RS2035H6A
RS2035H6A
    RICKY(浩瑞佳)
    TO-220A
    20A 600V IGT3:
RS2035H6A 数据手册
Shenzhen RICKY Electronic Technology Co.,Ltd RS16xxHxF Series 16A TRIACS High current density due to double mesa technology, glass passivation,guaranteed maximum junction temperature 150°C. RS16xxH series triacs are suitable for general purpose AC switching,They can be used as an ON/OFF function in applications such as static relays,washing machine,soymlik maker,flush tollet,hair drier,indution motor staing circuits...or for phase contol operation light dimmers,motor speed controllers. RS1610H-1620H-1635H-1650H are 3 quadrants triacs, They are specially recommended for use on inductive loads. RS16xxHxF series are full pack plastic e,they provide a 2000V RMS isolation voltage from all three terminals to external heat sink. TEL:+86-755-89519740 www.sika-wen.com RS16xxHxF Series Shenzhen RICKY Electronic Technology Co.,Ltd RS1610H RS1620H RS1635H RS1650H R S SIKA CO.,LIMITED F:TO-220F A:TO-220A B:TO-220B E:D2PAK 10:IGT123 10mA 20:IGT123 20mA 35:IGT123 35mA 50:IGT123 50mA TEL:+86-755-89519740 www.sika-wen.com RS16xxHxF Series TEL:+86-755-89519740 Shenzhen RICKY Electronic Technology Co.,Ltd www.sika-wen.com RS16xxHxF Series TEL:+86-755-89519740 Shenzhen RICKY Electronic Technology Co.,Ltd -4/4- www.sika-wen.com
RS2035H6A
物料型号:RS16xxHxF Series
器件简介: - 该系列三端双向可控硅采用双峰技术和玻璃钝化,具有高电流密度。 - 适用于通用交流开关,可作为静态继电器、洗衣机、豆浆机、冲洗马桶、吹风机、感应电机启动电路等应用的开/关功能。 - RS1610H-1620H-1635H-1650H是三象限三端双向可控硅,特别推荐用于感性负载。
引脚分配: - TO-220F和TO-220AB封装的三端双向可控硅具有三个引脚:T1(1)、G(3)、T2(2)。
参数特性: - 额定RMS电流(IT(RMS)):16A - 断态重复峰值电压(VDRM/VRRM):600V和800V - 维持电压(VTM):≤1.55V
功能详解: - 绝对最大额定值包括存储结温范围(Tstg):-40°C至+150°C,工作结温范围(Tj):-40°C至+150°C。 - 非重复浪涌峰值关断电压(VDSM)和非重复峰值反向电压(VRSM)分别为700V和900V(或600V和800V)。
应用信息: - 适用于需要高电流密度和高结温的应用,如家用电器和工业控制设备。
封装信息: - 提供TO-220F和TO-220AB封装,提供2000V RMS隔离电压从所有三个引脚到外部散热器。
