KBU8005 THRU KBU810
Reverse Voltage - 50 to 1000 Volts Forward Current - 8.0 Amperes
SILICON BRIDGE RECTIFIERS
Features
KBU
The plastic package carries Underwriters Laboratory
.157(4.0)*45°
Flammability Classification 94V-0
0.935(23.7)
0.895(22.7)
Ideal for printed circuit boards
Low reverse leakage
0.15 x0.23L
(3.8 x5.7L)
HOLE THRU
0.300
(7.5)
0.700(17.8)
0.600(16.8)
High forward surge current capability
High temperature soldering guaranteed:
260°C/10 seconds,0.375”(9.5mm) lead length,
0.780(19.8)
0.740(18.8)
AC
5 lbs. (2.3kg) tension
0.669
MIN.
(17.0)
0.866
MIN.
(22.0)
Mechanical Data
0.052(1.3)
DIA.
0.048(1.2)
Case : JEDEC KBU Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.3ounce,8.0grams
0.220(5.6)
0.180(4.6)
0.087(2.2)
0.071(1.8)
0.280(7.1)
0.236(6.0)
Maximum Ratings And Electrical Characteristics
Dimensions in inches and (millimeters)
Ratings at 25°C ambient temperature unless otherwisespecified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward output rectified current
at TA=50 ℃
Peak forward surge current
8.3ms single half sine-wave superimposed
on rated load (JEDEC Method)
Maximum instantaneous forward
voltage drop per birdge element at 8.0A
Maximum DC reverse current
TA=25°C
at rated DC blocking voltage
TA=125°C
Typical Junction Capacitance (Note 1)
Typical Thermal Resistance (Note 2)
Operating junction temperature range
storage temperature range
SYMBOLS
VRRM
VRMS
VDC
MDD
MDD
KBU8005 KBU801
50
35
50
100
70
100
MDD
KBU802
MDD
KBU804
MDD
KBU806
MDD
KBU808
MDD
KBU810
UNITS
200
140
200
400
280
400
600
420
600
800
560
800
1000
700
1000
V
V
V
I(AV)
8.0
A
IFSM
300
A
VF
1.1
V
10
0.5
200
2.7
-55 to +150
-55 to +150
μA
mA
pF
°C/W
°C
°C
IR
CJ
RθJA
TJ
TSTG
NOTES:
1.Thermal resistance from Junction to Ambemt on P.C.board mounting.
http://www.microdiode.com
Rev:2024A3
Page :1
KBU8005 THRU KBU810
Ratings And Characteristic Curves
Fig. 2 Maximum Non-repetitive Peak
Forward Surge Current
Fig. 1 Derating Curve for
Output Rectified Current
300
Heat Sink
mounting, Tc
Peak Forward Surge
Current, Amperes
Average Forward Output
Current, Amperes
8.0
6.0
4.0
60Hz Resistive
of
Inductive Load
Mounted on 4X4 inch
copper PC board,
TA
1.27 mm leadlength
2.0
100
8.3ms
Single half-sine-Wave
[JEDEC Method]
250
200
150
100
50
10
1
100
Number of Cycles at 60HZ
150
Fig. 4 Typical Reverse
Characteristics
Case Temperature, ℃
10
Fig. 3 Typical Instantaneous
Forward Characteristics
Instantaneous Reverse
Current ,Amperes
Tc=100 C
100
40
10
4.0
1.0
0.1
TA=25 C
.01
60
80
100
120
140
Percent of Rated Peak Reverse Voltage, %
0.1
Tj=25 C
Pulse Width=300us
2% duty cycle
.01
0.6
0.7
0.8
0.9
1.0
1.1
Fig. 5 Typical Junction Capacitance
1.2
Instantaneous Forward Voltage, Volts
400
1.3
Capacitance, pF
Current, Amperes
100
50
10
Tj=25 C
f=1.0MHz
Ving =50mV p.p.
1
1.5
10
2
100
Reverse Voltage, Volts
The curve above is for reference only.
Rev:2024A3
Page :2
很抱歉,暂时无法提供与“KBU810”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.42579
- 50+1.93432
- 150+1.72372
- 400+1.27567
- 国内价格
- 1+1.50700
- 50+1.15500
- 400+1.06920
- 国内价格
- 50+1.17463
- 500+1.16220
- 国内价格
- 5+2.67333
- 50+2.13171
- 150+1.89962
- 400+1.40584
- 2400+1.27689
- 4800+1.19956
