14D102K
14D102K
    RUILON(瑞隆源)
    VAR_D17X8.4MM_TM
    压敏电阻 = 1.1KV VC=1650V DIP
14D102K 数据手册
Metal Oxide Varistors 14D Series Features  Wide operating voltage (V1mA) range from 18V to 1800V  Fast responding to transient over-voltage.  Large absorbing transient energy capability.  Low clamping ratio and no following-on current. General Information  Surge protection in consumer electronics  Surge protection in industrial electronics  Relay and electromagnetic valve surge absorption General Characteristics  Transistor, diode, IC, thyristor or triac semiconductor  Body: Nickel Plated protection  Devices with No Leads: Nickel Plated  Surge protection in electronic home appliances, gas and  Storage Temperature: -40 ºC to +125ºC petroleum appliances  Axial Devices: Tin Plated  Agency: UL( E479668),CUL( E479668), CQC(22001337353),TUV(J50541477) Part Number Code 1 4 Element Diameter D 4 7 1 K J Type Nominal Varistor Voltage Surge Series D:Disk 471=47*101V No Suffix:Standard Type Varistor Voltage Tolerance J:High Surge Type K = ±10 % Agency Information Agency Information Agency File Number Operating temperature range UL E479668 - 40°C to 125°C CUL E479668 - 40°C to 105°C CQC 22001337360 - 40°C to +125°C TUV J50541477 - 40°C to +125°C Specifications are subject to change without notice. Please refer to http://www.ruilon.com.cn for current information. Revised: 2022-11-21 Version: A2 Page 1 of 10 Metal Oxide Varistors 14D Series Electrical Characteristics Type Number Varistor Voltage Max. Allowable Voltage Max. Energy (10/1000μs) VAC(V) VDC(V) (J) (J) Standard High Surge Standard High Surge V1mA(V) 14D180K / 15~22 11 14 5.7 14D220K / 20~26 14 18 14D270K / 24.3~31.1 17 14D330K / 29.7~37.9 20 14D390K / 35.2~44.8 14D470K / 14D560K Max. Clamping Voltage (8/20μs) Withstanding Surge Current(8/20μs) Typical Rated Capacitance Power (Reference) IP(A) VC(V) I(A) Standard I(A) High Surge (W) @1KHz(pf) / 10 38 1000 / 0.1 18000 7.0 / 10 43 1000 / 0.1 15000 22 8.5 / 10 53 1000 / 0.1 10000 26 10 / 10 65 1000 / 0.1 8500 25 31 12 / 10 77 1000 / 0.1 7500 43~53 30 38 15 / 10 93 1000 / 0.1 6500 / 51~63 35 45 18 / 10 110 1000 / 0.1 5600 14D680K / 62~76 40 56 21 / 10 135 1000 / 0.1 4700 14D820K 14D820KJ 74~90 50 65 26 31 50 135 4500 6000 0.6 3900 14D101K 14D101KJ 90~110 60 85 32 38 50 165 4500 6000 0.6 3400 14D121K 14D121KJ 108~132 75 100 38 46 50 200 4500 6000 0.6 3100 14D151K 14D151KJ 135~165 95 125 47 56 50 250 4500 6000 0.6 3000 14D181K 14D181KJ 162~198 115 150 57 60 50 300 4500 6000 0.6 1030 14D201K 14D201KJ 185~225 130 170 63 82 50 340 4500 6000 0.6 970 14D221K 14D221KJ 198~242 140 180 69 90 50 360 4500 6000 0.6 840 14D241K 14D241KJ 216~264 150 200 76 98 50 395 4500 6000 0.6 710 14D271K 14D271KJ 243~297 175 225 85 116 50 455 4500 6000 0.6 650 14D301K 14D301KJ 270~330 195 250 95 128 50 505 4500 6000 0.6 600 14D331K 14D331KJ 297~363 210 275 104 140 50 550 4500 6000 0.6 550 14D361K 14D361KJ 324~396 230 300 113 158 50 595 4500 6000 0.6 500 14D391K 14D391KJ 351~429 250 320 123 170 50 650 4500 6000 0.6 480 14D431K 14D431KJ 387~473 275 350 136 185 50 710 4500 6000 0.6 440 14D471K 14D471KJ 423~517 300 385 148 205 50 775 4500 6000 0.6 420 14D511K 14D511KJ 459~561 320 418 148 220 50 842 4500 6000 0.6 390 14D561K 14D561KJ 504~616 350 460 148 240 50 920 4500 6000 0.6 360 14D621K 14D621KJ 558~682 385 505 148 250 50 1025 4500 6000 0.6 320 14D681K 14D681KJ 612~748 420 560 148 260 50 1120 4500 6000 0.6 290 14D751K 14D751KJ 675~825 460 615 158 270 50 1240 4500 6000 0.6 260 14D781K 14D781KJ 702~858 485 640 164 275 50 1290 4500 6000 0.6 230 14D821K 14D821KJ 738~902 510 670 172 280 50 1355 4500 6000 0.6 230 14D911K 14D911KJ 819~1001 550 745 191 295 50 1500 4500 6000 0.6 200 14D951K 14D951KJ 855~1045 580 780 199 305 50 1570 4500 6000 0.6 190 14D102K 14D102KJ 900~1100 625 825 210 335 50 1650 4500 6000 0.6 180 14D112K 14D112KJ 990~1210 680 895 231 360 50 1815 4500 6000 0.6 150 14D142K 14D142KJ 1260~1540 870 1150 295 370 50 2310 4500 6000 0.6 140 14D152K 14D152KJ 1350~1650 900 1220 312 375 50 2475 4500 6000 0.6 140 14D182K 14D182KJ 1620~1980 1000 1465 378 450 50 2970 4500 6000 0.6 120 Specifications are subject to change without notice. Please refer to http://www.ruilon.com.cn for current information. Revised: 2022-11-21 Version: A2 Page 2 of 10 Metal Oxide Varistors 14D Series Electrical Ratings Items Test Condition/Description Varistor Voltage The voltage between two terminals with the specified measuring current 1mA.DC applied is called Vb. Maximum Allowable Voltage Requirement The recommended maximum sine wave voltage (RMS) or the Maximum DC voltage can be applied continuously. The maximum voltage between two terminals with the specification standard impulse current. Applied waveform: 8/20μs I 1.0 0.9 Maximum Clamping Voltage B 0.5 T2 0.1 0.0 To meet the Specified value C O1 T t T1 30% max. T1=1.25*T=8μs±20% T2=20μs±20% Rated Wattage The maximum average power that can be applied within the specified ambient temperature. Energy The maximum energy within the varistor voltage change of ±10% when one impulse of 10/1000μs or 2ms is applied. Withstanding Surge Current The maximum current within the varistor voltage change of ±10% with the standard impulse current (8/20μs) applied one time. The change of Vb shall be measured after the impulse listed below which is applied 10,000 times continuously with the interval of ten seconds at room temperature. Surge Life 14Φ series Specifications are subject to change without notice. Please refer to http://www.ruilon.com.cn for current information. 180K to 680K 75A (8/20μs) 820K to 182K 150A (8/20μs) Revised: 2022-11-21 Version: A2 ΔVb ≤ ± 10% Vb Page 3 of 10 Metal Oxide Varistors 14D Series Soldering Recommendation Wave Lead Free Soldering Recommendation 300 Preheating 250 Temperature(°C) Soldering Maximum Wave 265°C Cooling Item Conditions Peak Temperature 265ºC Dipping Time 10 seconds (max.) Soldering 1 time 200 150 100 50 0 0 0.5 1 1.5 2 2.5 Time(minutes) 3 3.5 4 Recommendation Reworking Conditions with Soldering Iron Item Conditions Temperature of Soldering Iron-tip 360ºC (max.) Soldering Time 3 seconds (max.) Distance from Varistor 2mm (min.) Dimensions TABLE 1 Symbol Millimeters Inches H(max) 20.0 0.787 L(min) 15.0 0.591 D(max) 17.0 0.669 D1(±1.0) 7.5 0.295 K(max) 2.0 0.079 T(max) TABLE 2 d(±0.1) 0.8 0.031 Packaging Quantity: 250pcs/bag TABLE 2---T(max.) Model Millimeters Inches Model Millimeters Inches 18V~39V 4.6 0.181 430V~560V 6.2 0.244 47V~68V 5.1 0.201 620V~780V 7.2 0.283 82V~150V 4.6 0.181 820V~1200V 8.4 0.331 180V~270V 5.1 0.201 1300V~1500V 9.5 0.374 330V~390V 5.6 0.220 1600V-1800V 11.3 0.445 Specifications are subject to change without notice. Please refer to http://www.ruilon.com.cn for current information. Revised: 2022-11-21 Version: A2 Page 4 of 10 Metal Oxide Varistors 系列 Series 14D 压敏电压 Varistor Voltage 751K~182K Specifications are subject to change without notice. Please refer to http://www.ruilon.com.cn for current information. 14D Series 编带包装数量 Taping Packaging Quantity 数量(K)/内盒 QTY(k)/Lnner Box 数量(K)/箱 QTY(k)/Carton 0.4 3.2 Revised: 2022-11-21 Version: A2 Page 5 of 10 Metal Oxide Varistors 14D Series 安全注意事项 SAFETY PRECAUTIONS 使用压敏电阻器时,压敏电阻器周围条件(设备设计中的材料、环境、电源条件、电路条件等)发生异常时,则可能引发火灾、触 电、烧伤、以及产品故障。 In case that a varistor is used, if an abnormality takes place because of peripheral conditions of the varistor(material, environments,power source conditions, circuit conditions, etc. In equipment design), fire, electric shock, burn, or product failure may be occur. 下列内容为使用时的相关注意事项,请认真确认后再行使用。如对未及事项有疑议,请速与我公司担当部门联系。 The precautions for this product are described below; understand the content thoroughly before usage. For more questions, contact us. 1 严格遵守事项 Precautions to be strictly observed 1.1 额定性能确认 Confirmation of performance ratings 请遵守压敏电阻器的最大连续工作电压,耐冲击电流、最大能量耐量、浪涌寿命、额定功率和操作温度范围等额定性能的规定,在规 定范围内使用。 Use the varistor within its rated range of performance such as the maximum continuous operating voltage, withstanding surge current, maximum energy, impulse life, rated power and operating temperature range。 超出规定范围使用,则会造成压敏电阻器性能劣化,破坏元件,严重可引起压敏电阻器冒烟或起火。 If used outside the range, the varistor can be degrade and have element fracture, which may result in smoking and ignition. 1.2 为避免意外现象发生,请采用如下对策 To avoid accidents due to unexpected phenomena, take the following measures 1) 压敏电阻器受损时,可能出现破碎飞散,因此要对集成产品加保护盖或外盒。 In the event of fracture of the varistor, its pieces may scatter; hence, put the case or cover of the set product in place. 2) 请勿安装在可燃物品(塑料电线、树脂合成物等)附近。若无法避免,请使用不燃性保护外壳。 Do not install the varistor near combustible substances (polyvinyl chloride wires, resin moldings, etc.). If it’s difficult to do, install a nonflammable cover. 3) 线间使用 Across-the-line use 在线间使用时,将保险丝与压敏电阻器串联。 When the varistor is used across a line, put a current fuse in series with the varistor. 4) 线-地间使用 Use between line to ground a) 在线-地间使用时,压敏电阻器短路时会产生接地电阻,电流保险丝不会熔断,可能引起压敏电阻器外涂层树脂冒烟或起火。 If the case that the varistor is used between a line to the ground, the short circuit of the varistor may not blow the current fuse because of grounding resistance, which may cause smoking and ignition of the varistors exterior resin. 为避免上述情况,请在电源端安装漏电断路器。如无漏电断路器,则需将电流保险丝与温度保险丝串联使用。 As the measure against it, install an earth leakage breaker on the power supply side of the varistor position. If no earth leakage breaker is installed, use a thermal fuse together with a current fuse in series. b) 在带电部件与金属部件之间使用压敏电阻器时,压敏电阻器短路时有触电危险,故请将金属部件接地或勿与人体接触。 If the case that the varistor is used between a live parts to metal case, an electric shock may develop at a shortcircuit of the varistor; hence, ground the metal case to the ground or keep it from the human body. Specifications are subject to change without notice. Please refer to http://www.ruilon.com.cn for current information. Revised: 2022-11-21 Version: A2 Page 6 of 10 Metal Oxide Varistors 2 14D Series 使用注意事项 Application notes 2.1 注意下列事项,可能导致压敏电阻器寿命缩短或引发故障 Pay attention to the following items to avoid the shortened life and failure of the varistor. 1) 电路条件 Circuit conditions a) 选定的压敏电阻器的电压最大值在最大连续工作电压值之上。 Select a varistor of which the maximum voltage including fluctuations in source voltage allows for the maximum permissible circuit voltage. b) 短间隔性地施加浪涌时(施加抗干扰模拟试验电压时) ,不可超过压敏电阻器的额定功率。 In cases that surges are intermittently applied at short intervals (for example, in case that the voltage of the noise simulator test is implemented etc.), c) 选定压敏电阻器时,须按照表 1 的标准产品型号。 Select a varistor recommended in table 1. ① 线间使用 Across-the-line use 单相三线式连线时单独配线负荷导致负荷不平衡、电压线和中性线短路、中性线欠损、容量性负荷情况下开闭时的共振等, 将导致电源电压的上升,可能使用表 1 中标有*的产品型号。 If possible, use a part no. Marked with ✽ in case of voltage temporarily rises load unbalance of separately-wired loads, short between hot and neutral-line, open of neutral line in single-phase-three-wired system, and due to resonance at switching for a capacitive, inductive load. ② 线-地间使用 Used between line to ground 出现故障时,对地电压将上升,因此,请使用附表 1 中推荐的产品型号。 Use a different part no. From “across-the-line use” as table 1, because of raising voltage in case of “line to ground fault”. 进行设备的绝缘电阻试验(DC500V)时,请使用表 1 中推荐的标有✽✽的产品型号。使用不可清除绝缘性能试验的压敏电阻电压 时,在一定的电路条件下,试验时可将压敏电阻器从电路上取下。 Use a varistor marked with ❉❉ in table 1, in case of the insulation resistance test (500Vdc) for equipment. When using a part of the varistor voltage that the insulation efficiency examination can not be cleared, there is a case where the varistor can be done by removing it from the circuit depending on the circuit condition. 进行设备的耐电压试验(AC1000V 或 AC1200V)时,请使用表 1 中推荐的标有✽✽✽的产品型号。 Use a varistor marked with ✽✽✽ in table 1, in case of the withstanding voltage test (1000Vac or 1200Vac) for equipment. d) 关于电流保险丝 Concerning current fuse ① 所用压敏电阻器与电流保险丝的额定电流,一般推荐按下表进行选定。此外,在用户端,当压敏电阻器损坏时,确认其设 备是否会发生 2 次伤害。 We recommend selecting a varistor and the rated current of a current fuse as follows. Finally, please be sure that there is no danger if the varistor mounted on the equipment breaks 规格 Specs 05D 07D 10D 14D 20D 保险丝额定电压 ≤2A ≤5A ≤5A ≤10A ≤10A Fuse rated current ② 保险丝的插入部位建议按表 1 操作。 The recommended fuse position is shown in table 1. Specifications are subject to change without notice. Please refer to http://www.ruilon.com.cn for current information. Revised: 2022-11-21 Version: A2 Page 7 of 10 Metal Oxide Varistors e) 14D Series 温度保险丝 Concerning thermal fuse 将压敏电阻器与温度保险丝连接时,用户端请尽量选用热结合较好的保险丝。 Set a thermal fuse to get high thermal conductivity with varistor. 表 1 – 压敏电阻器的适用范例 类别 线间使用 线-地使用 Type Across-the-line use Use between line to ground DC/AC 3-phase DC/AC 单相 AC 3-phase 三相 连线举例 Connections example MOV 电源电压 压敏电压 Source voltage 471,511,621❉ 821❉❉, 182❉❉❉ 201~361❉ AC120V 241~431❉ AC200V 431-561❉ AC220V 471-621❉ AC240V 511-621❉ varistor AC380V Specifications are subject to change without notice. Please refer to http://www.ruilon.com.cn for current information. Varistor AC220V AC100V MOV3 压敏电阻 AC100V 选型举例 Example of 电源电压 Source voltage Varistor 压敏电阻 MOV1 MOV MOV2 MOV4 821 Revised: 2022-11-21 Version: A2 AC230V 511,621❉ AC240V 821❉❉, 182❉❉❉ AC380V 182❉❉❉ 112❉❉, Page 8 of 10 Metal Oxide Varistors 14D Series 2.2 使用环境 Operating environments 1) 压敏电阻器不可在室外使用。 The varistor is designed to be used indoors. Do not use it exposed outdoors. 2) 不可在阳光直射场所、发热源附近或温度超过使用温度范围的场所使用。 Do not use the varistor in places exposed to temperatures beyond the operating temperature range, such as places exposed to sunlight and vicinities of heating equipment. 3) 不可在淋雨、蒸汽、高湿度的场所使用。 Do not use the varistor in places exposed to high temperatures and high humidity, such as places exposed directly to rain, wind, dew condensation, and vapor. 4) 不可在粉尘或盐分较多的场所以及被腐蚀性气体污染的环境中使用。 Do not use the varistor in dusty and salty places and atmospheres polluted by corrosive gases. 2.3 加工条件 Processing conditions 1) 不可采用可能导致外涂层树脂劣化的溶剂(稀释剂、丙酮等)进行清洗。 Do not wash the varistor by such solvents (thinner, acetone, etc) as its exterior resin deteriorates. 2) 不可施加可能导致外涂层树脂或元件出现破损的冲击或撞击、压力。 Do not apply a strong vibration or shock (by falling, etc) to the varistor, cracking to its exterior resin and element may occur. 3) 将压敏电阻器进行树脂镀膜(含护膜塑模)时,不可使用可能导致压敏电阻器劣化的树脂。 When coating the varistor with resin (including molding), do not use such resin. 4) 压敏电阻器外涂层树脂附近的引线部位不可进行强烈折弯或施加外力。 Do not bend the varistor lead wires at the position close to its varistor exterior resin, or apply external force to the position. 5) 焊接时,请在如下条件下进行。且不可将构成压敏电阻器的焊接部位或绝缘材料熔化。 When soldering the varistor lead wires, follow the recommended conditions and do not melt the solder and insulating materials constituting the varistor. 焊接方式 推荐条件 Soldering method Recommended condition 波峰焊 Flow soldering 注意事项 Attention item 260°C, 10 秒以内 260°C, within 10 sec 引线型不是回流焊对象产品 Lead wires type is not reflow soldering object part. 上述以外的条件下使用时,请用户端自行确认。 For use other than the above conditions, please the client to confirm. 仅限进行 1 次返工,烙铁温度 350°c 以下,时间控制在 5 秒以内。 Only 1 times rework, soldering iron temperature should not exceed 350°c and should not be applied for more than 5 ■ 推荐焊接条件 Soldering temperature-time profile to recommend Specifications are subject to change without notice. Please refer to http://www.ruilon.com.cn for current information. Revised: 2022-11-21 Version: A2 Page 9 of 10 Metal Oxide Varistors 14D Series 2.4.长期保管 Long-term storage 1) 压敏电阻器不可保存在高温、高湿场所。保存场所室温 40 ° C 以下,湿度 75%RH 以下,保存期限为 1 年。 Do not store the varistor under high temperature and high humidity. Store it at a temperature up to 40 °C and at humidity below 75% RH, and use it within 1 year. 长期间保管(1 年以上)时,使用时请确认产品的可焊性。 Before using the varistor that has been stored for a long period (1 years or longer), confirm the solderability. 2) 不可保存在腐蚀性气体(硫化氢、亚硫酸、氯气、氨气等)环境中。 Avoid atmospheres full of corrosive gases (hydrogen sulfide, sulfurous acid, chlorine, ammonia, etc). 3) 保存场所避免阳光直射、结露等。 Avoid direct sunlight and dew condensation. 3 说明 Notices 用于可靠性要求极高的设备(航空航天设备、医疗设备等)时,请事先至本公司咨询使用型号和保护措施等相关事宜。 In cases that the varistor is used in equipment (aerospace equipment, medical equipment, etc) requiring extremely high reliability, ask us for a selection of part no., and protection coordination, etc in advance. 若未按照产品规格书记载事项进行操作,并由此导致出现异常时,本公司不负任何责任。 Note that we do not take any responsibility for faults and abnormalities resulting from the use not in conformity with the contents of entries in the delivery specification. 出现使用电路电压的异常上升、超高浪涌的侵入等不可预期因素时,可能导致压敏电阻器起火。为防止延烧到使用设备上,外部 结构材料需使用阻燃材料进行多重保护。 There is a possibility that the varistor will unexpectedly cause smoke or ignite because of an abnormal rise of the circuit voltage and invasion of excessive surge. To prevent that accident from spreading over the equipment and not to expand the damage, use multiplex protection such as the adoption of frame- retardant materials for housing parts and structural parts. Specifications are subject to change without notice. Please refer to http://www.ruilon.com.cn for current information. Revised: 2022-11-21 Version: A2 Page 10 of 10
