SMD3225-090N
SMD3225-090N
    RUILON(瑞隆源)
    气体放电管, 电极数:2 直流击穿电压:90V 精度:±30% 脉冲放电电流:1kA 极间电容:0.5pF
SMD3225-090N 数据手册
Gas Discharge Tubes(GDT) SMD3225 Series Description Gas discharge tubes (GDT) use noble gasses enclosed in ceramic tubes to provide an alternate circuit path for voltage spikes. The ceramic envelope and with nickel connectors allow for high loads. SMD3225 Gas Discharge Tubes (GDT) series has a surge rating of 1kA, 8/20μs.Offered in a Squared Surface Mount package, which helps to make pick and place on PCB process easier. This GDT series is perfectly suited for broadband equipment applications. The GDT’s low off-state capacitance is compatible with high bandwidth applications and this capacitance loading value does not vary if the voltage across the GDT changes. Electrical symbol SMD3225 Gas Discharge Tube (GDT) series are specifically designed for protection of electrical, multimedia, and communication equipment against over voltage transients in surface mount assembly applications. Features Applications l l l l l l l l l l l Communication equipment l CATV equipment l Test equipment l Data lines l Power supplies l Telecom SLIC protection l Broadband equipment Excellent response to fast rising transients Stable breakdown voltage GHz working frequency 8/20μs Impulse current capability: 1KA Surface Mount package Non-Radioactive Ultra Low capacitance(
SMD3225-090N 价格&库存
很抱歉,暂时无法提供与“SMD3225-090N”相匹配的价格&库存,您可以联系我们找货
