GPC5010L100-5V2800
GPC5010L100-5V2800
    INGHAI(赢海)
    Lead wire
    频率2.8kHz 电压-额定5V
GPC5010L100-5V2800 数据手册
規 格 承 認 書 PECIFICATION FOR APPROVAL 客 戶 CUSTOMER 項 目 ITEM 型 號 TYPE 描述 : : 压电无源蜂鸣器(外部驱动) : GPC5010L100-5V2800 DESCRIPTION : Φ50 x H9.3 mm 客戶料號 CUSTOMER NO. : 規 格 書 號 2800Hz 5V ≥85DB L=100mm ABS 材质 SPECIFICATION NO.: 版 本 EDITION NO. 日 期 : DATE : V1.1 2013-5-22 客戶承認 CUSTOMER CONFIRM AND SIGN 檢查 審核 承認 TESTED BY CHECKED BY APPROVED BY 東莞市赢海電子有限公司 DONGUAN INGHAI ELECTRONICS CO.,LTD 製作 審查 確認 ISSUED BY CHECKED BY APPROVED BY 周明 李林 地址:廣東省東莞市長安鎮廈邊元灶頭工業區 16-6 號 1/3 電話 / TEL:0769-83060958 傳真 / FAX: 0769-81608993 網址:HTTP://WWW.INGHAI.COM DONGGUAN INGHAI ELECTRONICS CO.,LTD Model NO: GPC5010L100-5V2800 A: DIMEMSIONS Unit:mm Tolerance:±0.5 B: SPECIFICATIONS Model NO GPC5010L100 Sound Pressure level(dB)at10cm Min.85dB Resonant Frequency 2800Hz±500Hz Rated Current Max. 3mA Capacitance at 1KHz 75000±30% Rated Voltage 5Vp-p Operating Voltage 1~30 Vp-p Operating Temperature -20 ℃~+70 ℃ Storage Temperature -30 ℃~+80 ℃ Case material and color ABS/ Black 2/3 Measuring condition Part shall be measured under a condition (Temperature: 5~35℃, Humidity: 45%~85%R.H., Atmospheric pressure: 860 ~1060hPa) unless the standard condition (Temperature: 25±3℃, Humidity: 60±10%R.H. Atmospheric pressure: 860 ~1060hPa) is regulated to measure C: Acoustic Characteristics: The oscillation frequency, current consumption and sound pressure are measured by the measuring instruments shown below D: Reliability Test After any following tests the part shall meet specifications without any degradation in appearance and performance except SPL. SPL shall not deviate more than -10 dB from the initial value 1. 2. 3. 4. 5. 6. 7. Ordinary Temperature Life Test The part shall be subjected to 96 hours at 25±10℃. Input rated voltage Resonant frequency, 1/2 duty Square wave. High Temperature Test The part shall be capable of with standing a storage temperature of +70℃ for 96 hours. Low Temperature Test The part shall be capable of with standing a storage temperature of -30℃ for 96 hours. Humidity Test Temperature:+40℃±3℃ Relative Humidity:90%~95% Duration: 48 hours and expose to room temperature for 6 hours Temperature Shock Test Temperature:60℃ /1hour→ 25℃/3hours→-30℃/1hour→ 25℃/3hours (1cycle) Total cycle: 10 cycles Drop Test Standard Packaging From 120mm(Drop on hard wood or board of 5cm thick, three sides, six plain.) Vibration Test Vibration:1000cycles /min. Amplitude:1.5mm, Duration: 1 hour in each 3 axes Note: As this product is not protected from foreign material entering, please make sure that any foreign materials (e.g. magnetic powder, washing solvent, flux, corrosive gas) do not enter this product in your production processes. The functional degradation (e.g. SPL down) may occur if foreign material enter it. 3/3 Measuring condition Part shall be measured under a condition (Temperature: 5~35℃, Humidity: 45%~85%R.H., Atmospheric pressure: 860 ~1060hPa) unless the standard condition (Temperature: 25±3℃, Humidity: 60±10%R.H. Atmospheric pressure: 860 ~1060hPa) is regulated to measure. 4/3
GPC5010L100-5V2800
1. 物料型号:型号为GPC5010L100-5V2800,是一个压电无源蜂鸣器(外部驱动)。
2. 器件简介: - 尺寸:Φ50 x H9.3 mm - 频率:2800Hz - 音量:≥85dB - 电压:5V - 长度:100mm - 材料:ABS
3. 引脚分配:文档中未提供引脚分配信息。
4. 参数特性: - 声压级:最小85dB - 谐振频率:2800Hz±500Hz - 额定电流:最大3mA - 1KHz时电容:75000±30% - 额定电压:5Vp-p - 工作电压:1~30 Vp-p - 工作温度:-20 °C~+70°C - 存储温度:-30 °C~+80 °C - 外壳材料和颜色:ABS/黑色
5. 功能详解: - 测量条件:在特定温度、湿度和大气压下测量。 - 声学特性:通过特定测量仪器测量振荡频率、电流消耗和声压。
6. 应用信息:文档中未提供具体的应用信息
7. 封装信息:外壳材料为ABS,颜色为黑色。
GPC5010L100-5V2800 价格&库存
很抱歉,暂时无法提供与“GPC5010L100-5V2800”相匹配的价格&库存,您可以联系我们找货
GPC5010L100-5V2800
  • 1+11.97720
  • 10+10.19520
  • 30+9.07200
库存:1
GPC5010L100-5V2800
  • 1+10.86820
  • 10+9.25120
  • 30+8.23200
库存:100
