SZ452H - SZ45D0
ZENER DIODES
FEATURES :
Complete Voltage Range 2.7 to 200 Volts
High peak reverse power dissipation
High reliability
Low leakage current
Pb / RoHS Free
SMA/DO-214AC
0. 181( 4. 60)
0. 161( 4. 10)
0. 108(2.75)
0. 096( 2.45)
0. 063(1.60)
0. 051(1.30)
MECHANICAL DATA
0. 209( 5. 30)
0. 193( 4. 90)
Case : SMA (DO-214AC) Molded plastic
Epoxy : UL94V-O rate flame retardant
0. 012(0.30)
0. 006(0.15)
0.096(2.45)
0.078(2.00)
Lead : Lead formed for Surface mount
Polarity : Color band denotes cathode end
Mounting position : Any
Weight : 0.064 grams
0. 059( 1. 50)
0. 035( 0. 90)
0.008(0.20)
0. 002(0.05)
Dimensions in inches and(millimeters)
MAXIMUM RATINGS
Rating at 25 °C ambient temperature unless otherwise specified
Rating
Symbol
Value
Unit
DC Power Dissipation at TL = 75 °C (Note1)
PD
2.0
W
Maximum Forward Voltage at IF = 200 mA
VF
1.2
V
Junction Temperature Range
TJ
- 55 to + 150
°C
Storage Temperature Range
Ts
- 55 to + 150
°C
Note :
(1) T L = Lead temperature at 5.0 mm2 ( 0.013 mm thick ) copper land areas.
PD, MAXIMUM DISSIPATION
(WATTS)
Fig. 1 POWER TEMPERATURE DERATING CURVE
2.5
2.0
1.5
1.0
copper land areas.
0.5
50
75
100
125
150
175
TL, LEAD TEMPERATURE (°C)
ht t p : //
Revision:20170701-P1
www.lgesemi .c o m
mail:lge@lgesemi.com
SZ452H - SZ45D0
ZENER DIODES
ELECTRICAL CHARACTERISTICS
Nominal Zener
Maximum Zener
Voltage
Impedance
TYPE
V Z @ I ZT
IZT
Z ZT @ I ZT
Z ZK @ I ZK
(V)
(mA)
(Ω)
(Ω)
SZ452H
SZ453A
SZ453D
SZ453G
SZ453J
SZ454D
SZ454H
SZ455B
SZ455G
SZ456C
SZ456I
SZ457F
SZ458C
SZ459B
SZ4510
SZ4511
SZ4512
SZ4513
SZ4514
SZ4515
SZ4516
SZ4517
SZ4518
SZ4519
SZ4520
SZ4522
SZ4524
SZ4527
SZ4530
SZ4533
SZ4536
SZ4539
SZ4543
SZ4547
SZ4551
SZ4556
SZ4562
SZ4568
SZ4575
SZ4582
SZ4591
SZ45B0
SZ45B1
SZ45B2
SZ45B3
SZ45B4
SZ45B5
SZ45B6
SZ45B7
SZ45B8
SZ45B9
SZ45D0
2.7
3.0
3.3
3.6
3.9
4.3
4.7
5.1
5.6
6.2
6.8
7.5
8.2
9.1
10
11
12
13
14
15
16
17
18
19
24
27
30
33
36
39
43
47
51
56
62
68
75
82
91
100
110
120
130
140
150
160
170
180
190
200
80
160
145
139
128
116
106
98.0
89.5
80.5
73.5
66.5
61.0
55.0
50.0
45.5
41.5
38.5
35.7
33.4
31.2
29.4
27.8
26.3
25.0
22.8
20.8
18.5
16.6
15.1
13.9
12.8
11.6
10.6
9.8
9.0
8.1
7.4
6.7
6.1
5.5
5.0
4.5
4.2
3.8
3.6
3.3
3.1
2.9
2.8
2.6
2.5
10
8.0
8.0
5.0
5.0
4.5
4.5
3.5
2.5
1.5
2.0
2.0
2.3
2.5
3.5
4.0
4.5
5.0
5.5
7.0
8.0
9.0
10
11
11
12
13
18
25
30
35
40
48
55
60
75
90
100
125
175
250
325
400
500
575
650
675
725
825
900
400
400
400
400
400
400
550
600
500
700
700
700
700
700
700
700
700
700
700
700
700
750
750
750
750
750
750
750
1000
1000
1000
1000
1500
1500
1500
2000
2000
2000
2000
3000
3000
3000
4000
4500
5000
5500
6000
6500
7000
7000
8000
8000
IZK
(mA)
Maximum Reverse
Leakage Current
IR @ V R
(V)
(µA)
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
0.5
0.5
0.5
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
0.25
100
100
80
80
50
50
50
50
50
50
50
50
50
50
50
50
1.0
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
1.0
1.0
1.0
1.0
1.0
1.0
1.0
1.0
2.0
3.0
4.0
5.0
6.0
7.0
7.6
8.4
9.1
9.9
10.6
11.4
12.2
13.0
13.7
14.4
15.2
16.7
18.2
20.6
22.5
25.1
27.4
29.7
32.7
35.8
38.8
42.6
47.1
51.7
56.0
62.2
69.2
76.0
83.6
91.2
98.8
106.4
114.0
121.6
130.4
136.8
144.8
152.0
Maximum DC
Zener Current
IZM
(mA)
660
600
545
504
468
434
386
356
324
292
266
242
220
200
182
166
152
138
130
122
114
107
100
95
90
82
76
68
60
55
50
47
43
39
36
32
29
27
24
22
17
15
14
13
12
11
11
10
10
9.0
Notes :
( 1 ) The type number listed have a standard tolerance on the nominal zener voltage of ± 5.0%,
altered the fourth number of type from " 5 " for ± 5.0% tolerance to be " 0 " for ± 10% tolerance.
( 2 ) " SZ " will be omitted in marking on the diode.
PACKAGE
SPQ/PCS
CARTON
SPQ/PCS
CARTON
SIZE/CM
CARTON
GW/KG
CARTON
NW/KG
SMA
5000/REEL
80000
36X30.6X31
12.00
11.00
ht t p : //
www.lgesemi .c o m
很抱歉,暂时无法提供与“SZ4524”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.51497
- 100+0.42166
- 300+0.37500
- 1000+0.34001
- 5000+0.25574
- 10000+0.24174
