74HC393D-Q100J
74HC393D-Q100J
    NEXPERIA(安世)
    SOIC-14
    IC DUAL 4BIT BINARY COUNT 14SSOP
74HC393D-Q100J 数据手册
74HC393-Q100; 74HCT393-Q100 Dual 4-bit binary ripple counter Rev. 1 — 19 June 2014 Product data sheet 1. General description The 74HC393-Q100; 7474HCT393-Q100 is a dual 4-stage binary ripple counter. Each counter features a clock input (nCP), an overriding asynchronous master reset input (nMR) and 4 buffered parallel outputs (nQ0 to nQ3). The counter advances on the HIGH-to-LOW transition of nCP. A HIGH on nMR clears the counter stages and forces the outputs LOW, independent of the state of nCP. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. This product has been qualified to the Automotive Electronics Council (AEC) standard Q100 (Grade 1) and is suitable for use in automotive applications. 2. Features and benefits  Automotive product qualification in accordance with AEC-Q100 (Grade 1)  Specified from 40 C to +85 C and from 40 C to +125 C  Input levels:  For 74HC393-Q100: CMOS level  For 74HCT393-Q100: TTL level  Complies with JEDEC standard no. 7A  ESD protection:  MIL-STD-883, method 3015 exceeds 2000 V  HBM JESD22-A114F exceeds 2000 V  MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )  Two 4-bit binary counters with individual clocks  Divide by any binary module up to 28 in one package  Two master resets to clear each 4-bit counter individually 74HC393-Q100; 74HCT393-Q100 Nexperia Dual 4-bit binary ripple counter 3. Ordering information Table 1. Ordering information Type number 74HC393D-Q100 Package Temperature range Name Description Version 40 C to +125 C SO14 plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 40 C to +125 C TSSOP14 plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 40 C to +125 C DHVQFN14 plastic dual in-line compatible thermal enhanced very SOT762-1 thin quad flat package; no leads; 14 terminals; body 2.5  3  0.85 mm 74HCT393D-Q100 74HC393PW-Q100 74HCT393PW-Q100 74HC393BQ-Q100 74HCT393BQ-Q100 4. Functional diagram 1Q0 1 CTR4 3 1CP 1Q1 2 4 13 1Q2 5 1Q3 6 2Q0 11 1 1MR 12 10 74HC_HCT393_Q100 Product data sheet 3 6 0 11 CT = 0 10 CT 2Q2 9 2Q3 8 13 2MR 9 + 3 8 001aad533 001aad532 Logic symbol 5 CTR4 2CP 2Q1 Fig 1. 4 + 2 12 3 CT 1 2 0 CT = 0 Fig 2. IEC logic symbol All information provided in this document is subject to legal disclaimers. Rev. 1 — 19 June 2014 © Nexperia B.V. 2017. All rights reserved 2 of 20 74HC393-Q100; 74HCT393-Q100 Nexperia Dual 4-bit binary ripple counter 1Q0 1 2 3 1CP 1MR 4-BIT BINARY RIPPLE COUNTER 1Q1 4 1Q2 5 1Q3 2Q0 13 12 2MR 1 2 3 15 5 2Q1 10 2Q2 14 6 13 7 9 2Q3 8 12 11 10 9 001aad534 Fig 3. Fig 4. Q T 8 001aad535 Functional diagram CP 4 11 2CP 4-BIT BINARY RIPPLE COUNTER 0 6 State diagram Q FF 1 T RD Q FF 2 T RD Q FF 3 T RD FF 4 RD MR Q0 Q1 Q2 Q3 001aad536 Fig 5. Logic diagram (one counter) 74HC_HCT393_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 19 June 2014 © Nexperia B.V. 2017. All rights reserved 3 of 20 74HC393-Q100; 74HCT393-Q100 Nexperia Dual 4-bit binary ripple counter 5. Pinning information 5.1 Pinning +&4 +&74 &3   9&& 05   &3 4   05 4   4 4   4 4   4 *1'   4 DDD Fig 6. Pin configuration SO14 &3 WHUPLQDO LQGH[DUHD  +&4 +&74  9&& +&4 +&74 05   &3 &3   9&& 4   05 05   &3 4   4 4   05 4  4   4 4   4 4  4   4 *1'   4 9&&   4   *1' 4  4 DDD 7UDQVSDUHQWWRSYLHZ DDD (1) This is not a supply pin. The substrate is attached to this pad using conductive die attach material. There is no electrical or mechanical requirement to solder this pad. However, if it is soldered, the solder land should remain floating or be connected to VCC. Fig 7. Pin configuration TSSOP14 74HC_HCT393_Q100 Product data sheet Fig 8. Pin configuration DHVQFN14 All information provided in this document is subject to legal disclaimers. Rev. 1 — 19 June 2014 © Nexperia B.V. 2017. All rights reserved 4 of 20 74HC393-Q100; 74HCT393-Q100 Nexperia Dual 4-bit binary ripple counter 5.2 Pin description Table 2. Pin description Symbol Pin Description 1CP 1 clock input (HIGH-to-LOW, edge-triggered) 1MR 2 asynchronous master reset input (active HIGH) 1Q0 3 flip-flop output 1Q1 4 flip-flop output 1Q2 5 flip-flop output 1Q3 6 flip-flop output GND 7 ground (0 V) 2Q3 8 flip-flop output 2Q2 9 flip-flop output 2Q1 10 flip-flop output 2Q0 11 flip-flop output 2MR 12 asynchronous master reset input (active HIGH) 2CP 13 clock input (HIGH-to-LOW, edge-triggered) VCC 14 supply voltage 74HC_HCT393_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 19 June 2014 © Nexperia B.V. 2017. All rights reserved 5 of 20 74HC393-Q100; 74HCT393-Q100 Nexperia Dual 4-bit binary ripple counter 6. Functional description Table 3. Count sequence for one counter [1] Count Output nQ0 nQ1 nQ2 nQ3 0 L L L L 1 H L L L 2 L H L L 3 H H L L 4 L L H L 5 H L H L 6 L H H L 7 H H H L 8 L L L H 9 H L L H 10 L H L H 11 H H L H 12 L L H H 13 H L H H 14 L H H H 15 H H H H [1] H = HIGH voltage level; L = LOW voltage level. 7. Limiting values Table 4. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V). Symbol Parameter Conditions Min VCC supply voltage IIK input clamping current VI < 0.5 V or VI > VCC + 0.5 V IOK output clamping current VO < 0.5 V or VO > VCC + 0.5 V IO output current VO = 0.5 V to VCC + 0.5 V ICC supply current - ±50 mA IGND ground current - 50 mA Tstg storage temperature 65 +150 C - 500 mW total power dissipation Ptot [1] [1] Max Unit 0.5 +7 V - 20 mA - 20 mA - 25 mA For SO14 package: Ptot derates linearly with 8 mW/K above 70 C. For TSSOP14 packages: Ptot derates linearly with 5.5 mW/K above 60 C. For DHVQFN14 packages: Ptot derates linearly with 4.5 mW/K above 60 C. 74HC_HCT393_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 19 June 2014 © Nexperia B.V. 2017. All rights reserved 6 of 20 74HC393-Q100; 74HCT393-Q100 Nexperia Dual 4-bit binary ripple counter 8. Recommended operating conditions Table 5. Recommended operating conditions Voltages are referenced to GND (ground = 0 V) Symbol Parameter Conditions 74HC393-Q100 Min Typ 74HCT393-Q100 Max Min Typ Unit Max VCC supply voltage 2.0 5.0 6.0 4.5 5.0 5.5 V VI input voltage 0 - VCC 0 - VCC V VO output voltage 0 - VCC 0 - VCC V Tamb ambient temperature 40 +25 +125 40 +25 +125 C t/V input transition rise and fall rate VCC = 2.0 V - - 625 - - - ns/V VCC = 4.5 V - 1.67 139 - 1.67 139 ns/V VCC = 6.0 V - - 83 - - - ns/V 9. Static characteristics Table 6. Static characteristics At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 C Conditions Min Typ VCC = 2.0 V 1.5 VCC = 4.5 V 3.15 VCC = 6.0 V 4.2 VCC = 2.0 V - VCC = 4.5 V - VCC = 6.0 V 40 C to +85 C 40 C to +125 C Unit Max Min Max Min Max 1.2 - 1.5 - 1.5 - V 2.4 - 3.15 - 3.15 - V 3.2 - 4.2 - 4.2 - V 0.8 0.5 - 0.5 - 0.5 V 2.1 1.35 - 1.35 - 1.35 V - 2.8 1.8 - 1.8 - 1.8 V IO = 20 A; VCC = 2.0 V 1.9 2.0 - 1.9 - 1.9 - V IO = 20 A; VCC = 4.5 V 4.4 4.5 - 4.4 - 4.4 - V IO = 20 A; VCC = 6.0 V 5.9 6.0 - 5.9 - 5.9 - V IO = 4.0 mA; VCC = 4.5 V 3.98 4.32 - 3.84 - 3.7 - V IO = 5.2 mA; VCC = 6.0 V 5.48 5.81 - 5.34 - 5.2 - V IO = 20 A; VCC = 2.0 V - 0 0.1 - 0.1 - 0.1 V IO = 20 A; VCC = 4.5 V - 0 0.1 - 0.1 - 0.1 V IO = 20 A; VCC = 6.0 V - 0 0.1 - 0.1 - 0.1 V IO = 4.0 mA; VCC = 4.5 V - 0.15 0.26 - 0.33 - 0.4 V IO = 5.2 mA; VCC = 6.0 V - 0.16 0.26 - 0.33 - 0.4 V 74HC393-Q100 VIH VIL VOH VOL HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage VI = VIH or VIL VI = VIH or VIL II input leakage current VI = VCC or GND; VCC = 6.0 V - - 0.1 - 0.1 - 0.1 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 6.0 V - - 8.0 - 80 - 160 A 74HC_HCT393_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 19 June 2014 © Nexperia B.V. 2017. All rights reserved 7 of 20 74HC393-Q100; 74HCT393-Q100 Nexperia Dual 4-bit binary ripple counter Table 6. Static characteristics …continued At recommended operating conditions; voltages are referenced to GND (ground = 0 V). Symbol Parameter 25 C Conditions Min CI input capacitance Typ 40 C to +85 C 40 C to +125 C Unit Max - 3.5 - Min Max Min Max pF 74HCT393-Q100 VIH HIGH-level input voltage VCC = 4.5 V to 5.5 V 2.0 1.6 - 2.0 - 2.0 - V VIL LOW-level input voltage VCC = 4.5 V to 5.5 V - 1.2 0.8 - 0.8 - 0.8 V VOH HIGH-level output voltage VI = VIH or VIL; VCC = 4.5 V IO = 20 A 4.4 4.5 - 4.4 - 4.4 - V IO = 6 mA 3.98 4.32 - 3.84 - 3.7 - V LOW-level output voltage VI = VIH or VIL; VCC = 4.5 V IO = 20 A - 0 0.1 - 0.1 - 0.1 V IO = 6.0 mA - 0.15 0.26 - 0.33 - 0.4 V VOL II input leakage current VI = VCC or GND; VCC = 5.5 V - - 0.1 - 1.0 - 1.0 A ICC supply current VI = VCC or GND; IO = 0 A; VCC = 5.5 V - - 8.0 - 80 - 160 A ICC additional supply current VI = VCC  2.1 V; other inputs at VCC or GND; VCC = 4.5 V to 5.5 V; IO = 0 A per input pin; nCP - 40 144 - 180 - 196 A per input pin; nMR - 100 360 - 450 - 490 - 3.5 - CI input capacitance 74HC_HCT393_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 19 June 2014 A pF © Nexperia B.V. 2017. All rights reserved 8 of 20 74HC393-Q100; 74HCT393-Q100 Nexperia Dual 4-bit binary ripple counter 10. Dynamic characteristics Table 7. Dynamic characteristics Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit see Figure 11. Symbol Parameter 25 C Conditions Min Typ 40 C to +85 C 40 C to +125 C Unit Max Min Max Min Max 74HC393-Q100 tpd propagation delay [1] nCP to nQ0; see Figure 9 VCC = 2.0 V - 41 125 - 155 - 190 ns VCC = 4.5 V - 15 25 - 31 - 38 ns VCC = 5 V; CL = 15 pF - 12 - - - - - ns VCC = 6.0 V - 12 21 - 26 - 32 ns [1] nQx to nQ(x1); see Figure 9 tPHL HIGH to LOW propagation delay VCC = 2.0 V - 14 45 - 55 - 70 ns VCC = 4.5 V - 5 9 - 11 - 14 ns VCC = 5 V; CL = 15 pF - 5 - - - - - ns VCC = 6.0 V - 4 8 - 9 - 12 ns VCC = 2.0 V - 39 140 - 175 - 210 ns VCC = 4.5 V - 14 28 - 35 - 42 ns VCC = 5 V; CL = 15 pF - 11 - - - - - ns - 11 24 - 30 - 36 ns VCC = 2.0 V - 19 75 - 95 - 110 ns VCC = 4.5 V - 7 15 - 19 - 22 ns VCC = 6.0 V - 6 13 - 16 - 19 ns VCC = 2.0 V 80 17 - 100 - 120 - ns VCC = 4.5 V 16 6 - 20 - 24 - ns VCC = 6.0 V 14 5 - 17 - 20 - ns VCC = 2.0 V 80 19 - 100 - 120 - ns VCC = 4.5 V 16 7 - 20 - 24 - ns VCC = 6.0 V 14 6 - 17 - 20 - ns VCC = 2.0 V 5 3 - 5 - 5 - ns VCC = 4.5 V 5 1 - 5 - 5 - ns VCC = 6.0 V 5 1 - 5 - 5 - ns nMR to nQx; see Figure 10 VCC = 6.0 V tt tW transition time pulse width [2] Qn; see Figure 9 nCP HIGH or LOW; see Figure 9 nMR HIGH; see Figure 10 trec recovery time 74HC_HCT393_Q100 Product data sheet nMR to nCP; see Figure 10 All information provided in this document is subject to legal disclaimers. Rev. 1 — 19 June 2014 © Nexperia B.V. 2017. All rights reserved 9 of 20 74HC393-Q100; 74HCT393-Q100 Nexperia Dual 4-bit binary ripple counter Table 7. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit see Figure 11. Symbol Parameter 25 C Conditions Min fclk(max) maximum clock frequency power dissipation capacitance Max Min Max Min Max see Figure 9 VCC = 2.0 V 6 30 - 5 - 4 - MHz VCC = 4.5 V 30 90 - 24 - 20 - MHz VCC = 5 V; CL = 15 pF - 99 - 35 107 - - 23 - - 15 25 - 20 - VCC = 6.0 V CPD Typ 40 C to +85 C 40 C to +125 C Unit CL = 50 pF; f = 1 MHz; VI = GND to VCC [3] nCP to nQ0; see Figure 9 [1] - - 28 24 - - - - MHz MHz - pF 74HCT393-Q100 tpd propagation delay VCC = 4.5 V VCC = 5 V; CL = 15 pF 31 - - 38 - ns - ns [1] nQx to nQ(x1); see Figure 9 VCC = 4.5 V - 6 10 VCC = 5 V; CL = 15 pF - 6 - HIGH to LOW propagation delay nMR to nQx; see Figure 10 tt transition time Qn; see Figure 9 tW pulse width nCP HIGH or LOW; see Figure 9 tPHL - - 13 - - - 40 15 - - VCC = 4.5 V - 18 32 - 15 - - 7 15 - 19 - 22 ns 19 11 - 24 - 29 - ns 16 6 - 20 - 24 - ns 5 0 - 5 - 5 - ns VCC = 4.5 V 27 48 - 22 - 18 - MHz VCC = 5 V; CL = 15 pF - 53 - - 48 ns VCC = 5 V; CL = 15 pF - - ns - ns - ns [2] VCC = 4.5 V VCC = 4.5 V nMR HIGH; see Figure 10 VCC = 4.5 V trec recovery time nMR to nCP; see Figure 10 fclk(max) maximum clock frequency see Figure 9 VCC = 4.5 V 74HC_HCT393_Q100 Product data sheet - All information provided in this document is subject to legal disclaimers. Rev. 1 — 19 June 2014 - - © - MHz Nexperia B.V. 2017. All rights reserved 10 of 20 74HC393-Q100; 74HCT393-Q100 Nexperia Dual 4-bit binary ripple counter Table 7. Dynamic characteristics …continued Voltages are referenced to GND (ground = 0 V); CL = 50 pF unless otherwise specified; for test circuit see Figure 11. Symbol Parameter CPD power dissipation capacitance 25 C Conditions Min Typ Max Min Max Min Max - 25 - - - - - [3] CL = 50 pF; f = 1 MHz; VI = GND to VCC  1.5 V 40 C to +85 C 40 C to +125 C Unit [1] tpd is the same as tPLH and tPHL. [2] tt is the same as tTHL and tTLH. [3] CPD is used to determine the dynamic power dissipation (PD in W). pF PD = CPD  VCC2  fi  N + (CL  VCC2  fo) where: fi = input frequency in MHz; fo = output frequency in MHz; CL = output load capacitance in pF; VCC = supply voltage in V; N = number of inputs switching; (CL  VCC2  fo) = sum of outputs. 10.1 Waveforms 1/f max VI input nCP VM GND t PHL t PLH VOH output nQx VM VOL t THL t TLH 001aad537 Measurement points are given in Table 8. Fig 9. Table 8. Propagation delays clock (nCP) to output (nQx), the output transition times and the maximum clock frequency Measurement points Type Input Output VM VM 74HC393-Q100 0.5VCC 0.5VCC 74HCT393-Q100 1.3 V 1.3 V 74HC_HCT393_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 19 June 2014 © Nexperia B.V. 2017. All rights reserved 11 of 20 74HC393-Q100; 74HCT393-Q100 Nexperia Dual 4-bit binary ripple counter VI input nMR VM GND tW t rec VI VM input nCP GND t PHL VOH output nQx VM VOL 001aad538 Measurement points are given in Table 8. Fig 10. Propagation delays clock (nCP) to output (nQx), pulse width master reset (nMR), and recovery time master reset (nMR) to clock (nCP) 74HC_HCT393_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 19 June 2014 © Nexperia B.V. 2017. All rights reserved 12 of 20 74HC393-Q100; 74HCT393-Q100 Nexperia Dual 4-bit binary ripple counter tW VI 90 % 90 % negative pulse VM VM 10 % 0V VI tf tr tr tf 90 % positive pulse VM VM 10 % 0V 10 % tW 001aac221 Measurement points are given in Table 8. a. Input pulse definition VCC PULSE GENERATOR VI VO D.U.T. CL RT mna101 Test data is given in Table 9. Definitions test circuit: RT = Termination resistance should be equal to output impedance Zo of the pulse generator. CL = Load capacitance including jig and probe capacitance. b. Test circuit Fig 11. Test circuit for measuring switching times Table 9. Test data Type Input VI Load tr, tf CL 74HC393-Q100 VCC 6 ns 15 pF, 50 pF 74HCT393-Q100 3V 6 ns 15 pF, 50 pF 74HC_HCT393_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 19 June 2014 © Nexperia B.V. 2017. All rights reserved 13 of 20 74HC393-Q100; 74HCT393-Q100 Nexperia Dual 4-bit binary ripple counter 11. Package outline SO14: plastic small outline package; 14 leads; body width 3.9 mm SOT108-1 D E A X c y HE v M A Z 8 14 Q A2 A (A 3) A1 pin 1 index θ Lp 1 L 7 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (inch dimensions are derived from the original mm dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (1) e HE L Lp Q v w y Z (1) mm 1.75 0.25 0.10 1.45 1.25 0.25 0.49 0.36 0.25 0.19 8.75 8.55 4.0 3.8 1.27 6.2 5.8 1.05 1.0 0.4 0.7 0.6 0.25 0.25 0.1 0.7 0.3 0.01 0.019 0.0100 0.35 0.014 0.0075 0.34 0.16 0.15 0.010 0.057 inches 0.069 0.004 0.049 0.05 0.244 0.039 0.041 0.228 0.016 0.028 0.024 0.01 0.01 0.028 0.004 0.012 θ 8o o 0 Note 1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC SOT108-1 076E06 MS-012 JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-19 Fig 12. Package outline SOT108-1 (SO14) 74HC_HCT393_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 19 June 2014 © Nexperia B.V. 2017. All rights reserved 14 of 20 74HC393-Q100; 74HCT393-Q100 Nexperia Dual 4-bit binary ripple counter TSSOP14: plastic thin shrink small outline package; 14 leads; body width 4.4 mm SOT402-1 E D A X c y HE v M A Z 8 14 Q (A 3) A2 A A1 pin 1 index θ Lp L 1 7 e detail X w M bp 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A max. A1 A2 A3 bp c D (1) E (2) e HE L Lp Q v w y Z (1) θ mm 1.1 0.15 0.05 0.95 0.80 0.25 0.30 0.19 0.2 0.1 5.1 4.9 4.5 4.3 0.65 6.6 6.2 1 0.75 0.50 0.4 0.3 0.2 0.13 0.1 0.72 0.38 8o o 0 Notes 1. Plastic or metal protrusions of 0.15 mm maximum per side are not included. 2. Plastic interlead protrusions of 0.25 mm maximum per side are not included. OUTLINE VERSION SOT402-1 REFERENCES IEC JEDEC JEITA EUROPEAN PROJECTION ISSUE DATE 99-12-27 03-02-18 MO-153 Fig 13. Package outline SOT402-1 (TSSOP14) 74HC_HCT393_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 19 June 2014 © Nexperia B.V. 2017. All rights reserved 15 of 20 74HC393-Q100; 74HCT393-Q100 Nexperia Dual 4-bit binary ripple counter DHVQFN14: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads; SOT762-1 14 terminals; body 2.5 x 3 x 0.85 mm A B D A A1 E c detail X terminal 1 index area terminal 1 index area C e1 e 2 6 y y1 C v M C A B w M C b L 1 7 Eh e 14 8 13 9 Dh X 0 2.5 5 mm scale DIMENSIONS (mm are the original dimensions) UNIT A(1) max. A1 b c D (1) Dh E (1) Eh e e1 L v w y y1 mm 1 0.05 0.00 0.30 0.18 0.2 3.1 2.9 1.65 1.35 2.6 2.4 1.15 0.85 0.5 2 0.5 0.3 0.1 0.05 0.05 0.1 Note 1. Plastic or metal protrusions of 0.075 mm maximum per side are not included. REFERENCES OUTLINE VERSION IEC JEDEC JEITA SOT762-1 --- MO-241 --- EUROPEAN PROJECTION ISSUE DATE 02-10-17 03-01-27 Fig 14. Package outline SOT762-1 (DHVQFN14) 74HC_HCT393_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 19 June 2014 © Nexperia B.V. 2017. All rights reserved 16 of 20 74HC393-Q100; 74HCT393-Q100 Nexperia Dual 4-bit binary ripple counter 12. Abbreviations Table 10. Abbreviations Acronym Description CMOS Complementary Metal-Oxide Semiconductor DUT Device Under Test ESD ElectroStatic Discharge HBM Human Body Model MIL Military MM Machine Model 13. Revision history Table 11. Revision history Document ID Release date Data sheet status Change notice Supersedes 74HC_HCT393_Q100 v.1 20140619 Product data sheet - - 74HC_HCT393_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 19 June 2014 © Nexperia B.V. 2017. All rights reserved 17 of 20 74HC393-Q100; 74HCT393-Q100 Nexperia Dual 4-bit binary ripple counter 14. Legal information 14.1 Data sheet status Document status[1][2] Product status[3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] Please consult the most recently issued document before initiating or completing a design. [2] The term ‘short data sheet’ is explained in section “Definitions”. [3] The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the Internet at URL http://www.nexperia.com. 14.2 Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. 14.3 Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. 74HC_HCT393_Q100 Product data sheet Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of a Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. All information provided in this document is subject to legal disclaimers. Rev. 1 — 19 June 2014 © Nexperia B.V. 2017. All rights reserved 18 of 20 Nexperia 74HC393-Q100; 74HCT393-Q100 Dual 4-bit binary ripple counter No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. 14.4 Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. 15. Contact information For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com 74HC_HCT393_Q100 Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 19 June 2014 © Nexperia B.V. 2017. All rights reserved 19 of 20 Nexperia 74HC393-Q100; 74HCT393-Q100 Dual 4-bit binary ripple counter 16. Contents 1 2 3 4 5 5.1 5.2 6 7 8 9 10 10.1 11 12 13 14 14.1 14.2 14.3 14.4 15 16 © General description . . . . . . . . . . . . . . . . . . . . . . 1 Features and benefits . . . . . . . . . . . . . . . . . . . . 1 Ordering information . . . . . . . . . . . . . . . . . . . . . 2 Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2 Pinning information . . . . . . . . . . . . . . . . . . . . . . 4 Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4 Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 5 Functional description . . . . . . . . . . . . . . . . . . . 6 Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 6 Recommended operating conditions. . . . . . . . 7 Static characteristics. . . . . . . . . . . . . . . . . . . . . 7 Dynamic characteristics . . . . . . . . . . . . . . . . . . 9 Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . 11 Package outline . . . . . . . . . . . . . . . . . . . . . . . . 14 Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 17 Revision history . . . . . . . . . . . . . . . . . . . . . . . . 17 Legal information. . . . . . . . . . . . . . . . . . . . . . . 18 Data sheet status . . . . . . . . . . . . . . . . . . . . . . 18 Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 18 Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 19 Contact information. . . . . . . . . . . . . . . . . . . . . 19 Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 20 Nexperia B.V. 2017. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 19 June 2014
74HC393D-Q100J 价格&库存
很抱歉,暂时无法提供与“74HC393D-Q100J”相匹配的价格&库存,您可以联系我们找货
74HC393D-Q100J
  • 1+3.310451+0.41530
  • 10+2.3099310+0.28979
  • 50+1.8953950+0.23778
  • 100+1.76803100+0.22180
74HC393D-Q100J
  • 2500+1.412372500+0.17719
  • 5000+1.369555000+0.17181
