2R600TA-5
2R600TA-5
    RUILON(瑞隆源)
    GDT-2P_D5.5X6MM_TM
    气体放电管, 电极数:2 直流击穿电压:600V 精度:±20% 脉冲放电电流:5kA 极间电容:1pF
2R600TA-5 数据手册
Gas Discharge Tubes(GDT) 2RA-5 Series Description GDT is placed in front of, and in parallel with, sensitive telecom equipment such as power lines, communication lines, signal lines and data transmission lines to help protect them from damage caused by transient surge voltages that may result from lightning strikes and equipment switching operations. These devices do not influence the signal in normal operation. However, in the event of an overvoltage surge, such as a lightning strike, the GDT switches to a low impedance state and diverts the energy away from the sensitive equipment. Our GDT offer a high level of surge protection, a broad voltage range, low capacitance, and many form factors including new surface mount devices, which makes them suitable for applications such as Main Distribution Frame (MDF) modules, high data-rate telecom applications (e.g. ADSL, VDSL), and surge protection on power lines. Their low capacitance also results in less signal distortion. When used in a coordinated circuit protection solution with PolySwitch devices, they can help equipment manufacturers meet stringent safety regulatory standards. Electrical symbol Features Applications l l l l l l l l l l l l l l l l l l CATV equipment Antennas RS 485 Telecom Base Station Power Supply AC Main EV power Charging Inverter/Variable Frequency Drivers (VFDs) l IEEE 802.3 compliant Ethernet interfaces Excellent response to fast rising transients Stable breakdown voltage GHz working frequency 8/20μs Impulse current capability: 5KA Non-Radioactive Ultra Low capacitance (
2R600TA-5
物料型号:2RA-5 Series
器件简介: - GDT用于保护敏感的电信设备,如电源线、通信线路、信号线和数据传输线,防止由雷击和设备切换操作产生的瞬态过电压造成的损害。 - 在正常操作中不影响信号,但在过电压冲击时,GDT会切换到低阻抗状态,将能量从敏感设备转移。
引脚分配: - 2R: 2个电极 - T: 引线型 - S: 表面贴装型
参数特性: - 直流击穿电压:75V至800V不等,具体取决于型号 - 8/20μs冲击放电电流能力:5KA - 绝缘电阻:最小值未明确,但测量电压有具体说明 - 电容:最大值在1MHz时小于1pF - 使用温度范围:-40~+90°C
功能详解: - 快速响应瞬态冲击 - 稳定的击穿电压 - 低电容,减少信号失真 - 无放射性,符合RoHS标准
应用信息: - 主要应用于MDF模块、高速数据电信应用(如ADSL、VDSL)、电源线浪涌保护等 - 也适用于医疗电子、测试设备、可再生能源、频率驱动器(VFDs)等
封装信息: - 尺寸:Ф5.5mm6mm - 表面处理:DIP为镀镍,SMD为亚光锡镀层 - 包装信息:轴向封装(散装)塑料托盘,内盒装100个,每个内盒500个;SMD封装(带卷)胶带,每个卷1000个,每个内盒3000个
2R600TA-5 价格&库存
很抱歉,暂时无法提供与“2R600TA-5”相匹配的价格&库存,您可以联系我们找货
