
ns
1.0
1.0
ns
tt
transition
time
VCCI = 0.75 V to 2.7 V
[3]
[1]
Typical values are measured at nominal supply voltages and Tamb = +25 C.
[2]
tpd is the same as tPLH and tPHL (1A to 1Y) and tPLZ and tPZL (2A to 2Y).
[3]
tt is the same as tTHL and tTLH (1A to 1Y) and tPZL(2A to 2Y).
74AXP2T3407
Product data sheet
8 of 22
74AXP2T3407
Nexperia
Table 12. Dynamic characteristics
Symbol Parameter
Conditions
VCCO
2.5 V 0.2 V
Min
Unit
3.3 V 0.3 V
Typ[1] Max
Min
5.0 V 0.5 V
Typ[1] Max
Min
Typ[1] Max
Tamb = 25 C
delay
tpd
[2]
2
13
72
2
13
80
2
14
2.4
6.6
11.4
2.2
5.9
12.2
2.1
5.5
10.1 ns
92
ns
2.1
5.7
10.1
2.0
5.0
10.9
1.9
4.6
8.9
ns
2.0
5.3
9.5
1.8
4.6
10.3
1.8
4.2
8.3
ns
1.9
4.9
9.0
1.7
4.2
9.8
1.6
3.8
7.8
ns
2
13
167
2
13
194
2
14
225 ns
delay
tpd
[2]
2.4
6.6
11.4
2.2
5.9
12.2
2.1
5.5
10.1 ns
2.1
5.7
10.1
2.0
5.0
10.9
1.9
4.6
8.9
ns
2.0
5.3
9.5
1.8
4.6
10.3
1.8
4.2
8.3
ns
1.9
4.9
9.0
1.7
4.2
9.8
1.6
3.8
7.8
ns
1.0
1.0
1.0
ns
transition
time
tt
[3]
[1]
Typical values are measured at nominal supply voltages and tamb = +25 C.
[2]
[3]
74AXP2T3407
Product data sheet
9 of 22
74AXP2T3407
Nexperia
Table 13. Typical dynamic characteristics at Tamb = 25 C
Symbol Parameter
power
dissipation
capacitance
CPD
Conditions
VCCO
Unit
1.2 V
1.5 V
1.8 V
2.5 V
3.3 V
5.0 V
VCCI = 0.8 V
0.4
0.4
0.4
0.4
0.4
0.4
pF
VCCI = 1.2 V
0.4
0.4
0.4
0.4
0.4
0.4
pF
VCCI = 1.5 V
0.5
0.5
0.5
0.5
0.5
0.5
pF
VCCI = 1.8 V
0.5
0.5
0.5
0.5
0.5
0.5
pF
0.7
0.7
0.7
0.7
0.7
0.7
pF
VCCI = 0.8 V
6.7
6.8
6.8
6.9
7.5
9.5
pF
VCCI = 1.2 V
6.8
6.9
7.0
7.0
7.1
7.6
pF
VCCI = 1.5 V
6.9
6.9
6.9
7.0
7.1
7.6
pF
VCCI = 1.8 V
6.9
6.9
6.9
7.0
7.2
7.6
pF
VCCI = 2.5 V
6.9
7.0
7.0
7.0
7.2
7.6
pF
VCCI = 0.8 V
2.1
2.2
2.2
2.2
2.3
2.8
pF
VCCI = 1.2 V
2.2
2.3
2.4
2.3
2.4
2.5
pF
VCCI = 1.5 V
2.3
2.3
2.3
2.4
2.4
2.5
pF
VCCI = 1.8 V
2.3
2.3
2.3
2.4
2.4
2.5
pF
VCCI = 2.5 V
2.3
2.3
2.3
2.3
2.4
2.6
pF
fi = 1 MHz; RL = ; VI = 0 V to VCCI
[1]
[2]
1A, 2A; input supply
VCCI = 2.5 V
[3]
1Y; output supply
[3]
2Y; output supply
CI
input
capacitance
VI = 0 V or VCCI; VCCI = 0 V to 2.7 V
0.6
0.6
0.6
0.6
0.6
0.6
pF
CO
output
capacitance
2Y; VO = 0 V; VCCO = 0 V
1.3
1.3
1.3
1.3
1.3
1.3
pF
1Y; VO = 0 V; VCCO = 0 V
1.8
1.8
1.8
1.8
1.8
1.8
pF
[1]
CPD is used to determine the dynamic power dissipation (PD in W).
[2]
Power dissipated from input supply (VCCI)
PD = CPD VCCI2 fi N where:
CPD = power dissipation capacitance of the input supply.
VCCI = input supply voltage in V;
fi = input frequency in MHz;
N = number of inputs switching;
[3]
Power dissipated from output supply (VCCO)
PD = (CL + CPD) VCCO2 fo where:
CL = load capacitance in pF;
CPD = power dissipation capacitance of the output supply.
VCCO = output supply voltage in V;
fo = output frequency in MHz;
74AXP2T3407
Product data sheet
10 of 22
74AXP2T3407
Nexperia
11.1 Waveforms and graphs
9,
$LQSXW
90
90
*1'
W3/+
92+
W3+/
很抱歉,暂时无法提供与“74AXP2T3407DCH”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+6.611351+0.84804
- 10+4.7089910+0.60403
- 25+4.2363825+0.54340
- 100+3.71089100+0.47600
- 250+3.46081250+0.44392
- 国内价格 香港价格
- 417+7.72152417+0.99044
- 500+6.94971500+0.89144
- 1000+6.408591000+0.82203
- 10000+5.7139610000+0.73293
- 100000+4.78779100000+0.61413
