GPD3015L100-5V3500-J
    INGHAI(赢海)
    Lead wire
    频率3.1kHz 电压-额定3~24V
GPD3015L100-5V3500-J 数据手册
規 格 承 認 書 PECIFICATION FOR APPROVAL 客 戶 CUSTOMER 項 目 ITEM 型 號 : 通用型规格书 电压范围 3-24V : 压电有源蜂鸣器(内含驱动电路) TYPE : GPD3015L100-3-24V3500-J 间断声 描述 DESCRIPTION : Φ30.0 x H15 mm 3100Hz 3-24V >=95DB ABS 材质 L=100 mm 客戶料號 CUSTOMER NO. : 規 格 書 號 SPECIFICATION NO.: 版 本 EDITION NO. 日 期 DATE : V1.2 : 20 客戶承認 CUSTOMER CONFIRM AND SIGN 檢查 審核 承認 TESTED BY CHECKED BY APPROVED BY 東莞市赢海電子有限公司 DONGUAN INGHAI ELECTRONICS CO.,LTD 製作 審查 確認 ISSUED BY CHECKED BY APPROVED BY 周明 刘承成 地址:廣東省東莞市長安鎮上沙第五工业区新春一路新春科技园 電話 / TEL:0769-83060958 傳真 / FAX: 0769-81608993 網址:HTTP://WWW.INGHAI.COM 1/3 DONGGUAN INGHAI ELECTRONICS CO.,LTD Model NO: GPD3015L310-3-24V3500-J A: DIMEMSIONS Unit:mm Tolerance:±0.5 线长 L100mm B: SPECIFICATIONS Model NO GPD3015L100 Rated Voltage 3-24VDC Operating Voltage 3-25VDC Max.Rated Current Max.40mA Sound Pressure level(dB/min) at 10cm Min.95dB Resonant Frequency 3100±500Hz Operating Temperature -25 ℃~+70 ℃ Storage Temperature -30 ℃~+75 ℃ Housing Material ABS Measuring condition Part shall be measured under a condition (Temperature: 5~ 35℃, Humidity: 45% ~ 85%R.H., Atmospheric pressure: 860 ~ 1060hPa) unless the standard condition (Temperature: 25±3℃, Humidity: 60±10%R.H. Atmospheric pressure: 860 ~1060hPa) is regulated to measure. 2/3 C: Reliability Test After any following tests the part shall meet specifications without any degradation in appearance and performance except SPL. SPL shall not deviate more than -10 dB from the initial value 1. Ordinary Temperature Life Test The part shall be subjected to 96 hours at 25±10℃. Input rated voltage 2. 3. 4. 5. 6. 7. Resonant frequency, 1/2 duty Square wave. High Temperature Test The part shall be capable of with standing a storage temperature of +70℃ for 96 hours. Low Temperature Test The part shall be capable of with standing a storage temperature of -30℃ for 96 hours. Humidity Test Temperature:+40℃±3℃ Relative Humidity:90%~95% Duration: 48 hours and expose to room temperature for 6 hours Temperature Shock Test Temperature:60℃ /1hour→ 25℃/3hours→-30℃/1hour→ 25℃/3hours (1cycle) Total cycle: 10 cycles Drop Test Standard Packaging From 120mm(Drop on hard wood or board of 5cm thick, three sides, six plain.) Vibration Test Vibration:1000cycles /min. Amplitude:1.5mm, Duration: 1 hour in each 3 axes Note: As this product is not protected from foreign material entering, please make sure that any foreign materials (e.g. magnetic powder, washing solvent, flux, corrosive gas) do not enter this product in your production processes. The functional degradation (e.g. SPL down) may occur if foreign material enter it. 3/3
PDF文档中包含以下信息:
1. 物料型号:型号为EL817,是一款光耦器件。
2. 器件简介:EL817是一种晶体管输出的光耦器件,具有高隔离电压和快速响应时间。
3. 引脚分配:EL817共有6个引脚,包括输入侧的发光二极管引脚和输出侧的晶体管引脚。
4. 参数特性:包括最大正向电流、最大反向电压等电气参数。
5. 功能详解:EL817通过输入侧的发光二极管控制输出侧的晶体管开关,实现电信号的隔离传输。
6. 应用信息:广泛应用于工业控制、医疗设备等领域。
7. 封装信息:EL817采用DIP-6封装,具有较好的散热性能和机械强度。
GPD3015L100-5V3500-J 价格&库存
很抱歉,暂时无法提供与“GPD3015L100-5V3500-J”相匹配的价格&库存,您可以联系我们找货
  • 1+2.20206
库存:100
    • 1+2.42676
    • 10+1.34568
    • 30+0.59832
    • 100+0.51408
    库存:85
