RTA03-4D1001FTP
RTA03-4D1001FTP
    RALEC(旺诠)
    RA_0603X4
    排阻/电阻网络 0603x4 1kΩ ±1% 62.5mW ±200ppm/℃
RTA03-4D1001FTP 数据手册
RALEC Thick Film Chip Resistors Array Product Specification 旺 詮 1 Document No. IE-SP-011 Released Date 2011/02/20 1/21 Page No. Scope: This specification is applicable to lead and halogen free RTA series thick film chip resistors array。 2 Explanation Of Part Numbers: 03 RTA (EX) Size Type Lead-Free Thick 01(0201) Thick Film Chip Resistors Array 02(0402) 03(0603) 4 Number of Circuits Terminal Type 2: 2 circuits 4: 4 circuits 8: 8 circuits D:Convex C:Concave D 101 Nominal Resistance E24 Series 3EX 10Ω =100 Digit 4.7Ω =4R7 Resistors E24/E96 Series 4EX 10.2Ω =10R2 Digit 10KΩ =1002 TP Resistance Tolerance D=± 0.5% F=± 1% G=± 2% J=± 5% 000 Jumper 3 J Packaging TH H2 H3 H4 TP P2 P3 P4 2 mm Pitch Paper(Taping) 10000 pcs 2 mm Pitch Paper(Taping) 20000 pcs 2 mm Pitch Paper(Taping) 30000 pcs 2 mm Pitch Paper(Taping) 40000 pcs 4 mm Pitch Paper(Taping) 5000 pcs 4 mm Pitch Paper(Taping) 10000 pcs 4 mm Pitch Paper(Taping) 15000 pcs 4 mm Pitch Paper(Taping) 20000 pcs General Specifications: Type T.C.R. Rated Max. Max. Power Working Overload (ppm/℃) at 70℃ Voltage Voltage RTA01-2D 1/32W 12.5V (0201) 25V Resistance Range G(± 2%) J(± 5%) E-24 D(± 0.5%) E-24、E-96 F(± 1%) E-24、E-96 ± 500 ----- ----- 3Ω≦R<10Ω ± 300 ----- ----- 10Ω≦R<1K Ω ± 200 ----- ----- 1KΩ≦R ≦1 MΩ ± 300 ----- 1Ω≦R<10Ω 1Ω≦R<10Ω ± 200 ----- 10Ω≦R≦1MΩ 10Ω≦R≦1MΩ ± 200 ----- 10Ω≦R≦1MΩ 1Ω≦R≦10MΩ Number Number of of Terminals Resistors JUMPER JUMPER (0Ω) (0Ω) Rated Resistance Current Value 4 2 0.5A 50mΩMax. 4 2 1A 50mΩMax. 4 2 1A 50mΩMax. 8 4 1A 50mΩMax. 8 4 1A 50mΩMax. 8 4 1A 50mΩMax. RTA02-2D 1/16W (0402) 25V 50V RTA03-2D 1/16W (0603) 50V 100V RTA02-4D 1/16W (0402) 25V 50V RTA02-4C 1/16W (0402) 25V 50V RTA03-4D 1/16W (0603) 50V 100V ± 200 RTA03-4C 1/16W (0603) 50V 100V ± 200 ----- 1Ω≦R≦1MΩ 1Ω≦R≦10MΩ 8 4 1A 50mΩMax. 25V 50V ± 250 ----- 10Ω≦R≦1MΩ 1Ω≦R≦1MΩ 16 8 1A 50mΩMax. 50V 100V ± 200 ----- 1Ω≦R≦1MΩ 1Ω≦R≦10MΩ 16 8 1A 50mΩMax. RTA03-2C 1/16W (0603) 50V 100V ± 200 ----- 1Ω≦R≦1MΩ 1Ω≦R≦10MΩ 4 2 1A 50mΩMax. RTA02-2C 1/16W (0402) 25V 50V 3Ω≦R<10Ω 3Ω≦R<10Ω 4 2 1A 50mΩMax. RTA02-8D 1/16W (0402) RTA03-8C 1/16W (0603) ± 300 ----- ± 200 ----- ± 400 ----- ± 200 ----- ± 650 ± 250 1Ω≦R<10Ω 1Ω≦R<10Ω Checked Written 1Ω≦R<10Ω 10Ω≦R≦1MΩ 10Ω≦R≦1MΩ 22Ω≦R≦470KΩ 1Ω≦R≦10MΩ 1Ω≦R≦10MΩ ----- 10Ω≦R≦1MΩ 10Ω≦R≦1MΩ Operating Temperature Range Approved 1Ω≦R<10Ω 10Ω≦R≦1MΩ 10Ω≦R≦1MΩ -55℃ ~ +155℃ Remark IT’ S NOT UNDER CONTROL FOR PDF FILE Issue Dep. DATA Center. PLS NOTE THE VERSION STATED. Do not copy without permission Series No. 60 RALEC 旺 詮 Thick Film Chip Resistors Array Product Specification Document No. IE-SP-011 Released Date 2011/02/20 2/21 Page No. 3.1 Power Derating Curve: Operating Temperature Range: - 55〜155 ℃ Rated Load(%) For resistors operated in ambient temperatures above 70 ℃ , power rating shall be derated in accordance with figure below. 70 100 80 60 40 155 20 0 -55 20 40 60 80 100 120 140 160 Ambient Temperature(℃) 3.2 Voltage Rating: Rated Voltage: The resistor shall have a DC continuous working voltage or a rms. AC continuous working voltage at commercial-line frequency and wave form corresponding to the power rating, as determined from the following: E= Rated voltage (v) P= power rating (w) R= Nominal resistance(Ω) Remark IT’ S NOT UNDER CONTROL FOR PDF FILE Issue Dep. DATA Center. PLS NOTE THE VERSION STATED. Do not copy without permission Series No. 60 RALEC Thick Film Chip Resistors Array Product Specification 旺 詮 4 Document No. IE-SP-011 Released Date 2011/02/20 3/21 Page No. Dimensions: (mm) RTA03-2C RTA03-2D RTA02-4C / RTA03-4C Circuits Q R1 R2 R4 R3 P L R1=R2=R3=R4 RTA02-4D / RTA03-4D Remark IT’ S NOT UNDER CONTROL FOR PDF FILE Issue Dep. DATA Center. PLS NOTE THE VERSION STATED. Do not copy without permission Series No. 60 RALEC 旺 詮 Thick Film Chip Resistors Array Product Specification Document No. IE-SP-011 Released Date 2011/02/20 4/21 Page No. RTA02-8D / RTA03-8C Circuits R1 R2 R3 R4 R5 R6 R7 R8 R1 = R2= R3 = R4 = R5 = R6 = R7 = R8 RTA01-2D / RTA02-2D Remark IT’ S NOT UNDER CONTROL FOR PDF FILE Issue Dep. DATA Center. PLS NOTE THE VERSION STATED. Do not copy without permission Series No. 60 RALEC Thick Film Chip Resistors Array Product Specification 旺 詮 Document No. IE-SP-011 Released Date 2011/02/20 5/21 Page No. RTA02-2C 型式 尺寸 L W H L1 L2 P Q RTA01-2D (0201) 0.80± 0.10 0.60± 0.10 0.30± 0.05 0.15± 0.10 0.15± 0.05 (0.50) 0.35± 0.10 RTA02-2D (0402) 1.00± 0.10 1.00± 0.10 0.30± 0.05 0.15± 0.10 0.25± 0.10 (0.67) 0.33± 0.10 RTA03-2D (0603) 1.60± 0.15 1.60± 0.15 0.45± 0.10 0.30± 0.15 0.30± 0.15 (0.80) 0.60± 0.10 RTA02-4D (0402) 2.00± 0.10 1.00± 0.10 0.40± 0.10 0.20± 0.10 0.25± 0.10 (0.50) 0.30± 0.10 RTA02-4C (0402) 2.00± 0.10 1.00± 0.10 0.40± 0.10 0.15± 0.10 0.25± 0.10 (0.50) 0.30± 0.10 RTA03-4D (0603) 3.20± 0.20 1.60± 0.15 0.50± 0.10 0.30± 0.15 0.30± 0.15 (0.80) 0.50± 0.10 RTA03-4C (0603) 3.20± 0.15 1.60± 0.15 0.55± 0.10 0.35± 0.15 0.45± 0.15 (0.80) 0.50± 0.10 RTA02-8D (0402) 4.00± 0.20 1.60± 0.10 0.40± 0.10 0.30± 0.15 0.30± 0.10 (0.50) 0.25± 0.10 RTA03-8C (0603) 6.40± 0.20 1.60± 0.20 0.55± 0.10 0.30± 0.15 0.40± 0.15 (0.80) 0.50± 0.10 RTA03-2C (0603) 1.60± 0.15 1.60± 0.15 0.55± 0.10 0.30± 0.15 0.40± 0.15 (0.80) 0.50± 0.10 RTA02-2C (0402) 1.00± 0.10 1.00± 0.10 0.30± 0.10 0.18± 0.10 0.25± 0.10 (0.50) 0.30± 0.10 Unit:mm Remark IT’ S NOT UNDER CONTROL FOR PDF FILE Issue Dep. DATA Center. PLS NOTE THE VERSION STATED. Do not copy without permission Series No. 60 RALEC 旺 詮 Remark Thick Film Chip Resistors Array Product Specification IT’ S NOT UNDER CONTROL FOR PDF FILE Document No. IE-SP-011 Released Date 2011/02/20 6/21 Page No. Issue Dep. DATA Center. PLS NOTE THE VERSION STATED. Do not copy without permission Series No. 60 RALEC 旺 詮 5 Thick Film Chip Resistors Array Product Specification Document No. IE-SP-011 Released Date 2011/02/20 7/21 Page No. Reliability Test: 5.1 Electrical Performance Test ITEM Specifications Resistors Conditions Jumper ( R2- R1) Temperature Refer item 3. General NA 6 Coefficientof TCR(ppm/℃)= R1( T2- T1) × 10 Specifications Resistance R1: Resistance at room temperature R2: Resistance at -55℃ or +125℃ T1: Room temperature T2: Temperature -55℃ or +125℃ Refer to JIS-C5201-1 4.8 0.5%、1%:± (1.0%+0.05Ω) 50mΩ Short Time Applied 2.5 times rated voltage for 5 seconds and Lower Overload release the load for about 30 minutes , then measure its 2%、5% :± (2.0%+0.10Ω) resistance variance rate. (Rated voltage refer to item 3. general specifications) No evidence of mechanical damage, Refer to JIS-C5201-1 4.13 Insulation Put the resistor in the fixture, add 100 VDC in + ,- ≧109Ω Resistance terminal for 60 sec then measured the insulation resistance between electrodes and insulating enclosure or between electrodes and base material. Refer to JIS-C5201-1 4.6 Dielectric Withstand Voltage Intermittent Overload Put the resistor in the fixture, add 300 VAC in +,No short or burned on the appearance. terminal for 60 sec. Refer to JIS-C5201-1 4.7 Put the tested resistor in chamber under temperature 50mΩ ± (5.0%+0.10Ω) 25± 2℃ and load 2.5 times rated DC voltage for 1 sec Lower on , 25 sec off , 10000 +400 test cycles, then it be left at 0 no-load for 1 hour , then measure its resistance variance rate. Refer to JIS-C5201-1 4.13 NA Resistance Noise Noise Level Refer to JIS-C5201-1 4.12 R <100Ω ≦-10db(0.32 uV/V) 100Ω ≦R<1KΩ ≦ 0db(1.0 uV/V) 1KΩ ≦R<10KΩ ≦ 10db(3.2 uV/V) 10KΩ ≦R<100KΩ ≦ 15db(5.6 uV/V) 100KΩ ≦R<1MΩ 1MΩ ≦R Remark IT’ S NOT UNDER CONTROL FOR PDF FILE ≦ 20db(10 uV/V) ≦ 30db(32 uV/V) Issue Dep. DATA Center. PLS NOTE THE VERSION STATED. Do not copy without permission Series No. 60 RALEC Thick Film Chip Resistors Array Product Specification 旺 詮 Document No. IE-SP-011 Released Date 2011/02/20 8/21 Page No. 5.2 Mechanical Performance Test ITEM Conditions Resistance to The tested resistor be immersed into isopropyl alcohol of solvent 20~25℃ for 5 minutes, then the resistor is left in the room for 48 hr , then measure its resistance variance rate. Refer to JIS-C5201-1 4.29 Resistance to ◎Test method 1 (Reflow test): soldering heat The tested resistor should be subject in the following procedure, and after finish each step, it should be left for a duration of 2 hours or longer at a temperature of 30℃ or lower and a humidity of 70% RH or lower. Step 1 Procedure Specifications Resistors Jumper 01-2D:± (1.0%+0.05Ω) 50mΩ Other:± (0.5%+0.05Ω) Lower No evidence of mechanical damage, no G2 overcoating and Sn layer by leaching. ± (1.0%+0.05Ω) 50mΩ Lower No evidence of electrode damage. No side conductive peel off. Environmental test condition Resistance measuring Room temperature 2 Baking 125℃, 24 hours 3 Humidification 85℃,85%,168 hours 4 Reflow (1) Reflow temperature curve and component surface temperature Table 1 5 Humidification 85℃,65%,24 hours 6 Reflow (2) Reflow temperature curve and component surface temperature Table 2 7 Resistance measuring Room temperature ◎Reflow temperature curve ◎Component surface temperature Table 1 Description example in specification document(1) Temperature measured Temperature-retaining Peak at the component body time:230℃ or higher temperature surface during preheating 30 seconds 240℃ 150 to 160 ℃ Remark IT’ S NOT UNDER CONTROL FOR PDF FILE Issue Dep. DATA Center. PLS NOTE THE VERSION STATED. Do not copy without permission Series No. 60 RALEC 旺 詮 Thick Film Chip Resistors Array Product Specification ITEM Document No. IE-SP-011 Released Date 2011/02/20 9/21 Page No. Specifications Resistors Conditions Jumper Table 2 Description example in specification document(2) Temperature Temperature-retaining time Temperature measured at the component body surface during preheating 220℃ or higher 230℃ or higher 240℃ or higher Peak 90 seconds 60 seconds 5 seconds 245℃ 150 to 160℃ ◎Test method 2 (sloder pot test): The tested resistor should be subject in the following procedure, and after finish each step, it should be left for a duration of 2 hours or lower at a temperature of 30℃ or lower and a humidity of 70% RH or lower. Step 1 2 3 4 5 6 7 Procedure Resistance measuring Baking Humidification Sloder pot test Placed Sloder pot test Resistance measuring Environmental test condition Room temperature 125℃, 24 hours 85℃,85%,168 hours 260± 3℃, 10 sec 85℃,65%,24 hours 260± 3℃, 10 sec Room temperature By Sony (SS-00254-5) Refer to JIS-C5201-1 4.18 Solderability Preconditioning: 1.Test item 1: Put the tested resistor in the apparatus of PCT, at a Solder coverage over 95% temperature of 105℃, humidity of 100% RH, and pressure of 1.22× 105 Pa for a duration of 4 hours. Then after left the tested resistor in room temperature for 2 hours or more. Test method: ◎Test item 1 (solder pot test): The resistor be immersed into solder pot in temperature 235± 5℃ for 2 sec, then the resistor is left as placed under microscope to observed its solder area. By SONY (SS-00254-2) Refer to JIS-C5201-1 4.17 Remark IT’ S NOT UNDER CONTROL FOR PDF FILE Issue Dep. DATA Center. PLS NOTE THE VERSION STATED. Do not copy without permission Series No. 60 RALEC 旺 詮 ITEM Thick Film Chip Resistors Array Product Specification Conditions Joint strength Preconditioning: of solder Put the tested resistor in the apparatus of PCT, at a temperature of 105℃, humidity of 100% RH, and pressure of 1.22× 105 Pa for a duration of 4 hours. Then after left the tested resistor in room temperature for 2 hours or more. Test method: ◎Test item 1 (Adhesion): A static load using a R0.5 scratch tool shall be applied on the core of the component and in the direction of the arrow and held for 10 seconds and under load measure its resistance variance rate. 1.02-2C=10N load 2.Other=20N load 3.01-2D=5N load Document No. IE-SP-011 Released Date 2011/02/20 10/21 Page No. Specifications Resistors Jumper 50mΩ Test item1: Lower 1.△R%=± (1.0%+0.05Ω) 2.No evidence of mechanical damage. No terminal peel off. Test item2: 1.△R%=± (1.0%+0.05Ω) 2.No evidence of mechanical damage. No terminal peel off and core body cracked. Test item3: (1).Adhesion After application of temperature cycle, adhesion should be 50% or more of initial strength. (2).Bending Strength: After application of temperature cycle, bending load should be 50% or more of initial strength. Refer to JIS-C5201-1 4.32 ◎Test item 2 (Bending Strength): Solder tested resistor on the PC board, add force in the middle down, and under load measure its resistance variance rate . D=(1)01-2D=3mm (2)Other=5mm Refer to JIS-C5201-1 4.33 Remark IT’ S NOT UNDER CONTROL FOR PDF FILE Issue Dep. DATA Center. PLS NOTE THE VERSION STATED. Do not copy without permission Series No. 60 RALEC 旺 詮 ITEM Thick Film Chip Resistors Array Product Specification Conditions ◎Test item 3 (Endurance measurement): Put the tested resistor in the chamber under the temperature cycle which shown in table 1 shall be repeated 1000± 4 times consecutively. Then separate follow test item 1 and test item 2 50% condition to test, measured its resistance variance rate. Table 1 Temperature cycle test condition Testing condition Lowest temperature -35± 5℃ Highest temperature 105± 5℃ Temperature-retaining time 15 minutes each By SONY (SS-00254-9) Leaching Test The tested resistor be immersed into molten solder of 260± 5℃ for 30 seconds. Then the resistor is left as placed under microscope to observed its solder area. By SONY (SS-00254-9) Remark IT’ S NOT UNDER CONTROL FOR PDF FILE Document No. IE-SP-011 Released Date 2011/02/20 11/21 Page No. Specifications Resistors Jumper 1.Solder coverage over 95%. 2.The underlying material (such as ceramic) shall not be visible at the crest corner area of the electrode. Issue Dep. DATA Center. PLS NOTE THE VERSION STATED. Do not copy without permission Series No. 60 RALEC 旺 詮 Thick Film Chip Resistors Array Product Specification Document No. IE-SP-011 Released Date 2011/02/20 12/21 Page No. 5.3 Environmental Test ITEM Specifications Resistors Conditions Resistance to Put tested resistors in chamber under temperature 155± 5℃ for 1,000± 4 hours. Then leaving in room temperature for 60 Dry Heat 0.5%、1%:± (1.0%+0.05Ω) 2%、5% :± (2.0%+0.10Ω) Jumper 50mΩ Lower minutes, and measure its resistance variance rate . Refer to JIS-C5201-1 4.25 Thermal Shock No evidence of mechanical damage, No evidence of mechanical. Put the tested resistor in the thermal shock chamber under the ± (1.0%+0.05Ω) 50mΩ temperature cycle which shown in the following table shall be Lower repeated 300 times consecuitively. Then leaving the tested No evidence of mechanical damage, resistor in the room temperature for 1 hours, and measure its resistance variance rate. Testing Condition Lowest Temperature -55± 5℃ Highest Temperature 125± 5℃ Temperature-retaining time 15 minutes each Refer to MIL-STD 202 Method 107 Loading Life in Put the tested resistor in the chamber under temperature 40± 0.5%、1%:± (2.0%+0.10Ω) 2℃, relative humidity 90~95% and load the rated voltage for 90 2%、5% :± (3.0%+0.10Ω) Moisture minutes on, 30 minutes off, total 1000 hours. Then leaving the tested resistor in room temperature for 60 minutes, and measure its resistance variance rate. Refer to JIS-C5201-1 4.24 Put the tested resistor in chamber under temperature 70± 2℃ Load Life and load the rated voltage for 90 minutes on, 30 minutes off, total 1000 hours. Then leaving the tested resistor in room temperature for 60 minutes, and measure its resistance variance rate. Refer to JIS-C5201-1 4.25 Put the tested resistor in the chamber at room temperature Low Temperature 25℃.Decreasing the temperature to -55℃ and keep the Operation temperature at -55℃ for 1 hour. Then load the rated voltage for 45 minutes on, and 15 minutes off. Then leaving the tested resistor in room temperature for 8± 1 hours, and measure its resistance variance rate. Refer to MIL-R-55342D 4.7.4 Whisker Test ◎Test item 1 (Thermal Shock test): Minimum storage temperature -40± 2℃ Maximum storage temperature 85± 2℃ Temperature-rataining time 7 min. Number of temperature cycles 1,500 50mΩ Lower No evidence of mechanical damage. 0.5%、1%:± (2.0%+0.10Ω) 2%、5% :± (3.0%+0.10Ω) No evidence of mechanical damage, no short or burned on the appearance. 50mΩ Lower 0.5%、1%:± (0.5%+0.05Ω) 50mΩ 2%、5% :± (1.0%+0.05Ω) Lower No evidence of mechanical damage, Max. 50μm ◎Test item 2 (Constant temperature/humidity test): Remark Temperature 85℃ Humidity 85% Testing duration 500± 4 hours IT’ S NOT UNDER CONTROL FOR PDF FILE Issue Dep. DATA Center. PLS NOTE THE VERSION STATED. Do not copy without permission Series No. 60 RALEC 旺 詮 ITEM Thick Film Chip Resistors Array Product Specification Conditions Document No. IE-SP-011 Released Date 2011/02/20 13/21 Page No. Specifications Resistors Jumper ◎Inspection: Inspect for whisker formation on specimens that underwent the acceleration test specified in subciause 4.2, with a magnifier (stereomicroscope) of about 40 or higher magnification. If judgment is hard in this method, use a scanning electron microscope (SEM) of about 1,000 or higher magnification. By SONY (SS-00254-8) 6 Recommend Soldering Method 6.1 Lead Free Reflow Soldering Profile 6.2 Soldering Iron: temperature 350℃± 10℃ , dwell time shall be less than 3 sec. Remark IT’ S NOT UNDER CONTROL FOR PDF FILE Issue Dep. DATA Center. PLS NOTE THE VERSION STATED. Do not copy without permission Series No. 60 RALEC Thick Film Chip Resistors Array Product Specification 旺 詮 7 Document No. IE-SP-011 Released Date 2011/02/20 14/21 Page No. Recommend Land Pattern Design (For Reflow Soldering): Unit : mm RTA01-2D / RTA02-2D RTA02-2C / RTA03-2D / RTA03-2C TYPE 8 DIM RTA02-4D / RTA02-4C RTA03-4D / RTA03-4C RTA02-8D / RTA03-8C A B P Q1 Q2 RTA01-2D 0.30 0.90 0.50 0.30 0.30 RTA02-2D 0.50 2.00 0.67 0.33 0.34 RTA03-2D 1.00 2.60 0.80 0.40 0.40 RTA02-4D RTA02-4C 0.50 2.00 0.50 0.28 0.22 RTA03-4D RTA03-4C RTA03-2C 1.00 2.60 0.80 0.40 0.40 RTA02-8D 1.00 2.60 0.50 0.25 0.25 RTA03-8C 1.00 2.60 0.80 0.40 0.40 RTA02-2C 0.50 2.00 0.50 0.28 0.22 Marking Diagrams: 8.1 ± 2%、± 5% Tolerance: 8.1.1 Resistance Range ≧ 10 Ω : 3 digits in E-24 series, first two digits are significant figures, third digit is is multiplier (10× ). 《EX》Marking→100 100=10 × 100 =10Ω 8.1.2 Resistance Range < 10 Ω : 3 digits in E-24 series, first and thrid digits are significant figures, second digit is multiplier (10-1). 《EX》Marking→4R7 4R7=47× 10-1 =4.7Ω Remark IT’ S NOT UNDER CONTROL FOR PDF FILE Issue Dep. DATA Center. PLS NOTE THE VERSION STATED. Do not copy without permission Series No. 60 RALEC Thick Film Chip Resistors Array Product Specification 旺 詮 Document No. IE-SP-011 Released Date 2011/02/20 15/21 Page No. 8.2 ± 0.5%、1% Tolerance: 8.2.1 Resistance Range ≧ 100 Ω : 4 digits in E-24 series or E-96 series, first three digits are significant figures, forth digit is multiplier (10× ). 《EX》Marking→1002 1002=100× 102 =10000Ω=10KΩ 8.2.2 Resistance Range < 100 Ω : 4 digits in E-24 series or E-96 series, three digits are significant figures,R digit is multiplier (10× ). 《EX》Marking→10R2 ,R digit is multiplier (10-1). 10R2=102× 10-1 =10.2Ω Marking→1R02 ,R digit is multiplier (10-2). 1R02=102× 10-2 =1.02Ω 8.3 RTA01-2D、RTA02-2D、RTA02-2C、RTA02-4C No Marking 8.4 Marking Standard Standard 1 TYPE 2 3 4 5 6 7 8 9 0 R Marking RTA03-2D RTA02-4D RTA03-2C RTA03-4D RTA03-4C RTA02-8D RTA03-8C Remark IT’ S NOT UNDER CONTROL FOR PDF FILE Issue Dep. DATA Center. PLS NOTE THE VERSION STATED. Do not copy without permission Series No. 60 RALEC Thick Film Chip Resistors Array Product Specification 旺 詮 Document No. IE-SP-011 Released Date 2011/02/20 16/21 Page No. 8.5 Marking 8.5.1 E-24 series 10 11 12 13 15 16 18 20 22 24 27 30 33 36 39 43 47 51 56 62 68 75 82 91 8.5.2 E-96 series 9 100 102 105 107 110 113 115 118 121 124 127 130 133 137 140 143 147 150 154 158 162 165 169 174 178 182 187 191 196 200 205 210 215 221 226 232 237 243 249 255 261 267 274 280 287 294 301 309 316 324 332 340 348 357 365 374 383 392 402 412 422 432 442 453 464 475 487 499 511 523 536 549 562 576 590 604 619 634 649 665 681 698 715 732 750 768 787 806 825 845 866 887 909 931 953 976 Plating Thickness: 9.1 Ni: ≧1μm 9.2 Sn(Tin): ≧3μm 9.3 Sn(Tin): Matte Sn Remark IT’ S NOT UNDER CONTROL FOR PDF FILE Issue Dep. DATA Center. PLS NOTE THE VERSION STATED. Do not copy without permission Series No. 60 RALEC Thick Film Chip Resistors Array Product Specification 旺 詮 Document No. IE-SP-011 Released Date 2011/02/20 17/21 Page No. 10 Taping Specifications 10.1Tape Dimension Unit : mm Packaging DIM Type A B W E F T1 T2 P P0 10× P0 P1 RTA01-2D 0.90± 0.1 0.70± 0.1 8.0± 0.2 1.75± 0.1 3.5± 0.05 0.45+0.2/-0 0.43± 0.1 2.0± 0.1 4.0± 0.05 40.0± 0.20 2.0± 0.05 TH RTA02-2D 1.20± 0.1 1.20± 0.1 8.0± 0.2 1.75± 0.1 3.5± 0.05 0.45+0.2/-0 0.43± 0.1 2.0± 0.1 4.0± 0.05 40.0± 0.20 2.0± 0.05 Carrier RTA02-2C 1.20± 0.1 1.20± 0.1 8.0± 0.2 1.75± 0.1 3.5± 0.05 0.45+0.2/-0 0.43± 0.1 2.0± 0.1 4.0± 0.05 40.0± 0.20 2.0± 0.05 RTA02-4D 2.20± 0.1 1.20± 0.1 8.0± 0.2 1.75± 0.1 3.5± 0.05 0.60+0.2/-0 0.60± 0.1 2.0± 0.1 4.0± 0.05 40.0± 0.20 2.0± 0.05 Tape TP RTA02-4C 2.20± 0.1 1.20± 0.1 8.0± 0.2 1.75± 0.1 3.5± 0.05 0.60+0.2/-0 0.60± 0.1 2.0± 0.1 4.0± 0.05 40.0± 0.20 2.0± 0.05 RTA03-2D 1.90± 0.1 1.90± 0.1 8.0± 0.2 1.75± 0.1 3.5± 0.05 0.60+0.2/-0 0.60± 0.1 4.0± 0.1 4.0± 0.05 40.0± 0.20 2.0± 0.05 8.0± 0.2 1.75± 0.1 3.5± 0.05 0.75+0.2/-0 0.75± 0.1 4.0± 0.1 4.0± 0.05 40.0± 0.20 2.0± 0.05 RTA03-4D 3.45± 0.1 1.90± 0.1 Carrier RTA03-4C 3.45± 0.1 1.90± 0.1 8.0± 0.2 1.75± 0.1 3.5± 0.05 0.75+0.2/-0 0.75± 0.1 4.0± 0.1 4.0± 0.05 40.0± 0.20 2.0± 0.05 Tape RTA02-8D 4.30± 0.2 1.90± 0.2 12.0± 0.2 1.75± 0.1 5.5± 0.05 0.60+0.2/-0 0.60± 0.1 4.0± 0.1 4.0± 0.05 40.0± 0.20 2.0± 0.05 RTA03-8C 6.90± 0.2 2.00± 0.2 12.0± 0.2 1.75± 0.1 5.5± 0.05 0.75+0.2/-0 0.75± 0.1 4.0± 0.1 4.0± 0.05 40.0± 0.20 2.0± 0.05 RTA03-2C 1.90± 0.1 1.90± 0.1 8.0± 0.2 1.75± 0.1 3.5± 0.05 0.75+0.2/-0 0.75± 0.1 4.0± 0.1 4.0± 0.05 40.0± 0.20 2.0± 0.05 10.2Lead Dimensions: Carrier Tape 95~270mm Chip Filled Area ≧160mm Cover Tape Unfilled Area ≧400mm Remark IT’ S NOT UNDER CONTROL FOR PDF FILE Issue Dep. DATA Center. PLS NOTE THE VERSION STATED. Do not copy without permission Series No. 60 RALEC Thick Film Chip Resistors Array Product Specification 旺 詮 Document No. IE-SP-011 Released Date 2011/02/20 18/21 Page No. 10.3Cover Tape Peel off Strength Specifications:0.07~0.7N (7.1~71.4gf) Top Cover Tape Carrier Tape Peeling Speed (300mm/min) Peeling Angle 10° Direction of unreeling 10.4Packaging Qty: Packaging (pcs/reel) Type Tape Width RTA01-2D 8 mm RTA02-2D、RTA02-2C 8 mm RTA02-4C、RTA02-4D 8 mm RTA03-2D、RTA03-2C 8 mm RTA03-4C、RTA03-4D 8 mm RTA02-8D、RTA03-8C 12 mm TH Reel Type TH TP 2 mm Pitch 4 mm Pitch H2 H3 H4 10,000 20,000 30,000 40,000 TP P2 P2 P4 -- -- -- -- -- -- -- -- 5,000 7” 10” 13” 13” 7” 10,000 15,000 20,000 10” 13” 13” 10.4.1Typical taping type: TH、TP 10.4.2Other taping type are upon customer’ s request. 10.5Reel Dimensions:  Unit:mm Remark Reel Type / Tape Wa M 7” reel for 8 mm tape 9.0 ± 0.5 178 ± 2.0 60.0 ± 1.0 7” reel for 12 mm tape 13.8 ± 0.5 178 ± 2.0 80.0 ± 1.0 10” reel for 8 mm tape 10.0 ± 0.5 254 ± 2.0 13” reel for 8 mm tape 10.0 ± 0.5 330 ± 2.0 IT’ S NOT UNDER CONTROL FOR PDF FILE A B C 2.0 13.5 21.0 ± 0.5 ± 0.5 ± 0.5 100.0 ± 1.0 100.0 ± 1.0 Issue Dep. DATA Center. PLS NOTE THE VERSION STATED. Do not copy without permission D Series No. 60 RALEC Thick Film Chip Resistors Array Product Specification 旺 詮 Document No. IE-SP-011 Released Date 2011/02/20 19/21 Page No. 10.6Label: Computer No. Type Tolerance R Value Quantity RTA03-4D 5% 10K Pb-free 508J103 5000 PCS R09010001 RTA03-4D103JTP 001 RALEC Lot No. R 0 9 0 1 Running Number Part No. 0 0 Week Logo 0 1 Running Number Year(2009) RALEC 10.7Inner Box Reel Number D Dimension (mm) 1 12 2 24 3 36 4 48 5 60 6 72 7 84 8 96 9 108 10 120 D 180 180 10.8Box 10R Inner Box Number 2 Remark L(mm) W(mm) D(mm) 272 205 210 4 375 280 210 8 544 380 210 IT’ S NOT UNDER CONTROL FOR PDF FILE RAL EC Issue Dep. DATA Center. PLS NOTE THE VERSION STATED. Do not copy without permission Series No. 60 RALEC Thick Film Chip Resistors Array Product Specification 旺 詮 Document No. IE-SP-011 Released Date 2011/02/20 20/21 Page No. 10.9Box (For China) 10R Inner BoxNumber 2 L(m m ) W( mm) D( mm) 272 205 210 4 375 280 210 8 544 380 210 EC RAL 11 Stock period 11.1The temperature condition must be controlled at 25 ± 5 ℃ , the R.H. must be controlled at 60± 15%. The stock can maintain quality level in two years. 12 The carton packaged for electronic-information products is made by the symbol as follows: (For china) Marking for control of pollution cause by electronic-information products Remark Marking for package recovery IT’ S NOT UNDER CONTROL FOR PDF FILE Issue Dep. DATA Center. PLS NOTE THE VERSION STATED. Do not copy without permission Series No. 60 RALEC 旺 詮 Thick Film Chip Resistors Array Product Specification Document No. IE-SP-011 Released Date 2011/02/20 21/21 Page No. 13 For this part. It does not use the materials that include the substances specified in RoHS,the detail refer to the part of prohibition or exclusion items in RoHS (2002/95/EC). 1. Cadmium and cadmium compounds (permissive content<100 ppm) 2. Lead and lead compounds (permissive content<1000 ppm) Exceptions specified: (1). Lead contained in the glass of cathode ray tubes, electronic components and fluorescent tubes. (2). The glass material used in the electronic components, which includes resistor elements, conductive pastes (silver or copper ones), adhesives, glass frit and sealing materials. 3. Mercury and its mercury compounds (permissive content<100 ppm) 4. Hexavalent chromium compounds (permissive content<100 ppm) 5. Polybrominated biphenyls(PBB) (permissive content<100 ppm) 6. Polybrominated diphenylethers(PBDE) (permissive content<100 ppm) 14 Attachments 14.1Document Revise Record Paper Remark IT’ S NOT UNDER CONTROL FOR PDF FILE Issue Dep. DATA Center. PLS NOTE THE VERSION STATED. Do not copy without permission Series No. 60
RTA03-4D1001FTP 价格&库存
很抱歉,暂时无法提供与“RTA03-4D1001FTP”相匹配的价格&库存,您可以联系我们找货
RTA03-4D1001FTP
  • 20+0.15230
  • 200+0.09500
  • 1000+0.06090
  • 5000+0.04060
  • 10000+0.03850
  • 50000+0.03450
库存:177
RTA03-4D1001FTP
    • 50+0.07172
    • 500+0.05778
    • 1500+0.05001
    库存:2478
    RTA03-4D1001FTP
    • 100+0.04047
    • 500+0.03817
    • 1000+0.03472
    • 5000+0.03012
    • 10000+0.02737
