規 格 承 認 書
PECIFICATION FOR APPROVAL
客 戶
CUSTOMER
項 目
ITEM
型 號
: 立创
电磁有源一体蜂鸣器(内含驱动电路)
TYPE
: GMD1614YB-5V2400
DESCRIPTION :
D16 x H14 MM 2400Hz
客戶料號
CUSTOMER NO. :
規 格 書 號
DC5V ≥85DB
PPO 材质
P=7.6MM
SPECIFICATION NO.:
版 本
EDITION NO.
日 期
DATE
V1.1
客戶承認
CUSTOMER CONFIRM AND SIGN
檢查
審核
承認
TESTED BY
CHECKED BY
APPROVED BY
東莞市赢海電子有限公司
DONGUAN INGHAI ELECTRONICS CO.,LTD
製作
審查
確認
ISSUED BY
CHECKED BY
APPROVED BY
周明
李林
地址:廣東省東莞市長安鎮厦边元灶头工业区 16-6 號
電話 / TEL:0769-83060958
傳真 / FAX: 0769-81608993
網址:HTTP://WWW.INGHAI.COM
1/4
DONGGUAN INGHAI ELECTRONICS CO.,LTD
Model NO: GMD1614YB-5V2400
A:DIMEMSIONS:
Unit:mm
Tolerance:±0.5mm
14.0
16.0
7.6
14.0
12蓝帽
7.0
3.3
2- 0.7
5.5
Potting
0.5
侧面银色油墨
Sound Emission Hole
3.0
Tolerance:+0.5mm
Unit:mm
B:SPECIFICATIONS:
Model NO
Rated Voltage
GMD1614YB
5VDC
Operating Voltage
3.0~8.0VDC
Max.Rated Current
Max.35mA
Sound Pressure level(dB/min)at12DVC/10cm
Min 85dB
Resonant Frequency
2400±300Hz
Operating Temperature
-20 ℃~+70 ℃
Storage Temperature
-30 ℃~+80℃
Case material and color
PBT / Black
Measuring condition
Part shall be measured under a condition (Temperature: 5~ 35℃, Humidity: 45% ~ 85%R.H., Atmospheric
pressure: 860 ~ 1060hPa) unless the standard condition (Temperature: 25±3℃, Humidity: 60±10%R.H.
Atmospheric pressure: 860 ~1060hPa) is regulated to measure.
2/4
C:Acoustic Characteristics:
The oscillation frequency, current consumption and sound pressure are measured by the
measuring instruments shown below
In the measuring test, buzzer is placed as follows:
D:Typical Frequency Response Curve:
dB
mA
100
30
dB
90
25
80
mA
15
10 11 12 13 14 15
VDC
60
9
3/4
E:Reliability Test
After any following tests the part shall meet specifications without any degradation in
appearance and performance except SPL. SPL shall not deviate more than -10 dB
from the initial value
1.
Ordinary Temperature Life Test
The part shall be subjected to 96 hours at 25±10℃. Input rated voltage
2.
3.
4.
5.
6.
7.
Resonant frequency, 1/2 duty Square wave.
High Temperature Test
The part shall be capable of with standing a storage temperature of +80℃ for 96 hours.
Low Temperature Test
The part shall be capable of with standing a storage temperature of -30℃ for 96 hours.
Humidity Test
Temperature:+40℃±3℃
Relative Humidity:90%~95% Duration: 48 hours
and expose to room temperature for 6 hours
Temperature Shock Test
Temperature:70℃ /1hour→ 25℃/3hours→-30℃/1hour→ 25℃/3hours (1cycle)
Total cycle: 10 cycles
Drop Test
Standard Packaging From 120mm(Drop on hard wood or board of 5cm thick,
three sides, six plain.)
Vibration Test
Vibration:1000cycles /min. Amplitude:1.5mm, Duration: 1 hour in each 3 axes
Note:
As this product is not protected from foreign material entering, please make sure that any foreign materials
(e.g. magnetic powder, washing solvent, flux, corrosive gas) do not enter this product in your production
processes. The functional degradation (e.g. SPL down) may occur if foreign material enter it.
4/4
很抱歉,暂时无法提供与“GMD1614YB-5V2400”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+6.67440
- 10+5.46480
- 30+4.86000
- 100+4.25520
- 国内价格
- 1+3.17240
- 30+2.94580
- 100+2.71920
- 500+2.49260
- 1000+2.26600
- 国内价格
- 1+2.39400
- 30+2.30400
- 100+2.12400
- 500+1.94400
- 1000+1.85400
