DSK32 THRU DSK320
Reverse Voltage - 20 to 200 Volts
Forward Current - 3.0 Ampere
SOD-123FL
Features
0.114(2.9)
0.098(2.5)
0.030(0.76)
0.018(0.45)
Case: JEDEC SOD-123FL molded plastic body
Terminals: Plated axial leads, solderable per MIL-STD-750,
Method 2026
Polarity: Color band denotes cathode end
Mounting Position: Any
Weight:0.0007 ounce, 0.02 grams
0.154(3.9)
0.138(3.5)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Dimensions in inches and(millimeters)
Ratings at 25 C ambient temperature unless otherwise specified.
SYMBOLS DSK32 DSK33 DSK34 DSK35 DSK36 DSK38 DSK39 DSK310 DSK315 DSK320
MDD Catalog Number
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
28
40
30
21
30
50
35
50
60
42
60
80
56
80
90
63
90
100
70
100
150
105
150
200
140
200
UNITS
I(AV)
3.0
VOLTS
VOLTS
VOLTS
Amp
IFSM
80.0
Amps
VRRM
VRMS
VDC
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Maximum instantaneous forward voltage at 3.0A
Maximum DC reverse current
TA=25 C
at rated DC blocking voltage
TA=100 C
VF
IR
TJ
TSTG
ht t p : //
Revision:20170701-P1
0.008(0.20)
0.004(0.10)
0.047(1.19)
0.043(1.09)
Mechanical Data
Operating junction temperature range
Storage temperature range
0.043(1.09)
0.035(0.89)
0.075(1.90)
0.067(1.70)
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
Metal silicon junction,majority carrier conduction
Low power loss,high efficiency
High forward surge current capability
High temperature soldering guaranteed:
250 C/10 seconds,0.375”(9.5mm) lead length,
5 lbs. (2.3kg) tension
0.45
0.55
0.85
0.70
0.5
10.0
20.0
-50 to +150
-50 to +125
-50 to +150
www.lgesemi .c o m
Volts
mA
C
C
mail:lge@lgesemi.com
DSK32 THRU DSK320
FIG. 1- FORWARD CURRENT DERATING CURVE
3
2.4
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
1.8
1.2
DSK32-DSK36
DSK38-DSK310
0.6
50
75
100
125
150
PEAK FORWARD SURGE CURRENT,
AMPERES
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
RATINGS AND CHARACTERISTIC CURVES DSK32 THRU DSK320
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
80
64
48
32
16
175
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
1
10
AMBIENT TEMPERATURE, C
10
TJ=25 C
PULSE WIDTH=300 µs
1%DUTY CYCLE
DSK32-DSK34
DSK35-DSK36
DSK38-DSK310
0.1
0.01
0.2
0.4
0.6
0.8
1.0
1.1
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
INSTANTANEOUS REVERSE CURRENT,
MILLIAMPERES
INSTANTANEOUS FORWARD
CURRENT,AMPERES
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
100
NUMBER OF CYCLES AT 60 Hz
100
10
TJ=100 C
1
TJ=75 C
0.1
0.001
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
TJ=25 C
0.01
60
80
100
PERCENT OF PEAK REVERSE VOLTAGE,%
PACKAGE
SPQ/PCS
CARTON
SPQ/PCS
CARTON
SIZE/CM
CARTON
GW/KG
CARTON
NW/KG
SOD-123FL
3000/REEL
90000
40X20X22
5.00
4.00
ht t p : //
www.lgesemi .c o m
很抱歉,暂时无法提供与“DSK310”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.38501
- 100+0.31571
- 600+0.28106
- 1200+0.27684
- 3000+0.21057
- 国内价格
- 10+0.42002
- 100+0.34442
- 300+0.30662
- 3000+0.22972
- 6000+0.20704
- 9000+0.19570
