規 格 承 認 書
PECIFICATION FOR APPROVAL
客 戶
CUSTOMER
項 目
ITEM
型 號
立创
压电式无源蜂鸣器(外部驱动)
TYPE
: GPC1205YB-5V4000
DESCRIPTION :
D12 x H 5.5 MM 4000Hz
客戶料號
CUSTOMER NO. :
規 格 書 號
11000pF
5V >=80DB
PBT 材质
P=6.5 MM
SPECIFICATION NO.:
版 本
EDITION NO.
日 期
DATE
V1.1
2019-12-26
客戶承認
CUSTOMER CONFIRM AND SIGN
檢查
審核
承認
TESTED BY
CHECKED BY
APPROVED BY
東莞市赢海電子有限公司
DONGUAN INGHAI ELECTRONICS CO.,LTD
製作
審查
確認
ISSUED BY
CHECKED BY
APPROVED BY
周明
李林
地址:廣東省東莞市長安鎮上沙第五工业区新春 1 路新春科技园
電話 / TEL:0769-83060958
傳真 / FAX: 0769-81608993
網址:HTTP://WWW.INGHAI.COM
1/4
DONGGUAN INGHAI ELECTRONICS CO.,LTD
Model NO: GPC1205YB-5V4000
DIMEMSIONS Unit:mm
A: SPECIFICATIONS
Model NO
GPC1205YB-5V4000
Min Sound Pressure Level
80dB at 4KHZ at 5Vp-p at 10cm
Resonant Frequency
4000 +/-500 Hz
Rated Current
Max. 3mA
Capacitance at 1KHz
11000pF+30%
Rated Voltage
5Vp-p
Operating Voltage
3~25 Vp-p
Operating Temperature
-20 ℃~+70 ℃
Storage Temperature
-30 ℃~+80 ℃
Case material and color
PBT / Black
Measuring condition
Part shall be measured under a condition (Temperature: 5~ 35℃, Humidity: 45% ~ 85%R.H., Atmospheric
pressure: 860 ~ 1060hPa) unless the standard condition (Temperature: 25±3℃, Humidity: 60±10%R.H.
2/4
Atmospheric pressure: 860 ~1060hPa) is regulated to measure.
B: Acoustic Characteristics:
The oscillation frequency, current consumption and sound pressure are measured by the
measuring instruments shown below
C: Typical Frequency Response Curve
3/4
D: Reliability Test
After any following tests the part shall meet specifications without any degradation in
appearance and performance except SPL. SPL shall not deviate more than -10 dB
from the initial value
1.
Ordinary Temperature Life Test
The part shall be subjected to 96 hours at 25±10℃. Input rated voltage
2.
3.
4.
Resonant frequency, 1/2 duty Square wave.
High Temperature Test
The part shall be capable of with standing a storage temperature of +80℃ for 96 hours.
Low Temperature Test
The part shall be capable of with standing a storage temperature of -30℃ for 96 hours.
Humidity Test
Temperature:+40℃±3℃
Relative Humidity:90%~95% Duration: 48 hours
and expose to room temperature for 6 hours
5. Temperature Shock Test
Temperature:70℃ /1hour→ 25℃/3hours→-30℃/1hour→ 25℃/3hours (1cycle)
Total cycle: 10 cycles
6. Drop Test
Standard Packaging From 120mm(Drop on hard wood or board of 5cm thick,
three sides, six plain.)
7. Vibration Test
Vibration:1000cycles /min. Amplitude:1.5mm, Duration: 1 hour in each 3 axes
Note:
As this product is not protected from foreign material entering, please make sure that any foreign materials
(e.g. magnetic powder, washing solvent, flux, corrosive gas) do not enter this product in your production
processes. The functional degradation (e.g. SPL down) may occur if foreign material enter it.
4/4
很抱歉,暂时无法提供与“GPC1205YB-5V4000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.53800
- 50+1.99800
- 200+1.76040
- 500+1.39536
- 2000+1.27224
- 5000+1.20042
