74AVC16834ADGG,118
74AVC16834ADGG,118
    NEXPERIA(安世)
    TSSOP56_14.1X6.2MM
    具有反相寄存器使能和动态控制输出的18位寄存器驱动器;三态
74AVC16834ADGG,118 数据手册
74AVC16834A 18-bit registered driver with inverted register enable and Dynamic Controlled Outputs; 3-state Rev. 6 — 12 September 2018 Product data sheet 1. General description The 74AVC16834A is an 18-bit universal bus driver. Data flow is controlled by output enable (OE), latch enable (LE) and clock inputs (CP). This product is designed to have an extremely fast propagation delay and a minimum amount of power consumption. To ensure the high-impedance state during power up or power down, OE should be tied to VCC through a pullup resistor (Live Insertion). A Dynamic Controlled Output (DCO) circuitry is implemented to support termination line drive during transient. See Fig. 5 for typical curves. 2. Features and benefits • • • • • • • • Wide supply voltage range from 1.2 V to 3.6 V Complies with JEDEC standards: • JESD8-7 (1.2 V to 1.95 V) • JESD8-5 (1.8 V to 2.7 V) • JESD8-1A (2.7 V to 3.6 V) CMOS low power consumption Input/output tolerant up to 3.6 V Dynamic Controlled Output (DCO) circuit dynamically changes output impedance, resulting in noise reduction without speed degradation Low inductance multiple VCC and GND pins to minimize noise and ground bounce Power off disables 74AVC16834A outputs, permitting Live Insertion Integrated input diodes to minimize input overshoot and undershoot 3. Ordering information Table 1. Ordering information Type number Package Temperature range Name 74AVC16834ADGG -40 °C to + 85 °C Description TSSOP56 plastic thin shrink small outline package; 56 leads; body width 6.1 mm Version SOT364-1 74AVC16834A Nexperia 18-bit registered driver with inverted register enable and Dynamic Controlled Outputs; 3-state 4. Functional diagram OE CP 27 OE 30 CP 28 LE LE A1 D LE Y1 Y1 Y2 Y3 Y4 Y5 Y6 Y7 Y8 Y9 Y10 Y11 Y12 Y13 Y14 Y15 Y16 Y17 Y18 CP to the 17 other channels Fig. 1. aaa-027713 Logic diagram VCC A1 3 5 6 8 9 10 12 13 14 15 16 17 19 20 21 23 24 26 EN1 2C3 C3 G2 1 1 3D Typical input (data or control) 74AVC16834A Product data sheet A1 A2 A3 A4 A5 A6 A7 A8 A9 A10 A11 A12 A13 A14 A15 A16 A17 A18 aaa-027713 002aac725 Fig. 3. 54 52 51 49 48 47 45 44 43 42 41 40 38 37 36 34 33 31 Fig. 2. Logic symbol (IEEE/IEC) All information provided in this document is subject to legal disclaimers. Rev. 6 — 12 September 2018 © Nexperia B.V. 2018. All rights reserved 2 / 14 74AVC16834A Nexperia 18-bit registered driver with inverted register enable and Dynamic Controlled Outputs; 3-state 5. Pinning information 5.1. Pinning 74AVC16834A n.c. 1 56 GND n.c. 2 55 n.c. Y1 3 54 A1 GND 4 53 GND Y2 5 52 A2 Y3 6 51 A3 VCC 7 50 VCC Y4 8 49 A4 Y5 9 48 A5 Y6 10 47 A6 GND 11 46 GND Y7 12 45 A7 Y8 13 44 A8 Y9 14 43 A9 Y10 15 42 A10 Y11 16 41 A11 Y12 17 40 A12 GND 18 39 GND Y13 19 38 A13 Y14 20 37 A14 Y15 21 36 A15 VCC 22 35 VCC Y16 23 34 A16 Y17 24 33 A17 GND 25 32 GND Y18 26 31 A18 OE 27 30 CP LE 28 29 GND aaa-029045 Fig. 4. Pin configuration SOT364-1 (TSSOP56) 74AVC16834A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 12 September 2018 © Nexperia B.V. 2018. All rights reserved 3 / 14 74AVC16834A Nexperia 18-bit registered driver with inverted register enable and Dynamic Controlled Outputs; 3-state 5.2. Pin description Table 2. Pin description Symbol Pin Description OE 27 output enable input (active LOW) Y1, Y2, Y3, Y4, Y5, Y6, Y7, Y8, Y9, Y10, Y11, Y12, Y13, Y14, Y15, Y16, Y17, Y18 3, 5, 6, 8, 9, 10, 12, 13, 14, 15, 16, 17, 19, 20, 21, 23, 24, 26 data output GND 4, 11, 18, 25, 32, 39, 46, 53, 56 ground supply (0 V) VCC 7, 22, 35, 50 supply voltage n.c. 1, 2, 55 not connected LE 28 latch enable input (active LOW) A1, A2, A3, A4, A5, A6, A7, A8, A9, A10, A11, A12, A13, A14, A15, A16, A17, A18 54, 52, 51, 49, 48, 47, 45, 44, 43, 42, 41, 40, 38, 37, 36, 34, 33, 31 data input CP 30 clock input 6. Functional description Table 3. Function selection H = HIGH voltage level; L = LOW voltage level; X = Don’t care; Z = high-impedance OFF-state; ↑ = LOW to HIGH level transition. Outputs Inputs OE LE CP An Yn H X X X Z L L X L L L L X H H L H ↑ L L L H ↑ H H L H H X Y0 [1] L H L X Y0 [2] [1] [2] Output level before the indicated steady-state input conditions were established, provided that CP is high before LE goes low. Output level before the indicated steady-state input conditions were established. 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Max Unit -0.5 +4.6 V -50 - -0.5 +4.6 V - ±50 mA VCC supply voltage IIK input clamping current VI input voltage IOK output clamping current VO > VCC or VO < 0 V VO output voltage output HIGH or LOW [1] -0.5 output 3-state [1] -0.5 +4.6 V - ±50 mA - 100 mA IO output current ICC supply current 74AVC16834A Product data sheet VI < 0 V [1] VO = 0 V to VCC All information provided in this document is subject to legal disclaimers. Rev. 6 — 12 September 2018 © mA VCC + 0.5 V Nexperia B.V. 2018. All rights reserved 4 / 14 74AVC16834A Nexperia 18-bit registered driver with inverted register enable and Dynamic Controlled Outputs; 3-state Symbol Parameter Conditions Min Max Unit IGND ground current -100 - mA Tstg storage temperature -65 +150 °C Ptot total power dissipation - 600 mW [1] [2] Tamb = −40 °C to +85 °C [2] The input and output voltage ratings may be exceeded if the input and output current ratings are observed. Above 55 °C the value of Ptot derates linearly with 8 mW/K. 8. Recommended operating conditions Table 5. Recommended operating conditions Symbol Parameter Conditions VCC supply voltage Min Typ Max Unit for low-voltage applications 1.2 - 3.6 V according to JEDEC Low Voltage Standards 1.65 - 1.95 V 2.3 - 2.7 V 3.0 - 3.6 V 0 - 3.6 V 0 - VCC V VI input voltage VO output voltage Tamb ambient temperature in free air Δt/ΔV input transition rise and fall rate output HIGH or LOW output 3-state 0 - 3.6 V −40 - +85 °C VCC = 1.65 V to 2.3 V 0 - 30 ns/V VCC = 2.3 V to 3.0 V 0 - 20 ns/V VCC = 3.0 V to 3.6 V 0 - 10 ns/V 9. Static characteristics Table 6. Static characteristics At recommended operating conditions; Tamb = −40 °C to +85 °C; Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min Typ[1] Max VIH VCC = 1.2 V VCC - - V 0.65 × VCC 0.9 - V VCC = 2.3 V to 2.7 V 1.7 1.2 - V VCC = 3.0 V to 3.6 V 2.0 1.5 - V VCC = 1.2 V - - GND V VCC = 1.65 V to 1.95 V - 0.9 VCC = 2.3 V to 2.7 V - 1.2 0.7 V VCC = 3.0 V to 3.6 V - 1.5 0.8 V IO = -100 μA; VCC = 1.65 V to 3.6 V VCC - 0.20 VCC - V IO = -4 mA; VCC = 1.65 V VCC - 0.45 VCC - 0.10 - V IO = -8 mA; VCC = 2.3 V VCC - 0.55 VCC - 0.28 - V IO = -12 mA; VCC = 3.0 V VCC - 0.70 VCC - 0.32 - V VIL VOH HIGH-level input voltage LOW-level input voltage HIGH-level output voltage 74AVC16834A Product data sheet VCC = 1.65 V to 1.95 V Unit 0.35 × VCC V VI = VIH or VIL All information provided in this document is subject to legal disclaimers. Rev. 6 — 12 September 2018 © Nexperia B.V. 2018. All rights reserved 5 / 14 74AVC16834A Nexperia 18-bit registered driver with inverted register enable and Dynamic Controlled Outputs; 3-state Symbol Parameter Conditions VOL VI = VIH or VIL LOW-level output voltage Min Typ[1] Max Unit IO = 100 μA; VCC = 1.65 V to 3.6 V - GND 0.20 V IO = 4 mA; VCC = 1.65 V - 0.10 0.45 V IO = 8 mA; VCC = 2.3 V - 0.26 0.55 V IO = 12 mA; VCC = 3.0 V - 0.36 0.70 V II input leakage current VI = VCC or GND; VCC = 1.65 V to 3.6 V - 0.1 2.5 μA IOFF power-off leakage current VI or VO = 3.6 V; VCC = 0 V - 0.1 ±10 μA IIHZ/IILZ power-off leakage current VCC = 1.65 V to 3.6 V; VI = VCC or GND - 0.1 12.5 μA IOZ OFF-state output current VI = VIH or VIL; VO = VCC or GND VCC = 1.65 V to 2.7 V - 0.1 5 μA VCC = 3.0 V to 3.6 V - 0.1 10 μA VCC = 1.65 V to 2.7 V - 0.1 20 μA VCC = 3.0 V to 3.6 V - 0.2 40 μA - 5.0 - pF ICC CI [1] VI = VCC or GND; IO = 0 A supply current input capacitance All typical values are measured at Tamb = 25 °C. 9.1. Dynamic Controlled Output graphs A Dynamic Controlled Output (DCO) circuit is designed in. During the transition, it initially lowers the output impedance to effectively drive the load and, subsequently, raises the impedance to reduce noise. Fig. 5 shows VOL vs. IOL and VOH vs. IOH curves to illustrate the output impedance and drive capability of the circuit. At the beginning of the signal transition, the DCO circuit provides a maximum dynamic drive that is equivalent to a high drive standard output device. aaa-028429 3.5 VOL output 3 voltage (V) 2.5 VOH output 3 voltage (V) 2.5 2 2 1.5 1.5 1 0 VCC = 2.5 V 50 100 150 200 250 IOL output current (mA) a. HIGH-level output current Fig. 5. VCC = 2.5 V VCC = 1.8 V 0.5 VCC = 1.8 V 0 VCC = 3.3 V 1 VCC = 3.3 V 0.5 aaa-028430 3.5 0 -250 -200 -150 -100 -50 0 IOH output current (mA) b. LOW-level output current Output current as a function of output voltage 10. Dynamic characteristics 74AVC16834A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 12 September 2018 © Nexperia B.V. 2018. All rights reserved 6 / 14 74AVC16834A Nexperia 18-bit registered driver with inverted register enable and Dynamic Controlled Outputs; 3-state Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V). For test circuit see Fig. 12. Symbol Parameter tPHL HIGH to LOW propagation delay tPLH LOW to HIGH propagation delay Conditions VCC = 1.2 V VCC = 1.4 V to 1.6 V VCC = 1.65 V to 1.95 V VCC = 2.3 V to 2.7 V VCC = 3.0 V to 3.6 V Unit Typ Min Typ [1] Max Min Typ [1] Max Min Typ [1] Max Min Typ [1] Max An to Yn; see Fig. 6 5.9 2.0 3.6 5.8 1.5 2.8 4.9 1.0 2.0 3.2 0.9 1.7 2.6 ns LE to Yn; see Fig. 7 6.5 2.3 4.0 6.5 1.8 3.4 5.3 1.5 2.4 3.7 1.2 2.0 3.0 ns CP to Yn; see Fig. 9 4.9 2.0 3.7 5.1 1.6 2.8 4.4 1.1 2.0 3.0 0.8 1.7 2.5 ns An to Yn; see Fig. 6 5.2 2.0 3.6 5.8 1.0 2.6 4.5 0.8 2.0 3.0 0.7 1.7 2.5 ns LE to Yn; see Fig. 7 5.8 2.3 4.0 6.5 1.0 2.9 5.3 0.8 2.3 3.5 0.7 1.9 2.9 ns CP to Yn; see Fig. 9 5.2 2.0 3.7 5.1 1.0 2.6 4.5 0.8 2.0 3.0 0.7 1.7 2.5 ns tPZH OFF-state to HIGH propagation delay OE to Yn; see Fig. 11 8.0 2.8 5.0 8.2 2.2 4.0 6.7 1.6 2.8 4.8 1.3 2.5 4.3 ns tPZL OFF-state to LOW propagation delay OE to Yn; see Fig. 11 5.5 2.8 5.0 8.2 1.5 3.0 6.5 1.0 2.5 4.5 1.0 2.3 4.0 ns tPHZ HIGH to OFF-state propagation delay OE to Yn; see Fig. 11 6.5 2.1 4.5 6.9 2.4 4.6 7.2 1.5 3.4 5.6 1.5 3.0 4.7 ns tPLZ LOW to OFF-state propagation delay OE to Yn; see Fig. 11 5.5 2.1 4.5 6.9 1.5 3.5 6.5 1.0 2.2 4.0 1.0 2.3 3.5 ns tW pulse width CP HIGH or LOW; see Fig. 9. - - - - 2.0 - - 1.2 - - 1.0 - - ns LE HIGH; see Fig. 7. - - - - 2.0 - - 1.2 - - 1.0 - - ns An to CP; see Fig. 10 0.0 0.2 0.0 - 0.0 -0.2 - 0.1 -0.2 - 0.3 -0.5 - ns An to LE; see Fig. 8 1.5 1.5 0.8 - 1.0 0.5 - 0.6 0.1 - 0.5 0.1 - ns An to CP; see Fig. 10 0.1 0.6 0.3 - 0.7 0.3 - 0.7 0.3 - 0.9 0.6 - ns An to LE; see Fig. 8 -0.7 0.1 0.0 - 0.1 0.0 - 0.2 0.1 - 0.6 0.4 - ns - - - - 250 - - 400 - - 500 - - MHz tsu set-up time th hold time fmax [1] maximum frequency CP; see Fig. 9 Typical values are measured at Tamb = 25 °C and VCC = 1.5 V, 1.8 V, 2.5 V and 3.3 V respectively. 74AVC16834A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 12 September 2018 © Nexperia B.V. 2018. All rights reserved 7 / 14 74AVC16834A Nexperia 18-bit registered driver with inverted register enable and Dynamic Controlled Outputs; 3-state Table 8. Power dissipation capacitance Symbol Parameter Conditions Typ Max outputs enabled - 25 - pF outputs disabled - 6 - pF power dissipation capacitance per buffer; VI = GND to VCC CPD [1] Min Unit [1] CPD is used to determine the dynamic power dissipation (PD in μW). 2 2 PD = CPD x VCC x fi x N + Σ(CL x VCC x fo) where: fi = input frequency in MHz; fo = output frequency in MHz CL = output load capacitance in pF VCC = supply voltage in Volts N = number of inputs switching 2 Σ(CL x VCC x fo) = sum of the outputs. 10.1. Waveforms and test circuit An input LE input VI VM tPHL Yn output tw GND tPLH VOH VM Yn output 002aac726 An input LE input Input (An) to output (Yn) propagation delay VM tsu VM tPHL tPLH Fig. 7. tsu VM VI GND VOL 002aac727 LE input pulse width, LE input to Yn output propagation delays CP input VM tw Yn output VM tPHL tPLH Fig. 8. Data set-up and hold times, An input to LE input 74AVC16834A Product data sheet VI GND VOH VM VOL 002aac729 002aac728 Measurement points are given in Table 9. The shaded areas indicate when the input is permitted to change for predictable output performance. GND VOH VM 1 / fmax GND th VI Measurement points are given in Table 9. VOL and VOH are typical voltage output levels that occur with the output load. VI VM th VM VOL Measurement points are given in Table 9. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 6. VM Measurement points are given in Table 9. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 9. CP to Yn propagation delays, clock pulse width, and maximum clock frequency All information provided in this document is subject to legal disclaimers. Rev. 6 — 12 September 2018 © Nexperia B.V. 2018. All rights reserved 8 / 14 74AVC16834A Nexperia 18-bit registered driver with inverted register enable and Dynamic Controlled Outputs; 3-state CP input VI VM tsu th tsu th GND OE input VI An input GND VOH Yn output VOL 002aac730 Measurement points are given in Table 9. The shaded areas indicate when the input is permitted to change for predictable output performance. VOL and VOH are typical voltage output levels that occur with the output load. output LOW-to-OFF OFF-to-LOW VI VM tPLZ GND tPZL VX tPHZ output HIGH-to-OFF OFF-to-HIGH VCC VM VOL tPZH VY outputs enabled VM outputs disabled Measurement points are given in Table 9. VOL and VOH are typical voltage output levels that occur with the output load. Fig. 11. 3-state enable and disable times Table 9. Measurement points Supply voltage Input Output VCC VI VM VM VX VY ≤2.3 V VCC 0.5 x VCC 0.5 x VCC VOL + 0.15 V VOH - 0.15 V 2.3 V to 2.7 V VCC 0.5 x VCC 0.5 x VCC VOL + 0.15 V VOH - 0.15 V 3.0 V to 3.6 V VCC 0.5 x VCC 0.5 x VCC VOL + 0.3 V VOH - 0.3 V Product data sheet GND outputs enabled 002aac731 Fig. 10. Data set-up and hold times, An input to CP input 74AVC16834A VOH All information provided in this document is subject to legal disclaimers. Rev. 6 — 12 September 2018 © Nexperia B.V. 2018. All rights reserved 9 / 14 74AVC16834A Nexperia 18-bit registered driver with inverted register enable and Dynamic Controlled Outputs; 3-state VI negative pulse tW 90 % VM 0V VI positive pulse 0V VM 10 % tf tr tr tf 90 % VM VM 10 % tW VEXT VCC G VI RL VO DUT RT CL RL 001aae331 Test data is given in Table 10. Definitions for test circuit: RL = Load resistance. CL = Load capacitance including jig and probe capacitance. RT = Termination resistance should be equal to output impedance Zo of the pulse generator. VEXT = External voltage for measuring switching times. Fig. 12. Test circuit for measuring switching times Table 10. Test data Supply voltage Input VCC VI tr, tf CL RL tPLH, tPHL tPLZ, tPZL tPHZ, tPZH ≤2.3 V VCC ≤ 2.0 ns 30 pF 1000 Ω open 2 x VCC GND 2.3 V to 2.7 V VCC ≤ 2.0 ns 30 pF 500 Ω open 2 x VCC GND 3.0 V to 3.6 V VCC ≤ 2.0 ns 30 pF 500 Ω open 2 x VCC GND 74AVC16834A Product data sheet Load VEXT All information provided in this document is subject to legal disclaimers. Rev. 6 — 12 September 2018 © Nexperia B.V. 2018. All rights reserved 10 / 14 74AVC16834A Nexperia 18-bit registered driver with inverted register enable and Dynamic Controlled Outputs; 3-state 11. Package outline TSSOP56: plastic thin shrink small outline package; 56 leads; body width 6.1 mm SOT364-1 E D A X c HE y v M A Z 56 29 Q A2 (A 3 ) A1 pin 1 index A θ Lp L 1 28 w M bp e detail X 2.5 0 5 mm scale DIMENSIONS (mm are the original dimensions). UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z θ mm 1.2 0.15 0.05 1.05 0.85 0.25 0.28 0.17 0.2 0.1 14.1 13.9 6.2 6.0 0.5 8.3 7.9 1 0.8 0.4 0.50 0.35 0.25 0.08 0.1 0.5 0.1 8 o 0 o Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT364-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 MO-153 Fig. 13. Package outline SOT364-1 (TSSOP56) 74AVC16834A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 12 September 2018 © Nexperia B.V. 2018. All rights reserved 11 / 14 74AVC16834A Nexperia 18-bit registered driver with inverted register enable and Dynamic Controlled Outputs; 3-state 12. Abbreviations Table 11. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DCO Dynamic Controlled Output DUT Device Under Test 13. Revision history Table 12. Revision history Document ID Release date Data sheet status Change notice Supersedes 74AVC16834A v.6 20180912 Product data sheet - 74AVC16834A v.5 Modifications: • • • The format of this data sheet has been redesigned to comply with the identity guidelines of Nexperia. Legal texts have been adapted to the new company name where appropriate. Type number 74AVC16834ADGV (SOT481-2) removed. 74AVC16834A v.5 20020911 Modifications: • 74AVC16834A v.4 20000725 Product specification - 74AVC16834A v.3 74AVC16834A v.3 20000502 Preliminary specification - 74AVC16834 v.2 74AVC16834 v.2 19990723 Preliminary specification - 74AVC_AVCH16834 v.1 74AVC_AVCH16834 v.1 19990405 Preliminary specification - - 74AVC16834A Product data sheet Product data sheet - 74AVC16834A v.4 Type number 74AVC16834ADGV (SOT481-2) added. All information provided in this document is subject to legal disclaimers. Rev. 6 — 12 September 2018 © Nexperia B.V. 2018. All rights reserved 12 / 14 74AVC16834A Nexperia 18-bit registered driver with inverted register enable and Dynamic Controlled Outputs; 3-state 14. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal 74AVC16834A Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 6 — 12 September 2018 © Nexperia B.V. 2018. All rights reserved 13 / 14 74AVC16834A Nexperia 18-bit registered driver with inverted register enable and Dynamic Controlled Outputs; 3-state Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Ordering information....................................................1 4. Functional diagram.......................................................2 5. Pinning information......................................................3 5.1. Pinning.........................................................................3 5.2. Pin description............................................................. 4 6. Functional description................................................. 4 7. Limiting values............................................................. 4 8. Recommended operating conditions..........................5 9. Static characteristics....................................................5 9.1. Dynamic Controlled Output graphs..............................6 10. Dynamic characteristics............................................ 6 10.1. Waveforms and test circuit........................................ 8 11. Package outline........................................................ 11 12. Abbreviations............................................................ 12 13. Revision history........................................................12 14. Legal information......................................................13 © Nexperia B.V. 2018. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 12 September 2018 74AVC16834A Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 6 — 12 September 2018 © Nexperia B.V. 2018. All rights reserved 14 / 14
74AVC16834ADGG,118 价格&库存
很抱歉,暂时无法提供与“74AVC16834ADGG,118”相匹配的价格&库存,您可以联系我们找货
