74AVC2T45DC-Q100H
74AVC2T45DC-Q100H
    NEXPERIA(安世)
    VSSOP-8
    电压电平 转换器 双向 1 电路 2 通道 500Mbps 8-VSSOP
74AVC2T45DC-Q100H 数据手册
74AVC2T45-Q100 Dual-bit, dual-supply voltage level translator/transceiver; 3-state Rev. 4 — 6 May 2019 Product data sheet 1. General description The 74AVC2T45-Q100 is a dual-bit, dual-supply transceiver that enables bidirectional level translation. It features two data input-output ports (nA and nB), a direction control input (DIR) and dual supply pins (VCC(A) and VCC(B)). Both VCC(A) and VCC(B) can be supplied with any voltage between 0.8 V and 3.6 V. This flexibility makes the device suitable for translating between any of the low voltage nodes (0.8 V, 1.2 V, 1.5 V, 1.8 V, 2.5 V and 3.3 V). Pins nA and DIR are referenced to VCC(A) and pins nB are referenced to VCC(B). A HIGH on DIR allows transmission from nA to nB and a LOW on DIR allows transmission from nB to nA. The device is fully specified for partial power-down applications using IOFF. The IOFF circuitry disables the output, preventing any damaging backflow current through the device when it is powered down. In Suspend mode when either VCC(A) or VCC(B) are at GND level, both A and B are in the high-impedance OFF-state. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits • • • • • • • • • • • Automotive product qualification in accordance with AEC-Q100 (Grade 1) • Specified from -40 °C to +85 °C and from -40 °C to +125 °C Wide supply voltage range: • VCC(A): 0.8 V to 3.6 V • VCC(B): 0.8 V to 3.6 V High noise immunity Complies with JEDEC standards: • JESD8-12 (0.8 V to 1.3 V) • JESD8-11 (0.9 V to 1.65 V) • JESD8-7 (1.2 V to 1.95 V) • JESD8-5 (1.8 V to 2.7 V) • JESD8-B (2.7 V to 3.6 V) ESD protection: • MIL-STD-883, method 3015 Class 3B exceeds 8000 V • HBM JESD22-A114E Class 3B exceeds 8000 V • MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 Ω) Maximum data rates: • 500 Mbit/s (1.8 V to 3.3 V translation) • 320 Mbit/s (
74AVC2T45DC-Q100H 价格&库存
很抱歉,暂时无法提供与“74AVC2T45DC-Q100H”相匹配的价格&库存,您可以联系我们找货
74AVC2T45DC-Q100H
  • 1+4.642421+0.58240
  • 10+3.2699310+0.41022
  • 25+2.9221725+0.36659
  • 100+2.53864100+0.31848
  • 250+2.35699250+0.29569
  • 500+2.24698500+0.28189
  • 1000+2.177571000+0.27318
库存:2250
74AVC2T45DC-Q100H
  • 3000+1.842333000+0.23112
  • 6000+1.792176000+0.22483
  • 9000+1.767069000+0.22168
  • 15000+1.7392315000+0.21819
  • 21000+1.7229821000+0.21615
  • 30000+1.7073430000+0.21419
库存:2250
74AVC2T45DC-Q100H
    • 1+8.295961+1.04073
    • 10+5.1162910+0.64184
    • 50+4.5308050+0.56839
    • 100+4.14348100+0.51980
    • 500+4.07142500+0.51076
    • 1000+4.008371000+0.50285
    • 2000+3.981342000+0.49946
    库存:25
