SMBJ5333A-SMBJ5388A
Surface Mount Silicon Zener Diodes
VZ : 3.3 - 200 Volts
PD : 5 Watts
Features
SMB/DO-214AA
Complete Voltage Range 3.3 to 200 Volts
High peak reverse power dissipation
High reliability
Low leakage current
Pb / RoHS Free
0.180(4.57)
0.160(4.06)
0.086(2.20)
0.077(1.95)
0.209(5.30)
0.201(5.10)
Mechanical Data
0.155(3.94)
0.130(3.30)
0.012(0.30)
0.006(0.15)
Case : SMB (DO-214AA) Molded plastic
Epoxy : UL94V-O rate flame retardant
Lead : Lead formed for Surface mount
Polarity : Color band denotes cathode end
Mounting position : Any
0.096(2.44)
0.084(2.13)
0.059(1.50)
0.035(0.90)
0.008(0.20)
0.002(0.05)
Dimensions in inches and(millimeters)
MAXIMUM RATINGS
Rating at 25 °C ambient temperature unless otherwise specified
Rating
Symbol
Value
Unit
Power Dissipation at T L = 25 °C
PD
5
W
Maximum Forward Voltage at I F = 1.0 A
VF
1.2
V
Thermal Resistance, Junction to Ambient (Note 1)
RӨJA
90
°C/W
Thermal Resistance, Junction to Lead (Note 1)
RӨJL
25
°C/W
TJ, TSTG
- 65 to + 150
°C
Operating and Storage Temperature Range
Note :
(1) When mounted on FR4 PC board (1 oz Cu) with recommended footprint.
ht t p : //
Revision:20170701-P1
www.lgesemi .c o m
mail:lge@lgesemi.com
SMBJ5333A-SMBJ5388A
ELECTRICAL CHARACTERISTICS
Nominal Zener
Maximum Zener
Voltage
Impedance
TYPE
VZ @ IZT
IZT
ZZT @ IZT
ZZK @ IZK
(V)
(mA)
(Ω)
(Ω)
SMBJ5333A
SMBJ5334A
SMBJ5335A
SMBJ5336A
SMBJ5337A
SMBJ5338A
SMBJ5339A
SMBJ5340A
SMBJ5341A
SMBJ5342A
SMBJ5343A
SMBJ5344A
SMBJ5345A
SMBJ5346A
SMBJ5347A
SMBJ5348A
SMBJ5349A
SMBJ5350A
SMBJ5351A
SMBJ5352A
SMBJ5353A
SMBJ5354A
SMBJ5355A
SMBJ5356A
SMBJ5357A
SMBJ5358A
SMBJ5359A
SMBJ5360A
SMBJ5361A
SMBJ5362A
SMBJ5363A
SMBJ5364A
SMBJ5365A
SMBJ5366A
SMBJ5367A
SMBJ5368A
SMBJ5369A
SMBJ5370A
SMBJ5371A
SMBJ5372A
SMBJ5373A
SMBJ5374A
SMBJ5375A
SMBJ5376A
SMBJ5377A
SMBJ5378A
SMBJ5379A
SMBJ5380A
SMBJ5381A
SMBJ5382A
SMBJ5383A
SMBJ5384A
SMBJ5385A
SMBJ5386A
SMBJ5387A
SMBJ5388A
3.3
3.6
3.9
4.3
4.7
5.1
5.6
6.0
6.2
6.8
7.5
8.2
8.7
9.1
10
11
12
13
14
15
16
17
18
19
24
25
27
28
30
33
36
39
43
47
51
56
60
62
68
75
82
87
91
100
110
120
130
140
150
160
170
180
190
200
380
350
320
290
260
240
220
200
200
175
175
150
150
150
125
125
100
100
100
75
75
70
65
65
65
50
50
50
50
50
40
40
30
30
30
25
25
15
15
12
12
10
10
8.0
8.0
8.0
8.0
5.0
5.0
5.0
3.0
2.5
2.0
2.0
2.0
1.5
1.0
1.0
1.0
1.0
1.0
1.0
1.0
2.0
2.0
2.0
2.5
2.5
2.5
2.5
2.5
2.5
2.5
3.0
3.0
3.5
3.5
4.0
5.0
6.0
8.0
10
11
14
27
35
40
42
44
45
65
75
75
90
125
170
190
230
330
350
380
430
450
480
400
500
500
500
450
400
400
300
200
200
200
200
200
150
125
125
125
100
75
75
75
75
75
75
75
75
100
110
120
130
140
150
160
170
190
210
230
280
350
400
500
620
720
760
760
800
1000
1150
1250
1500
1500
1650
1750
1750
1850
1850
IZK
(mA)
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
Maximum Reverse
Leakage Current
IR @ VR
(V)
(μA)
300
150
50
10
5.0
1.0
1.0
1.0
1.0
10
10
10
10
7.5
5.0
5.0
2.0
1.0
1.0
1.0
1.0
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
1.0
1.0
1.0
1.0
1.0
1.0
2.0
3.0
4.0
4.9
5.4
5.9
6.3
6.6
7.2
8.0
8.6
9.4
10.1
10.8
11.5
12.2
13.0
13.7
14.4
15.8
17.3
18.0
19.4
20.1
21.6
23.8
25.9
28.1
31.0
33.8
36.7
40.3
43.0
44.6
49.0
54.0
59.0
63.0
65.5
72.0
79.2
86.4
93.2
101
108
115
122
130
137
144
Maximum DC
Zener Current
IZM
(mA)
1440
1320
1220
1100
1010
930
856
790
765
700
630
580
545
520
475
430
395
365
340
315
295
280
265
250
237
216
198
190
176
170
158
144
132
122
110
100
93.0
86.0
79.0
76.0
70.0
63.0
58.0
54.5
52.5
47.5
43.0
39.5
36.6
34.0
31.6
29.4
28.0
26.4
25.0
23.6
Note :
( 1 ) Suffix " A " indicates ± 10% tolerance, suffix " B " indicates± 5% tolerance.
ht t p : //
www.lgesemi .c o m
SMBJ5333A-SMBJ5388A
RATING AND CHARACTERISTIC CURVES ( SMBJ5333B - SMBJ5388B )
Fig. 1 POWER DERATING CURVE
PD, MAXIMUM DISSIPATION
(WATTS)
5.0
4.0
3.0
2.0
1.0
50
75
100
125
150
TL, LEAD TEMPERATURE (°C)
Ir, PEAK SURGE CURRENT (AMPS)
Fig.2 Maximum Non-Repetitive Surg Current
versus Nominal Zener Voltage
40
PW=1 ms*
PW=8.3 ms*
4
2
1
PW=100 ms*
0.4
PW=1000 ms*
0.2
*SQURE WAVE
0.1
3
4
6 8 10
40
80
100
200
NORMINAL Vz (V)
PACKAGE
SPQ/PCS
CARTON
SPQ/PCS
CARTON
SIZE/CM
CARTON
GW/KG
CARTON
NW/KG
SMB
3000/REEL
48000
36X35.8X36.5
12.00
11.00
ht t p : //
www.lgesemi .c o m
很抱歉,暂时无法提供与“SMBJ5337B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.72999
- 50+1.43599
- 600+1.15277
- 1200+1.13548
- 3000+0.91640
