SMD2018P100TF/33
SMD2018P100TF/33
    RUILON(瑞隆源)
    最大电压:33V 最大电流:100A 保持电流:1.1A 跳闸电流:2.2A
SMD2018P100TF/33 数据手册
Positive Thermal Coefficent Diodes SMD2018P030~200 Series The SMD2018 Series PTC provides surface mount overcurrent protection for applications where space is at a premium and resettable protection is desired. Features • RoHS compliant, lead-free and halogen-free • Fast response to fault currents • Compact design saves board space • Low resistance • Low-profile • Compatible with high temperature solders ROHS Applications • USB peripherals • Disk drives • CD-ROMs • Plug and play protection for motherboards and peripherals • Mobile phones - battery and port protection • Disk drives • PDAs / digital cameras • Game console port protection Dimension MARKING CODE VARIES WITH AMPERAGE RATING (See Electrical Characteristic Table) SHOWN IS 1.0AMP RATING 1.5 A Top View N B C N Bottom View 4.6 Side View D Bottom View N ModelD 3.4 A E 1.5 B C D Min. Max. Min. Max. Min. Max. Min. SMD2018P030TF 4.72 5.44 4.22 4.93 0.60 1.10 0.30 SMD2018P050TF 4.72 5.44 4.22 4.93 0.60 1.10 0.30 SMD2018P100TF 4.72 5.44 4.22 4.93 0.45 0.80 0.30 SMD2018P100TF/33 4.72 5.44 4.22 4.93 0.45 0.80 0.30 SMD2018P150TF 4.72 5.44 4.22 4.93 0.45 0.80 0.30 SMD2018P200TF 4.72 5.44 4.22 4.93 0.40 0.80 0.30 All data is subject to change,Please check our data sheets at www ruilon com for updates. ©2012 RuiLong Yuan,Inc. PTC 01 Electriacl Characteristics Maximum Time To Trip Current Time (A) (Sec.) Ihold Itrip Vmax Imax Pd max. (A) (A) V(dc) (A) (W) SMD2018P030TF 0.30 0.60 60 100 0.9 1.5 SMD2018P050TF 0.55 1.20 60 100 1.0 SMD2018P100TF 1.10 2.20 15 100 SMD2018P100TF/33 1.10 2.20 33 SMD2018P150TF 1.50 3.00 SMD2018P200TF 2.00 4.20 Type Number Resistance R min (Ω) R1max (Ω) 3.0 0.50 2.30 2.5 3.0 0.20 1.00 1.1 8.0 0.4 0.06 0.36 100 1.1 8.0 0.4 0.06 0.36 15 100 1.1 8.0 0.8 0.05 0.17 10 100 1.1 8.0 2.4 0.03 0.10 Ihold = Hold current: maximum current device will pass without tripping in 20°C still air. Itrip = Trip current: minimum current at which the device will trip in 20°C still air. Vmax = Maximum voltage device can withstand without damage at rated current (Imax) Imax = Maximum fault current device can withstand without damage at rated voltage (Vmax) Pd = Power dissipated from device when in the tripped state at 20°C still air. Rmin = Minimum resistance of device in initial (un-soldered) state. Thermal Derating Chart-IH(A) Maximum ambient operating temperature (Tmao) vs. hold current (Ihold) Model -40°C -20°C 0°C 25°C 40°C 50°C 60°C 70°C 85°C SMD2018P030TF 0.48 0.42 0.35 0.30 0.24 0.21 0.17 0.15 0.10 SMD2018P050TF 0.87 0.77 0.67 0.55 0.46 0.41 0.36 0.31 0.23 SMD2018P100TF 1.71 1.52 1.32 1.10 0.94 0.84 0.74 0.64 0.50 SMD2018P100TF/33 1.71 1.52 1.32 1.10 0.94 0.84 0.74 0.64 0.50 SMD2018P150TF 2.38 2.10 1.82 1.50 1.27 1.13 0.99 0.85 0.64 SMD2018P200TF 2.95 2.65 2.35 2.00 1.74 1.59 1.44 1.29 1.06 Thermal Deratin g Cu r v e Typ ical Time-To-Tri p At 25° C Derating Curves for SMD2018 Series Average Time Current Curves Percentage of Derated Current 160 050 100 140 10 Time In Second 120 100 80 60 40 100 1 150 0.1 200 0.01 20 0.001 0 -40 -20 0 20 40 Temperature (°C) PTC 02 60 80 133 0.1 1 10 Current In Amperes All data is subject to change,Please check our data sheets at www ruilon com for updates. 100 030 ©2012 RuiLong Yuan,Inc. Temperature(°C) Recommended Solder Reflow Conditions 300 250 200 190 160 100 0 Preheating Soldering Cooling •Recommended reflow methods:IR, vapor phase oven, hot air oven. •Devices are not designed to be wave soldered to the bottom side of the board. •Recommended maximum paste thickness is 0.25 mm (0.010 inch). •Devices can be cleaned using standard method and solvents. Note:If reflow temperatures exceed the recommended profile, devices may not meet the performance requirements. 60-120 sec. 120 sec. 30-60 sec. Tape And Reel S pecifications (mm ) Governing Specifications W P0 P1 P2 A0 B0 B1max. D0 F E1 E2min. Tmax. T1max. K0 Leader min. Trailer min. Reel Dimensions A max. N min. W1 W 2max. EIA 481-2 12.0 ± 0.20 4.0 ± 0.10 8.0 ± 0.10 2.0 ± 0.05 4.40 ± 0.10 5.50 ± 0.10 8.2 1.5 + 0.1, -0.0 5.5 ± 0.05 1.75 ± 0.10 10.25 0.6 0.1 1.36 ± 0.1 390 160 EIA Tape Com ponent Dimentions P0 T Embossment P2 E1 Cover tape A0 B1 F K0 B0 T1 P1 W E2 EIA Reel Dimentions W2(measured at hub) 178 50 12.4 + 2.0, -0.0 18.4 A Stora ge And Handlin g Cover tape • Storage conditions:40°C max, 70% R.H. • Devices may not meet specified performance if storage conditions are exceeded. Carrier tape Embossed cavity Or d er In f o r m at i o n D0 SMD2018 Product name 050 Hold Size 5045 mm / 2018 mils Current SMD:surface mount device 0.50A 0 N(hub dia.) W1(measured at hub) Pac k agin g Tape & Reel Quantity 030, 050 1,500 pcs/reel 100, 100-33V, 150, 200 2,500 pcs/reel Tape & reel packaging per EIA481-1 All data is subject to change,Please check our data sheets at www ruilon com for updates. ©2012 RuiLong Yuan,Inc. PTC 03 RUILONG.YUAN CO.,LTD Tel: +86- 0755-82908296 Fax: +86- 0755-82908002 Email: jack@ruilon.com Website: http://www.ruilon.com RuiLongYuan Electronics are trademarks. Information furnished is believed to be accurate and reliable. However, users should independently evaluate the suitability of and test each product selected for their own applications. RUILONYUAN Electronics reserves the right to change or update, without notice, any information contained in this publication; to change, without notice, the design, construction, processing, or specification of any product; and to discontinue or limit production or distribution of any product. This publication supersedes and replaces all information previously supplied. Without expressed or written consent by an officer of RUILONYUAN Electronics, RUILONYUAN Electronics does not authorize the use of any of its products as components in nuclear facility applications, aerospace, or in critical life support devices or systems. RUILONYUAN Electronics expressly disclaims all implied warranties regarding the information contained herein, including, but not limited to, any implied warranties of merchantability or fitness for a particular purpose. RUILONYUAN Electronics’ only obligations are those in the RUILONYUAN Electronics Standard Terms and Conditions of Sale and in no case will RUILONYUAN Electronics be liable for any incidental, indirect, or consequential damages. PTC 04 All data is subject to change,Please check our data sheets at www ruilon com for updates. ©2012 RuiLong Yuan,Inc.
SMD2018P100TF/33 价格&库存
很抱歉,暂时无法提供与“SMD2018P100TF/33”相匹配的价格&库存,您可以联系我们找货
SMD2018P100TF/33
  • 5+0.69230
  • 20+0.62780
  • 100+0.56330
  • 500+0.49880
  • 1000+0.46870
  • 2000+0.44720
SMD2018P100TF/33
  • 100+0.39155
  • 500+0.37911
库存:39
