P0080SB
P0080SB
    RUILON(瑞隆源)
    SMB(DO-214AA)
    SMB SMT 6V 2.2A
P0080SB 数据手册
Thyristor Surge Suppressors P0060~P3500SA_B_C Serise Description P0060~P3500SA_B_C Series are low capacitance devices designed to protect broadband equipment such as VOIP, DSL modems and DSLAMs from damaging overvoltage transients. The series provides a surface mount solution that enables equipment to comply with global regulatory standards while limiting the impact to broadband signals. Features and Benefits • Low voltagr overeshoot • Low on-state voltage • Does not degrade with use • Fails short circuit when surged in excess of ratings • Low Capacitance Applicable Global Standards • TIA-968-A • ITU K.20/21 Enhanced level* • ITU K.20/21 Basic Level • GR 1089 Inter building* • GR 1089 Inter building • IEC 6100-4-5 • YD/T 1082 • YD/T 993 • YD/T 950 Product Name P Logo 0 0 Vdrm 8 0 0:Represents a chip S B Type S:SMD SMB T:SMD SMA E:DIP TO-92 L:DIP D0-15 All data is subject to change,Please check our data sheets at www ruilon com for updates. Peak pilse current-Ipp 8/20μs A=150A B=250A C=400A ©2012 RuiLong Yuan,Inc. TSS 01 Electriacl Characteristics (@ TA = 25 °C Unless Otherwise Noted) Type Number VDRM IDRM VBO IH IS IT VT CJ V μA V MA MA A V pFMin P0080SA 6 5 25 50 800 2.2 4 25 150 P0080SB 6 5 25 50 800 2.2 4 25 150 pFMax P0080SC 6 5 25 50 800 2.2 4 35 260 P0300SA 25 5 40 50 800 2.2 4 15 140 P0300SB 25 5 40 50 800 2.2 4 15 140 P0300SC 25 5 40 50 800 2.2 4 25 250 P0640SA 58 5 77 150 800 2.2 4 40 60 P0640SB 58 5 77 150 800 2.2 4 40 60 155 P0640SC 58 5 77 150 800 2.2 4 55 P0720SA 65 5 88 150 800 2.2 4 35 60 P0720SB 65 5 88 150 800 2.2 4 35 75 150 P0720SC 65 5 88 150 800 2.2 4 50 P0900SA 75 5 98 150 800 2.2 4 35 55 P0900SB 75 5 98 150 800 2.2 4 35 70 140 P0900SC 75 5 98 150 800 2.2 4 45 P1100SA 90 5 130 150 800 2.2 4 30 50 P1100SB 90 5 130 150 800 2.2 4 30 70 115 P1100SC 90 5 130 150 800 2.2 4 45 P1300SA 120 5 160 150 800 2.2 4 25 45 P1300SB 120 5 160 150 800 2.2 4 25 60 105 P1300SC 120 5 160 150 800 2.2 4 40 P1500SA 140 5 180 150 800 2.2 4 25 40 P1500SB 140 5 180 150 800 2.2 4 25 55 P1500SC 140 5 180 150 800 2.2 4 35 95 P1800SA 170 5 220 150 800 2.2 4 25 35 P1800SB 170 5 220 150 800 2.2 4 25 50 P1800SC 170 5 220 150 800 2.2 4 35 90 P2300SA 190 5 260 150 800 2.2 4 25 35 P2300SB 190 5 260 150 800 2.2 4 25 50 P2300SC 190 5 260 150 800 2.2 4 30 80 P2600SA 220 5 300 150 800 2.2 4 20 35 P2600SB 220 5 300 150 800 2.2 4 20 45 P2600SC 220 5 300 150 800 2.2 4 30 80 P3100SA 275 5 350 150 800 2.2 4 20 35 P3100SB 275 5 350 150 800 2.2 4 20 45 70 P3100SC 275 5 350 150 800 2.2 4 30 P3500SA 320 5 400 150 800 2.2 4 20 35 P3500SB 320 5 400 150 800 2.2 4 20 40 P3500SC 320 5 400 150 800 2.2 4 25 65 Package Dimensions inch(mm) Notes: - Absolute maximum ratings measured at TA= 25ºC (unless otherwise noted). - Devices are bi-directional. SERIES TSS 02 Peak Pilse Current-lpp(A) 10/160µs 10/560µs 2/10µs 8/20µs A 200 150 100 60 50 B 250 250 150 100 80 C 500 400 200 120 100 All data is subject to change,Please check our data sheets at www ruilon com for updates. 10/1000µs ©2012 RuiLong Yuan,Inc. Surge Ratings IPP Series ITSM 50/60 Hz di/dt 2x10 µs 8x20 µs 10x160 µs 10x560 µs 10x1000 µs A min A min A min A min A min A min A/μs max A 150 150 90 50 45 20 500 B 250 250 150 100 80 30 500 C 500 400 200 150 100 50 500 Notes: 1 Current waveform in µs 2 Voltage waveform in µs - Peak pulse current rating (IPP) is repetitive and guaranteed for the life of the product. - IPP - The device must initially be in thermal equilibrium with -40°C < TJ < Thermal Considerations Package Symbol DO-214AA Parameter Value Unit TJ Operating Junction Temperature Range °C TS Storage Temperature Range °C R0JA Thermal Resistance: Junction to Ambient V-I Characteristics 90 °C/W t r x t d Pulse Waveform IPP – Peak Pulse Current – %I PP +I IT IS IH IDRM -V +V VT VDRM VS tr = rise time to peak v alue td = decay time to half value Peak Value 100 Waveform = t r x td 50 Half Value 0 0 td tr t – Time (µs) -I S Change vs. Junction Temperature Normalized DC Holding Current vs. Case Temperature 14 12 10 IH 8 6 25 °C 4 2 0 -4 -6 -8 IH (TC = 25ºC) 2.0 Ratio of Percent of V S Change – % Normalized V 1.8 1.6 1.4 1.0 0.8 0.6 0.4 -40 -20 0 20 40 60 80 100 120 140 160 Junction Temperature (T J) 25°C 1.2 -40 -20 – °C All data is subject to change,Please check our data sheets at www ruilon com for updates. 0 20 40 60 80 100 120 140 160 Case Temperature (T C) - ºC ©2012 RuiLong Yuan,Inc. TSS 03 Figure 1.E xamples of protection stages for line cards Line Protection stage Protection stage Ring relay Line Ex . A n al o g l i n e c ar d Ex . x DSL l i n e c ar d o r t er m i n al In such a stage, parallel function is assumed by one or several Trisil, and is used to protect against short duration surge (lightning). During this kind of surges the Trisil limits the voltage across the device to be protected at its break over value and then fires. The fuse assumes the series function, and is used to protect the module against long duration or very high current mains disturbances (50/60Hz). It acts by safe circuit opening. Lightning surge and mains disturbance surges are defined by standards like GR1089, FCC part 68, ITU-T K20. Figure 2. Typical circuits Fuse TCP 1.25A Tip L Tip S Gnd Gnd Fuse TCP 1.25A T1 T2 Fuse TCP 1.25A Ring S Ring L Typical circuit for subscriber side Typical circuit for central office side Figure 3.T est circuit 1 for Dynamic I BO and V BO parameters 100V/µ s, di /dt< 10 A/ µs, Ipp= XXXA 2 U 83 45 10 µF 66 46 µH 0.36 nF 470 KeyTek 'System 2' generatorw ithP N246I module 1k V/ µs, di /dt< 10 A/ µs, Ipp= 10 A 26 µH U 60 µF 250 47 46 µH 12 KeyTek 'System 2' generatorw ithP N246I module TSS 04 All data is subject to change,Please check our data sheets at www ruilon com for updates. ©2012 RuiLong Yuan,Inc. Figure 5. Test circuit 3 for dynamic I H parameter R Surge generator D.U.T VBAT =- 48 V This is a GO-NOGO test which allows to confirm the holding current (IH) level in a functional test circuit. TEST PROCEDURE 1/ Adjust the current level at the Iv Halue by short circuiting the AK of the D.U.T. 2/ Fire the D.U.T.w ith a surge current I= PP 10A, 10/1000µs. 3/ The D.U.T.w ill come back off-state within 50ms maximum. Figure 4. Test circuit 2 for I BO and V BO parameters K ton = 20ms R1 = 140 R2 = 240 220V 50Hz DUT Vout VBO measurement 1/4 IBO measurement TEST PROCEDURE Pulse test duration (tp = 20ms): for Bidirectional devices = Switch K is closed for Unidirectional devices = Switch K is open VOUT selection: Device with V< BO Device with VBO 200VV 200VV OUTR= OUTR= 250V MS, R1 = 140 480V MS, R2 = 240 All data is subject to change,Please check our data sheets at www ruilon com for updates. ©2012 RuiLong Yuan,Inc. TSS 05 Soldering Parameters Pb-Free assembly (see Fig. 1) Pre Heat - Temperature Max (T s(min) TP ) s(max) - Time (Min to Max) (t s) Average ramp up rate (Liquidus Temp (T to peak) 60-180 secs. ) L TS(max) to TL - Ramp-up Rate 3°C/sec. Max. 3°C/sec. Max. - Temperature (T L) (Liquidus) - Temperature (t L) 60-150 secs. Peak Temp (T P) 30 secs. Max. Ramp-down Rate 6°C/sec. Max. Time 2 5°C to Peak Temp (T P) 8 min. Max. Critical Zone TL to T P TL TS(max) tL Ramp-down Preheat TS(min) 25 Time within 5°C of actual Peak Temp (t p) tP Ramp-up ) Tem p er at u re - Temperature Min (T Figure 1 tS time to peak temperature (t 2 5ºC to peak) Time Do not exceed Lead Material Copper Alloy Terminal Finish 100% Matte-Tin Plated Body Material High Temp Voltage Blocking 80% Rated VDRM (VAC Peak 504 or 1008 hrs. MIL-STD-750 (Method 1040) JEDEC, JESD22-A-101 Temp Cycling cycles. MIL-STD-750 (Method 1051) EIA/JEDEC, JESD22-A104 Biased Temp & Humidity 52 VDC JEDEC, JESD22-A-101 High Temp Storage JEDEC, JESD22-A-101 Low Temp Storage -65°C, 1008 hrs. Thermal Shock 10 cycles. MIL-STD-750 (Method 1056) JEDEC, JESD22-A-106 Autoclave (Pressure Cooker Test) JEDEC, JESD22-A-102 Resistance to Solder Heat Moisture Sensitivity Level TSS 06 All data is subject to change,Please check our data sheets at www ruilon com for updates. ©2012 RuiLong Yuan,Inc. Dimensions — DO-214AA Pad Outline Case Temperature Measurement Point B D 0.110 (2.8) C A 0.079 (2.0) H E inch (millimeter) F K Inches Dimensions 0.079 (2.0) G Part Numbering Min Millimeters Max Min Max A 0.130 0.156 3.30 B 0.201 0.220 5.10 3.95 5.60 C 0.077 0.087 1.95 2.20 4.60 D 0.159 0.181 4.05 E 0.030 0.063 0.75 1.60 F 0.075 0.096 1.90 2.45 G 0.002 0.008 0.05 0.20 H 0.077 0.104 1.95 2.65 K 0.006 0.016 0.15 0.41 Part Marking P xxx 0 S C TYPE P = LOGO Pxxxx Part Marking Code (Refer to Electrical Characteristics Table) MEDIAN VOLTAGE CONSTRUCTION VARIABLE IPP RATING PACKAGE TYPE Packing Options Industry Standard S DO-214AA Tape & Reel Pack 2500 N/A EIA-481-D 0.157 (4.0) 0.472 (12.0) 0.36 (9.2) 0.315 (8.0) 0.059 DIA (1.5) 12.99 (330.0) 0.512 (13.0) Arbor Hole Dia. 0.49 (12.4) Cover tape Dimensions are in inches (and millimeters). Direction of Feed All data is subject to change,Please check our data sheets at www ruilon com for updates. ©2012 RuiLong Yuan,Inc. TSS 07 RUILONG.YUAN CO.,LTD Tel: +86- 0755-82908296 Fax: +86- 0755-82908002 Email: jack@ruilon.com Website: http://www.ruilon.com RuiLongYuan Electronics are trademarks. Information furnished is believed to be accurate and reliable. However, users should independently evaluate the suitability of and test each product selected for their own applications. RUILONYUAN Electronics reserves the right to change or update, without notice, any information contained in this publication; to change, without notice, the design, construction, processing, or specification of any product; and to discontinue or limit production or distribution of any product. This publication supersedes and replaces all information previously supplied. Without expressed or written consent by an officer of RUILONYUAN Electronics, RUILONYUAN Electronics does not authorize the use of any of its products as components in nuclear facility applications, aerospace, or in critical life support devices or systems. RUILONYUAN Electronics expressly disclaims all implied warranties regarding the information contained herein, including, but not limited to, any implied warranties of merchantability or fitness for a particular purpose. RUILONYUAN Electronics’ only obligations are those in the RUILONYUAN Electronics Standard Terms and Conditions of Sale and in no case will RUILONYUAN Electronics be liable for any incidental, indirect, or consequential damages. TSS 08 All data is subject to change,Please check our data sheets at www ruilon com for updates. ©2012 RuiLong Yuan,Inc.
P0080SB 价格&库存
很抱歉,暂时无法提供与“P0080SB”相匹配的价格&库存,您可以联系我们找货
P0080SB
  • 5+0.73031
  • 50+0.59437
  • 150+0.52645
  • 500+0.47545
  • 2500+0.37192
  • 5000+0.35151
库存:32031
P0080SB
    • 5+0.72300
    • 50+0.58840
    • 150+0.52120
    • 500+0.47070
    • 2500+0.36820
    • 5000+0.34800
    库存:688
    P0080SB
      • 5+0.66269
      • 50+0.53933
      • 150+0.47770
      库存:213
      P0080SB
        库存:688
        P0080SB
          • 1+0.30360
          • 2500+0.26620
          库存:5535
          P0080SB
          库存:2351
