2R400TB-8
2R400TB-8
    RUILON(瑞隆源)
    GDT-2P_D8X6MM_TM
    电极数:2 直流击穿电压(典型值):400V 精度:±20% 脉冲放电电流:10kA 极间电容:1.5pF
2R400TB-8 数据手册
Gas Discharge Tubes(GDT) 2RB-8 Series Description GDT is placed in front of, and in parallel with, sensitive telecom equipment such as power lines, communication lines, signal lines and data transmission lines to help protect them from damage caused by transient surge voltages that may result from lightning strikes and equipment switching operations. These devices do not influence the signal in normal operation. However, in the event of an overvoltage surge, such as a lightning strike, the GDT switches to a low impedance state and diverts the energy away from the sensitive equipment. Our GDT offer a high level of surge protection, a broad voltage range, low capacitance, and many form factors including new surface mount devices, which makes them suitable for applications such as Main Distribution Frame (MDF) modules, high data-rate telecom applications (e.g. ADSL, VDSL), and surge protection on power lines. Their low capacitance also results in less signal distortion. When used in a coordinated circuit protection solution with PolySwitch devices, they can help equipment manufacturers meet stringent safety regulatory standards. Electrical symbol Features Applications l Excellent response to fast rising transients l MDF modules l Stable breakdown voltage l xDSL equipment l GHz working frequency l RF systems l Line test equipment l 8/20μs Impulse current capability: 10KA l Antenna l Power supplies l Non-Radioactive l Base stations l Surge protectors, Alarm l Ultra Low capacitance (
