FCM1005KF-300T03
FCM1005KF-300T03
    TAI-TECH(台庆)
    贴片磁珠 0402 30Ω@100MHz ±25% 300mA 200mΩ
FCM1005KF-300T03 数据手册
TAI-TECH KBM01-170900598 P1. Ferrite Chip Bead(Lead Free) FCM1005KF-Series ECN HISTORY LIST REV DATE DESCRIPTION APPROVED CHECKED DRAWN 楊祥忠 羅培君 張嘉玲 楊祥忠 羅培君 張嘉玲 1.0 13/06/06 變更可靠度條件 2.0 14/01/24 3.0 14/03/20 修正包裝帶圖示 楊祥忠 羅培君 張嘉玲 4.0 14/08/01 變更 Reflow 圖示 楊祥忠 羅培君 張嘉玲 4.1 14/08/01 修正包裝帶尺寸 楊祥忠 羅培君 張嘉玲 5.0 16/01/26 楊祥忠 詹偉特 張嘉玲 6.0 17/02/16 修訂 Recommended PC Board Pattern 楊祥忠 詹偉特 張嘉玲 變更電鍍錫層厚度 3.0um min.=>3.5um min. 增訂可靠度 Thermal shock: (Bead) Step3:125±2℃ 30±5min 備 註 www.tai-tech.com.tw TAI-TECH KBM01-170900598 P2. Ferrite Chip Bead(Lead Free) FCM1005KF-Series 1.Features 1. Monolithic inorganic material construction. 2. Closed magnetic circuit avoids crosstalk. 3. S.M.T. type. 4. Suitable for reflow soldering. 5. Shapes and dimensions follow E.I.A. spec. 6. Available in various sizes. 7. Excellent solder ability and heat resistance. 8. High reliability. 9. 100% Lead(Pb) & Halogen-Free and RoHS compliant. Halogen Pb Halogen-free Pb-free 2.Dimensions Chip Size A 1.00±0.10 B 0.50±0.10 C 0.50±0.10 D 0.25±0.10 Units: mm 3.Part Numbering FCM 1005 KF A B C A: Series B: Dimension C: Material D: Impedance E: Packaging F: Rated Current - 121 T 01 D E F LxW Lead Free Material 121=120Ω T=Taping and Reel, B=Bulk(Bags) 01=100mA 4.Specification Tai-Tech Part Number Impedance (Ω) Test Frequency (MHz) DC Resistance (Ω) max. Rated Current (mA) max. FCM1005KF-300T03 30±25% 100 0.20 300 FCM1005KF-600T03 60±25% 100 0.25 300 FCM1005KF-121T01 120±25% 100 0.30 100 FCM1005KF-151T01 150±25% 100 0.30 100 FCM1005KF-221T01 220±25% 100 0.40 100 FCM1005KF-301T01 300±25% 100 0.50 100 FCM1005KF-471T01 470±25% 100 0.65 100 FCM1005KF-601T00 600±25% 100 0.80 80 FCM1005KF-102T00 1000±25% 100 1.20 50 ● ● Rated current: based on temperature rise test In compliance with EIA 595 www.tai-tech.com.tw TAI-TECH KBM01-170900598 P3. 5. Reliability and Test Condition Item Series No. Operating Temperature Performance FCB FCM HCB Test Condition GHB FCA -40~+125℃ (Including self-temperature rise) -40~+125℃ (on board) Transportation Storage Temperature --- For long storage conditions, please see the Application Notice Agilent4291 Agilent E4991 Impedance (Z) Agilent4287 Refer to standard electrical characteristics list Agilent16192 DC Resistance Agilent 4338 Rated Current DC Power Supply Over Rated Current requirements, there will be some risk Temperature Rise Test 1. Applied the allowed DC current. 2. Temperature measured by digital surface thermometer. Rated Current < 1A ΔT 20℃Max Rated Current ≧ 1A ΔT 40℃Max Life test Appearance: no damage. Impedance: within±15%of initial value. Inductance: within±10%of initial value. Q:Shall not exceed the specification value. RDC:within ±15% of initial value and shall not exceed the specification value Load Humidity Appearance: no damage. Thermal shock Impedance: within±15%of initial value. Inductance: within±10%of initial value. Q:Shall not exceed the specification value. RDC:within ±15% of initial value and shall not exceed the specification value Preconditioning: Run through IR reflow for 2 times.( IPC/JEDEC J-STD-020D Classification Reflow Profiles) Temperature: 125±2℃ Applied current: rated current. Duration: 1000±12hrs. Measured at room temperature after placing for 24±2 hrs. Preconditioning: Run through IR reflow for 2 times.( IPC/JEDEC J-STD-020D Classification Reflow Profiles) Humidity: 85±2%R.H. Temperature: 85±2℃. Duration: 1000hrs Min. with 100% rated current. Measured at room temperature after placing for 24±2 hrs. Preconditioning: Run through IR reflow for 2 times.( IPC/JEDEC J-STD-020D Classification Reflow Profiles) Condition for 1 cycle Step1: -40±2℃ 30±5 min. Step2: 25±2℃ ≦0.5min Step3: +125±2℃ 30±5min. Number of cycles: 500 Measured at room temperature after placing for 24±2 hrs. Appearance:No damage. Impedance:within±15% of initial value Inductance:within±10% of initial value Q:Shall not exceed the specification value. RDC:within ±15% of initial value and shall not exceed the specification value Preconditioning: Run through IR reflow for 2 times.( IPC/JEDEC J-STD-020D Classification Reflow Profiles) Oscillation Frequency: 10 ~ 2K ~ 10Hz for 20 minutes Equipment: Vibration checker Total Amplitude:1.52mm±10% Testing Time : 12 hours(20 minutes, 12 cycles each of 3 orientations)。 Bending Appearance:No damage. Impedance:within±10% of initial value Inductance:within±10% of initial value Q:Shall not exceed the specification value. RDC:within ±15% of initial value and shall not exceed the specification value Shall be mounted on a FR4 substrate of the following dimensions: >=0805inch(2012mm):40x100x1.2mm =0805inch(2012mm):1.2mm 0805inch(2012mm):1kg
FCM1005KF-300T03 价格&库存
很抱歉,暂时无法提供与“FCM1005KF-300T03”相匹配的价格&库存,您可以联系我们找货
FCM1005KF-300T03
  • 50+0.02070
  • 200+0.01560
  • 1000+0.01200
  • 10000+0.00870
  • 20000+0.00830
  • 100000+0.00770
FCM1005KF-300T03
  • 100+0.01073
  • 500+0.01011
  • 1000+0.00918
  • 5000+0.00794
  • 10000+0.00720
