ELECTRONICS
Transient
Voltage
Suppressors
SMCJ Series
Circuit Protection
System
Specifications are subject to change without notice.
Transient Voltage Suppressors - SMCJ Series
Features
UNI
1. Halogen-free
2. Rohs compliant
3. Typical maximum temperature coefficient
4. ΔVBR = 0.1% x VBR@25°C x ΔT
5. Glass passivated Chip junction in DO-214AB package
BI
6. 1500W peak pulse capadility at 10×1000μs waveform, repetition rate (duty
cycles):0.01%
7. Fast response time:typically less than 1.0ps from 0 Volts to BV min
8. Excellent clamping capability
9. Low incremental surge resistance
10. Typical IR less than 5μA above 12V
BI
Cathode
11. High temperature soldering guaranteed: 260°C/40 seconds / 0.375”,
Anode
12. (9.5mm) lead length, 5lbs., (2.3kg) tension
13. Plastic package has underwriters laboratory flammability classification
UNI
94v-0
Applications
TVS devices are ideal for the protection of I/O interfaces,VCC bus and other vulnerable circuits used in telecom, computer,
industrial and consumer electronic applications.
Mechanical Characteristics
Rating
Symbol
Value
Units
Peak Pulse Power Dissipation at TA=25°C by
10x1000μs waveform (Fig.1)(Note 1), (Note 2)
PPPM
1500
Watts
Power Dissipation on infinite heat sink at TA=50°C
PD
6.5
Watts
IFSM
200
Amps
VF
3.5V/5.0
V
Operating junction and Storage Temperature Range.
TJ,TSTG
-55°C to 150°C
°C
Typical Thermal Resistance Junction to Lead
RuJL
15
°C/W
to Ambient
RuJA
75
°C/W
Peak Forward Surge Current, 8.3ms Single Half
Sine Wave (Note 3)
Maximum Instantaneous Forward Voltage at 25A for
Unidirectional only (Note 4)
Notes:
1. Non-repetitive current pulse , per Fig. 3 and derated above TA = 25°C per Fig. 2.
2. Measured on 8.3ms single half sine wave or equivalent square wave, duty cycle=4 perminute maximum.
3. VF
很抱歉,暂时无法提供与“SMCJ26CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.85800
- 200+0.59180
- 1500+0.53790
- 3000+0.50380
- 国内价格
- 5+1.81412
- 50+1.49803
- 150+1.36250
- 500+1.10703
- 2500+1.03176
- 5000+0.98652
- 国内价格
- 5+1.64615
- 50+1.35932
- 150+1.23634
- 国内价格 香港价格
- 1000+2.780531000+0.36146
- 1000+1.776971000+0.23100
- 10000+1.6923510000+0.22000
