HEF4104BT,653
HEF4104BT,653
    NEXPERIA(安世)
    SOIC-16
    电压电平 转换器 单向 1 电路 4 通道 16SOIC
HEF4104BT,653 数据手册
HEF4104B Quad low-to-high voltage translator with 3-state outputs Rev. 9 — 29 March 2016 Product data sheet 1. General description The HEF4104B is a quad low voltage-to-high voltage translator with 3-state outputs. It provides the capability of interfacing low voltage circuits to high voltage circuits. For example low voltage Local Oxidation Complementary MOS (LOCMOS) and Transistor-Transistor Logic (TTL) to high voltage LOCMOS. It has four data inputs (A0 to A3), an active HIGH output enable input (OE), four data outputs (B0 to B3) and their complements (B0 to B3). With OE = HIGH, the outputs B0 to B3 and B0 to B3 are in the low impedance ON-state, either HIGH or LOW as determined by the inputs A0 to A3. With OE = LOW, the outputs B0 to B3 and B0 to B3 are in the high-impedance OFF-state. It uses a common negative supply (VSS) and separate positive supplies for the inputs (VDD(A)) and the outputs (VDD(B)). VDD(A) must always be less than or equal to VDD(B), even during power turn-on and turn-off. For the permissible operating range of VDD(A) and VDD(B) see Figure 4. Each input protection circuit is terminated between VDD(B) and VSS. This allows the input signals to be driven from any potential between VDD(B) and VSS, without regard to current limiting. When driving from potentials greater than VDD(B) or less than VSS, the current at each input must be limited to 10 mA. It operates over a recommended VDD power supply range of 3 V to 15 V referenced to VSS (usually ground). Unused inputs must be connected to VDD, VSS, or another input. 2. Features and benefits       Fully static operation 5 V, 10 V, and 15 V parametric ratings Standardized symmetrical output characteristics Inputs and outputs are protected against electrostatic effects Specified from 40 C to +85 C Complies with JEDEC standard JESD 13-B 3. Ordering information Table 1. Ordering information All types operate from 40 C to +85 C. Type number HEF4104BT Package Name Description Version SO16 plastic small outline package; 16 leads; body width 3.9 mm SOT109-1 HEF4104B Nexperia Quad low-to-high voltage translator with 3-state outputs 4. Functional diagram 9'' $ 9'' %    $   $   % % /(9(/ &219(57(5 $ % % %  $  /(9(/ &219(57(5 /(9(/ &219(57(5 $   $ % % % /(9(/ &219(57(5 $ % % % /(9(/ &219(57(5 $   % /(9(/ &219(57(5 2( 966 Logic symbol HEF4104B Product data sheet % %  Fig 1. %   2( % 9'' $ DDJ Fig 2. 9'' % DDJ Logic diagram All information provided in this document is subject to legal disclaimers. Rev. 9 — 29 March 2016 © Nexperia B.V. 2017. All rights reserved 2 of 14 HEF4104B Nexperia Quad low-to-high voltage translator with 3-state outputs 5. Pinning information 5.1 Pinning +()% 9'' %   9'' $ %   2( %   % $   % $   $ %   $ %   % 966   % DDJ Fig 3. Pin configuration 5.2 Pin description Table 2. Pin description Symbol Pin Description VDD(B) 1 supply voltage port B B0 to B3 2, 7, 9, 14 complementary data output B0 to B3 3, 6, 10, 13 data output A0 to A3 4, 5, 11, 12 data input VSS 8 common negative supply voltage (0 V) OE 15 output enable input VDD(A) 16 supply voltage port A 6. Functional description Table 3. Function table[1] Control Output OE Bn Bn H An An L Z Z [1] H = HIGH voltage level; L = LOW voltage level; Z = high-impedance OFF-state. HEF4104B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 29 March 2016 © Nexperia B.V. 2017. All rights reserved 3 of 14 HEF4104B Nexperia Quad low-to-high voltage translator with 3-state outputs 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to VSS = 0 V (ground). Symbol Parameter Conditions Min Max Unit VDD(A) supply voltage A port A; VDD(A)  VDD(B) 0.5 +18 V VDD(B) supply voltage B port B; VDD(B)  VDD(A) 0.5 +18 V IIK input clamping current VI < 0.5 V or VI > VDD(A) + 0.5 V - 10 mA VI input voltage IOK output clamping current 0.5 VO < 0.5 V or VO > VDD(B) + 0.5 V VDD(A) + 0.5 V - 10 - 10 mA - 50 mA mA II/O input/output current IDD supply current Tstg storage temperature 65 +150 C Tamb ambient temperature 40 +85 C Ptot total power dissipation - 500 mW - 100 mW [1] Tamb = 40 C to +85 C SO16 P power dissipation [2] per output [1] IDD is the combined current of IDD(A) and IDD(B). [2] For SO16 packages: above Tamb = 70 C, Ptot derates linearly at 8 mW/K. 8. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter Min Typ VDD(A) supply voltage A Conditions 3 - Max Unit VDD(B) supply voltage B  VDD(A) - 15 V VI input voltage 0 - VDD(A) V  VDD(B) V Tamb ambient temperature in free air 40 - +85 C t/V input transition rise and fall rate VDD(A) = 5 V - - 3.75 s/V VDD(A) = 10 V - - 0.5 s/V VDD(A) = 15 V - - 0.08 s/V HEF4104B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 29 March 2016 © Nexperia B.V. 2017. All rights reserved 4 of 14 HEF4104B Nexperia Quad low-to-high voltage translator with 3-state outputs 9. Static characteristics Table 6. Static characteristics VDD(A) = VDD(B); VSS = 0 V; VI = VSS or VDD(A); unless otherwise specified. Symbol Parameter HIGH-level input voltage VIH LOW-level input voltage VIL VOH VOL IO < 1 A IO < 1 A LOW-level output voltage IO < 1 A LOW-level output current IOL IO < 1 A HIGH-level output voltage HIGH-level output current IOH Conditions supply current IDD OFF-state output current IOZ input capacitance CI Min Max Min Max 5V 3.5 - 3.5 - 3.5 - V 10 V 7.0 - 7.0 - 7.0 - V 15 V 11.0 - 11.0 - 11.0 - V 5V - 1.5 - 1.5 - 1.5 V 10 V - 3.0 - 3.0 - 3.0 V 15 V - 4.0 - 4.0 - 4.0 V 5V 4.95 - 4.95 - 4.95 - V 10 V 9.95 - 9.95 - 9.95 - V 15 V 14.95 - 14.95 - 14.95 - V 5V - 0.05 - 0.05 - 0.05 V 10 V - 0.05 - 0.05 - 0.05 V 15 V - 0.05 - 0.05 - 0.05 V mA 5V - 1.7 - 1.4 - 1.1 5V - 0.52 - 0.44 - 0.36 mA VO = 9.5 V 10 V - 1.3 - 1.1 - 0.9 mA VO = 13.5 V 15 V - 3.6 - 3.0 - 2.4 mA VO = 0.4 V 5V 0.52 - 0.44 - 0.36 - mA VO = 0.5 V 10 V 1.3 - 1.1 - 0.9 - mA VO = 1.5 V 15 V 3.6 - 3.0 - 2.4 - mA - 0.3 - 0.3 - 1.0 A 15 V - 20 - 20 - 150 A 10 V - 40 - 40 - 300 A 15 V - 80 - 80 - 600 A HIGH level; VO = VDD(B) 15 V - 1.6 - 1.6 - 12.0 A LOW level; VO = VSS 15 V - 1.6 - 1.6 - 12.0 A digital inputs - - - - 7.5 - all valid input combinations; IO = 0 A [1] VDD is the same as VDD(A) and VDD(B). IDD is the combined current of IDD(A) and IDD(B). Product data sheet Max VO = 2.5 V [2] HEF4104B Min VO = 4.6 V input leakage current II Tamb = 40 C Tamb = +25 C Tamb = +85 C Unit VDD[1] 5V [2] All information provided in this document is subject to legal disclaimers. Rev. 9 — 29 March 2016 © - pF Nexperia B.V. 2017. All rights reserved 5 of 14 HEF4104B Nexperia Quad low-to-high voltage translator with 3-state outputs DDJ  9'' %  9 RSHUDWLQJDUHD        9'' $  9 The shaded area shows the permissible operating range. Fig 4. VDD(B) as a function of VDD(A) 10. Dynamic characteristics Table 7. Dynamic characteristics Tamb = 25 C; for test circuit see Figure 7; unless otherwise specified. Symbol Parameter tPHL tPLH tTHL tTLH tPHZ HIGH to LOW propagation delay LOW to HIGH propagation delay Extrapolation formula[1] Min Typ Max Unit VDD(A) = VDD(B) = 5 V 143 ns + (0.55 ns/pF)CL - 170 340 ns VDD(A) = VDD(B) = 10 V 69 ns + (0.23 ns/pF)CL - 80 160 ns VDD(A) = VDD(B) = 15 V 57 ns + (0.16 ns/pF)CL - 65 135 ns VDD(A) = VDD(B) = 5 V 143 ns + (0.55 ns/pF)CL - 170 340 ns VDD(A) = VDD(B) = 10 V 69 ns + (0.23 ns/pF)CL - 80 160 ns VDD(A) = VDD(B) = 15 V 62 ns + (0.16 ns/pF)CL - 70 140 ns 10 ns + (1.00 ns/pF)CL - 60 120 ns VDD(A) = VDD(B) = 10 V 9 ns + (0.42 ns/pF)CL - 30 60 ns VDD(A) = VDD(B) = 15 V 6 ns + (0.28 ns/pF)CL - 20 40 ns 10 ns + (1.00 ns/pF)CL - 60 120 ns VDD(A) = VDD(B) = 10 V 9 ns + (0.42 ns/pF)CL - 30 60 ns VDD(A) = VDD(B) = 15 V 6 ns + (0.28 ns/pF)CL - 20 40 ns VDD(A) = VDD(B) = 5 V - 70 135 ns VDD(A) = VDD(B) = 10 V - 55 110 ns VDD(A) = VDD(B) = 15 V - 60 120 ns Conditions An to Bn, Bn; see Figure 5 An to Bn, Bn; see Figure 5 HIGH to LOW output Bn or Bn; see Figure 6 transition time VDD(A) = VDD(B) = 5 V LOW to HIGH output Bn or Bn; see Figure 6 transition time VDD(A) = VDD(B) = 5 V HIGH to OFF-state propagation delay HEF4104B Product data sheet OE to Bn, Bn; see Figure 6 All information provided in this document is subject to legal disclaimers. Rev. 9 — 29 March 2016 © Nexperia B.V. 2017. All rights reserved 6 of 14 HEF4104B Nexperia Quad low-to-high voltage translator with 3-state outputs Table 7. Dynamic characteristics …continued Tamb = 25 C; for test circuit see Figure 7; unless otherwise specified. Extrapolation formula[1] Symbol Parameter Conditions tPLZ OE to Bn, Bn; see Figure 6 LOW to OFF-state propagation delay OFF-state to HIGH propagation delay tPZH OFF-state to LOW propagation delay tPZL [1] Min Typ Max Unit VDD(A) = VDD(B) = 5 V - 70 135 ns VDD(A) = VDD(B) = 10 V - 55 105 ns VDD(A) = VDD(B) = 15 V - 55 110 ns VDD(A) = VDD(B) = 5 V - 195 395 ns VDD(A) = VDD(B) = 10 V - 95 195 ns VDD(A) = VDD(B) = 15 V - 80 165 ns VDD(A) = VDD(B) = 5 V - 195 395 ns VDD(A) = VDD(B) = 10 V - 95 190 ns VDD(A) = VDD(B) = 15 V - 80 160 ns OE to Bn, Bn; see Figure 6 OE to Bn, Bn; see Figure 6 Typical value of the propagation delay and output transition time can be calculated with the extrapolation formula (CL in pF). Table 8. Dynamic power dissipation VDD(A) = VDD(B); VSS = 0 V; tr = tf  20 ns; Tamb = 25 C. Symbol Parameter dynamic power dissipation PD VDD[1] Typical formula (W) where 5V PD = 3000  fi + (fo  CL)  VDD 10 V PD = 12200  fi + (fo  CL)  VDD 15 V PD = 31000  fi + (fo  CL)  VDD2 2 fi = input frequency in MHz; 2 fo = output frequency in MHz; CL = output load capacitance in pF; (fo  CL) = sum of the outputs; VDD = supply voltage in V. [1] VDD is the same as VDD(A) and VDD(B). HEF4104B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 29 March 2016 © Nexperia B.V. 2017. All rights reserved 7 of 14 HEF4104B Nexperia Quad low-to-high voltage translator with 3-state outputs 11. Waveforms 9, $QLQSXW 90 9 W3+/ 92+ W3/+ 9< 90 %QRXWSXW 9; 92/ W7+/ W7/+ W3/+ 92+ W3+/ 9< %QRXWSXW 9; 92/ W7/+ W7+/ DDM Measurement points are given in Table 9. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Fig 5. Data input (An) to data output (Bn, Bn) propagation delays and output transition times 9, 2(LQSXW 90 966 W3/= RXWSXW /2:WR2)) 2))WR/2: W3=/ 92+ 9< 9; 92/ W3+= 92+ W3=+ 9< RXWSXW +,*+WR2)) 2))WR+,*+ 9; 92/ RXWSXWVRQ RXWSXWVRII RXWSXWVRQ DDM Measurement points are given in Table 9. Logic levels: VOL and VOH are typical output voltage levels that occur with the output load. Fig 6. Table 9. Enable and disable times Measurement points Input Output VI VM VM VX VY VSS or VDD(A) 0.5VDD(A) 0.5VDD(B) 0.1VDD(B) 0.9VDD(B) HEF4104B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 29 March 2016 © Nexperia B.V. 2017. All rights reserved 8 of 14 HEF4104B Nexperia Quad low-to-high voltage translator with 3-state outputs W: 9,   QHJDWLYH SXOVH 90 90  9  WI WU WU WI 9,  SRVLWLYH SXOVH  90 90  9  W: DDM a. Input waveforms 9(;7 9'' * 9, 5/ 92 '87 57 &/ DDM b. Test circuit Test data given in Table 10. Definitions for test circuit: DUT = Device Under Test. CL = load capacitance including jig and probe capacitance. RL = load resistance. RT = termination resistance should be equal to the output impedance Zo of the pulse generator. Fig 7. Test circuit for measuring switching times Table 10. Test data Supplies Input Load VDD(A) = VDD(B) tr, tf RL CL tPHL, tPLH tPZL, tPLZ tPZH, tPHZ 5 V to 15 V  20 ns 1 k 50 pF open VDD(B) VSS HEF4104B Product data sheet VEXT All information provided in this document is subject to legal disclaimers. Rev. 9 — 29 March 2016 © Nexperia B.V. 2017. All rights reserved 9 of 14 HEF4104B Nexperia Quad low-to-high voltage translator with 3-state outputs 12. Package outline 62SODVWLFVPDOORXWOLQHSDFNDJHOHDGVERG\ZLGWKPP 627 ' ( $ ; F \ +( Y 0 $ =   4 $ $ $   $ SLQLQGH[ ș /S  /  H Z 0 ES   GHWDLO; PP VFDOH ',0(16,216 LQFKGLPHQVLRQVDUHGHULYHGIURPWKHRULJLQDOPPGLPHQVLRQV  81,7 $ PD[ $ $ $ ES F '   (   H +( / /S 4 Y Z \ =   PP                                                 LQFKHV         ș R R 1RWH 3ODVWLFRUPHWDOSURWUXVLRQVRIPP LQFK PD[LPXPSHUVLGHDUHQRWLQFOXGHG Fig 8. 5()(5(1&(6 287/,1( 9(56,21 ,(& -('(& 627 ( 06 -(,7$ (8523($1 352-(&7,21 ,668('$7(   Package outline SOT109-1 (SO16) HEF4104B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 29 March 2016 © Nexperia B.V. 2017. All rights reserved 10 of 14 HEF4104B Nexperia Quad low-to-high voltage translator with 3-state outputs 13. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes HEF4104B v.9 20160329 Product data sheet - HEF4104B v.8 Modifications: HEF4104B v.8 Modifications: • Type number HEF4104BP (SOT38-4) removed. 20111111 • • Product data sheet - HEF4104B v.7 Section Applications removed Table 6: IOH minimum values changed to maximum HEF4104B v.7 20091216 Product data sheet - HEF4104B v.6 HEF4104B v.6 20091102 Product data sheet - HEF4104B v.5 HEF4104B v.5 20090728 Product data sheet - HEF4104B v.4 HEF4104B v.4 20090305 Product data sheet - HEF4104B_CNV v.3 HEF4104B_CNV v.3 19950101 Product specification - HEF4104B_CNV v.2 HEF4104B_CNV v.2 19950101 Product specification - - HEF4104B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 29 March 2016 © Nexperia B.V. 2017. All rights reserved 11 of 14 HEF4104B Nexperia Quad low-to-high voltage translator with 3-state outputs 14. Legal information 14.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 14.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 14.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. HEF4104B Product data sheet Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. All information provided in this document is subject to legal disclaimers. Rev. 9 — 29 March 2016 © Nexperia B.V. 2017. All rights reserved 12 of 14 HEF4104B Nexperia Quad low-to-high voltage translator with 3-state outputs Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. 14.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 15. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com HEF4104B Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 9 — 29 March 2016 © Nexperia B.V. 2017. All rights reserved 13 of 14 HEF4104B Nexperia Quad low-to-high voltage translator with 3-state outputs 16. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 11 12 13 14 14.1 14.2 14.3 14.4 15 16 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 1 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 3 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 3 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 3 Functional description . . . . . . . . . . . . . . . . . . . 3 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 4 Recommended operating conditions. . . . . . . . 4 Static characteristics. . . . . . . . . . . . . . . . . . . . . 5 Dynamic characteristics . . . . . . . . . . . . . . . . . . 6 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 10 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 11 Legal information. . . . . . . . . . . . . . . . . . . . . . . 12 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 12 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 12 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 13 Contact information. . . . . . . . . . . . . . . . . . . . . 13 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 14 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 29 March 2016
HEF4104BT,653 价格&库存
很抱歉,暂时无法提供与“HEF4104BT,653”相匹配的价格&库存,您可以联系我们找货
HEF4104BT,653
  • 1+7.739601+0.97094
  • 10+5.5369510+0.69462
  • 25+4.9869825+0.62562
  • 100+4.37878100+0.54932
  • 250+4.08953250+0.51304
  • 500+3.91505500+0.49115
  • 1000+3.891821000+0.48823
HEF4104BT,653
  • 2500+3.619602500+0.45408
  • 5000+3.528155000+0.44261
  • 7500+3.482367500+0.43687
  • 12500+3.4316412500+0.43050
  • 17500+3.4019817500+0.42678
  • 25000+3.3734725000+0.42321
HEF4104BT,653
  • 1+6.04968
  • 10+5.82281
  • 100+5.25986
