山东晶导微电子有限公司
S3ABF THRU S3MBF
Jingdao Microelectronics
Surface Mount General Purpose Silicon Rectifiers
Reverse Voltage - 50 to 1000 V
PINNING
Forward Current - 3 A
PIN
FEATURES
• For surface mounted applications
• Low profile package
• Glass Passivated Chip Junction
• Easy to pick and place
• Lead free in comply with EU RoHS 2011/65/EU directives
DESCRIPTION
1
Cathode
2
Anode
1
MECHANICAL DATA
• Case: SMBF
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 57mg / 0.002oz
2
Top View
Marking Code: S3AB-S3MB
Simplified outline SMBF and symbol
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.
Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %.
Symbols
S3ABF
S3BBF
S3DBF
S3GBF
S3JBF
S3KBF
S3MBF
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
50
100
200
400
600
800
1000
V
Maximum RMS voltage
V RMS
35
70
140
280
420
560
700
V
Maximum DC Blocking Voltage
V DC
50
100
200
400
600
800
1000
V
Maximum Average Forward Rectified Current
at T c = 115 °C
I F(AV)
3
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
I FSM
80
A
Maximum Instantaneous Forward Voltage at 3 A
VF
1.1
V
IR
5
150
μA
Cj
35
pF
RθJA
RθJC
45
15
°C/W
T j , T stg
-55 ~ +150
°C
Parameter
Maximum DC Reverse Current
T a = 25 °C
at Rated DC Blocking Voltage
T a =125 °C
Typical Junction Capacitance (1)
Typical Thermal Resistance (2)
Operating and Storage Temperature Range
(1)Measured at 1 MHz and applied reverse voltage of 4 V D.C
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
2016.01
SMAF-A-S3ABF~S3MBF-3A1KV
Page 1 of 3
山东晶导微电子有限公司
S3ABF THRU S3MBF
Fig.2 Typical Reverse Characteristics
3.0
2.0
1.0
0.0
25
50
75
100
125
150
175
Instaneous Reverse Current(μ A)
Average Forward Current (A)
Fig.1 Forward Current Derating Curve
100
T J =125°C
10
1.0
T J =25°C
0.1
00
Case Temperature (°C)
40
60
80
100
120
140
Fig.4 Typical Junction Capacitance
Fig.3 Typical Forward Characteristic
10
Junction Capacitance ( pF)
Instaneous Forward Current (A)
percent of Rated Peak Reverse Voltage (%)
1.0
T J =25°C
100
10
T J =25°C
0.1
0.4
1
0.6
0.8
1.0
1.2
1.4
1.6
1.8
0.1
1.0
10
100
Reverse Voltage (V)
Instaneous Forward Voltage (V)
Peak Forward Surage Current (A)
Fig.6 Maximum Non-Repetitive Peak
120
100
80
60
40
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles
2016.01
www.sdjingdao.com
Page 2 of 3
山东晶导微电子有限公司
S3ABF THRU S3MBF
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SMBF
∠ALL ROUND
C
A
∠ALL ROUND
D
E
A
V M
g
Top View
mil
Bottom View
A
C
D
E
HE
e
max
1.3
0.26
4.4
3.7
5.5
2.2
min
1.1
0.18
4.2
3.5
5.1
1.9
max
51
10
173
146
216
86
min
43
7
165
138
200
75
UNIT
mm
9°
Type number
Marking code
S3ABF
S3AB
S3BBF
S3BB
S3DBF
S3DB
S3GBF
S3GB
S3JBF
S3JB
S3KBF
S3KB
S3MBF
S3MB
1.8(71)
2.54(100)
3.0(118)
40
Marking
Unit:mm(mil)
2016.01
g
1.0
The recommended mounting pad size
1.8(71)
g
pad
e
E
A
pad
HE
JD601118B0
Page 3 of 3
很抱歉,暂时无法提供与“S3MBF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.34700
- 100+0.20700
- 500+0.14490
- 5000+0.10350
- 10000+0.09830
- 50000+0.09110
- 国内价格
- 20+0.22734
- 200+0.18015
- 600+0.15390
- 国内价格
- 20+0.22220
- 200+0.17490
- 600+0.14930
- 国内价格
- 20+0.20849
- 500+0.14107
- 2000+0.13966
- 5000+0.13687
