74ALVC162835A
18-bit registered driver with 30 Ω termination resistors;
3-state
Rev. 7 — 12 October 2017
1
Product data sheet
General description
The 74ALVC162835A is an 18-bit universal bus driver. Data flow is controlled by output
enable (OE), latch enable (LE) and clock inputs (CP).
When LE is HIGH, the A to Y data flow is transparent. When LE is LOW and CP is held
at LOW or HIGH, the data is latched; on the LOW to HIGH transient of CP the A-data is
stored in the latch/flip-flop.
When OE is LOW the outputs are active. When OE is HIGH, the outputs go to the high
impedance OFF-state. Operation of the OE input does not affect the state of the latch/
flip-flop.
To ensure the high-impedance state during power up or power down, OE should be tied
to VCC through a pull-up resistor; the minimum value of the resistor is determined by the
current-sinking capability of the driver.
The 74ALVC162835A is designed with 30 Ω series resistors in both HIGH or LOW output
stages.
2
Features and benefits
3
Wide supply voltage range from 1.2 V to 3.6 V
CMOS low-power consumption
Direct interface with TTL levels
Current drive ± 12 mA at 3.0 V
MULTIBYTE flow-through standard pin-out architecture
Low inductance multiple VCC and GND pins for minimum noise and ground bounce
Output drive capability 50 Ω transmission lines at 85°C
Integrated 30 Ω termination resistors
Diode clamps to VCC and GND on all inputs
Input diodes to accommodate strong drivers
Complies with JEDEC standard no. 8-1A
Ordering information
Table 1. Ordering information
Type number
Package
Temperature range Name
74ALVC162835ADGG -40 °C to + 85 °C
Description
TSSOP56 plastic thin shrink small outline package; 56 leads;
body width 6.1 mm
Version
SOT364-1
74ALVC162835A
Nexperia
18-bit registered driver with 30 Ω termination resistors; 3-state
4
Functional diagram
27
OE
30
CP
28
LE
Y1
Y2
Y3
Y4
Y5
Y6
Y7
Y8
Y9
Y10
Y11
Y12
Y13
Y14
Y15
Y16
Y17
Y18
OE
CP
LE
A1
D
LE
Y1
CP
to the 17 other channels
3
5
6
8
9
10
12
13
14
15
16
17
19
23
24
26
EN5
3C4
G7
4D
1, 2
8D
5, 6
54
52
51
49
48
47
45
44
43
42
41
40
38
37
36
34
33
31
A1
A2
A3
A4
A5
A6
A7
A8
A9
A10
A11
A12
A13
A14
A15
A16
A17
A18
aaa-027575
aaa-027574
Figure 1. Logic diagram
Figure 2. Logic symbol (IEEE/IEC)
VCC
A1
002aac725
Figure 3. Typical input (data or control)
74ALVC162835A
Product data sheet
All information provided in this document is subject to legal disclaimers.
© Nexperia B.V. 2017. All rights reserved.
2 / 15
74ALVC162835A
Nexperia
5
Pinning information
5.1 Pinning
74ALVC162835A
n.c.
1
56 GND
n.c.
2
55 n.c.
Y1
3
54 A1
GND
4
53 GND
Y2
5
52 A2
Y3
6
51 A3
VCC
7
Y4
8
50 VCC
49 A4
Y5
9
48 A5
Y6 10
47 A6
GND 11
46 GND
Y7 12
45 A7
Y8 13
44 A8
Y9 14
43 A9
Y10 15
42 A10
Y11 16
41 A11
Y12 17
40 A12
GND 18
39 GND
Y13 19
38 A13
Y14 20
37 A14
Y15 21
36 A15
VCC 22
Y16 23
35 VCC
34 A16
Y17 24
33 A17
GND 25
32 GND
Y18 26
31 A18
OE 27
30 CP
LE 28
29 GND
aaa-027576
Figure 4. Pin configuration TSSOP56
74ALVC162835A
Product data sheet
3 / 15
74ALVC162835A
Nexperia
5.2 Pin description
Table 2. Pin description
Symbol
Pin
Description
A1, A2, A3, A4, A5, A6,
A7, A8, A9, A10, A11, A12,
A13, A14, A15, A16, A17, A18
54, 52, 51, 49, 48, 47,
45, 44, 43, 42, 41, 40,
38, 37, 36, 34, 33, 31
data inputs
Y1, Y2, Y3, Y4, Y5, Y6,
Y7, Y8, Y9, Y10, Y11, Y12,
Y13, Y14, Y15, Y16, Y17, Y18
3, 5, 6, 8, 9, 10,
12, 13, 14, 15, 16, 17,
19, 20, 21, 23, 24, 26
data outputs
n.c.
1, 2, 55
no connected
LE
28
latch enable input (active HIGH)
OE
27
output enable input (active LOW)
CP
30
clock input
GND
4, 11, 18, 25, 32, 39, 46, 53, 56
ground (0 V)
VCC
7, 22, 35, 50
supply voltage
6
Functional description
Table 3. Function table
[1]
Input
Output
OE
LE
CP
An
Yn
H
X
X
X
Z
L
H
X
L
L
L
H
X
H
H
L
L
L
L
L
L
H
H
L
L
H
X
Yn
[2]
L
L
L
X
Yn
[3]
[1] H = HIGH voltage level;
L = LOW voltage level;
X = don’t care;
Z = high-impedance OFF-state;
↑ = LOW-to-HIGH clock transition.
[2] Yn = Output level before the indicated steady-state input conditions were established, provided that CP is high before LE goes low.
[3] Yn = Output level before the indicated steady-state input conditions were established.
74ALVC162835A
Product data sheet
4 / 15
74ALVC162835A
Nexperia
7
Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
Conditions
Min
Max
Unit
-0.5
+4.6
V
input voltage
[1]
-0.5
+4.6
V
VO
output voltage
[1]
-0.5
IIK
input clamping current
VI < 0 V
IOK
output clamping current
IO(sink/
output sink or source current
VI
VCC + 0.5 V
-50
mA
VO > VCC or VO < 0 V
±50
mA
VO = 0 V to VCC
±50
mA
source)
ICC
supply current
+100
mA
IGND
ground current
-100
mA
Tstg
storage temperature
-65
+150
°C
600
mW
Ptot
[2]
total power dissipation
[1] The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2] For TSSOP56 package: Ptot derates linearly with 8 mW/K above 55 °C.
8
Recommended operating conditions
Table 5. Recommended operating conditions
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VCC
supply voltage
2.5 V range for maximum speed performance
at 30 pF output load
2.3
2.7
V
3.3 V range for maximum speed performance
at 50 pF output load
3.0
3.6
V
for low-voltage applications
1.2
3.6
V
VI
input voltage
VCC
V
VO
output voltage
VCC
V
Tamb
ambient temperature
operating in free-air
-40
+85
°C
Δt/ΔV
input transition
rise and fall rate
VCC = 2.3 V to 3.0 V
ns/V
VCC = 3.0 V to 3.6 V
ns/V
74ALVC162835A
Product data sheet
5 / 15
74ALVC162835A
Nexperia
9
Static characteristics
Table 6. Static characteristics
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
[1]
Symbol
Parameter
Conditions
Min
Typ
VIH
HIGH-level input
voltage
VCC = 2.3 V to 2.7 V
1.7
1.2
V
VCC = 2.7 V to 3.6 V
2.0
1.5
V
LOW-level input
voltage
1.2
0.7
V
1.5
0.8
V
HIGH-level output
voltage
VI = VIH or VIL
VCC = 2.3 V to 3.6 V; IO = -100 μA
VCC - 0.2
VCC
V
VCC = 2.3 V; IO = -4 mA
VCC - 0.4 VCC - 0.11
V
VCC = 2.3 V; IO = -6 mA
VCC - 0.6 VCC - 0.17
V
VCC = 2.7 V; IO = -4 mA
VCC - 0.5 VCC - 0.09
V
VCC = 2.7 V; IO = -8 mA
VCC - 0.7 VCC - 0.19
V
VCC = 3.0 V; IO = -6 mA
VCC - 0.6 VCC - 0.13
V
VCC = 3.0 V; IO = -12 mA
VCC - 1.0 VCC - 0.27
V
VIL
VOH
VOL
LOW-level output
voltage
Max
Unit
VI = VIH or VIL
VCC = 2.3 V to 3.6 V; IO = 100 μA
GND
0.20
V
VCC = 2.3 V; IO = 4 mA
0.07
0.40
V
VCC = 2.3 V; IO = 6 mA
0.11
0.55
V
VCC = 2.7 V; IO = 4 mA
0.06
0.40
V
VCC = 2.7 V; IO = 8 mA
0.13
0.60
V
VCC = 3.0 V; IO = 6 mA
0.09
0.55
V
VCC = 3.0 V; IO = 12 mA
0.19
0.80
V
II
input leakage current
VCC = 2.3 V to 3.6 V; VI = VCC or GND
0.1
5
μA
IOZ
OFF-state output
current
VCC = 2.3 V to 3.6 V; VI = VIH or VIL;
VO = VCC or GND
0.1
10
μA
ICC
supply current
VCC = 2.3 V to 3.6 V; VI = VCC or GND;
IO = 0 A
0.2
40
μA
ΔICC
additional supply
current
VCC = 2.3 V to 3.6 V; VI = VCC - 0.6 V; IO = 0 A
150
750
μA
Ci
input capacitance
4.0
pF
CO
output capacitance
8.0
pF
[1] Typical values are measured at Tamb = 25 °C
74ALVC162835A
Product data sheet
6 / 15
74ALVC162835A
Nexperia
10 Dynamic characteristics
Table 7. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V). For test circuit, see Figure 11.
Symbol
tpd
Parameter
propagation delay
Conditions
Min
An to Yn; Figure 5
3.5
5.0
ns
VCC = 2.7 V
1.0
3.3
5.0
ns
1.0
2.9
4.2
ns
1.3
4.1
5.9
ns
VCC = 2.7 V
1.3
3.8
5.8
ns
1.3
3.4
5.1
ns
1.4
4.0
6.3
ns
VCC = 2.7 V
1.4
3.7
6.1
ns
1.4
3.3
5.4
ns
1.4
3.8
6.3
ns
VCC = 2.7 V
1.1
4.0
6.5
ns
1.1
3.4
5.5
ns
1.0
2.6
4.9
ns
VCC = 2.7 V
1.3
3.2
4.9
ns
1.3
3.0
4.5
ns
3.3
1.0
ns
VCC = 2.7 V
3.3
1.2
ns
3.3
0.7
ns
3.3
0.7
ns
VCC = 2.7 V
3.3
0.6
ns
3.3
0.6
ns
An to CP; VCC = 2.3 V to 3.6 V; Figure 9
1.0
ns
An to LE; VCC = 2.3 V to 3.6 V; Figure 7
1.5
ns
CP to Yn; Figure 8
[2]
[2]
OE to Yn; Figure 10
[3]
tw
disable time
pulse width
Unit
1.0
tdis
Max
LE to Yn; Figure 6
enable time
[1]
[2]
ten
Typ
OE to Yn; Figure 10
[4]
CP HIGH or LOW; Figure 8
LE HIGH; Figure 6
tsu
set-up time
74ALVC162835A
Product data sheet
7 / 15
74ALVC162835A
Nexperia
Symbol
Parameter
Conditions
Min
th
hold time
An to CP; Figure 9
Typ
[1]
Max
Unit
1.0
0.4
ns
VCC = 2.7 V
1.2
0.4
ns
0.9
0.7
ns
0.5
0.1
ns
VCC = 2.7 V
1.0
0.1
ns
1.0
0.4
ns
150
190
MHz
VCC = 2.7 V
150
190
MHz
150
240
MHz
transparent mode; output enabled
10
pF
transparent mode; output disabled
3
pF
clocked mode; output enabled
21
pF
clocked mode; output disabled
15
pF
An to LE; Figure 7
fmax
maximum frequency
CP; Figure 8
CPD
power dissipation
capacitance
per buffer; VI = GND to VCC
[5]
Typical values for VCC = 2.3 V to 2.7 V are measured at VCC = 2.5 V
Typical values for VCC = 3.0 V to 3.6 V are measured at VCC = 3.3 V
[2] tpd is the same as tPHL and tPLH.
[3] ten is the same as tPZH and tPZL.
[4] tdis is the same as tPHZ and tPLZ.
[5] CPD is used to determine the dynamic power dissipation (PD in μW):
2
2
PD = CPD × VCC × fi × N + ∑(CL × VCC × fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
2
∑(CL × VCC × fo) = sum of outputs.
74ALVC162835A
Product data sheet
8 / 15
74ALVC162835A
Nexperia
10.1 Waveforms and test circuit
An input
VI
VM
tPHL
Yn output
VI
LE input
GND
VM
tW
GND
tPLH
VOH
VM
VOL
VM
tPHL
VOH
tPLH
VM
Yn output
VOL
aaa-027577
002aac726
Measurement points are given in Table 8.
VOL and VOH are typical voltage output levels that occur with
VOL and VOH are typical voltage output levels that occur with the output load.
the output load.
Figure 6. LE input pulse width, LE input to Yn output
Figure 5. Input (An) to output (Yn) propagation delay
propagation delays
VI
An input
GND
VI
LE input
GND
VM
VM
th
1 / fmax
th
tsu
CP input
tsu
VM
VM
tw
VM
aaa-027578
Yn output
VI
VM
GND
tPLH
tPHL
VOH
VM
VOL
002aac729
the output load.
The shaded areas indicate when the input is permitted to
change for predictable output performance.
the output load.
Figure 7. Data set-up and hold times, An input to LE
input
CP
input
VI
VM
tsu
An
input
Yn
output
Figure 8. CP to Yn propagation delays, clock pulse
width,and maximum clock frequency
th
tsu
th
GND
OE input
VI
GND
VOH
VOL
002aac730
output
LOW-to-OFF
OFF-to-LOW
VI
VM
tPLZ
VM
VX
tPHZ
output
HIGH-to-OFF
OFF-to-HIGH
GND
tPZL
tPZH
VY
VM
VCC
VOL
VOH
GND
outputs
outputs
outputs
enabled
disabled
enabled
002aac731
the output load.
the output load.
Figure 9. Data set-up and hold times, An input to CP
input
74ALVC162835A
Product data sheet
Figure 10. 3-state enable and disable times
9 / 15
74ALVC162835A
Nexperia
Table 8. Measurement points
Supply voltage
Input
VCC
VI
VM
VM
VX
VY
≤ 2.3 V
VCC
0.5 x VCC
0.5 x VCC
VOL + 0.15 V
VOH - 0.15 V
2.3 V to 2.7 V
VCC
0.5 x VCC
0.5 x VCC
VOL + 0.15 V
VOH - 0.15 V
2.7 V
2.7 V
1.5 V
1.5 V
VOL + 0.3 V
VOH - 0.3 V
3.0 V to 3.6 V
2.7 V
1.5 V
1.5 V
VOL + 0.3 V
VOH - 0.3 V
Output
VI
negative
pulse
tW
90 %
VM
0V
VI
positive
pulse
0V
VM
10 %
tf
tr
tr
tf
90 %
VM
VM
10 %
tW
VEXT
VCC
G
VI
RL
VO
DUT
RT
CL
RL
001aae331
Test data is given in Table 9.
Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
VEXT = External voltage for measuring switching times.
Figure 11. Test circuit for measuring switching times
Table 9. Test data
Supply voltage
Input
VCC
VI
tr, tf
CL
RL
tPLH, tPHL
tPLZ, tPZL
tPHZ, tPZH
≤ 2.3 V
VCC
≤ 2.0 ns
30 pF
500 Ω
open
2 × VCC
GND
2.3 V to 2.7 V
VCC
≤ 2.0 ns
30 pF
500 Ω
open
2 × VCC
GND
2.7 V
2.7 V
≤ 2.5 ns
50 pF
500 Ω
open
2 × VCC
GND
3.0 V to 3.6 V
2.7 V
≤ 2.5 ns
50 pF
500 Ω
open
2 × VCC
GND
74ALVC162835A
Product data sheet
Load
VEXT
10 / 15
74ALVC162835A
Nexperia
11 Package outline
TSSOP56: plastic thin shrink small outline package; 56 leads; body width 6.1 mm
SOT364-1
E
D
A
X
c
HE
y
v M A
Z
56
29
Q
A2
(A 3 )
A1
pin 1 index
A
θ
Lp
L
1
28
w M
bp
e
detail X
2.5
5 mm
scale
DIMENSIONS (mm are the original dimensions).
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z
θ
mm
1.2
0.15
0.05
1.05
0.85
0.25
0.28
0.17
0.2
0.1
14.1
13.9
6.2
6.0
0.5
8.3
7.9
1
0.8
0.4
0.50
0.35
0.25
0.08
0.1
0.5
0.1
8
o
o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT364-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
MO-153
Figure 12. Package outline SOT364-1 (TSSOP56)
74ALVC162835A
Product data sheet
11 / 15
74ALVC162835A
Nexperia
12 Abbreviations
Table 10. Abbreviations
Acronym
Description
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
TTL
Transistor-Transistor Logic
13 Revision history
Table 11. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74ALVC162835A v.7
20171012
Product data sheet
74ALVC162835A v.6
Modifications:
• The format of this data sheet has been redesigned to comply with the identity guidelines of
Nexperia.
• Legal texts have been adapted to the new company name where appropriate.
74ALVC162835A v.6
20000620
Product specification
74ALVC162835A v.5
74ALVC162835A v.5
20000314
74ALVC162835A
Product data sheet
12 / 15
74ALVC162835A
Nexperia
14 Legal information
14.1 Data sheet status
Document status
[1][2]
Product status
[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product
development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple
devices. The latest product status information is available on the Internet at URL http://www.nexperia.com.
14.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the
relevant full data sheet, which is available on request via the local Nexperia
sales office. In case of any inconsistency or conflict with the short data sheet,
the full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
14.3 Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia. In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation lost profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory. Notwithstanding any damages that
customer might incur for any reason whatsoever, Nexperia's aggregate and
cumulative liability towards customer for the products described herein shall
be limited in accordance with the Terms and conditions of commercial sale of
Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use — Nexperia products are not designed, authorized or
warranted to be suitable for use in life support, life-critical or safety-critical
74ALVC162835A
Product data sheet
systems or equipment, nor in applications where failure or malfunction
of an Nexperia product can reasonably be expected to result in personal
injury, death or severe property or environmental damage. Nexperia and its
suppliers accept no liability for inclusion and/or use of Nexperia products in
such equipment or applications and therefore such inclusion and/or use is at
the customer’s own risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification. Customers are responsible for the
design and operation of their applications and products using Nexperia
products, and Nexperia accepts no liability for any assistance with
applications or customer product design. It is customer’s sole responsibility
to determine whether the Nexperia product is suitable and fit for the
customer’s applications and products planned, as well as for the planned
application and use of customer’s third party customer(s). Customers should
provide appropriate design and operating safeguards to minimize the risks
associated with their applications and products. Nexperia does not accept
any liability related to any default, damage, costs or problem which is based
on any weakness or default in the customer’s applications or products, or
the application or use by customer’s third party customer(s). Customer is
responsible for doing all necessary testing for the customer’s applications
and products using Nexperia products in order to avoid a default of the
applications and the products or of the application or use by customer’s third
party customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or
the grant, conveyance or implication of any license under any copyrights,
patents or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
13 / 15
74ALVC162835A
Nexperia
Non-automotive qualified products — Unless this data sheet expressly
states that this specific Nexperia product is automotive qualified, the
product is not suitable for automotive use. It is neither qualified nor tested in
accordance with automotive testing or application requirements. Nexperia
accepts no liability for inclusion and/or use of non-automotive qualified
products in automotive equipment or applications. In the event that customer
uses the product for design-in and use in automotive applications to
automotive specifications and standards, customer (a) shall use the product
without Nexperia's warranty of the product for such automotive applications,
use and specifications, and (b) whenever customer uses the product for
automotive applications beyond Nexperia's specifications such use shall be
solely at customer’s own risk, and (c) customer fully indemnifies Nexperia
for any liability, damages or failed product claims resulting from customer
74ALVC162835A
Product data sheet
design and use of the product for automotive applications beyond Nexperia's
standard warranty and Nexperia's product specifications.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
14.4 Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
14 / 15
74ALVC162835A
Nexperia
Contents
1
2
3
4
5
5.1
5.2
6
7
8
9
10
10.1
11
12
13
14
General description ............................................ 1
Features and benefits .........................................1
Ordering information .......................................... 1
Functional diagram ............................................. 2
Pinning information ............................................ 3
Pinning ............................................................... 3
Pin description ................................................... 4
Functional description ........................................4
Limiting values .................................................... 5
Recommended operating conditions ................ 5
Static characteristics .......................................... 6
Dynamic characteristics .....................................7
Waveforms and test circuit ................................ 9
Package outline .................................................11
Abbreviations .................................................... 12
Revision history ................................................ 12
Legal information .............................................. 13
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section 'Legal information'.
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 12 October 2017
Document identifier: 74ALVC162835A
