74LVCH1T45GN,132
74LVCH1T45GN,132
    NEXPERIA(安世)
    XSON6_0.9X1MM
    电压电平转换器 1.2~5.5V 100mA XSON6_0.9X1MM
74LVCH1T45GN,132 数据手册
74LVC1T45; 74LVCH1T45 Dual supply translating transceiver; 3-state Rev. 7 — 19 March 2019 Product data sheet 1. General description The 74LVC1T45; 74LVCH1T45 are single bit, dual supply transceivers with 3-state outputs that enable bidirectional level translation. They feature two 1-bit input-output ports (A and B), a direction control input (DIR) and dual supply pins (VCC(A) and VCC(B)). Both VCC(A) and VCC(B) can be supplied at any voltage between 1.2 V and 5.5 V making the device suitable for translating between any of the low voltage nodes (1.2 V, 1.5 V, 1.8 V, 2.5 V, 3.3 V and 5.0 V). Pins A and DIR are referenced to VCC(A) and pin B is referenced to VCC(B). A HIGH on DIR allows transmission from A to B and a LOW on DIR allows transmission from B to A. The devices are fully specified for partial power-down applications using IOFF. The IOFF circuitry disables the output, preventing any damaging backflow current through the device when it is powered down. In suspend mode when either VCC(A) or VCC(B) are at GND level, both A port and B port are in the high-impedance OFF-state. Active bus hold circuitry in the 74LVCH1T45 holds unused or floating data inputs at a valid logic level. 2. Features and benefits • • • • • • • • • • • • • Wide supply voltage range: • VCC(A): 1.2 V to 5.5 V • VCC(B): 1.2 V to 5.5 V High noise immunity Complies with JEDEC standards: • JESD8-7 (1.2 V to 1.95 V) • JESD8-5 (1.8 V to 2.7 V) • JESD8C (2.7 V to 3.6 V) • JESD36 (4.5 V to 5.5 V) ESD protection: • HBM JESD22-A114F Class 3A exceeds 4000 V • CDM JESD22-C101E exceeds 1000 V Maximum data rates: • 420 Mbps (3.3 V to 5.0 V translation) • 210 Mbps (translate to 3.3 V)) • 140 Mbps (translate to 2.5 V) • 75 Mbps (translate to 1.8 V) • 60 Mbps (translate to 1.5 V) Suspend mode Latch-up performance exceeds 100 mA per JESD 78 Class II ±24 mA output drive (VCC = 3.0 V) Inputs accept voltages up to 5.5 V Low power consumption: 16 μA maximum ICC IOFF circuitry provides partial Power-down mode operation Multiple package options Specified from -40 °C to +85 °C and -40 °C to +125 °C 74LVC1T45; 74LVCH1T45 Nexperia Dual supply translating transceiver; 3-state 3. Ordering information Table 1. Ordering information Type number Package 74LVC1T45GW Temperature range Name Description Version -40 °C to +125 °C SC-88 plastic surface-mounted package; 6 leads SOT363 -40 °C to +125 °C XSON6 plastic extremely thin small outline package; no leads; 6 terminals; body 1 × 1.45 × 0.5 mm SOT886 -40 °C to +125 °C XSON6 plastic extremely thin small outline package; no leads; 6 terminals; body 1 × 1 × 0.5 mm SOT891 -40 °C to +125 °C XSON6 extremely thin small outline package; no leads; 6 terminals; body 0.9 × 1.0 × 0.35 mm SOT1115 -40 °C to +125 °C XSON6 extremely thin small outline package; no leads; 6 terminals; body 1.0 × 1.0 × 0.35 mm SOT1202 74LVCH1T45GW 74LVC1T45GM 74LVCH1T45GM 74LVC1T45GF 74LVCH1T45GF 74LVC1T45GN 74LVCH1T45GN 74LVC1T45GS 74LVCH1T45GS 4. Marking Table 2. Marking Type number Marking code [1] 74LVC1T45GW V5 74LVCH1T45GW X5 74LVC1T45GM V5 74LVCH1T45GM X5 74LVC1T45GF V5 74LVCH1T45GF X5 74LVC1T45GN V5 74LVCH1T45GN X5 74LVC1T45GS V5 74LVCH1T45GS X5 [1] The pin 1 indicator is located on the lower left corner of the device, below the marking code. 5. Functional diagram DIR A 5 DIR 3 A 4 VCC(A) B B VCC(B) VCC(A) VCC(B) 001aag885 Fig. 1. Logic symbol 74LVC_LVCH1T45 Product data sheet 001aag886 Fig. 2. Logic diagram All information provided in this document is subject to legal disclaimers. Rev. 7 — 19 March 2019 © Nexperia B.V. 2019. All rights reserved 2 / 31 74LVC1T45; 74LVCH1T45 Nexperia Dual supply translating transceiver; 3-state 6. Pinning information 6.1. Pinning 74LVC1T45 74LVCH1T45 74LVC1T45 74LVCH1T45 VCC(A) VCC(A) 1 6 VCC(B) GND 2 5 DIR A 3 4 6 VCC(B) GND 2 5 DIR A 3 4 B B Transparent top view Pin configuration SOT363 (SC-88) VCC(A) 1 6 VCC(B) GND 2 5 DIR A 3 4 B 001aaj993 001aaj992 001aaj991 Fig. 3. 1 74LVC1T45 74LVCH1T45 Fig. 4. Pin configuration SOT886 (XSON6) Transparent top view Fig. 5. Pin configuration SOT891, SOT1115 and SOT1202 (XSON6) 6.2. Pin description Table 3. Pin description Symbol Pin Description VCC(A) 1 supply voltage port A and DIR GND 2 ground (0 V) A 3 data input or output B 4 data input or output DIR 5 direction control VCC(B) 6 supply voltage port B 7. Functional description Table 4. Function table H = HIGH voltage level; L = LOW voltage level; X = don’t care; Z = high-impedance OFF-state. Supply voltage Input Input/output [1] VCC(A), VCC(B) DIR A B 1.2 V to 5.5 V L A=B input 1.2 V to 5.5 V H input B=A GND [2] X Z Z [1] [2] The input circuit of the data I/O is always active. When either VCC(A) or VCC(B) is at GND level, the device goes into suspend mode. 74LVC_LVCH1T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 19 March 2019 © Nexperia B.V. 2019. All rights reserved 3 / 31 74LVC1T45; 74LVCH1T45 Nexperia Dual supply translating transceiver; 3-state 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Max Unit VCC(A) supply voltage A -0.5 +6.5 V VCC(B) supply voltage B -0.5 +6.5 V IIK input clamping current VI input voltage IOK output clamping current VO < 0 V VO output voltage Active mode VI < 0 V [1] -50 - -0.5 +6.5 -50 - [1][2][3] -0.5 Suspend or 3-state mode [1] -0.5 [2] mA V mA VCCO + 0.5 V +6.5 V - ±50 mA - 100 mA IO output current VO = 0 V to VCCO ICC supply current ICC(A) or ICC(B) IGND ground current -100 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 250 mW [1] [2] [3] [4] Tamb = -40 °C to +125 °C [4] The minimum input voltage ratings and output voltage ratings may be exceeded if the input and output current ratings are observed. VCCO is the supply voltage associated with the output port. VCCO + 0.5 V should not exceed 6.5 V. For SC-88 package: above 87.5 °C the value of Ptot derates linearly with 4.0 mW/K. For XSON6 package: above 118 °C the value of Ptot derates linearly with 7.8 mW/K. 9. Recommended operating conditions Table 6. Recommended operating conditions Symbol Parameter Conditions Min Max Unit VCC(A) supply voltage A 1.2 5.5 V VCC(B) supply voltage B 1.2 5.5 V VI input voltage 0 5.5 V VO output voltage 0 VCCO V 0 5.5 V -40 +125 °C - 20 ns/V VCCI = 1.4 V to 1.95 V - 20 ns/V VCCI = 2.3 V to 2.7 V - 20 ns/V VCCI = 3 V to 3.6 V - 10 ns/V VCCI = 4.5 V to 5.5 V - 5 ns/V Active mode [1] Suspend or 3-state mode Tamb ambient temperature Δt/ΔV input transition rise and fall rate [1] [2] VCCI = 1.2 V [2] VCCO is the supply voltage associated with the output port. VCCI is the supply voltage associated with the input port. 74LVC_LVCH1T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 19 March 2019 © Nexperia B.V. 2019. All rights reserved 4 / 31 74LVC1T45; 74LVCH1T45 Nexperia Dual supply translating transceiver; 3-state 10. Static characteristics Table 7. Typical static characteristics at Tamb = 25 °C At recommended operating conditions; voltages are referenced to GND (ground = 0 V). [1][2] Symbol Parameter Conditions Min Typ Max VOH HIGH-level output voltage VOL Unit VI = VIH or VIL; IO = -3 mA; VCCO = 1.2 V - 1.09 - V LOW-level output voltage VI = VIH or VIL; IO = 3 mA; VCCO = 1.2 V - 0.07 - V II input leakage current DIR input; VI = 0 V to 5.5 V; VCCI = 1.2 V to 5.5 V - - ±1 μA IBHL bus hold LOW current A or B port; VI = 0.42 V; VCCI = 1.2 V - 19 - μA IBHH bus hold HIGH current A or B port; VI = 0.78 V; VCCI = 1.2 V - -19 - μA IBHLO bus hold LOW overdrive current A or B port; VCCI = 1.2 V [3] - 19 - μA IBHHO bus hold HIGH overdrive current A or B port; VCCI = 1.2 V [3] - -19 - μA IOZ OFF-state output current A or B port; VO = 0 V or VCCO; VCCO = 1.2 V to 5.5 V - - ±1 μA IOFF power-off leakage current A port; VI or VO = 0 V to 5.5 V; VCC(A) = 0 V; VCC(B) = 1.2 V to 5.5 V - - ±1 μA B port; VI or VO = 0 V to 5.5 V; VCC(B) = 0 V; VCC(A) = 1.2 V to 5.5 V - - ±1 μA CI input capacitance DIR input; VI = 0 V or 3.3 V; VCC(A) = VCC(B) = 3.3 V - 2.2 - pF CI/O input/output capacitance A and B port; suspend mode; VO = 3.3 V or 0 V; VCC(A) = VCC(B) = 3.3 V - 6.0 - pF [1] [2] [3] VCCI is the supply voltage associated with the data input port. VCCO is the supply voltage associated with the output port. To guarantee the node switches, an external driver must source/sink at least IBHLO/IBHHO when the input is in the range VIL to VIH. Table 8. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). [1][2] Symbol Parameter VIH HIGH-level input voltage Conditions -40 °C to +85 °C Min Max VCCI = 1.2 V 0.8VCCI VCCI = 1.4 V to 1.95 V 0.65VCCI VCCI = 2.3 V to 2.7 V -40 °C to +125 °C Unit Min Max - 0.8VCCI - V - 0.65VCCI - V 1.7 - 1.7 - V VCCI = 3.0 V to 3.6 V 2.0 - 2.0 - V VCCI = 4.5 V to 5.5 V 0.7VCCI - 0.7VCCI - V VCCI = 1.2 V 0.8VCC(A) - 0.8VCC(A) - V VCCI = 1.4 V to 1.95 V 0.65VCC(A) - 0.65VCC(A) - V VCCI = 2.3 V to 2.7 V 1.7 - 1.7 - V VCCI = 3.0 V to 3.6 V 2.0 - 2.0 - V VCCI = 4.5 V to 5.5 V 0.7VCC(A) - 0.7VCC(A) - V data input DIR input 74LVC_LVCH1T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 19 March 2019 © Nexperia B.V. 2019. All rights reserved 5 / 31 74LVC1T45; 74LVCH1T45 Nexperia Dual supply translating transceiver; 3-state Symbol Parameter Conditions -40 °C to +85 °C Min VIL LOW-level input voltage -40 °C to +125 °C Max Min Unit Max data input VCCI = 1.2 V - 0.2VCCI - 0.2VCCI VCCI = 1.4 V to 1.95 V - 0.35VCCI - 0.35VCCI V V VCCI = 2.3 V to 2.7 V - 0.7 - 0.7 V VCCI = 3.0 V to 3.6 V - 0.8 - 0.8 V VCCI = 4.5 V to 5.5 V - 0.3VCCI - 0.3VCCI V VCCI = 1.2 V - 0.2VCC(A) - 0.2VCC(A) V VCCI = 1.4 V to 1.95 V - 0.35VCC(A) - 0.35VCC(A) V VCCI = 2.3 V to 2.7 V - 0.7 - 0.7 V VCCI = 3.0 V to 3.6 V - 0.8 - 0.8 V VCCI = 4.5 V to 5.5 V - 0.3VCC(A) - VCCO - 0.1 - VCCO - 0.1 - V IO = -6 mA; VCCO = 1.4 V 1.0 - 1.0 - V IO = -8 mA; VCCO = 1.65 V 1.2 - 1.2 - V IO = -12 mA; VCCO = 2.3 V 1.9 - 1.9 - V IO = -24 mA; VCCO = 3.0 V 2.4 - 2.4 - V IO = -32 mA; VCCO = 4.5 V 3.8 - 3.8 - V IO = 100 μA; VCCO = 1.2 V to 4.5 V - 0.1 - 0.1 V IO = 6 mA; VCCO = 1.4 V - 0.3 - 0.3 V IO = 8 mA; VCCO = 1.65 V - 0.45 - 0.45 V IO = 12 mA; VCCO = 2.3 V - 0.3 - 0.3 V IO = 24 mA; VCCO = 3.0 V - 0.55 - 0.55 V IO = 32 mA; VCCO = 4.5 V - 0.55 - 0.55 V - ±2 - ±10 μA VI = 0.49 V; VCCI = 1.4 V 15 - 10 - μA VI = 0.58 V; VCCI = 1.65 V 25 - 20 - μA VI = 0.70 V; VCCI = 2.3 V 45 - 45 - μA VI = 0.80 V; VCCI = 3.0 V 100 - 80 - μA VI = 1.35 V; VCCI = 4.5 V 100 - 100 - μA bus hold HIGH A or B port current VI = 0.91 V; VCCI = 1.4 V -15 - -10 - μA VI = 1.07 V; VCCI = 1.65 V -25 - -20 - μA VI = 1.60 V; VCCI = 2.3 V -45 - -45 - μA VI = 2.00 V; VCCI = 3.0 V -100 - -80 - μA VI = 3.15 V; VCCI = 4.5 V -100 - -100 - μA DIR input VOH VOL HIGH-level output voltage LOW-level output voltage IO = -100 μA; VCCO = 1.2 V to 4.5 V VI = VIL II input leakage current DIR input; VI = 0 V to 5.5 V; VCCI = 1.2 V to 5.5 V IBHL bus hold LOW current A or B port IBHH 74LVC_LVCH1T45 Product data sheet 0.3VCC(A) V VI = VIH All information provided in this document is subject to legal disclaimers. Rev. 7 — 19 March 2019 © Nexperia B.V. 2019. All rights reserved 6 / 31 74LVC1T45; 74LVCH1T45 Nexperia Dual supply translating transceiver; 3-state Symbol Parameter IBHLO IBHHO bus hold LOW overdrive current Conditions -40 °C to +85 °C -40 °C to +125 °C Unit Min Max Min Max VCCI = 1.6 V 125 - 125 - μA VCCI = 1.95 V 200 - 200 - μA VCCI = 2.7 V 300 - 300 - μA VCCI = 3.6 V 500 - 500 - μA VCCI = 5.5 V 900 - 900 - μA -125 - -125 - μA -200 - -200 - μA VCCI = 2.7 V -300 - -300 - μA VCCI = 3.6 V -500 - -500 - μA VCCI = 5.5 V A or B port [3] bus hold HIGH A or B port overdrive VCCI = 1.6 V current VCCI = 1.95 V [3] -900 - -900 - μA IOZ OFF-state output current A or B port; VO = 0 V or VCCO; VCCO = 1.2 V to 5.5 V - ±2 - ±10 μA IOFF power-off leakage current A port; VI or VO = 0 V to 5.5 V; VCC(A) = 0 V; VCC(B) = 1.2 V to 5.5 V - ±2 - ±10 μA B port; VI or VO = 0 V to 5.5 V; VCC(B) = 0 V; VCC(A) = 1.2 V to 5.5 V - ±2 - ±10 μA supply current A port; VI = 0 V or VCCI; IO = 0 A VCC(A), VCC(B) = 1.2 V to 5.5 V - 8 - 8 μA VCC(A), VCC(B) = 1.65 V to 5.5 V - 3 - 3 μA VCC(A) = 5.5 V; VCC(B) = 0 V - 2 - 2 μA VCC(A) = 0 V; VCC(B) = 5.5 V -2 - -2 - μA VCC(A), VCC(B) = 1.2 V to 5.5 V - 8 - 8 μA VCC(A), VCC(B) = 1.65 V to 5.5 V - 3 - 3 μA VCC(B) = 5.5 V; VCC(A) = 0 V - 2 - 2 μA VCC(B) = 0 V; VCC(A) = 5.5 V -2 - -2 - μA VCC(A), VCC(B) = 1.2 V to 5.5 V - 16 - 16 μA VCC(A), VCC(B) = 1.65 V to 5.5 V - 4 - 4 μA - 50 - 75 μA - 50 - 75 μA - 50 - 75 μA ICC B port; VI = 0 V or VCCI; IO = 0 A A plus B port (ICC(A) + ICC(B)); IO = 0 A; VI = 0 V or VCCI ΔICC additional supply current VCC(A), VCC(B) = 3.0 V to 5.5 V A port; A port at VCC(A) - 0.6 V; DIR at VCC(A); B port = open [4] DIR input; DIR at VCC(A) - 0.6 V; A port at VCC(A) or GND; B port = open B port; B port at VCC(B) - 0.6 V; DIR at GND; A port = open [1] [2] [3] [4] [4] VCCI is the supply voltage associated with the data input port. VCCO is the supply voltage associated with the output port. To guarantee the node switches, an external driver must source/sink at least IBHLO/IBHHO when the input is in the range VIL to VIH. For non bus hold parts only (74LVC1T45). 74LVC_LVCH1T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 19 March 2019 © Nexperia B.V. 2019. All rights reserved 7 / 31 74LVC1T45; 74LVCH1T45 Nexperia Dual supply translating transceiver; 3-state 11. Dynamic characteristics Table 9. Typical dynamic characteristics at VCC(A) = 1.2 V and Tamb = 25 °C Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 8; for waveforms see Fig. 6 and Fig. 7 Symbol Parameter Conditions VCC(B) Unit 1.2 V 1.5 V 1.8 V 2.5 V 3.3 V 5.0 V tPLH LOW to HIGH propagation delay A to B 10.6 8.1 7.0 5.8 5.3 5.1 ns B to A 10.6 9.5 9.0 8.5 8.3 8.2 ns tPHL HIGH to LOW propagation delay A to B 10.1 7.1 6.0 5.3 5.2 5.4 ns B to A 10.1 8.6 8.1 7.8 7.6 7.6 ns HIGH to OFF-state propagation delay DIR to A 9.4 9.4 9.4 9.4 9.4 9.4 ns DIR to B 12.0 9.4 9.0 7.8 8.4 7.9 ns LOW to OFF-state propagation delay DIR to A 7.1 7.1 7.1 7.1 7.1 7.1 ns DIR to B 9.5 7.8 7.7 6.9 7.6 7.0 ns OFF-state to HIGH propagation delay DIR to A [1] 20.1 17.3 16.7 15.4 15.9 15.2 ns DIR to B [1] 17.7 15.2 14.1 12.9 12.4 12.2 ns OFF-state to LOW propagation delay DIR to A [1] 22.1 18.0 17.1 15.6 16.0 15.5 ns DIR to B [1] 19.5 16.5 15.4 14.7 14.6 14.8 ns tPHZ tPLZ tPZH tPZL [1] tPZH and tPZL are calculated values using the formula shown in Section 13.4 Table 10. Typical dynamic characteristics at VCC(B) = 1.2 V and Tamb = 25 °C Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 8; for waveforms see Fig. 6 and Fig. 7. Symbol Parameter Conditions VCC(A) Unit 1.2 V 1.5 V 1.8 V 2.5 V 3.3 V 5.0 V LOW to HIGH propagation delay A to B 10.6 9.5 9.0 8.5 8.3 8.2 ns B to A 10.6 8.1 7.0 5.8 5.3 5.1 ns tPHL HIGH to LOW propagation delay A to B 10.1 8.6 8.1 7.8 7.6 7.6 ns B to A 10.1 7.1 6.0 5.3 5.2 5.4 ns tPHZ HIGH to OFF-state propagation delay DIR to A 9.4 6.5 5.7 4.1 4.1 3.0 ns DIR to B 12.0 6.1 5.4 4.6 4.3 4.0 ns LOW to OFF-state propagation delay DIR to A 7.1 4.9 4.5 3.2 3.4 2.5 ns DIR to B 9.5 7.3 6.6 5.9 5.7 5.6 ns OFF-state to HIGH propagation delay DIR to A [1] 20.1 15.4 13.6 11.7 11.0 10.7 ns DIR to B [1] 17.7 14.4 13.5 11.7 11.7 10.7 ns OFF-state to LOW propagation delay DIR to A [1] 22.1 13.2 11.4 9.9 9.5 9.4 ns DIR to B [1] 19.5 15.1 13.8 11.9 11.7 10.6 ns tPLH tPLZ tPZH tPZL [1] tPZH and tPZL are calculated values using the formula shown in Section 13.4 74LVC_LVCH1T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 19 March 2019 © Nexperia B.V. 2019. All rights reserved 8 / 31 74LVC1T45; 74LVCH1T45 Nexperia Dual supply translating transceiver; 3-state Table 11. Typical power dissipation capacitance at VCC(A) = VCC(B) and Tamb = 25 °C Voltages are referenced to GND (ground = 0 V). [1] [2] Symbol Parameter Conditions 1.8 V 2.5 V 3.3 V 5.5 V CPD A port: (direction A to B); B port: (direction B to A) 2 3 3 4 pF A port: (direction B to A); B port: (direction A to B) 15 16 16 18 pF [1] [2] power dissipation capacitance VCC(A) and VCC(B) Unit CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD × VCC × fi × N + Σ(CL × VCC × fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; 2 Σ(CL × VCC × fo) = sum of the outputs. fi = 10 MHz; VI = GND to VCC; tr = tf = 1 ns; CL = 0 pF; RL = ∞ Ω. Table 12. Dynamic characteristics for temperature range -40 °C to +85 °C Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 8; for wave forms see Fig. 6 and Fig. 7 Symbol Parameter Conditions VCC(B) 1.5 V ± 0.1 V 1.8 V ± 0.15 V 2.5 V ± 0.2 V Unit 3.3 V ± 0.3 V 5.0 V ± 0.5 V Min Max Min Max Min Max Min Max Min Max VCC(A) = 1.4 V to 1.6 V tPLH tPHL tPHZ tPLZ LOW to HIGH propagation delay A to B 2.8 21.3 2.4 17.6 2.0 13.5 1.7 11.8 1.6 10.5 ns B to A 2.8 21.3 2.6 19.1 2.3 14.9 2.3 12.4 2.2 12.0 ns HIGH to LOW propagation delay A to B 2.6 19.3 2.2 15.3 1.8 11.8 1.7 10.9 1.7 10.8 ns B to A 2.6 19.3 2.4 17.3 2.3 13.2 2.2 11.3 2.3 11.0 ns HIGH to OFF-state DIR to A propagation delay DIR to B 3.0 18.7 3.0 18.7 3.0 18.7 3.0 18.7 3.0 18.7 ns 3.5 24.8 3.5 23.6 3.0 11.0 3.3 11.3 2.8 10.3 ns LOW to OFF-state DIR to A propagation delay DIR to B 2.4 11.4 2.4 11.4 2.4 11.4 2.4 11.4 2.4 11.4 ns 2.8 18.3 3.0 17.2 2.5 9.4 3.0 10.1 2.5 9.4 ns tPZH OFF-state to HIGH DIR to A propagation delay DIR to B [1] - 39.6 - 36.3 - 24.3 - 22.5 - 21.4 ns [1] - 32.7 - 29.0 - 24.9 - 23.2 - 21.9 ns tPZL OFF-state to LOW DIR to A propagation delay DIR to B [1] - 44.1 - 40.9 - 24.2 - 22.6 - 21.3 ns [1] - 38.0 - 34.0 - 30.5 - 29.6 - 29.5 ns 74LVC_LVCH1T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 19 March 2019 © Nexperia B.V. 2019. All rights reserved 9 / 31 74LVC1T45; 74LVCH1T45 Nexperia Dual supply translating transceiver; 3-state Symbol Parameter Conditions VCC(B) 1.5 V ± 0.1 V 1.8 V ± 0.15 V 2.5 V ± 0.2 V Unit 3.3 V ± 0.3 V 5.0 V ± 0.5 V Min Max Min Max Min Max Min Max Min Max VCC(A) = 1.65 V to 1.95 V LOW to HIGH propagation delay A to B 2.6 19.1 2.2 17.7 2.2 9.3 1.7 7.2 1.4 6.8 B to A 2.4 17.6 2.2 17.7 2.3 16.0 2.1 15.5 1.9 15.1 ns tPHL HIGH to LOW propagation delay A to B 2.4 17.3 2.0 14.3 1.6 8.5 1.8 7.1 1.7 7.0 B to A 2.2 15.3 2.0 14.3 2.1 12.9 2.0 12.6 1.8 12.2 ns tPHZ HIGH to OFF-state DIR to A propagation delay DIR to B 2.9 17.1 2.9 17.1 2.9 17.1 2.9 17.1 2.9 17.1 ns 3.2 24.1 3.2 21.9 2.7 11.5 3.0 10.3 2.5 8.2 LOW to OFF-state DIR to A propagation delay DIR to B 2.4 10.5 2.4 10.5 2.4 10.5 2.4 10.5 2.4 10.5 ns 2.5 17.6 2.6 16.0 2.2 9.2 2.7 8.4 2.4 6.4 tPLH tPLZ tPZH tPZL ns ns ns ns OFF-state to HIGH DIR to A propagation delay DIR to B [1] - 35.2 - 33.7 - 25.2 - 23.9 - 21.8 ns [1] - 29.6 - 28.2 - 19.8 - 17.7 - 17.3 ns OFF-state to LOW DIR to A propagation delay DIR to B [1] - 39.4 - 36.2 - 24.4 - 22.9 - 20.4 ns [1] - 34.4 - 31.4 - 25.6 - 24.2 - 24.1 ns VCC(A) = 2.3 V to 2.7 V tPLH tPHL LOW to HIGH propagation delay A to B 2.3 17.9 2.3 16.0 1.5 8.5 1.3 6.2 1.1 4.8 ns B to A 2.0 13.5 2.2 9.3 1.5 8.5 1.4 8.0 1.0 7.5 ns HIGH to LOW propagation delay A to B 2.3 15.8 2.1 12.9 1.4 7.5 1.3 5.4 0.9 4.6 ns B to A 1.8 11.8 1.9 8.5 1.4 7.5 1.3 7.0 0.9 6.2 ns tPHZ HIGH to OFF-state DIR to A propagation delay DIR to B 2.1 8.1 2.1 8.1 2.1 8.1 2.1 8.1 2.1 8.1 ns 3.0 22.5 3.0 21.4 2.5 11.0 2.8 9.3 2.3 6.9 ns tPLZ LOW to OFF-state DIR to A propagation delay DIR to B 1.7 5.8 1.7 5.8 1.7 5.8 1.7 5.8 1.7 5.8 ns 2.3 14.6 2.5 13.2 2.0 9.0 2.5 8.4 1.8 5.3 ns tPZH tPZL OFF-state to HIGH DIR to A propagation delay DIR to B [1] - 28.1 - 22.5 - 17.5 - 16.4 - 12.8 ns [1] - 23.7 - 21.8 - 14.3 - 12.0 - 10.6 ns OFF-state to LOW DIR to A propagation delay DIR to B [1] - 34.3 - 29.9 - 18.5 - 16.3 - 13.1 ns [1] - 23.9 - 21.0 - 15.6 - 13.5 - 12.7 ns VCC(A) = 3.0 V to 3.6 V LOW to HIGH propagation delay A to B 2.3 17.1 2.1 15.5 1.4 8.0 0.8 5.6 0.7 4.4 ns B to A 1.7 11.8 1.7 7.2 1.3 6.2 0.7 5.6 0.6 5.4 ns HIGH to LOW propagation delay A to B 2.2 15.6 2.0 12.6 1.3 7.0 0.8 5.0 0.7 4.0 ns B to A 1.7 10.9 1.8 7.1 1.3 5.4 0.8 5.0 0.7 4.5 ns HIGH to OFF-state DIR to A propagation delay DIR to B 2.3 7.3 2.3 7.3 2.3 7.3 2.3 7.3 2.7 7.3 ns 2.9 18.0 2.9 16.5 2.3 10.1 2.7 8.6 2.2 6.3 ns tPLZ LOW to OFF-state DIR to A propagation delay DIR to B 2.0 5.6 2.0 5.6 2.0 5.6 2.0 5.6 2.0 5.6 ns 2.3 13.6 2.4 12.5 1.9 7.8 2.3 7.1 1.7 4.9 ns tPZH OFF-state to HIGH DIR to A propagation delay DIR to B [1] - 25.4 - 19.7 - 14.0 - 12.7 - 10.3 ns [1] - 22.7 - 21.1 - 13.6 - 11.2 - 10.0 ns OFF-state to LOW DIR to A propagation delay DIR to B [1] - 28.9 - 23.6 - 15.5 - 13.6 - 10.8 ns [1] - 22.9 - 19.9 - 14.3 - 12.3 - 11.3 ns tPLH tPHL tPHZ tPZL 74LVC_LVCH1T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 19 March 2019 © Nexperia B.V. 2019. All rights reserved 10 / 31 74LVC1T45; 74LVCH1T45 Nexperia Dual supply translating transceiver; 3-state Symbol Parameter Conditions VCC(B) 1.5 V ± 0.1 V 1.8 V ± 0.15 V 2.5 V ± 0.2 V Unit 3.3 V ± 0.3 V 5.0 V ± 0.5 V Min Max Min Max Min Max Min Max Min Max VCC(A) = 4.5 V to 5.5 V LOW to HIGH propagation delay A to B 2.2 16.6 1.9 15.1 1.0 7.5 0.7 5.4 0.5 3.9 ns B to A 1.6 10.5 1.4 6.8 1.0 4.8 0.7 4.4 0.5 3.9 ns tPHL HIGH to LOW propagation delay A to B 2.3 15.3 1.8 12.2 1.0 6.2 0.7 4.5 0.5 3.5 ns B to A 1.7 10.8 1.7 7.0 0.9 4.6 0.7 4.0 0.5 3.5 ns tPHZ HIGH to OFF-state DIR to A propagation delay DIR to B 1.7 5.4 1.7 5.4 1.7 5.4 1.7 5.4 1.7 5.4 ns 2.9 17.3 2.9 16.1 2.3 9.7 2.7 8.0 2.5 5.7 ns LOW to OFF-state DIR to A propagation delay DIR to B 1.4 3.7 1.4 3.7 1.3 3.7 1.0 3.7 0.9 3.7 ns 2.3 13.1 2.4 12.1 1.9 7.4 2.3 7.0 1.8 4.5 ns tPLH tPLZ tPZH tPZL [1] OFF-state to HIGH DIR to A propagation delay DIR to B [1] - 23.6 - 18.9 - 12.2 - 11.4 - 8.4 ns [1] - 20.3 - 18.8 - 11.2 - 9.1 - 7.6 ns OFF-state to LOW DIR to A propagation delay DIR to B [1] - 28.1 - 23.1 - 14.3 - 12.0 - 9.2 ns [1] - 20.7 - 17.6 - 11.6 - 9.9 - 8.9 ns tPZH and tPZL are calculated values using the formula shown in Section 13.4 Table 13. Dynamic characteristics for temperature range -40 °C to +125 °C Voltages are referenced to GND (ground = 0 V); for test circuit see Fig. 8; for wave forms see Fig. 6 and Fig. 7 Symbol Parameter Conditions VCC(B) 1.5 V ± 0.1 V 1.8 V ± 0.15 V 2.5 V ± 0.2 V Unit 3.3 V ± 0.3 V 5.0 V ± 0.5 V Min Max Min Max Min Max Min Max Min Max VCC(A) = 1.4 V to 1.6 V tPLH tPHL LOW to HIGH propagation delay A to B 2.5 23.5 2.1 19.4 1.8 14.9 1.5 13.0 1.4 11.6 ns B to A 2.5 23.5 2.3 21.1 2.0 16.4 2.0 13.7 1.9 13.2 ns HIGH to LOW propagation delay A to B 2.3 21.3 1.9 16.9 1.6 13.0 1.5 12.0 1.5 11.9 ns B to A 2.3 21.3 2.1 19.1 2.0 14.6 1.9 12.5 2.0 12.1 ns tPHZ HIGH to OFF-state DIR to A propagation delay DIR to B 2.7 20.6 2.7 20.6 2.7 20.6 2.7 20.6 2.7 20.6 ns 3.1 27.3 3.1 26.0 2.7 12.1 2.9 12.5 2.5 11.4 ns tPLZ LOW to OFF-state DIR to A propagation delay DIR to B 2.1 12.6 2.1 12.6 2.1 12.6 2.1 12.6 2.1 12.6 ns 2.5 20.2 2.7 19.0 2.2 10.4 2.7 11.2 2.2 10.4 ns tPZH tPZL OFF-state to HIGH DIR to A propagation delay DIR to B [1] - 43.7 - 40.1 - 26.8 - 24.9 - 23.6 ns [1] - 36.1 - 32.0 - 27.5 - 25.6 - 24.2 ns OFF-state to LOW DIR to A propagation delay DIR to B [1] - 48.6 - 45.1 - 26.7 - 25.0 - 23.5 ns [1] - 41.9 - 37.5 - 33.6 - 32.6 - 32.5 ns 74LVC_LVCH1T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 19 March 2019 © Nexperia B.V. 2019. All rights reserved 11 / 31 74LVC1T45; 74LVCH1T45 Nexperia Dual supply translating transceiver; 3-state Symbol Parameter Conditions VCC(B) 1.5 V ± 0.1 V 1.8 V ± 0.15 V 2.5 V ± 0.2 V Unit 3.3 V ± 0.3 V 5.0 V ± 0.5 V Min Max Min Max Min Max Min Max Min Max VCC(A) = 1.65 V to 1.95 V LOW to HIGH propagation delay A to B 2.3 21.1 1.9 19.5 1.9 10.3 1.5 8.0 1.2 7.5 B to A 2.1 19.4 1.9 19.5 2.0 17.6 1.8 17.1 1.7 16.7 ns tPHL HIGH to LOW propagation delay A to B 2.1 19.1 1.8 15.8 1.4 9.4 1.6 7.9 1.5 7.7 B to A 1.9 16.9 1.8 15.8 1.8 14.2 1.8 13.9 1.6 13.5 ns tPHZ HIGH to OFF-state DIR to A propagation delay DIR to B 2.6 18.9 2.6 18.9 2.6 18.9 2.6 18.9 2.6 18.9 ns 2.8 26.6 2.8 24.1 2.4 12.7 2.7 11.4 2.2 9.1 LOW to OFF-state DIR to A propagation delay DIR to B 2.1 11.6 2.1 11.6 2.1 11.6 2.1 11.6 2.1 11.6 ns 2.2 19.4 2.3 17.6 1.9 10.2 2.4 9.3 2.1 7.4 tPLH tPLZ tPZH tPZL ns ns ns ns OFF-state to HIGH DIR to A propagation delay DIR to B [1] - 38.8 - 37.1 - 27.8 - 26.4 - 24.1 ns [1] - 32.7 - 31.1 - 21.9 - 19.6 - 19.1 ns OFF-state to LOW DIR to A propagation delay DIR to B [1] - 43.5 - 39.9 - 26.9 - 25.3 - 22.6 ns [1] - 38.0 - 34.7 - 28.3 - 26.8 - 26.6 ns VCC(A) = 2.3 V to 2.7 V tPLH tPHL LOW to HIGH propagation delay A to B 2.0 19.7 2.0 17.6 1.3 9.4 1.1 6.9 0.9 5.3 ns B to A 1.8 14.9 1.9 10.3 1.3 9.4 1.2 8.8 0.9 8.3 ns HIGH to LOW propagation delay A to B 2.0 17.4 1.8 14.2 1.2 8.3 1.1 6.0 0.8 5.1 ns B to A 1.6 13.0 1.7 9.4 1.2 8.3 1.1 7.7 0.8 6.9 ns tPHZ HIGH to OFF-state DIR to A propagation delay DIR to B 1.8 9.0 1.8 9.0 1.8 9.0 1.8 9.0 1.8 9.0 ns 2.7 24.8 2.7 23.6 2.2 12.1 2.5 10.3 2.0 7.6 ns tPLZ LOW to OFF-state DIR to A propagation delay DIR to B 1.5 6.4 1.5 6.4 1.5 6.4 1.5 6.4 1.5 6.4 ns 2.0 16.1 2.2 14.6 1.8 9.9 2.2 9.3 1.6 5.9 ns tPZH tPZL OFF-state to HIGH DIR to A propagation delay DIR to B [1] - 31.0 - 24.9 - 19.3 - 18.1 - 14.2 ns [1] - 26.1 - 24.0 - 15.8 - 13.3 - 11.7 ns OFF-state to LOW DIR to A propagation delay DIR to B [1] - 37.8 - 33.0 - 20.4 - 18.0 - 14.5 ns [1] - 26.4 - 23.2 - 17.3 - 15.0 - 14.1 ns VCC(A) = 3.0 V to 3.6 V LOW to HIGH propagation delay A to B 2.0 18.9 1.8 17.1 1.2 8.8 0.7 6.2 0.6 4.9 ns B to A 1.5 13.0 1.5 8.0 1.1 6.9 0.6 6.2 0.5 6.0 ns HIGH to LOW propagation delay A to B 1.9 17.2 1.8 13.9 1.1 7.7 0.7 5.5 0.6 4.4 ns B to A 1.5 12.0 1.6 7.9 1.1 6.0 0.7 5.5 0.6 5.0 ns HIGH to OFF-state DIR to A propagation delay DIR to B 2.0 8.1 2.0 8.1 2.0 8.1 2.0 8.1 2.4 8.1 ns 2.6 19.8 2.6 18.2 2.0 11.2 2.4 9.5 1.9 7.0 ns tPLZ LOW to OFF-state DIR to A propagation delay DIR to B 1.8 6.2 1.8 6.2 1.8 6.2 1.8 6.2 1.8 6.2 ns 2.0 15.0 2.1 13.8 1.7 8.6 2.0 7.9 1.5 5.4 ns tPZH OFF-state to HIGH DIR to A propagation delay DIR to B [1] - 28.0 - 21.8 - 15.5 - 14.1 - 11.4 ns [1] - 25.1 - 23.3 - 15.0 - 12.4 - 11.1 ns OFF-state to LOW DIR to A propagation delay DIR to B [1] - 31.8 - 26.1 - 17.2 - 15.0 - 12.0 ns [1] - 25.3 - 22.0 - 15.8 - 13.6 - 12.5 ns tPLH tPHL tPHZ tPZL 74LVC_LVCH1T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 19 March 2019 © Nexperia B.V. 2019. All rights reserved 12 / 31 74LVC1T45; 74LVCH1T45 Nexperia Dual supply translating transceiver; 3-state Symbol Parameter Conditions VCC(B) 1.5 V ± 0.1 V 1.8 V ± 0.15 V 2.5 V ± 0.2 V Unit 3.3 V ± 0.3 V 5.0 V ± 0.5 V Min Max Min Max Min Max Min Max Min Max VCC(A) = 4.5 V to 5.5 V LOW to HIGH propagation delay A to B 1.9 18.3 1.7 16.7 0.9 8.3 0.6 6.0 0.4 4.3 ns B to A 1.4 11.6 1.2 7.5 0.9 5.3 0.6 4.9 0.4 4.3 ns tPHL HIGH to LOW propagation delay A to B 2.0 16.9 1.6 13.5 0.9 6.9 0.6 5.0 0.4 3.9 ns B to A 1.5 11.9 1.5 7.7 0.8 5.1 0.6 4.4 0.4 3.9 ns tPHZ HIGH to OFF-state DIR to A propagation delay DIR to B 1.5 6.0 1.5 6.0 1.5 6.0 1.5 6.0 1.5 6.0 ns 2.6 19.1 2.6 17.8 2.0 10.7 2.4 8.8 2.2 6.3 ns LOW to OFF-state DIR to A propagation delay DIR to B 1.2 4.1 1.2 4.1 1.1 4.1 0.9 4.1 0.8 4.1 ns 2.0 14.5 2.1 13.4 1.7 8.2 2.0 7.7 1.6 5.0 ns tPLH tPLZ tPZH tPZL [1] OFF-state to HIGH DIR to A propagation delay DIR to B [1] - 26.1 - 20.9 - 13.5 - 12.6 - 9.3 ns [1] - 22.4 - 20.8 - 12.4 - 10.1 - 8.4 ns OFF-state to LOW DIR to A propagation delay DIR to B [1] - 31.0 - 25.5 - 15.8 - 13.2 - 10.2 ns [1] - 22.9 - 19.5 - 12.9 - 11.0 - 9.9 ns tPZH and tPZL are calculated values using the formula shown in Section 13.4 11.1. Waveforms and test circuit VI VM A, B input GND tPHL tPLH VOH B, A output VM 001aae967 VOL Measurement points are given in Table 14. VOL and VOH are typical output voltage levels that occur with the output load. Fig. 6. The data input (A, B) to output (B, A) propagation delay times 74LVC_LVCH1T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 19 March 2019 © Nexperia B.V. 2019. All rights reserved 13 / 31 74LVC1T45; 74LVCH1T45 Nexperia Dual supply translating transceiver; 3-state VI DIR input VM GND t PLZ output LOW-to-OFF OFF-to-LOW t PZL VCCO VM VX VOL t PHZ output HIGH-to-OFF OFF-to-HIGH VOH t PZH VY VM GND outputs enabled outputs disabled outputs enabled 001aae968 Measurement points are given in Table 14. VOL and VOH are typical output voltage levels that occur with the output load. Fig. 7. Enable and disable times Table 14. Measurement points Supply voltage Input [1] Output [2] VCC(A), VCC(B) VM VM VX VY 1.2 V to 1.6 V 0.5VCCI 0.5VCCO VOL + 0.1 V VOH - 0.1 V 1.65 V to 2.7 V 0.5VCCI 0.5VCCO VOL + 0.15 V VOH - 0.15 V 3.0 V to 5.5 V 0.5VCCI 0.5VCCO VOL + 0.3 V VOH - 0.3 V [1] [2] VCCI is the supply voltage associated with the data input port. VCCO is the supply voltage associated with the output port. 74LVC_LVCH1T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 19 March 2019 © Nexperia B.V. 2019. All rights reserved 14 / 31 74LVC1T45; 74LVCH1T45 Nexperia Dual supply translating transceiver; 3-state VI negative pulse tW 90 % VM 0V VI positive pulse 0V VM 10 % tf tr tr tf 90 % VM VM 10 % tW VEXT VCC G VI RL VO DUT RT CL RL 001aae331 Test data is given in Table 15. RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance. VEXT = External voltage for measuring switching times. Fig. 8. Test circuit for measuring switching times Table 15. Test data Supply voltage Input VCC(A), VCC(B) VI [1] Δt/ΔV [2] CL RL tPLH, tPHL tPZH, tPHZ tPZL, tPLZ [3] 1.2 V to 5.5 V VCCI ≤ 1.0 ns/V 15 pF 2 kΩ open GND 2VCCO [1] [2] [3] Load VEXT VCCI is the supply voltage associated with the data input port. dV/dt ≥ 1.0 V/ns VCCO is the supply voltage associated with the output port. 74LVC_LVCH1T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 19 March 2019 © Nexperia B.V. 2019. All rights reserved 15 / 31 74LVC1T45; 74LVCH1T45 Nexperia Dual supply translating transceiver; 3-state 12. Typical propagation delay characteristics 001aai907 14 tPHL (ns) 12 (1) 10 001aai908 14 tPLH (ns) 12 (1) 10 (2) 8 (2) 8 (3) 6 (3) (4) (5) (6) 6 (4) (5) (6) 4 4 2 2 0 0 5 10 15 20 25 30 35 CL (pF) a. HIGH to LOW propagation delay (A to B) 001aai909 14 tPHL (ns) 12 (1) 0 10 8 (4) (5) (6) 8 6 6 4 4 2 2 5 10 15 20 25 30 35 CL (pF) c. HIGH to LOW propagation delay (B to A) 10 15 20 25 30 35 CL (pF) 001aai910 14 tPLH (ns) 12 (2) (3) 0 5 b. LOW to HIGH propagation delay (A to B) 10 0 0 0 (1) (2) (3) (4) (5) (6) 0 5 10 15 20 25 30 35 CL (pF) d. LOW to HIGH propagation delay (B to A) (1) VCC(B) = 1.2 V. (2) VCC(B) = 1.5 V. (3) VCC(B) = 1.8 V. (4) VCC(B) = 2.5 V. (5) VCC(B) = 3.3 V. (6) VCC(B) = 5.0 V. Fig. 9. Typical propagation delay vs load capacitance; Tamb = 25 °C; VCC(A) = 1.2 V 74LVC_LVCH1T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 19 March 2019 © Nexperia B.V. 2019. All rights reserved 16 / 31 74LVC1T45; 74LVCH1T45 Nexperia Dual supply translating transceiver; 3-state 001aai911 14 tPHL (ns) 12 001aai912 14 tPLH (ns) 12 (1) 10 10 (1) 8 8 (2) (2) 6 (3) 6 (3) (4) (5) (6) (4) 4 4 (5) 2 0 2 (6) 0 5 10 15 20 25 30 35 CL (pF) a. HIGH to LOW propagation delay (A to B) 001aai913 14 tPHL (ns) 12 10 0 0 5 10 15 20 25 30 35 CL (pF) b. LOW to HIGH propagation delay (A to B) 001aai914 14 tPLH (ns) 12 10 (1) 8 (1) 8 6 (2) (3) (4) 6 (2) (3) (4) (5) (5) (6) 4 2 0 (6) 4 2 0 5 10 15 20 25 30 35 CL (pF) c. HIGH to LOW propagation delay (B to A) 0 0 5 10 15 20 25 30 35 CL (pF) d. LOW to HIGH propagation delay (B to A) (1) VCC(B) = 1.2 V. (2) VCC(B) = 1.5 V. (3) VCC(B) = 1.8 V. (4) VCC(B) = 2.5 V. (5) VCC(B) = 3.3 V. (6) VCC(B) = 5.0 V. Fig. 10. Typical propagation delay vs load capacitance; Tamb = 25 °C; VCC(A) = 1.5 V 74LVC_LVCH1T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 19 March 2019 © Nexperia B.V. 2019. All rights reserved 17 / 31 74LVC1T45; 74LVCH1T45 Nexperia Dual supply translating transceiver; 3-state 001aai915 14 tPHL (ns) 12 10 (1) 10 (1) 8 8 (2) 6 (3) (4) 4 (5) (6) 2 0 001aai916 14 tPLH (ns) 12 0 5 10 15 20 25 6 (3) 4 (4) (5) (6) 2 30 35 CL (pF) a. HIGH to LOW propagation delay (A to B) 001aai917 14 tPHL (ns) 12 (2) 10 0 0 5 10 15 20 25 b. LOW to HIGH propagation delay (A to B) 001aai918 14 tPLH (ns) 12 10 8 8 (1) (1) 6 (2) (3) (4) (5) (6) 6 (2) (3) (4) (5) (6) 4 4 2 0 30 35 CL (pF) 2 0 5 10 15 20 25 30 35 CL (pF) c. HIGH to LOW propagation delay (B to A) 0 0 5 10 15 20 25 30 35 CL (pF) d. LOW to HIGH propagation delay (B to A) (1) VCC(B) = 1.2 V. (2) VCC(B) = 1.5 V. (3) VCC(B) = 1.8 V. (4) VCC(B) = 2.5 V. (5) VCC(B) = 3.3 V. (6) VCC(B) = 5.0 V. Fig. 11. Typical propagation delay vs load capacitance; Tamb = 25 °C; VCC(A) = 1.8 V 74LVC_LVCH1T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 19 March 2019 © Nexperia B.V. 2019. All rights reserved 18 / 31 74LVC1T45; 74LVCH1T45 Nexperia Dual supply translating transceiver; 3-state 001aai919 14 tPHL (ns) 12 10 001aai920 14 tPLH (ns) 12 (1) 10 (1) 8 8 (2) (2) 6 6 (3) (3) 4 2 0 0 5 10 15 20 25 2 30 35 CL (pF) a. HIGH to LOW propagation delay (A to B) 001aai921 14 tPHL (ns) 12 0 8 8 0 (2) (3) (4) (5) (6) 0 5 10 15 20 25 10 15 20 25 (1) (2) (3) (4) (5) (6) 4 2 30 35 CL (pF) c. HIGH to LOW propagation delay (B to A) 30 35 CL (pF) 001aai922 6 (1) 2 5 14 tPLH (ns) 12 10 4 0 b. LOW to HIGH propagation delay (A to B) 10 6 (4) (5) (6) 4 (4) (5) (6) 0 0 5 10 15 20 25 30 35 CL (pF) d. LOW to HIGH propagation delay (B to A) (1) VCC(B) = 1.2 V. (2) VCC(B) = 1.5 V. (3) VCC(B) = 1.8 V. (4) VCC(B) = 2.5 V. (5) VCC(B) = 3.3 V. (6) VCC(B) = 5.0 V. Fig. 12. Typical propagation delay vs load capacitance; Tamb = 25 °C; VCC(A) = 2.5 V 74LVC_LVCH1T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 19 March 2019 © Nexperia B.V. 2019. All rights reserved 19 / 31 74LVC1T45; 74LVCH1T45 Nexperia Dual supply translating transceiver; 3-state 001aai923 14 tPHL (ns) 12 10 001aai924 14 tPLH (ns) 12 10 (1) (1) 8 8 (2) 6 (2) 6 (3) (3) 4 2 0 4 (4) (5) (6) 0 5 10 15 20 25 2 30 35 CL (pF) a. HIGH to LOW propagation delay (A to B) 001aai925 14 tPHL (ns) 12 0 8 8 (2) (3) (4) (5) (6) 4 2 0 0 5 10 15 20 25 30 35 CL (pF) c. HIGH to LOW propagation delay (B to A) 5 10 15 20 25 30 35 CL (pF) 001aai926 14 tPLH (ns) 12 10 (1) 0 b. LOW to HIGH propagation delay (A to B) 10 6 (4) (5) (6) 6 (1) 4 (2) (3) 2 (4) (5) (6) 0 0 5 10 15 20 25 30 35 CL (pF) d. LOW to HIGH propagation delay (B to A) (1) VCC(B) = 1.2 V. (2) VCC(B) = 1.5 V. (3) VCC(B) = 1.8 V. (4) VCC(B) = 2.5 V. (5) VCC(B) = 3.3 V. (6) VCC(B) = 5.0 V. Fig. 13. Typical propagation delay vs load capacitance; Tamb = 25 °C; VCC(A) = 3.3 V 74LVC_LVCH1T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 19 March 2019 © Nexperia B.V. 2019. All rights reserved 20 / 31 74LVC1T45; 74LVCH1T45 Nexperia Dual supply translating transceiver; 3-state 001aai927 14 tPHL (ns) 12 10 001aai928 14 tPLH (ns) 12 10 (1) (1) 8 8 (2) 6 (2) 6 (3) (3) 4 2 0 4 (4) (5) (6) 0 5 10 15 20 25 2 30 35 CL (pF) a. HIGH to LOW propagation delay (A to B) 001aai929 14 tPHL (ns) 12 (4) (5) (6) 0 0 5 10 15 20 25 30 35 CL (pF) b. LOW to HIGH propagation delay (A to B) 001aai930 14 tPLH (ns) 12 10 10 8 8 6 (1) 6 4 (2) (3) 4 (2) (3) 2 (4) (5) (6) 2 (4) (5) (6) 0 0 5 10 15 20 25 30 35 CL (pF) c. HIGH to LOW propagation delay (B to A) 0 (1) 0 5 10 15 20 25 30 35 CL (pF) d. LOW to HIGH propagation delay (B to A) (1) VCC(B) = 1.2 V. (2) VCC(B) = 1.5 V. (3) VCC(B) = 1.8 V. (4) VCC(B) = 2.5 V. (5) VCC(B) = 3.3 V. (6) VCC(B) = 5.0 V. Fig. 14. Typical propagation delay vs load capacitance; Tamb = 25 °C; VCC(A) = 5.0 V 74LVC_LVCH1T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 19 March 2019 © Nexperia B.V. 2019. All rights reserved 21 / 31 74LVC1T45; 74LVCH1T45 Nexperia Dual supply translating transceiver; 3-state 13. Application information 13.1. Unidirectional logic level-shifting application The circuit given in Fig. 15 is an example of the 74LVC1T45; 74LVCH1T45 being used in a unidirectional logic level-shifting application. 74LVC1T45 74LVCH1T45 VCC1 VCC1 VCC(A) GND A 1 6 2 5 3 4 VCC(B) DIR VCC2 VCC2 B system-1 system-2 001aaj994 Fig. 15. Unidirectional logic level-shifting application Table 16. Description unidirectional logic level-shifting application Pin Name Function Description 1 VCC(A) VCC1 supply voltage of system-1 (1.2 V to 5.5 V) 2 GND GND device GND 3 A OUT output level depends on VCC1 voltage 4 B IN input threshold value depends on VCC2 voltage 5 DIR DIR the GND (LOW level) determines B port to A port direction 6 VCC(B) VCC2 supply voltage of system-2 (1.2 V to 5.5 V) 13.2. Bidirectional logic level-shifting application Fig. 16 shows the 74LVC1T45; 74LVCH1T45 being used in a bidirectional logic level-shifting application. Since the device does not have an output enable pin, the system designer should take precautions to avoid bus contention between system-1 and system-2 when changing directions. 74LVC1T45 74LVCH1T45 VCC1 VCC1 I/O-1 PULL-UP/DOWN VCC(A) GND A 1 6 2 5 3 4 VCC(B) DIR VCC2 VCC2 I/O-2 PULL-UP/DOWN B DIR CTRL system-1 system-2 001aaj995 Pull-up or pull-down only needed for 74LVC1T45. Fig. 16. Bidirectional logic level-shifting application 74LVC_LVCH1T45 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 7 — 19 March 2019 © Nexperia B.V. 2019. All rights reserved 22 / 31 74LVC1T45; 74LVCH1T45 Nexperia Dual supply translating transceiver; 3-state Table 17 provides a sequence that illustrates data transmission from system-1 to system-2 and then from system-2 to system-1. Table 17. Description bidirectional logic level-shifting application H = HIGH voltage level; L = LOW voltage level; Z = high-impedance OFF-state. State DIR CTRL I/O-1 I/O-2 Description 1 H output input system-1 data to system-2 2 H Z Z system-2 is getting ready to send data to system-1. I/O-1 and I/O-2 are disabled. The bus-line state depends on bus hold. 3 L Z Z DIR bit is set LOW. I/O-1 and I/O-2 are still disabled. The bus-line state depends on bus hold. 4 L input output system-2 data to system-1 13.3. Power-up considerations The device is designed such that no special power-up sequence is required other than GND being applied first. Table 18. Typical total supply current (ICC(A) + ICC(B)) VCC(A) VCC(B) Unit 0V 1.8 V 2.5 V 3.3 V 5.0 V 0V 0
74LVCH1T45GN,132 价格&库存
很抱歉,暂时无法提供与“74LVCH1T45GN,132”相匹配的价格&库存,您可以联系我们找货
