74HC193-Q100; 74HCT193-Q100
Presettable synchronous 4-bit binary up/down counter
Rev. 1 — 12 July 2013
Product data sheet
1. General description
The 74HC193-Q100; 74HCT193-Q100 is a 4-bit synchronous binary up/down counter.
Separate up/down clocks, CPU and CPD respectively, simplify operation. The outputs
change state synchronously with the LOW-to-HIGH transition of either clock input. If the
CPU clock is pulsed while CPD is held HIGH, the device counts up. If the CPD clock is
pulsed while CPU is held HIGH, the device counts down. Only one clock input can be held
HIGH at any time to guarantee predictable behavior. The device can be cleared at any
time by the asynchronous master reset input (MR). It may also be loaded in parallel by
activating the asynchronous parallel load input (PL). The terminal count up (TCU) and
terminal count down (TCD) outputs are normally HIGH. When the circuit has reached the
maximum count state of 15, the next HIGH-to-LOW transition of CPU causes TCU to go
LOW. TCU remains LOW until CPU goes HIGH again, duplicating the count up clock.
Likewise, the TCD output goes LOW when the circuit is in the zero state and the CPD
goes LOW. The terminal count outputs duplicate the clock waveforms and can be used as
the clock input signals to the next higher-order circuit in a multistage counter. Multistage
counters are not fully synchronous, since there is a slight delay time difference added for
each stage that is added. The counter may be preset by the asynchronous parallel load
capability of the circuit. Information on the parallel data inputs (D0 to D3), is loaded into
the counter. This information appears on the outputs (Q0 to Q3) regardless of the
conditions of the clock inputs when the parallel load (PL) input is LOW. A HIGH level on
the master reset (MR) input disables the parallel load gates. It overrides both clock inputs
and sets all outputs (Q0 to Q3) LOW. If one of the clock inputs is LOW during and after a
reset or load operation, the next LOW-to-HIGH transition of that clock is interpreted as a
legitimate signal and it is counted. Inputs include clamp diodes that enable the use of
current limiting resistors to interface inputs to voltages in excess of VCC.
This product has been qualified to the Automotive Electronics Council (AEC) standard
Q100 (Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
Specified from 40 C to +85 C and from 40 C to +125 C
Input levels:
For 74HC193-Q100: CMOS level
For 74HCT193-Q100: TTL level
Synchronous reversible 4-bit binary counting
Asynchronous parallel load
Asynchronous reset
Expandable without external logic
Complies with JEDEC standard no. 7A
Nexperia
ESD protection:
MIL-STD-883, method 3015 exceeds 2000 V
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V (C = 200 pF, R = 0 )
Multiple package options
3. Ordering information
Table 1.
Type number
Package
Temperature
range
Name
Description
Version
74HC193D-Q100
40 C to +125 C
SO16
plastic small outline package; 16 leads;
body width 3.9 mm
SOT109-1
74HC193DB-Q100
40 C to +125 C
SSOP16
plastic shrink small outline package; 16 leads;
body width 5.3 mm
SOT338-1
74HC193PW-Q100
40 C to +125 C
TSSOP16
plastic thin shrink small outline package;
16 leads; body width 4.4 mm
SOT403-1
74HCT193D-Q100
40 C to +125 C
SO16
body width 3.9 mm
SOT109-1
74HCT193DB-Q100
40 C to +125 C
SSOP16
body width 5.3 mm
SOT338-1
74HCT193PW-Q100
40 C to +125 C
TSSOP16
SOT403-1
4. Functional diagram
15
11
5
4
14
1
D0
PL
10
D1
9
D2
D3
TCU
CPU
COUNTER
TCD
CPD
MR
3
Q1
2
Fig 1. Functional diagram
Product data sheet
13
FLIP-FLOPS
Q0
74HC_HCT139_Q100
12
Q2
6
CPU
5
CPD
4
001aag405
D0
D1
D2
D3
11
15
1
10
9
14
3
2
6
7
MR
Q0
Q1
Q2
Q3
Q3
7
PL
12
TCU
13
TCD
001aag409
Fig 2. Logic symbol
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2017. All rights reserved
2 of 29
Nexperia
11
5
4
14
15
1
10
9
C3
2+
G1
1−
G2
R
CTR4
3
2
6
7
3D
2CT = 0
1CT = 15
13
12
001aag410
Fig 3. IEC logic symbol
74HC_HCT139_Q100
Product data sheet
3 of 29
xxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxx x x x xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxx xx xx xxxxx
xxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxx xxxxxx xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxx x x
xxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxx xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxx
xxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxxx xxx
Nexperia
74HC_HCT139_Q100
Product data sheet
D0
D1
D2
D3
PL
CPU
TCU
T
FF1
SD
Q
FF2
T
FF3
Q
Q
T
Q
FF4
Q
RD
RD
SD
Q
Q
RD
RD
TCD
CPD
MR
Q0
4 of 29
Fig 4. Logic diagram
Q1
Q2
Q3
001aag412
T
SD
Q
SD
Nexperia
5. Pinning information
5.1 Pinning
+&4
+&74
9&&
4
4
05
&3'
7&'
&38
7&8
4
3/
4
*1'
+&4
+&74
4
9&&
4
05
&3'
7&'
&38
7&8
4
3/
4
*1'
DDD
DDD
Fig 5. Pin configuration SO16
Fig 6. Pin configuration TSSOP16 and SSOP16
5.2 Pin description
Table 2.
Pin description
Symbol
Pin
Description
D0
15
data input 0
D1
1
data input 1
D2
10
data input 2
D3
9
data input 3
Q0
3
flip-flop output 0
Q1
2
flip-flop output 1
Q2
6
flip-flop output 2
Q3
7
flip-flop output 3
CPD
4
count down clock input[1]
CPU
5
count up clock input[1]
GND
8
ground (0 V)
PL
11
asynchronous parallel load input (active LOW)
TCU
12
terminal count up (carry) output (active LOW)
TCD
13
terminal count down (borrow) output (active LOW)
MR
14
asynchronous master reset input (active HIGH)
VCC
16
supply voltage
[1]
LOW-to-HIGH, edge triggered.
74HC_HCT139_Q100
Product data sheet
5 of 29
Nexperia
6. Functional description
Table 3.
Function table[1]
Operating mode
Inputs
Outputs
MR
PL
CPU CPD D0
D1
D2
D3
Q0
Q1
Q2
Q3
TCU TCD
Reset (clear)
H
X
X
X
X
X
L
L
L
L
H
H
X
X
H
X
X
X
X
L
L
L
L
H
H
Parallel load
L
L
X
L
L
L
L
L
L
L
L
L
H
L
L
L
X
H
L
L
L
L
L
L
L
L
H
H
L
L
L
X
H
H
H
H
H
H
H
H
L
H
H
H
H
L
X
L
L
L
H
X
H
H
H
H
H
H
H
Count up
L
H
H
X
X
X
X
count up
H[2]
H
Count down
L
H
H
X
X
X
X
count down
H
H[3]
[1]
H = HIGH voltage level
L = LOW voltage level
X = don’t care
= LOW-to-HIGH clock transition.
[2]
TCU = CPU at terminal count up (HHHH)
[3]
TCD = CPD at terminal count down (LLLL).
74HC_HCT139_Q100
Product data sheet
6 of 29
Nexperia
MR(1)
PL
D0
D1
D2
D3
CPU(2)
CPD(2)
Q0
Q1
Q2
Q3
TCU
TCD
CLEAR
PRESET
14
15
COUNT UP
1
2
1
14
COUNT DOWN
13
001aag411
(1) Clear overrides load, data and count inputs.
(2) When counting up, the count down clock input (CPD) must be HIGH, when counting down the count up clock input
(CPU) must be HIGH.
Sequence
Clear (reset outputs to zero);
load (preset) to binary thirteen;
count up to fourteen, fifteen, terminal count up, zero, one and two;
count down to one, zero, terminal count down, fifteen, fourteen and thirteen.
Fig 7. Typical clear, load and count sequence
74HC_HCT139_Q100
Product data sheet
7 of 29
Nexperia
7. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
Conditions
Min
Max
Unit
0.5
+7.0
V
mA
mA
25
mA
IIK
input clamping current
VI < 0.5 V or VI > VCC + 0.5 V
[1]
IOK
output clamping current
VO < 0.5 V or VO > VCC + 0.5 V
[1]
IO
output current
VO = 0.5 V to VCC + 0.5 V
ICC
supply current
50
mA
IGND
ground current
50
mA
Tstg
storage temperature
65
+150
C
500
mW
[2]
total power dissipation
Ptot
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
For SO16 packages: above 70 C the value of Ptot derates linearly at 8 mW/K.
For SSOP16 and TSSOP16 packages: above 60 C the value of Ptot derates linearly at 5.5 mW/K.
8. Recommended operating conditions
Table 5.
Symbol Parameter
Conditions
Min
Typ
Max
Unit
74HC193-Q100
VCC
supply voltage
2.0
5.0
6.0
V
VI
input voltage
VCC
V
VO
output voltage
VCC
V
Tamb
ambient temperature
40
+25
+125 C
t/V
input transition rise and
fall rate
VCC = 2.0 V
625
ns/V
VCC = 4.5 V
1.67
139
ns/V
VCC = 6.0 V
83
ns/V
74HCT193-Q100
VCC
supply voltage
4.5
5.0
5.5
V
VI
input voltage
VCC
V
VO
output voltage
VCC
V
Tamb
ambient temperature
40
+25
+125 C
t/V
fall rate
1.67
139
74HC_HCT139_Q100
Product data sheet
VCC = 4.5 V
ns/V
8 of 29
Nexperia
9. Static characteristics
Table 6.
Static characteristics type 74HC193-Q100
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Tamb = 25 C
VIH
VIL
VOH
VOL
HIGH-level input voltage
LOW-level input voltage
HIGH-level output voltage
LOW-level output voltage
VCC = 2.0 V
1.5
1.2
V
VCC = 4.5 V
3.15
2.4
V
VCC = 6.0 V
4.2
3.2
V
VCC = 2.0 V
0.8
0.5
V
VCC = 4.5 V
2.1
1.35
V
VCC = 6.0 V
2.8
1.8
V
VI = VIH or VIL
IO = 20 A; VCC = 2.0 V
1.9
2.0
V
IO = 20 A; VCC = 4.5 V
4.4
4.5
V
IO = 20 A; VCC = 6.0 V
5.9
6.0
V
IO = 4.0 mA; VCC = 4.5 V
3.98
4.32
V
IO = 5.2 mA; VCC = 6.0 V
5.48
5.81
V
V
V
V
0.15
0.26
V
0.16
0.26
V
VI = VIH or VIL
II
input leakage current
VI = VCC or GND; VCC = 6.0 V
0.1
A
ICC
supply current
VI = VCC or GND; IO = 0 A;
VCC = 6.0 V
8.0
A
Ci
input capacitance
3.5
pF
VCC = 2.0 V
1.5
V
VCC = 4.5 V
3.15
V
VCC = 6.0 V
4.2
V
VCC = 2.0 V
0.5
V
VCC = 4.5 V
1.35
V
VCC = 6.0 V
1.8
V
1.9
V
4.4
V
5.9
V
3.84
V
5.34
V
Tamb = 40 C to +85 C
VIH
VIL
VOH
74HC_HCT139_Q100
Product data sheet
VI = VIH or VIL
9 of 29
Nexperia
Table 6.
Static characteristics type 74HC193-Q100 …continued
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VOL
VI = VIH or VIL
0.1
V
0.1
V
0.1
V
0.33
V
0.33
V
II
1.0
A
ICC
supply current
VCC = 6.0 V
80
A
Tamb = 40 C to +125 C
VIH
VIL
VOH
VOL
VCC = 2.0 V
1.5
V
VCC = 4.5 V
3.15
V
VCC = 6.0 V
4.2
V
VCC = 2.0 V
0.5
V
VCC = 4.5 V
1.35
V
VCC = 6.0 V
1.8
V
1.9
V
4.4
V
5.9
V
3.7
V
5.2
V
0.1
V
0.1
V
0.1
V
VI = VIH or VIL
VI = VIH or VIL
0.4
V
0.4
V
II
1.0
A
ICC
supply current
VCC = 6.0 V
160
A
74HC_HCT139_Q100
Product data sheet
10 of 29
Nexperia
Table 7.
Static characteristics type 74HCT193-Q100
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Tamb = 25 C
VIH
VCC = 4.5 V to 5.5 V
2.0
1.6
V
VIL
1.2
0.8
V
VOH
VI = VIH or VIL; VCC = 4.5 V
IO = 20 A
4.4
4.5
V
IO = 4.0 mA
3.98
4.32
V
IO = 20 A
V
IO = 4.0 mA
VOL
0.15
0.26
V
II
VI = VCC or GND; VCC = 5.5 V
0.1
A
ICC
supply current
VCC = 5.5 V
8.0
A
ICC
additional supply current
per input pin; VI = VCC 2.1 V and
other inputs at VCC or GND;
IO = 0 A; VCC = 4.5 V to 5.5 V
pin Dn
35
126
A
pins CPU, CPD
140
504
A
pin PL
65
234
A
pin MR
105
378
A
3.5
pF
Ci
input capacitance
VIH
2.0
V
VIL
0.8
V
VOH
VOL
IO = 20 A
4.4
V
IO = 4.0 mA
3.84
V
0.1
V
IO = 20 A
0.33
V
II
IO = 4.0 mA
1.0
A
ICC
supply current
VCC = 5.5 V
80
A
ICC
pin Dn
157.5
A
pins CPU, CPD
630
A
pin PL
292.5
A
pin MR
472.5
A
74HC_HCT139_Q100
Product data sheet
11 of 29
Nexperia
Table 7.
Static characteristics type 74HCT193-Q100 …continued
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
2.0
V
0.8
V
IO = 20 A
4.4
V
IO = 4.0 mA
3.7
V
IO = 20 A
0.1
V
IO = 4.0 mA
0.4
V
VIH
VIL
VOH
VOL
II
1.0
A
ICC
supply current
VCC = 5.5 V
160
A
ICC
pin Dn
171.5
A
pins CPU, CPD
686
A
pin PL
318.5
A
pin MR
514.5
A
74HC_HCT139_Q100
Product data sheet
12 of 29
Nexperia
10. Dynamic characteristics
Table 8.
Dynamic characteristics type 74HC193 -Q100
Symbol
Parameter
25 C
Conditions
Min
tpd
propagation
delay
CPU, CPD to Qn;
see Figure 8
[1]
40 C to +85 C 40 C to +125 C Unit
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
63
215
270
325
ns
VCC = 4.5 V
23
43
54
65
ns
VCC = 6.0 V
18
37
46
55
ns
VCC = 2.0 V
39
125
155
190
ns
VCC = 4.5 V
14
25
31
38
ns
VCC = 6.0 V
11
21
26
32
ns
39
125
155
190
ns
VCC = 4.5 V
14
25
31
38
ns
VCC = 6.0 V
11
21
26
32
ns
CPU to TCU; see
Figure 9
CPD to TCD; see
Figure 9
VCC = 2.0 V
PL to Qn; see
Figure 10
VCC = 2.0 V
69
220
275
330
ns
VCC = 4.5 V
25
44
55
66
ns
VCC = 6.0 V
47
56
ns
VCC = 2.0 V
58
200
250
300
ns
VCC = 4.5 V
21
40
50
60
ns
VCC = 6.0 V
17
34
43
51
ns
VCC = 2.0 V
69
210
265
315
ns
VCC = 4.5 V
25
42
53
63
ns
VCC = 6.0 V
45
54
ns
VCC = 2.0 V
80
290
365
435
ns
VCC = 4.5 V
29
58
73
87
ns
VCC = 6.0 V
23
49
62
74
ns
MR to Qn; see
Figure 11
Dn to Qn; see
Figure 10
PL to TCU, PL to
TCD; see Figure 13
MR to TCU, MR to
TCD; see Figure 13
74HC_HCT139_Q100
Product data sheet
VCC = 2.0 V
74
285
355
430
ns
VCC = 4.5 V
27
57
71
86
ns
VCC = 6.0 V
22
48
60
73
ns
13 of 29
Nexperia
Table 8.
Dynamic characteristics type 74HC193 …continued-Q100
Symbol
Parameter
tpd
tTHL
tTLH
tW
propagation
delay
25 C
Conditions
Min
Typ
Max
Min
Max
Min
Max
Dn to TCU, Dn to
TCD; see Figure 13
VCC = 2.0 V
80
290
365
435
ns
VCC = 4.5 V
29
58
73
87
ns
VCC = 6.0 V
23
49
62
74
ns
HIGH to LOW
see Figure 11
output transition
VCC = 2.0 V
time
VCC = 4.5 V
19
75
95
110
ns
7
15
19
22
ns
VCC = 6.0 V
6
13
16
19
ns
LOW to HIGH
see Figure 11
output transition
VCC = 2.0 V
time
VCC = 4.5 V
19
75
95
110
ns
7
15
19
22
ns
VCC = 6.0 V
6
13
16
19
ns
VCC = 2.0 V
100
22
125
150
ns
VCC = 4.5 V
25
30
ns
VCC = 6.0 V
17
6
21
26
ns
VCC = 2.0 V
100
25
125
150
ns
VCC = 4.5 V
25
30
ns
VCC = 6.0 V
17
7
21
26
ns
pulse width
CPU, CPD (HIGH
or LOW); see
Figure 8
MR (HIGH); see
Figure 11
PL (LOW); see
Figure 10
trec
recovery time
VCC = 2.0 V
100
19
125
150
ns
VCC = 4.5 V
25
30
ns
VCC = 6.0 V
17
6
21
26
ns
VCC = 2.0 V
50
8
65
75
ns
VCC = 4.5 V
10
3
13
15
ns
VCC = 6.0 V
9
2
11
13
ns
VCC = 2.0 V
50
75
ns
VCC = 4.5 V
10
15
ns
VCC = 6.0 V
9
13
ns
PL to CPU, CPD;
see Figure 10
MR to CPU, CPD;
see Figure 11
74HC_HCT139_Q100
Product data sheet
14 of 29
Nexperia
Table 8.
Symbol
Parameter
tsu
th
set-up time
hold time
25 C
Conditions
Min
Typ
Max
Min
Max
Min
Max
VCC = 2.0 V
80
22
100
120
ns
VCC = 4.5 V
16
8
ns
VCC = 6.0 V
14
6
17
ns
VCC = 2.0 V
ns
VCC = 4.5 V
ns
VCC = 6.0 V
ns
VCC = 2.0 V
80
22
100
120
ns
VCC = 4.5 V
16
8
ns
VCC = 6.0 V
8
6
17
ns
VCC = 2.0 V
4.0
13.5
3.2
2.6
MHz
VCC = 4.5 V
16
13
MHz
24
49
19
15
MHz
24
pF
Dn to PL; see
Figure 12; note:
CPU = CPD =
HIGH
Dn to PL; see
Figure 12
CPU to CPD,
CPD to CPU; see
Figure 14
fmax
maximum
frequency
CPU, CPD; see
Figure 8
VCC = 6.0 V
CPD
power
dissipation
capacitance
VI = GND to VCC;
VCC = 5 V;
fi = 1 MHz
[2]
[1]
tpd is the same as tPHL and tPLH.
[2]
CPD is used to determine the dynamic power dissipation (PD in W):
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
(CL VCC2 fo) = sum of outputs.
74HC_HCT139_Q100
Product data sheet
15 of 29
Nexperia
Table 9.
Dynamic characteristics type 74HCT193 -Q100
Symbol
Parameter
tpd
25 C
Conditions
Min
Typ
Max
Min
Max
Min
Max
23
43
54
65
ns
15
27
34
41
ns
15
27
34
41
ns
26
46
58
69
ns
22
40
50
60
ns
27
46
58
69
ns
31
55
69
83
ns
29
55
69
83
ns
VCC = 4.5 V
32
58
73
87
ns
HIGH to LOW
see Figure 11
output transition
VCC = 4.5 V
time
7
15
19
22
ns
LOW to HIGH
see Figure 11
output transition
VCC = 4.5 V
time
7
15
19
22
ns
25
11
31
38
ns
25
30
ns
25
30
ns
propagation
delay
CPU, CPD to Qn;
see Figure 8
VCC = 4.5 V
[1]
CPU to TCU; see
Figure 9
VCC = 4.5 V
CPD to TCD; see
Figure 9
VCC = 4.5 V
PL to Qn; see
Figure 10
VCC = 4.5 V
MR to Qn; see
Figure 11
VCC = 4.5 V
Dn to Qn; see
Figure 10
VCC = 4.5 V
PL to TCU, PL to
TCD; see Figure 13
VCC = 4.5 V
MR to TCU, MR to
TCD; see Figure 13
VCC = 4.5 V
Dn to TCU, Dn to
TCD; see Figure 13
tTHL
tTLH
tW
pulse width
CPU, CPD (HIGH
or LOW); see
Figure 8
VCC = 4.5 V
MR (HIGH); see
Figure 11
VCC = 4.5 V
PL (LOW); see
Figure 10
VCC = 4.5 V
74HC_HCT139_Q100
Product data sheet
16 of 29
Nexperia
Table 9.
Dynamic characteristics type 74HCT193 …continued-Q100
Symbol
Parameter
trec
recovery time
25 C
Conditions
Min
Typ
Max
Min
Max
Min
Max
10
2
13
15
ns
10
15
ns
16
8
ns
ns
16
7
ns
16
13
MHz
26
pF
PL to CPU, CPD;
see Figure 10
VCC = 4.5 V
MR to CPU, CPD;
see Figure 11
VCC = 4.5 V
tsu
set-up time
Dn to PL; see
Figure 12; note:
CPU = CPD =
HIGH
th
hold time
Dn to PL; see
Figure 12
VCC = 4.5 V
VCC = 4.5 V
CPU to CPD,
CPD to CPU; see
Figure 14
VCC = 4.5 V
fmax
maximum
frequency
CPU, CPD; see
Figure 8
VCC = 4.5 V
CPD
[1]
[2]
power
dissipation
capacitance
VI = GND to VCC
1.5 V; VCC = 5 V;
fi = 1 MHz
[2]
74HC_HCT139_Q100
Product data sheet
17 of 29
Nexperia
11. Waveforms
1/fmax
VI
CPU, CPD
input
VM
GND
tW
t PHL
t PLH
VOH
VM
Qn output
001aag413
VOL
Measurement points are given in Table 10.
tPLH and tPHL are the same as tpd.
Logic levels VOL and VOH are typical output voltage levels that occur with the output load.
Fig 8. The clock (CPU, CPD) to output (Qn) propagation delays, the clock pulse width, and the maximum clock
pulse frequency
VI
CPU, CPD
input
VM
GND
tPHL
tPLH
VOH
TCU, TCD
output
VM
VOL
001aag414
Fig 9.
The clock (CPU, CPD) to terminal count output (TCU, TCD) propagation delays
74HC_HCT139_Q100
Product data sheet
18 of 29
Nexperia
VI
Dn input
VM
GND
VI
PL input
VM
GND
t rec
tW
VI
CPU, CPD
input
VM
GND
t PLH
t PHL
VOH
Qn output
VM
VOL
001aag415
Fig 10. The parallel load input (PL) and data (Dn) to Qn output propagation delays and PL removal time to clock
input (CPU, CPD)
VI
MR input
VM
GND
tW
t rec
VI
CPU, CPD
input
VM
GND
t PHL
VOH
Qn output
VOL
90 %
VM
10 %
t THL
t TLH
001aag416
Fig 11. The master reset input (MR) pulse width, MR to Qn propagation delays, MR to CPU, CPD removal time and
output transition times
74HC_HCT139_Q100
Product data sheet
19 of 29
Nexperia
VI
VM
Dn input
GND
tsu
tsu
th
th
VI
VM
PL input
GND
VOH
Qn output
VOL
001aag417
The shaded areas indicate when the input is permitted to change for predictable output performance.
Fig 12. The data input (Dn) to parallel load input (PL) set-up and hold times
VI
PL, MR, Dn
input
VM
GND
tPLH
tPHL
VOH
TCU, TCD
output
VM
VOL
001aag418
Fig 13. The data input (Dn), parallel load input (PL) and the master reset input (MR) to the terminal count outputs
VI
CPU or CPD
input
VM
GND
th
VI
CPD or CPU
input
VM
GND
001aag419
Fig 14. The CPU to CPD or CPD to CPU hold times
74HC_HCT139_Q100
Product data sheet
20 of 29
Nexperia
Table 10.
Measurement points
Type
Input
Output
VM
VI
VM
74HC193-Q100
0.5 VCC
GND to VCC
0.5 VCC
74HCT193-Q100
1.3 V
GND to 3 V
1.3 V
VI
tW
90 %
negative
pulse
VM
0V
VI
tf
tr
tr
tf
90 %
positive
pulse
0V
VM
10 %
VM
VM
10 %
tW
VCC
VCC
G
VI
VO
RL
S1
open
DUT
CL
RT
001aad983
Test data is given in Table 11.
Definitions test circuit:
RT = Termination resistance should be equal to output impedance Zo of the pulse generator
CL = Load capacitance including jig and probe capacitance
RL = Load resistor
S1 = Test selection switch
Fig 15. Load circuitry for measuring switching times
Table 11.
Test data
Type
Input
Load
S1 position
VI
tr, tf
CL
RL
tPHL, tPLH
74HC193-Q100
VCC
6 ns
15 pF, 50 pF
1 k
open
74HCT193-Q100
3V
6 ns
15 pF, 50 pF
1 k
open
74HC_HCT139_Q100
Product data sheet
21 of 29
Nexperia
12. Application information
data input
D0 D1 D2 D3
D0 D1 D2 D3
up clock
CPU
TCU
CPU
TCU
down clock
CPD
IC1 TCD
CPD
IC2 TCD
PL
MR
PL
Q0 Q1 Q2 Q3
carry
borrow
MR
Q0 Q1 Q2 Q3
asynchronous
parallel load
reset
data output
001aag420
Fig 16. Application for cascaded up/down counter with parallel load
74HC_HCT139_Q100
Product data sheet
22 of 29
Nexperia
13. Package outline
SO16: plastic small outline package; 16 leads; body width 3.9 mm
SOT109-1
D
E
A
X
c
y
HE
v M A
Z
16
9
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
8
e
detail X
w M
bp
2.5
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
10.0
9.8
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
0.01
0.019 0.0100 0.39
0.014 0.0075 0.38
0.039
0.016
0.028
0.020
inches
0.010 0.057
0.069
0.004 0.049
0.16
0.15
0.05
0.244
0.041
0.228
0.01
0.01
0.028
0.004
0.012
θ
8o
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT109-1
076E07
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Fig 17. Package outline SOT109-1 (SO16)
74HC_HCT139_Q100
Product data sheet
23 of 29
Nexperia
SSOP16: plastic shrink small outline package; 16 leads; body width 5.3 mm
D
SOT338-1
E
A
X
c
y
HE
v M A
Z
9
16
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
L
8
1
detail X
w M
bp
e
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
2
0.21
0.05
1.80
1.65
0.25
0.38
0.25
0.20
0.09
6.4
6.0
5.4
5.2
0.65
7.9
7.6
1.25
1.03
0.63
0.9
0.7
0.2
0.13
0.1
1.00
0.55
8o
o
Note
1. Plastic or metal protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT338-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
MO-150
Fig 18. Package outline SOT338-1 (SSOP16)
74HC_HCT139_Q100
Product data sheet
24 of 29
Nexperia
TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm
SOT403-1
E
D
A
X
c
y
HE
v M A
Z
9
16
Q
(A 3)
A2
A
A1
pin 1 index
θ
Lp
L
1
8
e
detail X
w M
bp
5 mm
scale
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
5.1
4.9
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.40
0.06
8o
o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT403-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
MO-153
Fig 19. Package outline SOT403-1 (TSSOP16)
74HC_HCT139_Q100
Product data sheet
25 of 29
Nexperia
14. Abbreviations
Table 12.
Abbreviations
Acronym
Description
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
LSTTL
Low-power Schottky Transistor-Transistor Logic
MM
Machine Model
MIL
Military
TTL
15. Revision history
Table 13.
Revision history
Document ID
Release date
74HC_HCT193_Q100 v.1 20130712
74HC_HCT139_Q100
Product data sheet
Data sheet status
Change notice
Supersedes
Product data sheet
26 of 29
Nexperia
16. Legal information
16.1 Data sheet status
Document status[1][2]
Product status[3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term ‘short data sheet’ is explained in section “Definitions”.
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status
information is available on the Internet at URL http://www.nexperia.com.
16.2 Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the Nexperia product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
16.3 Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no
responsibility for the content in this document if provided by an information
source outside of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
74HC_HCT139_Q100
Product data sheet
Suitability for use in automotive applications — This Nexperia
product has been qualified for use in automotive
applications. Unless otherwise agreed in writing, the product is not designed,
authorized or warranted to be suitable for use in life support, life-critical or
safety-critical systems or equipment, nor in applications where failure or
malfunction of a Nexperia product can reasonably be expected
to result in personal injury, death or severe property or environmental
damage. Nexperia and its suppliers accept no liability for
inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the Nexperia
product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
Nexperia does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using Nexperia
products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). Nexperia does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nexperia.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. Nexperia hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of Nexperia products by customer.
27 of 29
Nexperia
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
16.4 Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
17. Contact information
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
74HC_HCT139_Q100
Product data sheet
28 of 29
Nexperia
18. Contents
1
2
3
4
5
5.1
5.2
6
7
8
9
10
11
12
13
14
15
16
16.1
16.2
16.3
16.4
17
18
General description . . . . . . . . . . . . . . . . . . . . . . 1
Features and benefits . . . . . . . . . . . . . . . . . . . . 1
Ordering information . . . . . . . . . . . . . . . . . . . . . 2
Functional diagram . . . . . . . . . . . . . . . . . . . . . . 2
Pinning information . . . . . . . . . . . . . . . . . . . . . . 5
Pinning . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 5
Pin description . . . . . . . . . . . . . . . . . . . . . . . . . 5
Functional description . . . . . . . . . . . . . . . . . . . 6
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 8
Recommended operating conditions. . . . . . . . 8
Static characteristics. . . . . . . . . . . . . . . . . . . . . 9
Dynamic characteristics . . . . . . . . . . . . . . . . . 13
Waveforms . . . . . . . . . . . . . . . . . . . . . . . . . . . . 18
Application information. . . . . . . . . . . . . . . . . . 22
Package outline . . . . . . . . . . . . . . . . . . . . . . . . 23
Abbreviations . . . . . . . . . . . . . . . . . . . . . . . . . . 26
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 26
Legal information. . . . . . . . . . . . . . . . . . . . . . . 27
Data sheet status . . . . . . . . . . . . . . . . . . . . . . 27
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 27
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . 27
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . 28
Contact information. . . . . . . . . . . . . . . . . . . . . 28
Contents . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 29
Date of release: 12 July 2013
