FCM1608KF-181T05
FCM1608KF-181T05
    TAI-TECH(台庆)
    贴片磁珠 0603 180Ω@100MHz ±25% 500mA
FCM1608KF-181T05 数据手册
TAI-TECH KBM01-171100483 Ferrite Chip Bead(Lead Free) FCM1608KF-Series ECN HISTORY LIST REV DATE DESCRIPTION P1. APPROVED CHECKED DRAWN 楊祥忠 羅培君 張嘉玲 楊祥忠 羅培君 張嘉玲 1.0 13/06/06 變更可靠度條件 2.0 14/01/24 3.0 14/08/01 變更 Reflow 圖示 楊祥忠 羅培君 張嘉玲 3.1 14/08/01 修正包裝帶尺寸 楊祥忠 羅培君 張嘉玲 4.0 14/10/13 訂正 1608 包裝帶 Ao 尺寸 楊祥忠 羅培君 張嘉玲 5.0 16/01/26 楊祥忠 詹偉特 張嘉玲 6.0 17/02/16 修訂 Recommended PC Board Pattern 楊祥忠 詹偉特 張嘉玲 變更電鍍錫層厚度 3.0um min.=>3.5um min. 增訂可靠度 Thermal shock: (Bead) Step3:125±2℃ 30±5min 備 註 www.tai-tech.com.tw TAI-TECH KBM01-171100483 Ferrite Chip Bead(Lead Free) P2. FCM1608KF-Series 1.Features 1. Monolithic inorganic material construction. 2. Closed magnetic circuit avoids crosstalk. 3. S.M.T. type. 4. Suitable for reflow soldering. 5. Shapes and dimensions follow E.I.A. spec. 6. Available in various sizes. 7. Excellent solderability and heat resistance. 8. High reliability. 9. 100% Lead(Pb) & Halogen-Free and RoHS compliant. Halogen Pb Halogen-free Pb-free 2.Dimensions Chip Size A 1.60±0.15 B 0.80±0.15 C 0.80±0.15 D 0.30±0.20 Units: mm 3.Part Numbering FCM 1608 KF A B C A: Series B: Dimension C: Material D: Impedance E: Packaging F: Rated Current - 121 T 06 D E F LxW Lead Free Material 121=120Ω T=Taping and Reel, B=Bulk(Bags) 06=600mA 4.Specification Tai-Tech Part Number ● ● Impedance (Ω) Test Frequency (MHz) DC Resistance (Ω) max. Rated Current (mA) max. FCM1608KF-300T07 30±25% 100 0.20 700 FCM1608KF-600T07 60±25% 100 0.20 700 FCM1608KF-121T03 120±25% 100 0.25 300 FCM1608KF-121T06 120±25% 100 0.25 600 FCM1608KF-151T06 150±25% 100 0.25 600 FCM1608KF-221T05 220±25% 100 0.30 550 FCM1608KF-301T05 300±25% 100 0.35 500 FCM1608KF-471T03 470±25% 100 0.45 350 FCM1608KF-601T02 600±25% 100 0.50 200 FCM1608KF-601T03 600±25% 100 0.50 350 FCM1608KF-102T02 1000±25% 100 0.70 200 Rated current: based on temperature rise test In compliance with EIA 595 www.tai-tech.com.tw TAI-TECH KBM01-171100483 P3. 5. Reliability and Test Condition Item Series No. Operating Temperature Performance FCB FCM HCB Test Condition GHB FCA -40~+125℃ (Including self-temperature rise) -40~+125℃ (on board) Transportation Storage Temperature --- For long storage conditions, please see the Application Notice Agilent4291 Agilent E4991 Impedance (Z) Agilent4287 Refer to standard electrical characteristics list Agilent16192 DC Resistance Agilent 4338 Rated Current DC Power Supply Over Rated Current requirements, there will be some risk Temperature Rise Test Rated Current < 1A ΔT 20℃Max Rated Current ≧ 1A ΔT 40℃Max Life test Appearance: no damage. Impedance: within±15%of initial value. Inductance: within±10%of initial value. Q:Shall not exceed the specification value. RDC:within ±15% of initial value and shall not exceed the specification value Load Humidity Appearance: no damage. Thermal shock Impedance: within±15%of initial value. Inductance: within±10%of initial value. Q:Shall not exceed the specification value. RDC:within ±15% of initial value and shall not exceed the specification value 1. Applied the allowed DC current. 2. Temperature measured by digital surface thermometer. Preconditioning: Run through IR reflow for 2 times.( IPC/JEDEC J-STD-020D Classification Reflow Profiles) Temperature: 125±2℃ Applied current: rated current. Duration: 1000±12hrs. Measured at room temperature after placing for 24±2 hrs. Preconditioning: Run through IR reflow for 2 times.( IPC/JEDEC J-STD-020D Classification Reflow Profiles) Humidity: 85±2%R.H. Temperature: 85±2℃. Duration: 1000hrs Min. with 100% rated current. Measured at room temperature after placing for 24±2 hrs. Preconditioning: Run through IR reflow for 2 times.( IPC/JEDEC J-STD-020D Classification Reflow Profiles) Condition for 1 cycle Step1: -40±2℃ 30±5 min. Step2: 25±2℃ ≦0.5min Step3: +125±2℃ 30±5min. Number of cycles: 500 Measured at room temperature after placing for 24±2 hrs. Appearance:No damage. Impedance:within±15% of initial value Inductance:within±10% of initial value Q:Shall not exceed the specification value. RDC:within ±15% of initial value and shall not exceed the specification value Preconditioning: Run through IR reflow for 2 times.( IPC/JEDEC J-STD-020D Classification Reflow Profiles) Oscillation Frequency: 10 ~ 2K ~ 10Hz for 20 minutes Equipment: Vibration checker Total Amplitude:1.52mm±10% Testing Time : 12 hours(20 minutes, 12 cycles each of 3 orientations)。 Bending Appearance:No damage. Impedance:within±10% of initial value Inductance:within±10% of initial value Q:Shall not exceed the specification value. RDC:within ±15% of initial value and shall not exceed the specification value Shall be mounted on a FR4 substrate of the following dimensions: >=0805inch(2012mm):40x100x1.2mm =0805inch(2012mm):1.2mm 0805inch(2012mm):1kg
FCM1608KF-181T05 价格&库存
很抱歉,暂时无法提供与“FCM1608KF-181T05”相匹配的价格&库存,您可以联系我们找货
FCM1608KF-181T05
  • 100+0.01620
  • 500+0.01520
  • 1000+0.01370
  • 5000+0.01170
  • 10000+0.01050
库存:2996
