SF1004DS
SF1004DS
    JINGDAO(晶导微电子)
    TO-252(DPAK)
    快/超快恢复二极管 TO252 VRRM=400V Io=10A VF=1.3V
SF1004DS 数据手册
山东晶导微电子股份有限公司 SF1001 THRU SF1006 Jingdao Microelectronics co.LTD SUPER FAST GLASS PASSIVATED RECTIFIERS Reverse Voltage – 100 to 600 V Forward Current – 10 A FEATURES • High current capability • Low forward voltage drop • Low power loss, high efficiency • High surge capability • High temperature soldering guaranteed • Mounting position: any 1 3 2 1 4 1 3 2 1 4 MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25℃ ambient temperature unless otherwise specified TO-251 SF1001VS SF1002VS SF1003VS SF1004VS SF1005VS SF1006VS CHARACTERISTICS Units TO-252 SF1001DS SF1002DS SF1003DS SF1004DS SF1005DS SF1006DS Maximum Recurrent Peak Reverse Voltage V RRM 100 200 300 400 500 600 V Maximum RMS voltage V RMS 70 140 210 280 350 420 V Maximum DC Blocking Voltage V DC 700 200 300 400 500 600 V Maximum Average Forward Rectified Current I F(AV) 10 A Peak Forward Surge Current,8.3ms Single Half Sine-wave Superimposed on Rated Load (JEDEC method) I FSM 170 A VF Max Instantaneous Forward Voltage at 10 A DC (1) Maximum Reverse Recovery Time 1.70 V 1 300 uA Cj 45 pF RθJA 15 °C/W t rr 35 ns Tj -55 ~ +150 °C T stg -55 ~ +150 °C T a =125°C Typical Junction Capacitance f=1MHz,4V DC Typical Thermal Resistance 1.30 IR Maximum DC Reverse Current T a = 25°C at Rated DC Reverse Voltage 0.95 (2) Operating Junction Temperature Range Storage Temperature Range (1)P.C.B. mounted with 10cm x 10cm x 1mm copper pad areas. (2)Measured with I F = 0.5 A, I R = 1 A, I rr = 0.25 A. 2018.12 TO-251& TO-252 -E-SF1001~SF1006-10A600V Page 1 of 4 山东晶导微电子股份有限公司 SF1001 THRU SF1006 Jingdao Microelectronics co.LTD Fig.2 Typical Reverse Characteristics 300 10.0 I R - Reverse Current ( μ A) Average Forward Current (A) Fig.1 Maximum Average Forward Current Rating 8.0 6.0 4.0 2.0 RESISTIVE OR INDUCTIVE LOAD 100 T J =125°C 10 T J =75°C 1.0 T J =25°C 0.1 0.0 25 50 75 100 125 150 Case Temperature (°C) 10 100~200V 300~400V 500~600V 0.1 Junction Capacitance ( pF) Instaneous Forward Current (A) T J =25°C 1.0 1.5 80 100 T J =25°C 100 0.01 0.5 60 Fig.4 Typical Junction Capacitance 100 0 40 Percent of rated peak reverse voltage % Fig.4 Typical Forward Characteristics 1.0 20 0 175 2.0 2.5 Instaneous Forward Voltage (V) 10 T J=25°C f = 1.0MHz V sig = 50mV p-p 1 0.1 1.0 10 100 Reverse Voltage (V) Peak Forward Surage Current (A) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current 210 180 150 120 90 60 30 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 10 100 Number of Cycles 2018.12 www.sdjingdao.com Page 2 of 4 山东晶导微电子股份有限公司 SF1001 THRU SF1006 Jingdao Microelectronics co.LTD TO-251(D-PAK) Package Outline Dimensions A B C E L1 + D L M N b1 b G H F G TO-251(I-PAK) mechanical data UNIT A B b b1 C D E F G H L L1 M N max 6.7 5.5 0.8 0.9 2.5 6.3 0.6 1.8 0.55 4.3 1.2 min 6.3 5.1 0.3 0.76 2.1 5.9 0.4 1.3 2.29 TYPICAL 0.45 3.9 0.8 1.8 TYPICAL 1.3 TYPICAL max 264 217 31 35 98 248 24 71 22 169 47 min 248 201 12 30 83 232 16 51 18 154 31 71 TYPICAL 51 TYPICAL mm mil 90 TYPICAL Important Notice and Disclaimer Jingdao Microelectronics reserves the right to make changes to this document and its products and specifications at any time without notice. Customers should obtain and confirm the latest product information and specifications before final design, purchase or use. Jingdao Microelectronics makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, not does Jingdao Microelectronics assume any liability for application assistance or customer product design. Jingdao Microelectronics does not warrant or accept any liability with products which are purchased or used for any unintended or unauthorized application. No license is granted by implication or otherwise under any intellectual property rights of Jingdao Microelectronics. Jingdao Microelectronics products are not authorized for use as critical components in life support devices or systems without express written approval of Jingdao Microelectronics. 2018.12 JD81225 Page 3 of 4 山东晶导微电子股份有限公司 SF1001 THRU SF1006 Jingdao Microelectronics co.LTD TO-252(D-PAK) Package Outline Dimensions A B C E L1 + D M N J K T S L2 L L3 b G H G F TO-252(D-PAK) mechanical data UNIT mm mil A B b C D E F max 6.7 5.5 0.8 2.5 6.3 0.6 1.8 min 6.3 5.1 0.3 2.1 5.9 max 264 217 31 98 min 248 201 12 83 G H L L1 L2 L3 S 1.2 1.0 1.75 0.1 0.4 0.55 3.1 2.29 TYPICAL 1.3 0.45 2.7 0.8 0.6 1.40 0.0 248 24 71 122 47 39 69 4 232 16 51 22 90 TYPICAL 18 106 31 24 55 0 M N J K T 3.16 1.80 4.83 1.8 1.3 TYPICAL TYPICAL ref. ref. ref. 124 71 190 71 51 TYPICAL TYPICAL ref. ref. ref. Important Notice and Disclaimer Jingdao Microelectronics reserves the right to make changes to this document and its products and specifications at any time without notice. Customers should obtain and confirm the latest product information and specifications before final design, purchase or use. Jingdao Microelectronics makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, not does Jingdao Microelectronics assume any liability for application assistance or customer product design. Jingdao Microelectronics does not warrant or accept any liability with products which are purchased or used for any unintended or unauthorized application. No license is granted by implication or otherwise under any intellectual property rights of Jingdao Microelectronics. Jingdao Microelectronics products are not authorized for use as critical components in life support devices or systems without express written approval of Jingdao Microelectronics. 2018.12 JD70422 Page 4 of 4
SF1004DS 价格&库存
很抱歉,暂时无法提供与“SF1004DS”相匹配的价格&库存,您可以联系我们找货
SF1004DS
    • 1+0.83960
    库存:5
    SF1004DS
    • 1+0.41055
    • 100+0.38318
    • 300+0.35581
    • 500+0.32844
    • 2000+0.31475
    • 5000+0.30654
    SF1004DS
    • 20+1.35220
    • 100+0.80660
    • 500+0.56460
    • 2500+0.40330
    • 5000+0.38320
    • 25000+0.35490
    库存:419
