MBR201500CT THRU MBR20200CT
SCHOTTKY BARRIER RECTIFIER
Reverse Voltage - 150 to 200 Volts
FEATURES
TO-220AB
0.185(4.70)
0.175(4.44)
0.154(3.91)
DIA
0.148(3.74)
0.415(10.54)
MAX
0.057(1.45)
0.051(1.30)
0.113(2.87)
0.103(2.62)
0.145(3.68)
0.135(3.43)
0.410(10.41)
0.390(9.91)
PIN
1
2
3
0.635(16.13)
0.625(15.87)
0.560(14.2)
0.530(13.4)
0.350(8.89)
0.330(8.38)
1.148(29.16)
1.118(28.40)
0.160 (4.05)
0.140 (3.55)
Forward Current - 20.0 Amperes
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
Construction utilizes void-free
molded plastic technique
Low reverse leakage
High forward surge current capability
High temperature soldering guaranteed:
250 C,0.25”(6.35mm) from case for 10 seconds
0.110(2.79)
0.100(2.54)
0.590(14.22)
0.530(13.46)
MECHANICAL DATA
0.037(0.94)
0.027(0.68)
0.105 (2.67)
0.095 (2.41)
0.105 (2.67)
0.095 (2.41)
0.205 (5.20)
0.195 (4.95)
0.022(0.58)
0.014(0.35)
PIN 1
PIN 2
PIN 3
CASE
Dimensions in inches and (millimeters)
Case: TO-220AB molded plastic body
Terminals: Leads solderable per MIL-STD-750,
Method 2026
Polarity: As marked
Mounting Position: Any
Weight:0.080 ounce, 2.24 grams
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
SYMBOLS
MBR 20150CT
MBR 20200CT
UNITS
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
(see fig.1)
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Maximum instantaneous forward voltage at 10.0A
Maximum DC reverse current
TA=25 C
at rated DC blocking voltage
TA=100 C
VRRM
VRMS
VDC
150
135
150
200
140
200
VOLTS
VOLTS
VOLTS
Maximum thermal resistance(NOTE 1)
Operating junction temperature range
Storage temperature range
RθJC
TJ
TSTG
MDD Catalog Number
Note: 1.Thermal resistance from junction to case
I(AV)
20.0
Amps
IFSM
150.0
Amps
VF
0.95
Volts
IR
0.2
50.0
mA
1.5
-55 to +150
-55 to +150
C/W
C
C
RATINGS AND CHARACTERISTIC CURVES MBR20150CT THRU MBR20200CT
FIG.1 TYPICAL FORWARD CHARACTERISTICS
FIG.2 FORWARD DERATING CURVE
Average Forward Rectified
Current, (A)
Instantaneous Forward Current, (A)
100
10
1.0
16
12
8.0
4.0
0.8 0.9 1.0
1.1
1.2 1.3
1.4
Instantaneous Forward Voltage, ( V )
FIG.3 TYPICAL REVERSE CHARACTERISTICS
50
75
100
125
150
Case Temperature, ( °C )
FIG.4 PEAK FORWARD SURGE CURRENT
1000
150
Peak Forward Surge Current,
(A)
Instantaneous Reverse Leakage
µ A)
Current, (μ
m
μ
25
100
10
TA=100°C
1.0
TA=25°C
0.1
120
90
60
30
60
80
100
120 140
Percent Of Rated Peak Reverse Voltage, %
1
10
Number Of Cycles At 60Hz
The cruve graph is for reference only, can't be the basis for judgment(曲线图仅供参考)!
100
很抱歉,暂时无法提供与“MBR20200CT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+1.37327
- 500+1.33772
