山东晶导微电子股份有限公司
Jingdao Microelectronics co.LTD
MM3Z2V0B THRU MM3Z75B
Silicon Planar Zener Diodes
PINNING
PIN
FEATURES
• Total power dissipation: Max. 300mW.
• Wide zener reverse voltage range 2.0V to 75V.
• Small plastic package suitable for surface mounted design.
• Tolerance approximately±2%
DESCRIPTION
1
Cathode
2
Anode
2
1
MECHANICAL DATA
▪Case: SOD-323
▪Terminals: Solderable per MIL-STD-750, Method 2026
▪A pprox. Weight: 5.48mg / 0.00019oz
Top View
Simplified outline SOD-323 and symbol
Absolute Maximum Ratings And Characteristics (Ta = 25 °C)
Symbol
Value
Unit
Power Dissipation
P tot
300
mW
Forward Voltage at I F = 10 mA
VF
0.9
V
RθJA
417
°C/W
T j , T stg
-55 ~ +150
°C
Parameter
Typical thermal resistance juncting to ambient
Operating and Storage Temperature Range
(1)
Fig.1 Maximum Continuous Power Derating
0.35
Power Dissipation ( W )
0.3
0.25
0.2
0.15
0.1
0.05
0.0
25
50
75
100
125
150
T c ,Case Temperature (°C)
2017.12
175
Transient Thermal Impedance( °C /W)
(1) Thermal resistance from junction to ambient at P.C.B. mounted with 2 .0" X 2.0" (5 X 5 cm) copper areas pads.
Fig.2 Typical Transient Thermal Impedance
2000
1000
100
10
0.01
0.1
1
10
100
t, Pulse Duration(sec)
SOD323-W-MM3Z2V0B~MM3Z75B-300mW
Page 1 of 3
山东晶导微电子股份有限公司
Characteristics at Ta = 25°C
Zener Voltage Range (1)
I ZT
Type
Marking
V ZT(at I ZT)
Min(V)
Nom(V)
Max(V)
(mA)
Dynamic
Impedance
Reverse Current
Z ZT(at I ZT)
IR
at V R
Max (Ω)
Max(μA)
(V)
MM3Z2V0B
B0
1.96
2.0
2.04
5
100
120
0.5
MM3Z2V2B
C0
2.16
2.2
2.24
5
100
120
0.7
MM3Z2V4B
1C
2.35
2.4
2.45
5
100
120
1
MM3Z2V7B
1D
2.65
2.7
2.75
5
110
120
1
MM3Z3V0B
1E
2.94
3.0
3.06
5
120
50
1
MM3Z3V3B
1F
3.23
3.3
3.37
5
130
MM3Z3V6B
1H
3.53
3.6
3.67
5
130
10
1
MM3Z3V9B
1J
3.82
3.9
3.98
5
130
5
1
MM3Z4V3B
1K
4.21
4.3
4.39
5
130
5
1
MM3Z4V7B
1M
4.61
4.7
4.79
5
130
2
1
MM3Z5V1B
1N
5
5.1
5.2
5
130
2
1.5
MM3Z5V6B
1P
5.49
5.6
5.71
5
80
1
2.5
MM3Z6V2B
1R
6.08
6.2
6.32
5
50
1
3
MM3Z6V8B
1X
6.66
6.8
6.94
5
30
0.5
3.5
MM3Z7V5B
1Y
7.35
7.5
7.65
5
30
0.5
4
MM3Z8V2B
1Z
8.04
8.2
8.36
5
30
0.5
5
MM3Z9V1B
2A
8.92
9.1
9.28
5
30
0.5
6
MM3Z10B
2B
9.8
10
10.2
5
30
0.1
7
MM3Z11B
2C
10.78
11
11.22
5
30
0.1
8
MM3Z12B
2D
11.76
12
12.24
5
35
0.1
9
MM3Z13B
2E
12.74
13
13.26
5
35
0.1
10
MM3Z15B
2F
14.7
15
15.3
5
40
0.1
11
MM3Z16B
2H
15.68
16
16.32
5
40
0.1
12
MM3Z18B
2J
17.64
18
18.36
5
45
0.1
13
MM3Z20B
2K
19.6
5
50
0.1
15
MM3Z22B
2M
21.56
22
22.44
5
55
0.1
17
MM3Z24B
2N
23.52
24
24.48
5
60
0.1
19
MM3Z27B
2P
26.46
27
27.54
2
70
0.1
21
MM3Z30B
2R
29.4
30
30.60
2
80
0.1
23
MM3Z33B
2X
32.34
33
33.66
2
80
0.1
25
0.1
27
MM3Z36B
2Y
35.28
36
36.72
2
90
MM3Z39B
2Z
38.22
39
39.78
2
100
0.1
30
MM3Z43B
3A
42.14
43
43.86
2
130
0.1
33
MM3Z47B
3B
46.06
47
47.94
2
150
0.1
36
MM3Z51B
3C
49.98
51
52.02
2
180
0.1
39
MM3Z56B
3D
54.88
56
57.12
2
200
0.1
43
MM3Z62B
3E
60.76
62
63.24
2
215
0.1
47
MM3Z68B
3F
66.64
68
69.36
2
240
0.1
52
MM3Z75B
3H
73.5
75
76.5
2
265
0.1
56
(1) V ZT is tested with pulses (20 ms)
2017.12
www.sdjingdao.com
Page 2 of 3
山东晶导微电子股份有限公司
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SOD-323
E
E
D
b
A
C
A1
∠ALL ROUND
L1
E1
SOD-323 mechanical data
A
C
D
E
E1
b
L1
A1
max
1.1
0.15
1.4
1.8
2.75
0.4
0.45
0.2
min
0.8
0.08
1.2
1.4
2.55
0.25
0.2
max
43
5.9
55
70
108
16
16
min
32
3.1
47
63
100
9.8
7.9
UNIT
mm
9°
8
mil
The recommended mounting pad size
1.4
(55)
1.2
(47)
1.2
(47)
1.2
(47)
Unit: mm
(mil)
2017.12
www.sdjingdao.com
Page 3 of 3
很抱歉,暂时无法提供与“MM3Z4V7B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.08085
- 500+0.07595
- 2000+0.06615
- 5000+0.06125
- 15000+0.05635
- 30000+0.05390
