規 格 承 認 書
PECIFICATION FOR APPROVAL
客 戶
CUSTOMER
: 立创
項 目
ITEM
: 贴片式压电无源蜂鸣器(外部驱动)
型 號
TYPE
: GSC9018RA-5V4000
DESCRIPTION : L9.0 x W9.0 x H1.8 MM 4000Hz 5V ≥70DB 正发音 LCP 材质
客戶料號
CUSTOMER NO. :
規格書號
SPECIFICATION NO.:
版 本
EDITION NO. :
V1.1
日 期
DATE
2018-7-18
客戶承認
CUSTOMER CONFIRMAND SIGN
檢查
TESTED BY
審核
CHECKED BY
承認
APPROVED BY
東莞市赢海電子有限公司
DONGUAN INGHAI ELECTRONICS CO.,LTD
製作
ISSUED BY
審查
CHECKED BY
周明
刘承成
地址:廣東省東莞市虎门镇怀德社区雅瑶工业区
電話 / TEL:0769-83060958 傳真 / FAX: 0769-81608993
網址:HTTP://WWW.INGHAI.COM
確認
APPROVED BY
A. SCOPE
This specification applies Piezo buzzer, GSC9018RA-5V4000
B. SPECIFICATION
No.
Item
Unit
Specification
Condition
1
Oscillation Frequency
Hz
4000
Square Wave
2
Operating Voltage
Vp-p
1~25
3
Rated Voltage
Vp-p
5
4
Current Consumption
mA
MAX. 3
at Rated Voltage
5
Sound Pressure Level
dB
MIN.70
at 10cm at Rated Voltage
6
Electrostatic Capacity
pF
12000±30%
at 100Hz 1V
7
Operating Temperature
-20~ +70
8
Storage Temperature
-30 ~ +80
9
Dimension
mm
9.0 x 9.0 x H1.8
10
Weight (MAX)
gram
0.3
11
Housing Material
PPA( Black )
12
Leading Pin
Tin Plated Brass(Sn)
13
Environmental
Protection Regulation
RoHS
See appearance drawing
C. APPEARANCE DRAWING
开放孔
点胶
点胶
点胶
Mark
Tol : ± 0.5
Sound holes
Unit: mm
建议焊盘尺寸
D.TESTING METHOD
Standard Measurement conditions
Temperature:25±2℃ Humidity:45-65%
Acoustic Characteristics:
The oscillation frequency, current consumption and sound pressure are measured by the
measuring instruments shown below
In the measuring test, buzzer is placed as follows:
E. Typical Frequency Response Curve
F. Soldering Condition
(1)Recommendable reflow soldering condition is as follows
(Reflow soldering is twice)
Note:It is requested that reflow soldering should be executed
after heat of product goes down to normal.
Heat resistant line
(Used when heat resistant reliability test is performed)
(2)Manual soldering
Manual soldering temperature 350º C within 5 sec.
G. RELIABILITY TEST
NO.
ITEM
1
High Temperature
Test (Storage)
2
Low Temperature
Test (Storage)
After being Placed in a chamber with -302ºC for 96 hours and then
being placed in normal condition for 2 hours.
Allowable variation of SPL after test: 10dB.
Humidity Test
After being Placed in a chamber with 90-95% R.H. at 402ºC for 96
hours and then being placed in normal condition for 2 hours.
3
TEST CONDITION AND REQUIREMENT
After being placed in a chamber with 802ºC for 96 hours and then
The part shall be subjected to 5 cycles. One cycle shall be consist of:
+70ºC
+25ºC
4
Temperature Cycle
Test
+25ºC
- 20ºC
5
6
Drop on a hard wood board of 4cm thick, any directions ,6 times,
at the height of 75cm .
Drop Test
After being applied vibration of amplitude of 1.5mm with 10 to 55 Hz
band of vibration frequency to each of 3 perpendicular directions for
2 hours .
Vibration Test
Lead terminals are immersed in rosin for 5 seconds and then
immersed in solder bath of +3005ºC for 31 seconds .
7
Solderability
Test
8
Terminal Strength
Pulling Test
90% min. lead terminals shall be wet with solder
(Except the edge of terminals).
The force of 9.8N(1.0kg) is applied to each terminal in axial direction for
10 seconds.
No visible damage and cutting off.
TEST CONDITION.
Standard Test Condition
一般测试条件
Judgment Test Condition
争议时测试条件
a) Temperature : +5 ~ +35℃
a) 温度 : +5 ~ +35℃
a) Temperature : +25 ± 2℃
a) 温度 : +25 ± 2℃
b) Humidity : 45-85%
b) 湿度 : 45-85%
b) Humidity : 60-70%
b) 湿度 : 60-70%
c) Pressure : 860-1060mbar
c) 气压 : 860-1060mbar
H. PACKING STANDARD
1 Reel : 2000PCS
发音孔
通孔
Carton Box
(5 Inner Box)
Inner Box
(1Layer Reel)
Inner Box
340mmx340mmx30mm
1x2000PCS=2000PCS
Carton Box
350mmx355mmx175mm
5x2000PCS=10,000PCS
Revision History
修改项目
1 编带修改
②公差
修改前
16 宽
± 0.2
修改后
24 宽
±0.5
修改日期
2014-7-8
2014-9-26
修改人
Zhu
Zhu
确认人
很抱歉,暂时无法提供与“GSC9018RA-5V4000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+4.42960
- 10+3.57700
- 30+3.15560
- 100+2.73420
- 国内价格
- 1+4.88160
- 10+3.94200
- 30+3.47760
- 100+2.86254
- 500+2.44188
- 1000+2.30850
